[U-Boot-Users] [PATCH RFC] ARM: Davinci: NAND fix for large page ECC and linux compatibility
U-boot's HW ECC support for large page NAND on Davinci is completely broken. Some kernels, such as the 2.6.10 one supported by MontaVista for Davinci, rely upon this broken behaviour as they share the same code for ECCs. In the existing scheme, error detection *might* work on large page, but error correction definitely does not. Small page ECC correction works, but the format is not compatible with the mainline git kernel.
This patch adds ECC code that matches what is currently in the Davinci git repository (since NAND support was added in 2.6.24). This makes the ECC and OOB layout written by u-boot compatible with Linux for both small page and large page devices and fixes ECC correction for large page devices.
The code depends on a #define CFG_LINUX_COMPATIBLE_ECC, which is undefined by default, making the default state backwards compatible. I have verified this by compiling without the #define and producing a binary byte-for-byte identical to one without this patch.
[NOTE: I have not yet been able to get my hands on a board with small-page NAND to test, but large page does work. If anybody is interested in testing it, please do and let me know if it works for you (i.e. uboot with this patch and davinci git kernel can read/write the same NAND).]
Signed-off-by: Bernard Blackham bernard@largestprime.net
--- cpu/arm926ejs/davinci/nand.c | 79 ++++++++++++++++++++++++++++++++++++++-- include/configs/davinci_dvevm.h | 12 ++++++ 2 files changed, 89 insertions(+), 2 deletions(-)
Index: u-boot-1.3.3/cpu/arm926ejs/davinci/nand.c =================================================================== --- u-boot-1.3.3.orig/cpu/arm926ejs/davinci/nand.c 2008-05-19 18:47:11.000000000 +0800 +++ u-boot-1.3.3/cpu/arm926ejs/davinci/nand.c 2008-06-27 13:04:03.000000000 +0800 @@ -87,6 +87,10 @@ static void nand_davinci_select_chip(str }
#ifdef CFG_NAND_HW_ECC + +#ifndef CFG_LINUX_COMPATIBLE_ECC +/* Linux-compatible ECC uses MTD defaults. */ +/* These layouts are not compatible with Linux or RBL/UBL. */ #ifdef CFG_NAND_LARGEPAGE static struct nand_oobinfo davinci_nand_oobinfo = { .useecc = MTD_NANDECC_AUTOPLACE, @@ -104,6 +108,7 @@ static struct nand_oobinfo davinci_nand_ #else #error "Either CFG_NAND_LARGEPAGE or CFG_NAND_SMALLPAGE must be defined!" #endif +#endif
static void nand_davinci_enable_hwecc(struct mtd_info *mtd, int mode) { @@ -141,12 +146,29 @@ static u_int32_t nand_davinci_readecc(st
static int nand_davinci_calculate_ecc(struct mtd_info *mtd, const u_char *dat, u_char *ecc_code) { +#ifdef CFG_LINUX_COMPATIBLE_ECC + unsigned int ecc_val = nand_davinci_readecc(mtd, 1); + /* squeeze 0 middle bits out so that it fits in 3 bytes */ + unsigned int tmp = (ecc_val&0x0fff)|((ecc_val&0x0fff0000)>>4); + /* invert so that erased block ecc is correct */ + tmp = ~tmp; + ecc_code[0] = (u_char)(tmp); + ecc_code[1] = (u_char)(tmp >> 8); + ecc_code[2] = (u_char)(tmp >> 16); +#else u_int32_t tmp; int region, n; struct nand_chip *this = mtd->priv;
n = (this->eccmode == NAND_ECC_HW12_2048) ? 4 : 1;
+ /* + * This is not how you should read ECCs on large page Davinci devices. + * The region parameter gets you ECCs for flash chips on different chip + * selects, not the 4x512 byte pages in a 2048 byte page. + * + * Preserved for backwards compatibility though. + */ region = 1; while (n--) { tmp = nand_davinci_readecc(mtd, region); @@ -155,9 +177,51 @@ static int nand_davinci_calculate_ecc(st *ecc_code++ = ((tmp >> 8) & 0x0f) | ((tmp >> 20) & 0xf0); region++; } +#endif + return(0); }
+#ifdef CFG_LINUX_COMPATIBLE_ECC +static int nand_davinci_correct_data(struct mtd_info *mtd, u_char *dat, + u_char *read_ecc, u_char *calc_ecc) +{ + struct nand_chip *chip = mtd->priv; + u_int32_t ecc_nand = read_ecc[0] | (read_ecc[1] << 8) | + (read_ecc[2] << 16); + u_int32_t ecc_calc = calc_ecc[0] | (calc_ecc[1] << 8) | + (calc_ecc[2] << 16); + u_int32_t diff = ecc_calc ^ ecc_nand; + + if (diff) { + if ((((diff>>12)^diff) & 0xfff) == 0xfff) { + /* Correctable error */ + if ((diff>>(12+3)) < chip->eccsize) { + uint8_t find_bit = 1 << ((diff>>12)&7); + uint32_t find_byte = diff>>(12+3); + dat[find_byte] ^= find_bit; + DEBUG (MTD_DEBUG_LEVEL0, "Correcting single bit ECC error at offset: %d, bit: %d\n", find_byte, find_bit); + return 1; + } else { + return -1; + } + } else if (!(diff & (diff-1))) { + /* Single bit ECC error in the ECC itself, + nothing to fix */ + DEBUG (MTD_DEBUG_LEVEL0, "Single bit ECC error in ECC.\n"); + return 1; + } else { + /* Uncorrectable error */ + DEBUG (MTD_DEBUG_LEVEL0, "ECC UNCORRECTED_ERROR 1\n"); + return -1; + } + + } + return 0; +} + +#else + static void nand_davinci_gen_true_ecc(u_int8_t *ecc_buf) { u_int32_t tmp = ecc_buf[0] | (ecc_buf[1] << 16) | ((ecc_buf[2] & 0xf0) << 20) | ((ecc_buf[2] & 0x0f) << 8); @@ -291,7 +355,9 @@ static int nand_davinci_correct_data(str } return(0); } -#endif +#endif /* CFG_LINUX_COMPATIBLE_ECC */ + +#endif /* CFG_NAND_HW_ECC */
static int nand_davinci_dev_ready(struct mtd_info *mtd) { @@ -356,7 +422,13 @@ int board_nand_init(struct nand_chip *na #ifdef CFG_NAND_USE_FLASH_BBT nand->options = NAND_USE_FLASH_BBT; #endif + #ifdef CFG_NAND_HW_ECC + +#ifdef CFG_LINUX_COMPATIBLE_ECC + nand->eccmode = NAND_ECC_HW3_512; +#else + #ifdef CFG_NAND_LARGEPAGE nand->eccmode = NAND_ECC_HW12_2048; #elif defined(CFG_NAND_SMALLPAGE) @@ -365,12 +437,15 @@ int board_nand_init(struct nand_chip *na #error "Either CFG_NAND_LARGEPAGE or CFG_NAND_SMALLPAGE must be defined!" #endif nand->autooob = &davinci_nand_oobinfo; + +#endif /* CFG_LINUX_COMPATIBLE_ECC */ + nand->calculate_ecc = nand_davinci_calculate_ecc; nand->correct_data = nand_davinci_correct_data; nand->enable_hwecc = nand_davinci_enable_hwecc; #else nand->eccmode = NAND_ECC_SOFT; -#endif +#endif /* CFG_NAND_HW_ECC */
/* Set address of hardware control function */ nand->hwcontrol = nand_davinci_hwcontrol; Index: u-boot-1.3.3/include/configs/davinci_dvevm.h =================================================================== --- u-boot-1.3.3.orig/include/configs/davinci_dvevm.h 2008-05-19 18:47:11.000000000 +0800 +++ u-boot-1.3.3/include/configs/davinci_dvevm.h 2008-06-27 13:04:07.000000000 +0800 @@ -46,6 +46,18 @@ #define CONFIG_NOR_UART_BOOT */
+/* + * Previous versions of u-boot (1.3.3 and prior) and Montavista Linux kernels + * generated bogus ECCs on large-page NAND. Both large and small page NAND ECCs + * were incompatible with the Linux davinci git tree (since NAND was integrated + * in 2.6.24). + * Don't turn this on if you want backwards compatibility. + * Do turn this on if you want u-boot to be able to read and write NAND + * that can be written or read by the Linux davinci git kernel. + * +#define CFG_LINUX_COMPATIBLE_ECC + */ + /*=======*/ /* Board */ /*=======*/
#endif +#endif
- unsigned int ecc_val = nand_davinci_readecc(mtd, 1);
- /* squeeze 0 middle bits out so that it fits in 3 bytes */
- unsigned int tmp = (ecc_val&0x0fff)|((ecc_val&0x0fff0000)>>4);
unsigned int tmp = (ecc_val & 0x0fff) | ((ecc_val & 0x0fff0000) >> 4); please and space between operator
plese use the same alignement add an empty line
- /* invert so that erased block ecc is correct */
- tmp = ~tmp;
- ecc_code[0] = (u_char)(tmp);
- ecc_code[1] = (u_char)(tmp >> 8);
- ecc_code[2] = (u_char)(tmp >> 16);
- struct nand_chip *chip = mtd->priv;
- u_int32_t ecc_nand = read_ecc[0] | (read_ecc[1] << 8) |
- u_int32_t ecc_calc = calc_ecc[0] | (calc_ecc[1] << 8) |
- u_int32_t diff = ecc_calc ^ ecc_nand;
- if (diff) {
uint32_t find_byte = diff >> 15; please and space between operator
too long please split
return 1;
} else {
return -1;
nothing to fix */
please use this style of comment /* * */
return 1;
} else {
/* Set address of hardware control function */ nand->hwcontrol = nand_davinci_hwcontrol;return -1;
- Previous versions of u-boot (1.3.3 and prior) and Montavista Linux kernels
- generated bogus ECCs on large-page NAND. Both large and small page NAND ECCs
- were incompatible with the Linux davinci git tree (since NAND was integrated
- in 2.6.24).
- Don't turn this on if you want backwards compatibility.
- Do turn this on if you want u-boot to be able to read and write NAND
- that can be written or read by the Linux davinci git kernel.
please move this in README.davinci
Best Regards, J.
ARM DaVinci: Fix broken HW ECC for large page NAND.
Signed-off-by: Hugo Villeneuve hugo.villeneuve@lyrtech.com
Based on original patch by Bernard Blackham bernard@largestprime.net
U-boot's HW ECC support for large page NAND on Davinci is completely broken. Some kernels, such as the 2.6.10 one supported by MontaVista for DaVinci, rely upon this broken behaviour as they share the same code for ECCs. In the existing scheme, error detection *might* work on large page, but error correction definitely does not. Small page ECC correction works, but the format is not compatible with the mainline git kernel.
The old behaviour can be restored by defining the macro CFG_DAVINCI_BROKEN_ECC, which is undefined by default.
cpu/arm926ejs/davinci/nand.c | 81 +++++++++++++++++++++++++++++++++++++++--- doc/README.nand | 8 ++++ 2 files changed, 84 insertions(+), 5 deletions(-)
diff --git a/cpu/arm926ejs/davinci/nand.c b/cpu/arm926ejs/davinci/nand.c index 5a1da63..f7cf0c9 100644 --- a/cpu/arm926ejs/davinci/nand.c +++ b/cpu/arm926ejs/davinci/nand.c @@ -88,6 +88,9 @@ static void nand_davinci_select_chip(struct mtd_info *mtd, int chip) }
#ifdef CFG_NAND_HW_ECC +#ifdef CFG_DAVINCI_BROKEN_ECC +/* Linux-compatible ECC uses MTD defaults. */ +/* These layouts are not compatible with Linux or RBL/UBL. */ #ifdef CFG_NAND_LARGEPAGE static struct nand_ecclayout davinci_nand_ecclayout = { .eccbytes = 12, @@ -112,6 +115,7 @@ static struct nand_ecclayout davinci_nand_ecclayout = { #else #error "Either CFG_NAND_LARGEPAGE or CFG_NAND_SMALLPAGE must be defined!" #endif +#endif /* CFG_DAVINCI_BROKEN_ECC */
static void nand_davinci_enable_hwecc(struct mtd_info *mtd, int mode) { @@ -150,6 +154,15 @@ static u_int32_t nand_davinci_readecc(struct mtd_info *mtd, u_int32_t region) static int nand_davinci_calculate_ecc(struct mtd_info *mtd, const u_char *dat, u_char *ecc_code) { u_int32_t tmp; +#ifdef CFG_DAVINCI_BROKEN_ECC + /* + * This is not how you should read ECCs on large page Davinci devices. + * The region parameter gets you ECCs for flash chips on different chip + * selects, not the 4x512 byte pages in a 2048 byte page. + * + * Preserved for backwards compatibility though. + */ + int region, n; struct nand_chip *this = mtd->priv;
@@ -163,9 +176,26 @@ static int nand_davinci_calculate_ecc(struct mtd_info *mtd, const u_char *dat, u *ecc_code++ = ((tmp >> 8) & 0x0f) | ((tmp >> 20) & 0xf0); region++; } +#else + const int region = 1; + + tmp = nand_davinci_readecc(mtd, region); + + /* Squeeze 4 bytes ECC into 3 bytes by removing RESERVED bits + * and shifting. RESERVED bits are 31 to 28 and 15 to 12. */ + tmp = (tmp & 0x00000fff) | ((tmp & 0x0fff0000) >> 4); + + /* Invert so that erased block ECC is correct */ + tmp = ~tmp; + + *ecc_code++ = tmp; + *ecc_code++ = tmp >> 8; + *ecc_code++ = tmp >> 16; +#endif /* CFG_DAVINCI_BROKEN_ECC */ return(0); }
+#ifdef CFG_DAVINCI_BROKEN_ECC static void nand_davinci_gen_true_ecc(u_int8_t *ecc_buf) { u_int32_t tmp = ecc_buf[0] | (ecc_buf[1] << 16) | ((ecc_buf[2] & 0xf0) << 20) | ((ecc_buf[2] & 0x0f) << 8); @@ -282,13 +312,14 @@ static int nand_davinci_compare_ecc(u_int8_t *ecc_nand, u_int8_t *ecc_calc, u_in return(-1); } } +#endif /* CFG_DAVINCI_BROKEN_ECC */
static int nand_davinci_correct_data(struct mtd_info *mtd, u_char *dat, u_char *read_ecc, u_char *calc_ecc) { - struct nand_chip *this; + struct nand_chip *this = mtd->priv; +#ifdef CFG_DAVINCI_BROKEN_ECC int block_count = 0, i, rc;
- this = mtd->priv; block_count = (this->ecc.size/512); for (i = 0; i < block_count; i++) { if (memcmp(read_ecc, calc_ecc, 3) != 0) { @@ -301,9 +332,44 @@ static int nand_davinci_correct_data(struct mtd_info *mtd, u_char *dat, u_char * calc_ecc += 3; dat += 512; } +#else + u_int32_t ecc_nand = read_ecc[0] | (read_ecc[1] << 8) | + (read_ecc[2] << 16); + u_int32_t ecc_calc = calc_ecc[0] | (calc_ecc[1] << 8) | + (calc_ecc[2] << 16); + u_int32_t diff = ecc_calc ^ ecc_nand; + + if (diff) { + if ((((diff >> 12) ^ diff) & 0xfff) == 0xfff) { + /* Correctable error */ + if ((diff >> (12 + 3)) < this->ecc.size) { + uint8_t find_bit = 1 << ((diff >> 12) & 7); + uint32_t find_byte = diff >> (12 + 3); + + dat[find_byte] ^= find_bit; + MTDDEBUG(MTD_DEBUG_LEVEL0, "Correcting single " + "bit ECC error at offset: %d, bit: " + "%d\n", find_byte, find_bit); + return 1; + } else { + return -1; + } + } else if (!(diff & (diff - 1))) { + /* Single bit ECC error in the ECC itself, + nothing to fix */ + MTDDEBUG(MTD_DEBUG_LEVEL0, "Single bit ECC error in " + "ECC.\n"); + return 1; + } else { + /* Uncorrectable error */ + MTDDEBUG(MTD_DEBUG_LEVEL0, "ECC UNCORRECTED_ERROR 1\n"); + return -1; + } + } +#endif /* CFG_DAVINCI_BROKEN_ECC */ return(0); } -#endif +#endif /* CFG_NAND_HW_ECC */
static int nand_davinci_dev_ready(struct mtd_info *mtd) { @@ -370,6 +436,8 @@ int board_nand_init(struct nand_chip *nand) #endif #ifdef CFG_NAND_HW_ECC nand->ecc.mode = NAND_ECC_HW; +#ifdef CFG_DAVINCI_BROKEN_ECC + nand->ecc.layout = &davinci_nand_ecclayout; #ifdef CFG_NAND_LARGEPAGE nand->ecc.size = 2048; nand->ecc.bytes = 12; @@ -379,13 +447,16 @@ int board_nand_init(struct nand_chip *nand) #else #error "Either CFG_NAND_LARGEPAGE or CFG_NAND_SMALLPAGE must be defined!" #endif - nand->ecc.layout = &davinci_nand_ecclayout; +#else + nand->ecc.size = 512; + nand->ecc.bytes = 3; +#endif /* CFG_DAVINCI_BROKEN_ECC */ nand->ecc.calculate = nand_davinci_calculate_ecc; nand->ecc.correct = nand_davinci_correct_data; nand->ecc.hwctl = nand_davinci_enable_hwecc; #else nand->ecc.mode = NAND_ECC_SOFT; -#endif +#endif /* CFG_NAND_HW_ECC */
/* Set address of hardware control function */ nand->cmd_ctrl = nand_davinci_hwcontrol; diff --git a/doc/README.nand b/doc/README.nand index 171380e..6dac24c 100644 --- a/doc/README.nand +++ b/doc/README.nand @@ -174,6 +174,14 @@ More Definitions: #define NAND_MAX_FLOORS 1 #define NAND_MAX_CHIPS 1
+ #define CFG_DAVINCI_BROKEN_ECC + Versions of U-Boot <= 1.3.3 and Montavista Linux kernels + generated bogus ECCs on large-page NAND. Both large and small page + NAND ECCs were incompatible with the Linux davinci git tree (since + NAND was integrated in 2.6.24). + Turn this ON if you want backwards compatibility. + Turn this OFF if you want U-Boot and the Linux davinci git kernel + to use the same ECC format.
NOTE: =====
On Sat, 30 Aug 2008, Hugo Villeneuve wrote:
ACK-by: Sergey Kubushyn ksi@koi8.net
devices.
different chip
- int region, n; struct nand_chip *this = mtd->priv;
- const int region = 1;
- tmp = nand_davinci_readecc(mtd, region);
- /* Squeeze 4 bytes ECC into 3 bytes by removing RESERVED bits
- tmp = (tmp & 0x00000fff) | ((tmp & 0x0fff0000) >> 4);
- /* Invert so that erased block ECC is correct */
- tmp = ~tmp;
- *ecc_code++ = tmp;
- *ecc_code++ = tmp >> 8;
- *ecc_code++ = tmp >> 16;
- struct nand_chip *this = mtd->priv;
- if (diff) {
7);
single "
bit: "
return 1;
} else {
return -1;
nothing to fix */
in "
"ECC.\n");
return 1;
} else {
return -1;
+#else
- nand->ecc.size = 512;
- nand->ecc.bytes = 3;
- #define CFG_DAVINCI_BROKEN_ECC
page
(since
NOTE:
--- ****************************************************************** * KSI@home KOI8 Net < > The impossible we do immediately. * * Las Vegas NV, USA < > Miracles require 24-hour notice. * ******************************************************************
Thanks for following up on this, Hugo.
This version should now be 1.3.4. Otherwise, ack.
Cheers, Bernard.
Applied to u-boot-nand-flash. Next time, please put the commit message above the "---", except for extra commentary that isn't intended to go into the git history.
-Scott
participants (5)
Bernard Blackham
Hugo Villeneuve
Jean-Christophe PLAGNIOL-VILLARD
ksi@koi8.net
Scott Wood
