Re: [DNX#2006040142001507] [U-Boot-Users] i.MX support for scb9328 cleaned up [...]
Hello list,
inside the automatic U-Boot patch tracking system a new ticket [DNX#2006040142001507] was created:
<snip>
At Tue, 11 Oct 2005 22:34:24 +0200, Wolfgang Denk wd@denx.de wrote:
Does that mean that I should ignore the link you posted earlier today?
I cleared up the structure now.
http://www.ludenkalle.de/u-boot/
Has my last clean up effort and the old stuff in deprecated. The u-boot-git-20051012.diff is a diff between yesterdays git checkout and my actual modifications. the directory content of u-boot-git-20051012/ is the same splittet with splitdiff vor viewing convenience on a per file basis (so pretty redundant).
Make sure to include or exactly the needed features only. "all but X" is asking for problems when a new feature Y gets added which is not supported by your board. Rather use "default - M - N + X + Y".
But is
+#define CONFIG_COMMANDS \ (CONFIG_CMD_DFL\ & ~CFG_CMD_NET\ & ~CFG_CMD_IMLS\
& ~CFG_CMD_MISC\ | CFG_CMD_CACHE)
not your described way to do this?
Yes, there are several of these stupidly configured boards which I have to cleanup nearly each time a new command gets added. See
Do you have an example in mind where I should have a look at?
Regards, Konsti
-- GPG KeyID EF62FCEF Fingerprint: 13C9 B16B 9844 EC15 CC2E A080 1E69 3FDA EF62 FCEF
This SF.Net email is sponsored by: Power Architecture Resource Center: Free content, downloads, discussions, and more. http://solutions.newsforge.com/ibmarch.tmpl _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
</snip>
Your U-Boot support team
DENX Support System
