[PATCH] xilinx: zynqmp: Remove conditional check for bootmenu_default variable
From: John Vicky Vykuntapu johnvicky.vykuntapu@amd.com
As per bootmenu support added default boot options to CC on AMD CCs and default to SOM on others. However, if no secondary boot device is enabled in the design,it should be the default boot option for SOM when combined with AMD CCs because it only contains SOM peripherals. To address this issue, The conditional check for the bootmenu_default variable was removed, and it has always been set to SOM as the default boot option. In this way, users can choose preferred boot options from the bootmenu based on the boot devices configured in the design for AMD CCs.
Fixes: 61bf0fa8663d ("xilinx: zynqmp: Add bootmenu support") Signed-off-by: John Vicky Vykuntapu johnvicky.vykuntapu@amd.com Signed-off-by: Michal Simek michal.simek@amd.com ---
board/xilinx/zynqmp/zynqmp_kria.env | 3 +-- 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/board/xilinx/zynqmp/zynqmp_kria.env b/board/xilinx/zynqmp/zynqmp_kria.env index d0e431ebb46f..927f398c3c38 100644 --- a/board/xilinx/zynqmp/zynqmp_kria.env +++ b/board/xilinx/zynqmp/zynqmp_kria.env @@ -51,8 +51,7 @@ som_mmc_boot=setenv boot_targets mmc0 && run distro_bootcmd
# To disable bootmenu set enable_bootmenu=0 enable_bootmenu=1 -check_cc_for_default_boot=if test ${card1_name} = SCK-KV-G || test ${card1_name} = SCK-KR-G || test ${card1_name} = SCK-KD-G; then setenv bootmenu_default 1; else setenv bootmenu_default 0; fi -som_bootmenu=if test ${enable_bootmenu} = 1; then run check_cc_for_default_boot; bootmenu; else run som_mmc_boot; fi +som_bootmenu=if test ${enable_bootmenu} = 1; then bootmenu; else run som_mmc_boot; fi
k26_starter=SMK-K26-XCL2G k24_starter=SMK-K24-XCL2G
Applied. M
Michal Simek
