[U-Boot] Integity validation (checksum) of a squashfs root file system
I would like to validate the integrity (checksum) of a squashfs root file system before starting Linux.
Current strategy I am using is: - Wrap squashfs rootfs inside a u-boot image - TFTP download on the target - Download validation using iminfo - Save squashfs rootfs in flash without the image header (Linux failed to load squashfs rootfs if u-boot image is present)
Problems: - I need to hardcode squashfs rootfs offset in u-boot image in order to be able to flash it - U-Boot image header information (size, crc, ...) is lost after a reboot. It is not possible to check the integrity of the flash content.
I would like to save some fields of u-boot image header (size, crc, ...) in u-boot environment variables. And then do an integrity check at boot time.
I have not find a way to extract those fields and save them without changing u-boot code. I have added some code to “iminfo” command to set environment variables for CRC, size, payload offset, timestamp.
Is it an acceptable way of doing it? Is there a better way of doing it?
Thanks in advance,
Pascal
Pascal Levesque
