[PATCH] net: zynq_gem: Add a 10ms delay in zynq_gem_init()
In our system using ZynqMP with an external SGMII PHY it's necessary to wait a short while after the configuration in zynq_gem_init() before the xfer starts. Otherwise the first packet(s) might get dropped, resulting in a delay at the start of the ethernet transfers.
This patch adds a minimal delay of 10ms which fixes problems of dropped first packages.
Signed-off-by: Stefan Roese sr@denx.de Cc: Michal Simek michal.simek@amd.com Cc: Ramon Fried rfried.dev@gmail.com Cc: Sean Anderson sean.anderson@seco.com --- drivers/net/zynq_gem.c | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/drivers/net/zynq_gem.c b/drivers/net/zynq_gem.c index 507b19b75975..26e468766871 100644 --- a/drivers/net/zynq_gem.c +++ b/drivers/net/zynq_gem.c @@ -522,6 +522,13 @@ static int zynq_gem_init(struct udevice *dev) return ret; } } + + /* + * Some additional minimal delay seems to be needed so that + * the first packet will be sent correctly + */ + mdelay(10); + setbits_le32(®s->nwctrl, ZYNQ_GEM_NWCTRL_RXEN_MASK | ZYNQ_GEM_NWCTRL_TXEN_MASK);
+ Hi Stefan,
-----Original Message----- From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of Stefan Roese Sent: Wednesday, January 11, 2023 1:01 PM To: u-boot@lists.denx.de Cc: Michal Simek michal.simek@amd.com; Ramon Fried rfried.dev@gmail.com; Sean Anderson sean.anderson@seco.com Subject: [PATCH] net: zynq_gem: Add a 10ms delay in zynq_gem_init()
- mdelay(10);
Thanks for the patch. The PCS status check in your v1 seems valid. However, this delay of 10 msecs should not be necessary. If the PCS status (when autoneg is enabled with the external PHY on your board) shows link up, that's enough. Could you please consider the following to investigate why initial packets are lost? -> If the external PHY on your board has a hardware reset please consider updating the reset-assert-us and reset-deassert-us properties to ensure PHY is ready before access. -> Can you please check if there's any link stability issues in the initial msecs? Monitoring the serdes/GTR SGMII lane that's setup on ZynqMP will be useful.
Regards, Harini
Hi Harini,
On 1/11/23 12:20, Katakam, Harini wrote:
Hi Stefan,
- mdelay(10);
Unfortunately this is not the case. Regardless of using the PCS check from the v1 patch from yesterday, such a minimal delay is necessary on our setup.
Not sure if this will help. See my comment at the end please for this.
I tested 2 situations:
a) Starting network traffic very early in U-Boot, before the aneg link establishment has finished (preboot=ping 192.168.1.5):
[8.448005 0.007878] Net: [8.453711 0.005706] ZYNQ GEM: ff0d0000, mdio bus ff0d0000, phyaddr 0, interface sgmii [8.454449 0.000739] eth0: ethernet@ff0d0000 [8.454752 0.000303] ethernet@ff0d0000 Waiting for PHY auto negotiation to complete..... done [10.915882 2.461130] Using ethernet@ff0d0000 device [10.916228 0.000346] host 192.168.1.5 is alive [10.917247 0.001019] Hit any key to stop autoboot: 0
b) Late in U-Boot, after waiting for some seconds (or even minutes, it makes no difference) on the prompt (preboot=sleep 10;ping 192.168.1.5):
[4.655932 0.007849] Net: [4.661612 0.005680] ZYNQ GEM: ff0d0000, mdio bus ff0d0000, phyaddr 0, interface sgmii [4.662367 0.000755] eth0: ethernet@ff0d0000 [14.671655 10.009288] Using ethernet@ff0d0000 device [14.672018 0.000364] host 192.168.1.5 is alive [14.673032 0.001014] Hit any key to stop autoboot: 0
The delay is needed in both cases. In a) you see, that the PHY aneg takes a bit of time to finish. The link is established at this time.
My feeling is that configuration of "pcscntrl" (or some other register) after phy_startup() in zynq_gem_init() introduces this necessity of this additional delay.
Thanks, Stefan
Hi Stefan,
On 1/11/23 12:38, Stefan Roese wrote:
Hi Harini,
Hi Stefan,
I think this will require further investigation what it is really happening. If this is related to SGMII only or also RGMII. Obviously adding some delay without proper explanation is not the right way to go. Pretty much if something is not stable there should be a way to pooling any bit.
There is ongoing effort on moving clock from direct register access to using firmware interface. And maybe this issue will be resolve by that that simply clock is not stable at the time when driver tries to enable RX/TX. And current clock driver is not waiting for clock to be stable but firmware base driver does it.
Thanks, Michal
Hi Michal,
On 1/24/23 14:12, Michal Simek wrote:
Hi Stefan,
Hi Harini,
Hi Stefan,
Agreed. I'm also not 100% satisfied with this "solution".
You mean polling (instead of pooling)? Again, the link is already established when "pcscntrl" is configured. I can try to double-check again, if I can poll for something in this "pcscntrl".
As mentioned above, my feeling is that configuration of "pcscntrl" (or some other register) after phy_startup() in zynq_gem_init() introduces this necessity of this additional delay. If this is the case, then changes in the clock access won't make any difference here IIUTC.
Still I will do some more tests with this "pcscntrl" hopefully later today and will report back. Stay tuned...
Thanks, Stefan
Katakam, Harini
Michal Simek
Stefan Roese
