[U-Boot] [PATCH] at91_udc.c: Fix unused variable warning
With gcc-6 and later we see warnings that at91sam9263_udc_caps and at91rm9200_udc_caps are unused.
Fixes: 620197670a69 ("usb: gadget: at91_udc: add at91_udc into U-Boot") Cc: Lukasz Majewski lukma@denx.de Cc: Marek Vasut marex@denx.de Signed-off-by: Tom Rini trini@konsulko.com --- drivers/usb/gadget/at91_udc.c | 10 ---------- 1 file changed, 10 deletions(-)
diff --git a/drivers/usb/gadget/at91_udc.c b/drivers/usb/gadget/at91_udc.c index f5bc277fa6e0..01a59078b84a 100644 --- a/drivers/usb/gadget/at91_udc.c +++ b/drivers/usb/gadget/at91_udc.c @@ -1386,11 +1386,6 @@ static void at91rm9200_udc_pullup(struct at91_udc *udc, int is_on) gpio_set_value(udc->board.pullup_pin, !active); }
-static const struct at91_udc_caps at91rm9200_udc_caps = { - .init = at91rm9200_udc_init, - .pullup = at91rm9200_udc_pullup, -}; - static int at91sam9260_udc_init(struct at91_udc *udc) { struct at91_ep *ep; @@ -1503,11 +1498,6 @@ static int at91sam9263_udc_init(struct at91_udc *udc) return 0; }
-static const struct at91_udc_caps at91sam9263_udc_caps = { - .init = at91sam9263_udc_init, - .pullup = at91sam9260_udc_pullup, -}; - int usb_gadget_handle_interrupts(int index) { struct at91_udc *udc = controller;
I'd like Heiko's ACK on this one, since it's his patch which dropped the references. IMO looks OK tho.
Hello Tom, Marek,
Am 19.04.2017 um 04:23 schrieb Tom Rini:
Acked-by: Heiko Schocher hs@denx.de
bye, Heiko
Heiko Schocher
