[U-Boot] [PATCH] arm:trats: Increase malloc pool size (for DFU ext4 transfers)
Commit: dfu: make data buffer size configurable SHA1: 89a72b2e0e141042c9109185e02d39b2107ffc62
replaced statically allocated buffers with one allocated with memalign.
Malloc pool size of 1MiB was too small, since we needed bigger buffer to transfer for example uImage.
Signed-off-by: Lukasz Majewski l.majewski@samsung.com Cc: Minkyu Kang mk7.kang@samsung.com --- include/configs/trats.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/configs/trats.h b/include/configs/trats.h index 53fcf79..90562c4 100644 --- a/include/configs/trats.h +++ b/include/configs/trats.h @@ -66,7 +66,7 @@ #define CONFIG_MACH_TYPE MACH_TYPE_TRATS
/* Size of malloc() pool */ -#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (1 << 20)) +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (16 << 20))
/* select serial console configuration */ #define CONFIG_SERIAL2 /* use SERIAL 2 */
applied to u-boot-samsung.
Thanks, Minkyu Kang.
Lukasz Majewski
Minkyu Kang
