[U-Boot] [PATCH V4 1/4] dm: spi: soft_spi bug fix
When doing xfer, should use device->parent, but not device When doing bit xfer, should use "!!(tmpdout & 0x80)", but not "(tmpdout & 0x80)"
Signed-off-by: Peng Fan van.freenix@gmail.com Cc: Simon Glass sjg@chromium.org Cc: Jagan Teki jteki@openedev.com Reviewed-by: Simon Glass sjg@chromium.org ---
V4: None
V3: None
V2: Follow Simon's comments, split bug fix into seperate patch.
drivers/spi/soft_spi.c | 19 ++++++++++++------- 1 file changed, 12 insertions(+), 7 deletions(-)
diff --git a/drivers/spi/soft_spi.c b/drivers/spi/soft_spi.c index aa4abcc..8cdb520 100644 --- a/drivers/spi/soft_spi.c +++ b/drivers/spi/soft_spi.c @@ -34,7 +34,8 @@ struct soft_spi_priv {
static int soft_spi_scl(struct udevice *dev, int bit) { - struct soft_spi_platdata *plat = dev->platdata; + struct udevice *bus = dev_get_parent(dev); + struct soft_spi_platdata *plat = dev_get_platdata(bus);
dm_gpio_set_value(&plat->sclk, bit);
@@ -43,7 +44,8 @@ static int soft_spi_scl(struct udevice *dev, int bit)
static int soft_spi_sda(struct udevice *dev, int bit) { - struct soft_spi_platdata *plat = dev->platdata; + struct udevice *bus = dev_get_parent(dev); + struct soft_spi_platdata *plat = dev_get_platdata(bus);
dm_gpio_set_value(&plat->mosi, bit);
@@ -52,7 +54,8 @@ static int soft_spi_sda(struct udevice *dev, int bit)
static int soft_spi_cs_activate(struct udevice *dev) { - struct soft_spi_platdata *plat = dev->platdata; + struct udevice *bus = dev_get_parent(dev); + struct soft_spi_platdata *plat = dev_get_platdata(bus);
dm_gpio_set_value(&plat->cs, 0); dm_gpio_set_value(&plat->sclk, 0); @@ -63,7 +66,8 @@ static int soft_spi_cs_activate(struct udevice *dev)
static int soft_spi_cs_deactivate(struct udevice *dev) { - struct soft_spi_platdata *plat = dev->platdata; + struct udevice *bus = dev_get_parent(dev); + struct soft_spi_platdata *plat = dev_get_platdata(bus);
@@ -100,8 +104,9 @@ static int soft_spi_release_bus(struct udevice *dev) static int soft_spi_xfer(struct udevice *dev, unsigned int bitlen, const void *dout, void *din, unsigned long flags) { - struct soft_spi_priv *priv = dev_get_priv(dev); - struct soft_spi_platdata *plat = dev->platdata; + struct udevice *bus = dev_get_parent(dev); + struct soft_spi_priv *priv = dev_get_priv(bus); + struct soft_spi_platdata *plat = dev_get_platdata(bus); uchar tmpdin = 0; uchar tmpdout = 0; const u8 *txd = dout; @@ -134,7 +139,7 @@ static int soft_spi_xfer(struct udevice *dev, unsigned int bitlen,
if (!cpha) soft_spi_scl(dev, 0); - soft_spi_sda(dev, tmpdout & 0x80); + soft_spi_sda(dev, !!(tmpdout & 0x80)); udelay(plat->spi_delay_us); if (cpha) soft_spi_scl(dev, 0);
V4: None
V3: None
Applied to u-boot-dm, thanks!
Peng Fan
