[PATCH] sunxi: dts: arm64: update devicetree files
Sync the devicetree files from the Linux kernel repo, v6.2-rc2. This enables GPU power management in the kernel for the H6, enables Bluetooth on the Pinebook, and enables USB on the H616 devices (just for newer Linux kernels at the moment, U-Boot support is pending).
As before, this omits the non-backwards compatible changes to the R_INTC controller, to remain compatible with older kernels.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- arch/arm/dts/axp803.dtsi | 10 -- arch/arm/dts/sun50i-a64-pinebook.dts | 14 ++ arch/arm/dts/sun50i-h6-beelink-gs1.dts | 1 + arch/arm/dts/sun50i-h6-gpu-opp.dtsi | 87 +++++++++++ arch/arm/dts/sun50i-h6.dtsi | 52 ++++++- arch/arm/dts/sun50i-h616-orangepi-zero2.dts | 41 +++++ arch/arm/dts/sun50i-h616-x96-mate.dts | 25 +++ arch/arm/dts/sun50i-h616.dtsi | 160 ++++++++++++++++++++ 8 files changed, 378 insertions(+), 12 deletions(-) create mode 100644 arch/arm/dts/sun50i-h6-gpu-opp.dtsi
diff --git a/arch/arm/dts/axp803.dtsi b/arch/arm/dts/axp803.dtsi index 578ef368e2b..a6b4b87f185 100644 --- a/arch/arm/dts/axp803.dtsi +++ b/arch/arm/dts/axp803.dtsi @@ -25,16 +25,6 @@ compatible = "x-powers,axp803-gpio", "x-powers,axp813-gpio"; gpio-controller; #gpio-cells = <2>; - - gpio0_ldo: gpio0-ldo-pin { - pins = "GPIO0"; - function = "ldo"; - }; - - gpio1_ldo: gpio1-ldo-pin { - pins = "GPIO1"; - function = "ldo"; - }; };
battery_power_supply: battery-power { diff --git a/arch/arm/dts/sun50i-a64-pinebook.dts b/arch/arm/dts/sun50i-a64-pinebook.dts index c00c4c1e9e7..576eae13223 100644 --- a/arch/arm/dts/sun50i-a64-pinebook.dts +++ b/arch/arm/dts/sun50i-a64-pinebook.dts @@ -406,6 +406,20 @@ status = "okay"; };
+&uart1 { + pinctrl-names = "default"; + pinctrl-0 = <&uart1_pins>, <&uart1_rts_cts_pins>; + uart-has-rtscts; + status = "okay"; + + bluetooth { + compatible = "realtek,rtl8723cs-bt"; + device-wake-gpios = <&r_pio 0 5 GPIO_ACTIVE_LOW>; /* PL5 */ + enable-gpios = <&r_pio 0 4 GPIO_ACTIVE_HIGH>; /* PL4 */ + host-wake-gpios = <&r_pio 0 6 GPIO_ACTIVE_HIGH>; /* PL6 */ + }; +}; + &usb_otg { dr_mode = "host"; }; diff --git a/arch/arm/dts/sun50i-h6-beelink-gs1.dts b/arch/arm/dts/sun50i-h6-beelink-gs1.dts index 649b146dfff..d6897ec9799 100644 --- a/arch/arm/dts/sun50i-h6-beelink-gs1.dts +++ b/arch/arm/dts/sun50i-h6-beelink-gs1.dts @@ -5,6 +5,7 @@
#include "sun50i-h6.dtsi" #include "sun50i-h6-cpu-opp.dtsi" +#include "sun50i-h6-gpu-opp.dtsi"
#include <dt-bindings/gpio/gpio.h>
diff --git a/arch/arm/dts/sun50i-h6-gpu-opp.dtsi b/arch/arm/dts/sun50i-h6-gpu-opp.dtsi new file mode 100644 index 00000000000..b48049c4fc8 --- /dev/null +++ b/arch/arm/dts/sun50i-h6-gpu-opp.dtsi @@ -0,0 +1,87 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +// Copyright (C) 2022 Clément Péron peron.clem@gmail.com + +/ { + gpu_opp_table: opp-table-gpu { + compatible = "operating-points-v2"; + + opp-216000000 { + opp-hz = /bits/ 64 <216000000>; + opp-microvolt = <810000 810000 1200000>; + }; + + opp-264000000 { + opp-hz = /bits/ 64 <264000000>; + opp-microvolt = <810000 810000 1200000>; + }; + + opp-312000000 { + opp-hz = /bits/ 64 <312000000>; + opp-microvolt = <810000 810000 1200000>; + }; + + opp-336000000 { + opp-hz = /bits/ 64 <336000000>; + opp-microvolt = <810000 810000 1200000>; + }; + + opp-360000000 { + opp-hz = /bits/ 64 <360000000>; + opp-microvolt = <820000 820000 1200000>; + }; + + opp-384000000 { + opp-hz = /bits/ 64 <384000000>; + opp-microvolt = <830000 830000 1200000>; + }; + + opp-408000000 { + opp-hz = /bits/ 64 <408000000>; + opp-microvolt = <840000 840000 1200000>; + }; + + opp-420000000 { + opp-hz = /bits/ 64 <420000000>; + opp-microvolt = <850000 850000 1200000>; + }; + + opp-432000000 { + opp-hz = /bits/ 64 <432000000>; + opp-microvolt = <860000 860000 1200000>; + }; + + opp-456000000 { + opp-hz = /bits/ 64 <456000000>; + opp-microvolt = <870000 870000 1200000>; + }; + + opp-504000000 { + opp-hz = /bits/ 64 <504000000>; + opp-microvolt = <890000 890000 1200000>; + }; + + opp-540000000 { + opp-hz = /bits/ 64 <540000000>; + opp-microvolt = <910000 910000 1200000>; + }; + + opp-576000000 { + opp-hz = /bits/ 64 <576000000>; + opp-microvolt = <930000 930000 1200000>; + }; + + opp-624000000 { + opp-hz = /bits/ 64 <624000000>; + opp-microvolt = <950000 950000 1200000>; + }; + + opp-756000000 { + opp-hz = /bits/ 64 <756000000>; + opp-microvolt = <1040000 1040000 1200000>; + }; + }; +}; + +&gpu { + operating-points-v2 = <&gpu_opp_table>; +}; diff --git a/arch/arm/dts/sun50i-h6.dtsi b/arch/arm/dts/sun50i-h6.dtsi index afbbfc25269..3c85c8cc8ea 100644 --- a/arch/arm/dts/sun50i-h6.dtsi +++ b/arch/arm/dts/sun50i-h6.dtsi @@ -161,6 +161,7 @@ clocks = <&ccu CLK_BUS_VP9>, <&ccu CLK_VP9>; clock-names = "bus", "mod"; resets = <&ccu RST_BUS_VP9>; + iommus = <&iommu 5>; };
video-codec@1c0e000 { @@ -186,6 +187,7 @@ clocks = <&ccu CLK_GPU>, <&ccu CLK_BUS_GPU>; clock-names = "core", "bus"; resets = <&ccu RST_BUS_GPU>; + #cooling-cells = <2>; status = "disabled"; };
@@ -1070,9 +1072,55 @@ };
gpu-thermal { - polling-delay-passive = <0>; - polling-delay = <0>; + polling-delay-passive = <1000>; + polling-delay = <2000>; thermal-sensors = <&ths 1>; + + trips { + gpu_alert0: gpu-alert-0 { + temperature = <95000>; + hysteresis = <2000>; + type = "passive"; + }; + + gpu_alert1: gpu-alert-1 { + temperature = <100000>; + hysteresis = <2000>; + type = "passive"; + }; + + gpu_alert2: gpu-alert-2 { + temperature = <105000>; + hysteresis = <2000>; + type = "passive"; + }; + + gpu-crit { + temperature = <115000>; + hysteresis = <0>; + type = "critical"; + }; + }; + + cooling-maps { + // Forbid the GPU to go over 756MHz + map0 { + trip = <&gpu_alert0>; + cooling-device = <&gpu 1 THERMAL_NO_LIMIT>; + }; + + // Forbid the GPU to go over 624MHz + map1 { + trip = <&gpu_alert1>; + cooling-device = <&gpu 2 THERMAL_NO_LIMIT>; + }; + + // Forbid the GPU to go over 576MHz + map2 { + trip = <&gpu_alert2>; + cooling-device = <&gpu 3 THERMAL_NO_LIMIT>; + }; + }; }; }; }; diff --git a/arch/arm/dts/sun50i-h616-orangepi-zero2.dts b/arch/arm/dts/sun50i-h616-orangepi-zero2.dts index 02893f3ac99..cb8600d0ea1 100644 --- a/arch/arm/dts/sun50i-h616-orangepi-zero2.dts +++ b/arch/arm/dts/sun50i-h616-orangepi-zero2.dts @@ -49,8 +49,24 @@ regulator-max-microvolt = <5000000>; regulator-always-on; }; + + reg_usb1_vbus: regulator-usb1-vbus { + compatible = "regulator-fixed"; + regulator-name = "usb1-vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <®_vcc5v>; + enable-active-high; + gpio = <&pio 2 16 GPIO_ACTIVE_HIGH>; /* PC16 */ + }; };
+&ehci1 { + status = "okay"; +}; + +/* USB 2 & 3 are on headers only. */ + &emac0 { pinctrl-names = "default"; pinctrl-0 = <&ext_rgmii_pins>; @@ -76,6 +92,10 @@ status = "okay"; };
+&ohci1 { + status = "okay"; +}; + &r_rsb { status = "okay";
@@ -211,3 +231,24 @@ pinctrl-0 = <&uart0_ph_pins>; status = "okay"; }; + +&usbotg { + /* + * PHY0 pins are connected to a USB-C socket, but a role switch + * is not implemented: both CC pins are pulled to GND. + * The VBUS pins power the device, so a fixed peripheral mode + * is the best choice. + * The board can be powered via GPIOs, in this case port0 *can* + * act as a host (with a cable/adapter ignoring CC), as VBUS is + * then provided by the GPIOs. Any user of this setup would + * need to adjust the DT accordingly: dr_mode set to "host", + * enabling OHCI0 and EHCI0. + */ + dr_mode = "peripheral"; + status = "okay"; +}; + +&usbphy { + usb1_vbus-supply = <®_usb1_vbus>; + status = "okay"; +}; diff --git a/arch/arm/dts/sun50i-h616-x96-mate.dts b/arch/arm/dts/sun50i-h616-x96-mate.dts index 6619db34714..07424c28b69 100644 --- a/arch/arm/dts/sun50i-h616-x96-mate.dts +++ b/arch/arm/dts/sun50i-h616-x96-mate.dts @@ -32,6 +32,14 @@ }; };
+&ehci0 { + status = "okay"; +}; + +&ehci2 { + status = "okay"; +}; + &ir { status = "okay"; }; @@ -54,6 +62,14 @@ status = "okay"; };
+&ohci0 { + status = "okay"; +}; + +&ohci2 { + status = "okay"; +}; + &r_rsb { status = "okay";
@@ -175,3 +191,12 @@ pinctrl-0 = <&uart0_ph_pins>; status = "okay"; }; + +&usbotg { + dr_mode = "host"; /* USB A type receptable */ + status = "okay"; +}; + +&usbphy { + status = "okay"; +}; diff --git a/arch/arm/dts/sun50i-h616.dtsi b/arch/arm/dts/sun50i-h616.dtsi index 622a1f7d164..74aed0d232a 100644 --- a/arch/arm/dts/sun50i-h616.dtsi +++ b/arch/arm/dts/sun50i-h616.dtsi @@ -504,6 +504,166 @@ }; };
+ usbotg: usb@5100000 { + compatible = "allwinner,sun50i-h616-musb", + "allwinner,sun8i-h3-musb"; + reg = <0x05100000 0x0400>; + clocks = <&ccu CLK_BUS_OTG>; + resets = <&ccu RST_BUS_OTG>; + interrupts = <GIC_SPI 25 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "mc"; + phys = <&usbphy 0>; + phy-names = "usb"; + extcon = <&usbphy 0>; + status = "disabled"; + }; + + usbphy: phy@5100400 { + compatible = "allwinner,sun50i-h616-usb-phy"; + reg = <0x05100400 0x24>, + <0x05101800 0x14>, + <0x05200800 0x14>, + <0x05310800 0x14>, + <0x05311800 0x14>; + reg-names = "phy_ctrl", + "pmu0", + "pmu1", + "pmu2", + "pmu3"; + clocks = <&ccu CLK_USB_PHY0>, + <&ccu CLK_USB_PHY1>, + <&ccu CLK_USB_PHY2>, + <&ccu CLK_USB_PHY3>, + <&ccu CLK_BUS_EHCI2>; + clock-names = "usb0_phy", + "usb1_phy", + "usb2_phy", + "usb3_phy", + "pmu2_clk"; + resets = <&ccu RST_USB_PHY0>, + <&ccu RST_USB_PHY1>, + <&ccu RST_USB_PHY2>, + <&ccu RST_USB_PHY3>; + reset-names = "usb0_reset", + "usb1_reset", + "usb2_reset", + "usb3_reset"; + status = "disabled"; + #phy-cells = <1>; + }; + + ehci0: usb@5101000 { + compatible = "allwinner,sun50i-h616-ehci", + "generic-ehci"; + reg = <0x05101000 0x100>; + interrupts = <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_OHCI0>, + <&ccu CLK_BUS_EHCI0>, + <&ccu CLK_USB_OHCI0>; + resets = <&ccu RST_BUS_OHCI0>, + <&ccu RST_BUS_EHCI0>; + phys = <&usbphy 0>; + phy-names = "usb"; + status = "disabled"; + }; + + ohci0: usb@5101400 { + compatible = "allwinner,sun50i-h616-ohci", + "generic-ohci"; + reg = <0x05101400 0x100>; + interrupts = <GIC_SPI 27 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_OHCI0>, + <&ccu CLK_USB_OHCI0>; + resets = <&ccu RST_BUS_OHCI0>; + phys = <&usbphy 0>; + phy-names = "usb"; + status = "disabled"; + }; + + ehci1: usb@5200000 { + compatible = "allwinner,sun50i-h616-ehci", + "generic-ehci"; + reg = <0x05200000 0x100>; + interrupts = <GIC_SPI 28 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_OHCI1>, + <&ccu CLK_BUS_EHCI1>, + <&ccu CLK_USB_OHCI1>; + resets = <&ccu RST_BUS_OHCI1>, + <&ccu RST_BUS_EHCI1>; + phys = <&usbphy 1>; + phy-names = "usb"; + status = "disabled"; + }; + + ohci1: usb@5200400 { + compatible = "allwinner,sun50i-h616-ohci", + "generic-ohci"; + reg = <0x05200400 0x100>; + interrupts = <GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_OHCI1>, + <&ccu CLK_USB_OHCI1>; + resets = <&ccu RST_BUS_OHCI1>; + phys = <&usbphy 1>; + phy-names = "usb"; + status = "disabled"; + }; + + ehci2: usb@5310000 { + compatible = "allwinner,sun50i-h616-ehci", + "generic-ehci"; + reg = <0x05310000 0x100>; + interrupts = <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_OHCI2>, + <&ccu CLK_BUS_EHCI2>, + <&ccu CLK_USB_OHCI2>; + resets = <&ccu RST_BUS_OHCI2>, + <&ccu RST_BUS_EHCI2>; + phys = <&usbphy 2>; + phy-names = "usb"; + status = "disabled"; + }; + + ohci2: usb@5310400 { + compatible = "allwinner,sun50i-h616-ohci", + "generic-ohci"; + reg = <0x05310400 0x100>; + interrupts = <GIC_SPI 31 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_OHCI2>, + <&ccu CLK_USB_OHCI2>; + resets = <&ccu RST_BUS_OHCI2>; + phys = <&usbphy 2>; + phy-names = "usb"; + status = "disabled"; + }; + + ehci3: usb@5311000 { + compatible = "allwinner,sun50i-h616-ehci", + "generic-ehci"; + reg = <0x05311000 0x100>; + interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_OHCI3>, + <&ccu CLK_BUS_EHCI3>, + <&ccu CLK_USB_OHCI3>; + resets = <&ccu RST_BUS_OHCI3>, + <&ccu RST_BUS_EHCI3>; + phys = <&usbphy 3>; + phy-names = "usb"; + status = "disabled"; + }; + + ohci3: usb@5311400 { + compatible = "allwinner,sun50i-h616-ohci", + "generic-ohci"; + reg = <0x05311400 0x100>; + interrupts = <GIC_SPI 33 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_OHCI3>, + <&ccu CLK_USB_OHCI3>; + resets = <&ccu RST_BUS_OHCI3>; + phys = <&usbphy 3>; + phy-names = "usb"; + status = "disabled"; + }; + rtc: rtc@7000000 { compatible = "allwinner,sun50i-h616-rtc"; reg = <0x07000000 0x400>;
Andre Przywara
