[U-Boot] [PATCH v2] bootvx: Clear and disable data cache, and call vxWorks with parameter.
This patch clear and disable the data cache for vxWorks.
The entry point sysInit(int) intended by Windriver to be called from the vxWorks bootrom, a very small vxWorks system. The routine is called by the go() handler in the bootrom, that clears the cache from start of image to end of usable memory.
The PowerPC implementations only invalidates and disable the cache, the ARM implementations also flush it.
U-Boot will be on the save side, if it disables the data cache before calling vxWorks sysInit(int).
Signed-off-by: Reinhard Arlt reinhard.arlt@esd.eu
diff --git a/common/cmd_elf.c b/common/cmd_elf.c index 11ffc1b..8266bba 100644 --- a/common/cmd_elf.c +++ b/common/cmd_elf.c @@ -230,7 +230,8 @@ int do_bootvx (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) (char *) bootaddr); printf ("## Starting vxWorks at 0x%08lx ...\n", addr);
- ((void (*)(void)) addr) (); + dcache_disable(); + ((void (*)(int)) addr) (0);
puts ("## vxWorks terminated\n"); return 1;
Dear Reinhard Arlt,
Applied, thanks.
Mike Frysinger
Reinhard Arlt
