[U-Boot] SZ_* errors compiling mmc master branch
Jaehoon,
When building git://git.denx.de/u-boot-mmc.git master for sandbox, I see the following error, and many more like it:
Building current source for 3 boards (3 threads, 4 jobs per thread) sandbox: + sandbox_noblk +drivers/mmc/mmc.c:25:6: error: ‘SZ_16K’ undeclared here (not in a function)
- 0, SZ_16K / 512, SZ_32K / 512,
+drivers/mmc/mmc.c:25:21: error: ‘SZ_32K’ undeclared here (not in a function)
Hi Stephen,
On 08/31/2016 01:11 AM, Stephen Warren wrote:
Jaehoon,
Thanks for pointing out. I'm testing the building with buildman. I knew that there is buildman in u-boot. After checking this, i will do to request pull. (Actually, i don't know exactly how to use the buildman. So i'm checking this.)
This way is right?
Anyway, i will check this and fix everything until today.
Best Regards, Jaehoon Chung
Hi Stephen,
On 08/31/2016 10:02 AM, Jaehoon Chung wrote:
Hi Stephen,
Jaehoon,
This way is right?
Thank you! I have checked with buildman..In future, i will do to check with buildman. It's useful!
On 08/30/2016 07:02 PM, Jaehoon Chung wrote:
Hi Stephen,
Jaehoon,
This way is right?
I run the following to run buildman:
time SOURCE_DATE_EPOCH=0 ./tools/buildman/buildman -I -P tegra sandbox
The -I and -P options are optional(!) They make the builds faster for me by using per-board build directories rather than per-thread. Feel free to use them or skip them.
SOURCE_DATE_EPOCH=0 uses a zero value for the build timestamp so that it doesn't change every time. This avoids rebuilding and relinking when nothing has changed. Again, feel free to skip this.
So, the simplest invocation might be:
./tools/buildman/buildman tegra sandbox # adjusted to whatever set of builds you want to build
BTW, my ~/.buildman configuration file contains:
[toolchain] distro-packages = /usr/bin download = /home/swarren/.buildman-toolchains/*/*
[toolchain-alias] x86: i386 x86_64 blackfin: bfin nds32: nds32le openrisc: or1k sh: sh4
[toolchain-prefix] arm: arm-linux-gnueabi- aarch64: aarch64-linux-gnu-
You can probably get away with simpler content; see the buildman README.
(but FWIW I see the same errors that I quoted in the original email simply by running a regular make sandbox_defconfig; make.)
Jaehoon Chung
Stephen Warren
