[U-Boot] Commit 8b5a02640adf77301f943e8754992c50df004e8a breaks about 20 ARM builds
Hi all,
I have encountered an issue when rebasing the ARM tree above u-boot/master, with this commit :
It seems to break about 20 ARM builds, for instance spear600, on my stock Ubuntu 12.04 ARM gcc:
uboot@lilith:~/src/u-boot-arm$ git checkout 8b5a02640adf77301f943e8754992c50df004e8a^ Previous HEAD position was 8b5a026... Makefile: cosmetic: optimize usage of LIBS-y HEAD is now at f52d7b3... Makefile: replace LIBS by LIBS-y uboot@lilith:~/src/u-boot-arm$ LANG=C ./MAKEALL spear600 Configuring for spear600 - Board: spear6xx_evb, Options: spear600 text data bss dec hex filename 190670 8604 21924 221198 3600e ./u-boot
--------------------- SUMMARY ---------------------------- Boards compiled: 1 ---------------------------------------------------------- uboot@lilith:~/src/u-boot-arm$ git checkout 8b5a02640adf77301f943e8754992c50df004e8a Previous HEAD position was f52d7b3... Makefile: replace LIBS by LIBS-y HEAD is now at 8b5a026... Makefile: cosmetic: optimize usage of LIBS-y uboot@lilith:~/src/u-boot-arm$ LANG=C ./MAKEALL spear600 Configuring for spear600 - Board: spear6xx_evb, Options: spear600 make: *** [u-boot] Error 139 arm-linux-gnueabi-size: ./u-boot: File format not recognized arch/arm/cpu/arm926ejs/start.o: In function `flush_dcache': /home/uboot/src/u-boot-arm/arch/arm/cpu/arm926ejs/start.S:393: undefined reference to `lowlevel_init' arch/arm/lib/libarm.o: In function `board_init_r': /home/uboot/src/u-boot-arm/arch/arm/lib/board.c:585: undefined reference to `misc_init_r' arch/arm/lib/libarm.o:(.data+0x4): undefined reference to `board_early_init_f' arch/arm/lib/libarm.o:(.data+0x28): undefined reference to `dram_init' board/spear/spear600/libspear600.o: In function `board_init': /home/uboot/src/u-boot-arm/board/spear/spear600/spear600.c:38: undefined reference to `spear_board_init' arm-linux-gnueabi-ld: BFD (GNU Binutils for Ubuntu) 2.22 assertion fail ../../bfd/elf32-arm.c:13830 /bin/bash: line 1: 10706 Segmentation fault (core dumped) arm-linux-gnueabi-ld -pie -T u-boot.lds -Bstatic -Ttext 0x00700000 $UNDEF_SYM arch/arm/cpu/arm926ejs/start.o --start-group api/libapi.o arch/arm/cpu/arm926ejs/libarm926ejs.o arch/arm/cpu/arm926ejs/spear/libspear.o arch/arm/lib/libarm.o common/libcommon.o disk/libdisk.o drivers/bios_emulator/libatibiosemu.o drivers/block/libblock.o drivers/dma/libdma.o drivers/fpga/libfpga.o drivers/gpio/libgpio.o drivers/hwmon/libhwmon.o drivers/i2c/libi2c.o drivers/input/libinput.o drivers/misc/libmisc.o drivers/mmc/libmmc.o drivers/mtd/libmtd.o drivers/mtd/nand/libnand.o drivers/mtd/onenand/libonenand.o drivers/mtd/spi/libspi_flash.o drivers/mtd/ubi/libubi.o drivers/net/libnet.o drivers/net/phy/libphy.o drivers/pci/libpci.o drivers/pcmcia/libpcmcia.o drivers/power/libpower.o drivers/rtc/librtc.o drivers/serial/libserial.o drivers/spi/libspi.o drivers/twserial/libtws.o drivers/usb/eth/libusb_eth.o drivers/usb/gadget/libusb_gadget.o drivers/usb/host/libusb_host.o drivers/usb/musb/libusb_musb.o drivers/usb/phy/libusb_phy.o drivers/usb/ulpi/libusb_ulpi.o drivers/video/libvideo.o drivers/watchdog/libwatchdog.o fs/cramfs/libcramfs.o fs/ext2/libext2fs.o fs/fat/libfat.o fs/fdos/libfdos.o fs/jffs2/libjffs2.o fs/reiserfs/libreiserfs.o fs/ubifs/libubifs.o fs/yaffs2/libyaffs2.o fs/zfs/libzfs.o lib/libfdt/libfdt.o lib/libgeneric.o lib/lzma/liblzma.o lib/lzo/liblzo.o lib/zlib/libz.o net/libnet.o post/libpost.o test/libtest.o board/spear/spear600/libspear600.o --end-group /home/uboot/src/u-boot-arm/arch/arm/lib/eabi_compat.o -L /usr/lib/gcc/arm-linux-gnueabi/4.6 -lgcc -Map u-boot.map -o u-boot make: *** [u-boot] Error 139
--------------------- SUMMARY ---------------------------- Boards compiled: 1 Boards with errors: 1 ( spear600 ) ----------------------------------------------------------
Daniel, can you please investigate this?
Amicalement,
Hi Albert,
2012/8/14 Albert ARIBAUD albert.u.boot@aribaud.net:
Hi all,
I changed the HAVE_VENDOR_COMMON_LIB macro in v2 of the patch as suggested by Mike to get rid of the $(shell ..) call. The change was trivial so I did not compile all boards again and I missed the extra spaces. Sorry for that.
I have sent a v2 of Scott's patch, which also fixes the spl/Makefile. http://patchwork.ozlabs.org/patch/177235/
Detlef, could you pick up this patch on behalf of Wolfgang? Thanks in advance.
Best regards, Daniel
Albert ARIBAUD
Daniel Schwierzeck
