[U-Boot] [PATCH] net: phy: marvell: Add functions to read PHY's extended registers
This commit allows extended Marvell registers to be read with:
foo > mdio rx FEC 3.10 Reading from bus FEC PHY at address 0: 3.16 - 0x1063 foo > mdio wx FEC 3.10 0x1011
The above code changes the way ETH connector LEDs blink.
Signed-off-by: Lukasz Majewski lukma@denx.de --- drivers/net/phy/marvell.c | 27 +++++++++++++++++++++++++++ 1 file changed, 27 insertions(+)
diff --git a/drivers/net/phy/marvell.c b/drivers/net/phy/marvell.c index b7f300e..a167c34 100644 --- a/drivers/net/phy/marvell.c +++ b/drivers/net/phy/marvell.c @@ -104,6 +104,31 @@ #define MIIM_88E151x_MODE_SGMII 1 #define MIIM_88E151x_RESET_OFFS 15
+static int m88e1xxx_phy_extread(struct phy_device *phydev, int addr, + int devaddr, int regnum) +{ + int oldpage = phy_read(phydev, MDIO_DEVAD_NONE, MII_MARVELL_PHY_PAGE); + int val; + + phy_write(phydev, MDIO_DEVAD_NONE, MII_MARVELL_PHY_PAGE, devaddr); + val = phy_read(phydev, MDIO_DEVAD_NONE, regnum); + phy_write(phydev, MDIO_DEVAD_NONE, MII_MARVELL_PHY_PAGE, oldpage); + + return val; +} + +static int m88e1xxx_phy_extwrite(struct phy_device *phydev, int addr, + int devaddr, int regnum, u16 val) +{ + int oldpage = phy_read(phydev, MDIO_DEVAD_NONE, MII_MARVELL_PHY_PAGE); + + phy_write(phydev, MDIO_DEVAD_NONE, MII_MARVELL_PHY_PAGE, devaddr); + phy_write(phydev, MDIO_DEVAD_NONE, regnum, val); + phy_write(phydev, MDIO_DEVAD_NONE, MII_MARVELL_PHY_PAGE, oldpage); + + return 0; +} + /* Marvell 88E1011S */ static int m88e1011s_config(struct phy_device *phydev) { @@ -669,6 +694,8 @@ static struct phy_driver M88E1510_driver = { .config = &m88e1510_config, .startup = &m88e1011s_startup, .shutdown = &genphy_shutdown, + .readext = &m88e1xxx_phy_extread, + .writeext = &m88e1xxx_phy_extwrite, };
Dear All,
Gentle ping about this patch.
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de
- int oldpage = phy_read(phydev, MDIO_DEVAD_NONE, MII_MARVELL_PHY_PAGE);
- int val;
- phy_write(phydev, MDIO_DEVAD_NONE, MII_MARVELL_PHY_PAGE, devaddr);
- val = phy_read(phydev, MDIO_DEVAD_NONE, regnum);
- phy_write(phydev, MDIO_DEVAD_NONE, MII_MARVELL_PHY_PAGE, oldpage);
- return val;
- phy_write(phydev, MDIO_DEVAD_NONE, regnum, val);
- .readext = &m88e1xxx_phy_extread,
- .writeext = &m88e1xxx_phy_extwrite,
I guess this feature is usable. You only enable it for M88E1510. Can the same be applied to other Marvell PHYs?
York
- int val;
devaddr);
oldpage); +
- return val;
devaddr);
oldpage); +
It should work...
However, in this patch I've only enabled one - which I could test.....
I can enable more if you can help me with debugging.
York
Lukasz Majewski
- int val;
devaddr);
oldpage); +
- return val;
val) +{
devaddr);
oldpage); +
It should work...
s/debugging/testing
York
Lukasz Majewski
Lukasz Majewski
- int val;
devaddr);
oldpage); +
- return val;
val) +{
devaddr);
oldpage); +
It should work...
s/debugging/testing
I can try to find some old boards with Marvell PHYs, but it is not easy. Our recent boards don't use their PHYs (don't ask me why). Maybe we can take another approach. If you have access to the PHY manual, maybe you can confirm the extended page is available. This actually prompts another thought. What would happen if you access to a non-exist page? I hope it doesn't lock the system. Please try it.
York
Hi York,
- int val;
devaddr);
oldpage); +
- return val;
val) +{
devaddr);
oldpage); +
It should work...
s/debugging/testing
It should not harm the devices. I would add the code to devices which we can test.
Support for others would be added on demand if somebody can test the code.
York
Lukasz Majewski
Lukasz Majewski
York Sun
