[U-Boot] [PATCH v4 6/6] MX31: Add NAND SPL boot support to i.MX31 PDK board.
Hello,
I'm trying to boot from my board with a i.MX31 and small page (512Byte) NAND Flash. I applied the patches in v4 which introduce the CONFIG_PRELOADER macro. The only example I found where this macro is used is in part 6/6 of the patch. There a separate folder structure in nand_spl for the PDK Board is created.
Could you describe the mode of operation of the CONFIG_PRELOADER macro and in particular NAND SPL? I'm not sure how to use this functionality in my case.
Thank you very mutch, Ulrich Gerster
Hi
2009/6/22 Ulrich Gerster gersteru@dhbw-loerrach.de:
Hello,
The whole NAND booting procedure is described i http://lists.denx.de/pipermail/u-boot/2009-April/051826.html . That description is still valid with the addition that CONFIG_PRELOADER is now defined when compiling the NAND SPL (in step 2). Also nand_boot_mx31.c has been renamed to nand_boot_fsl_nfc.c.
Regards, Magnus
Magnus Lilja
Ulrich Gerster
