[U-Boot] [PATCH] mvebu: turris_omnia: Only set eth?addr env if CONFIG_CMD_NET
Otherwise the linking will fail since eth_env_set_enetaddr cannot be found.
Signed-off-by: Marek Behun marek.behun@nic.cz --- board/CZ.NIC/turris_omnia/turris_omnia.c | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/board/CZ.NIC/turris_omnia/turris_omnia.c b/board/CZ.NIC/turris_omnia/turris_omnia.c index af66837909..7db3b8ff3b 100644 --- a/board/CZ.NIC/turris_omnia/turris_omnia.c +++ b/board/CZ.NIC/turris_omnia/turris_omnia.c @@ -470,6 +470,7 @@ out: return 0; }
+#if defined(CONFIG_ATSHA204A) && defined(CONFIG_CMD_NET) static void increment_mac(u8 *mac) { int i; @@ -480,10 +481,11 @@ static void increment_mac(u8 *mac) break; } } +#endif
int misc_init_r(void) { -#ifdef CONFIG_ATSHA204A +#if defined(CONFIG_ATSHA204A) && defined(CONFIG_CMD_NET) int err; struct udevice *dev = get_atsha204a_dev(); u8 mac0[4], mac1[4], mac[6];
Hi Marek,
Perhaps its better to select or imply ATSHA204A and CMD_NET for turris_omnia in Kconfig instead. You can then remove all the #ifdef's from the code here.
Just curious: Where did you see this compile / linking problem. Compiling current mainline does not cause any issues.
Thanks, Stefan
Hi Marek,
diff --git a/board/CZ.NIC/turris_omnia/turris_omnia.c b/board/CZ.NIC/turris_omnia/turris_omnia.c index af66837909..7db3b8ff3b 100644 --- a/board/CZ.NIC/turris_omnia/turris_omnia.c +++ b/board/CZ.NIC/turris_omnia/turris_omnia.c @@ -470,6 +470,7 @@ out: return 0; } +#if defined(CONFIG_ATSHA204A) && defined(CONFIG_CMD_NET) static void increment_mac(u8 *mac) { int i; @@ -480,10 +481,11 @@ static void increment_mac(u8 *mac) break; } } +#endif int misc_init_r(void) { -#ifdef CONFIG_ATSHA204A +#if defined(CONFIG_ATSHA204A) && defined(CONFIG_CMD_NET) int err; struct udevice *dev = get_atsha204a_dev(); u8 mac0[4], mac1[4], mac[6];
I didn't receive any answers on these questions. Could you please check again?
Thanks, Stefan
Marek Behún
Stefan Roese
