[U-Boot-Users] U-Boot Memory Allocation for Framebuffer?
I'm doing some development on a LCD framebuffer for the OMAP 1510 Innovator board (ARM925T CPU), and am encountering some difficulties with code flying off to strange places.
I'm theorizing that the code flies off because memory is not properly allocated for the framebuffer. I'm basing all of my new U-Boot related code on cpu/mpc8xx/lcd.c, and adding LCD code from the OMAP kernel to get a final product.
I make use of this code from lib_arm/board.c:
#ifdef CONFIG_LCD /* * reserve memory for LCD display (always full pages) */ /* bss_end is defined in the board-specific linker script */ addr = (_bss_end + (PAGE_SIZE - 1)) & ~(PAGE_SIZE - 1); size = lcd_setmem (addr); gd->fb_base = addr; #endif /* CONFIG_LCD */
I have a lcd_setmem function that works fine, but I don't think the memory map gets properly initialized once it knows how much framebuffer memory is needed.
As the board initializes, "U-Boot code: 11080000 -> 1109D7B0 BSS: -> 110A1DA0" is printed, and the call lcd_setmem(0x110a2000) happens. lcd_setmem wants to reserve the size 0x13000, which causes 'addr' in the above code block to be 1108f000, and that is the location of the framebuffer.
With the framebuffer occupying 1108f000 to 110A2000, that leaves only 1108000 to 1108f000 for U-Boot. Taking a look at disassembly of the binary, there is definitely valid code in the framebuffer range.
I'm wondering how the code block above, which also appears in roughly the same form in lib_ppc/board.c, is supposed to grab a block of free memory for the framebuffer. Do I need to just allocate uchar framebuffer[col*row*depth+palette] and point the framebuffer address to that instead? Something else?
Thanks,
-Michael Bendzick Systems and Software Engineering Logic Product Development michael.b@logicpd.com 612-436-5122 www.logicpd.com
If you look at the lcd_setmem() function in cpu/pxa/pxafb.c you can see that it does nothing worth calling it - maybe just for information that we are "reserving" FB mem. It just calculates the size, prints it out and does nothing else on that chunk. Also note that returned value by lcd_setmem() is not being used anywhere, for that matter. For my pxa255 arm target board I commented out call to lcd_setmem().
When it prints out, it prints out the wrong value. Actually FB starts at passed address - 0x110a2000 in your case (which is page aligned location after _bss_end). Memory in size = fb_size + page_size is then used for: * FB * DMA descriptors * palette
in that order.
I don't know how the ppc deals with it, but above works for me - I'm also memcpy'ing fb and palette allocated by u-boot later in linux, so I can confirm that locations on FB and palette are correct.
HTH, himba
In message 31ADFA827355984B9E2A161514595B561C330E@lpdsrv04.logicpd.com you wrote:
It is not a good idea to use the PPC code as a model as it is based on a different memory map. It may not work on ARM - on PPC, we actually compute the relocation address depeding on how much memory we need to reserve. All this is missing for ARM.
It does not gram anything. It is just a copy of PPC code which is used in a completely different context on PPC.
Either you simply make sure not to use the framebuffer area which follows the BSS segment, or (more complicated) you fix the ARM implementation and implement real relocation as done for PPC. I'd prefer to see (2) because this is long overdue, but I could understand if you chose the simple route.
himba
Michael Bendzick
