[PATCH v6 0/8] Bug-fixes for a few boards (reduced series)
This series includes fixes to get some rockchip and nvidia boards working again. It also drops the broken Beaglebone Black config and provides a devicetree fix for coral (x86).
Note that since this series fixes bugs, it is targeted at -master
Note that this series does not include:
fdt: Correct condition for bloblist existing
which is needed to fix booting on several boards.
(no changes since v4)
Changes in v4: - Add new patch to set a board-size limit for chromebook_link - Fix 'stating' typo - Move Binman size feature to a separate series
Changes in v2: - Put the conditions under EFI_TCG2_PROTOCOL - Consider MEASURED_BOOT too - Remove the superfluous if() and drop the debug() as well - Drop patch "regulator: rk8xx: Fix incorrect parameter" - Rewrite boneblack patch to onstead drop the target and update docs
Simon Glass (8): nvidia: nyan-big: Disable debug UART tpm: Avoid code bloat when not using EFI_TCG2_PROTOCOL x86: Set a board-size limit for chromebook_link rockchip: veyron: Add logging for power init power: regulator: Handle autoset in regulators_enable_boot_on() spl: Allow ATF to work when dcache is disabled rockchip: bob: kevin: Disable dcache in SPL Drop the special am335x_boneblack_vboot target
board/google/veyron/veyron.c | 30 +++---- board/ti/am335x/MAINTAINERS | 1 - boot/Kconfig | 4 + common/spl/spl_atf.c | 3 +- configs/am335x_boneblack_vboot_defconfig | 94 ---------------------- configs/am335x_evm_defconfig | 3 +- configs/chromebook_bob_defconfig | 1 + configs/chromebook_kevin_defconfig | 1 + configs/chromebook_link_defconfig | 2 + configs/nyan-big_defconfig | 1 - doc/usage/fit/beaglebone_vboot.rst | 21 +++-- drivers/power/regulator/regulator-uclass.c | 2 +- lib/Kconfig | 4 - 13 files changed, 35 insertions(+), 132 deletions(-) delete mode 100644 configs/am335x_boneblack_vboot_defconfig
This cannot be enabled early in boot since some other init is needed. At this point it is unclear exactly what init is needed, so disable the debug UART to avoid a hang.
(no changes since v1)
configs/nyan-big_defconfig | 1 - 1 file changed, 1 deletion(-)
diff --git a/configs/nyan-big_defconfig b/configs/nyan-big_defconfig index 1483d17d975..4dec710cf8d 100644 --- a/configs/nyan-big_defconfig +++ b/configs/nyan-big_defconfig @@ -17,7 +17,6 @@ CONFIG_TEGRA124=y CONFIG_TARGET_NYAN_BIG=y CONFIG_TEGRA_GPU=y CONFIG_SYS_LOAD_ADDR=0x82408000 -CONFIG_DEBUG_UART=y CONFIG_FIT=y CONFIG_FIT_BEST_MATCH=y CONFIG_BOOTSTAGE=y
It does not make sense to enable all SHA algorithms unless they are needed. It bloats the code and in this case, causes chromebook_link to fail to build. That board does use the TPM, but not with measured boot, nor EFI.
Since EFI_TCG2_PROTOCOL already selects these options, we just need to add them to MEASURED_BOOT as well.
Note that the original commit combines refactoring and new features, which makes it hard to see what is going on.
Fixes: 97707f12fda tpm: Support boot measurements Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de Signed-off-by: Simon Glass sjg@chromium.org ---
(no changes since v2)
boot/Kconfig | 4 ++++ lib/Kconfig | 4 ---- 2 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/boot/Kconfig b/boot/Kconfig index 36bdc83b957..4c9d2c0f79a 100644 --- a/boot/Kconfig +++ b/boot/Kconfig @@ -734,6 +734,10 @@ config LEGACY_IMAGE_FORMAT config MEASURED_BOOT bool "Measure boot images and configuration when booting without EFI" depends on HASH && TPM_V2 + select SHA1 + select SHA256 + select SHA384 + select SHA512 help This option enables measurement of the boot process when booting without UEFI . Measurement involves creating cryptographic hashes diff --git a/lib/Kconfig b/lib/Kconfig index 189e6eb31aa..568892fce44 100644 --- a/lib/Kconfig +++ b/lib/Kconfig @@ -438,10 +438,6 @@ config TPM bool "Trusted Platform Module (TPM) Support" depends on DM imply DM_RNG - select SHA1 - select SHA256 - select SHA384 - select SHA512 help This enables support for TPMs which can be used to provide security features for your board. The TPM can be connected via LPC or I2C
Set a size limit for this board so that we get a build error if it grows too much.
Note that the limit is approximately, since it does not include the FDT, microcode and fdtmap, which can change in size. However this board is fairly stable, so overflowing this limit will likely result in the image not fitting in the ROM space available for U-Boot.
configs/chromebook_link_defconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/configs/chromebook_link_defconfig b/configs/chromebook_link_defconfig index a9f91dd9b26..1a72fd178a8 100644 --- a/configs/chromebook_link_defconfig +++ b/configs/chromebook_link_defconfig @@ -15,6 +15,8 @@ CONFIG_DEBUG_UART=y CONFIG_HAVE_MRC=y CONFIG_SMP=y CONFIG_HAVE_VGA_BIOS=y +CONFIG_HAS_BOARD_SIZE_LIMIT=y +CONFIG_BOARD_SIZE_LIMIT=630000 CONFIG_FIT=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y
Add better logging for power init so that CONFIG_LOG_ERROR_RETURN can be enabled.
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Quentin Schulz quentin.schulz@cherry.de ---
Changes in v2: - Remove the superfluous if() and drop the debug() as well
board/google/veyron/veyron.c | 30 ++++++++++++------------------ 1 file changed, 12 insertions(+), 18 deletions(-)
diff --git a/board/google/veyron/veyron.c b/board/google/veyron/veyron.c index 32dbcdc4d10..6d4c9debdee 100644 --- a/board/google/veyron/veyron.c +++ b/board/google/veyron/veyron.c @@ -29,44 +29,38 @@ static int veyron_init(void) int ret;
ret = regulator_get_by_platname("vdd_arm", &dev); - if (ret) { - debug("Cannot set regulator name\n"); - return ret; - } + if (ret) + return log_msg_ret("vdd", ret);
/* Slowly raise to max CPU voltage to prevent overshoot */ ret = regulator_set_value(dev, 1200000); if (ret) - return ret; + return log_msg_ret("s12", ret); udelay(175); /* Must wait for voltage to stabilize, 2mV/us */ ret = regulator_set_value(dev, 1400000); if (ret) - return ret; + return log_msg_ret("s14", ret); udelay(100); /* Must wait for voltage to stabilize, 2mV/us */
ret = rockchip_get_clk(&clk.dev); if (ret) - return ret; + return log_msg_ret("clk", ret); clk.id = PLL_APLL; ret = clk_set_rate(&clk, 1800000000); if (IS_ERR_VALUE(ret)) - return ret; + return log_msg_ret("s18", ret);
ret = regulator_get_by_platname("vcc33_sd", &dev); - if (ret) { - debug("Cannot get regulator name\n"); - return ret; - } + if (ret) + return log_msg_ret("vcc", ret);
ret = regulator_set_value(dev, 3300000); if (ret) - return ret; + return log_msg_ret("s33", ret);
ret = regulators_enable_boot_on(false); - if (ret) { - debug("%s: Cannot enable boot on regulators\n", __func__); - return ret; - } + if (ret) + return log_msg_ret("boo", ret);
return 0; } @@ -81,7 +75,7 @@ int board_early_init_r(void) if (!fdt_node_check_compatible(gd->fdt_blob, 0, "google,veyron")) { ret = veyron_init(); if (ret) - return ret; + return log_msg_ret("vey", ret); } #endif /*
With a recent change, regulators_enable_boot_on() returns an error if a regulator is already set. Check for and handle this situation.
Fixes: d99fb64a98a power: regulator: Only run autoset once for each regulator Reviewed-by: Jonas Karlman jonas@kwiboo.se Reviewed-by: Quentin Schulz quentin.schulz@cherry.de
drivers/power/regulator/regulator-uclass.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/power/regulator/regulator-uclass.c b/drivers/power/regulator/regulator-uclass.c index 77d101f262e..d9e1fb68295 100644 --- a/drivers/power/regulator/regulator-uclass.c +++ b/drivers/power/regulator/regulator-uclass.c @@ -518,7 +518,7 @@ int regulators_enable_boot_on(bool verbose) dev; uclass_next_device(&dev)) { ret = regulator_autoset(dev); - if (ret == -EMEDIUMTYPE) { + if (ret == -EMEDIUMTYPE || ret == -EALREADY) { ret = 0; continue; }
The dcache may not be enabled in SPL. Add a check to avoid trying to use an undefined function.
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Tom Rini trini@konsulko.com ---
common/spl/spl_atf.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/common/spl/spl_atf.c b/common/spl/spl_atf.c index 3bdd013a35f..9afe6456bc4 100644 --- a/common/spl/spl_atf.c +++ b/common/spl/spl_atf.c @@ -204,7 +204,8 @@ static void __noreturn bl31_entry(uintptr_t bl31_entry, uintptr_t bl32_entry, fdt_addr);
raw_write_daif(SPSR_EXCEPTION_MASK); - dcache_disable(); + if (!CONFIG_IS_ENABLED(SYS_DCACHE_OFF)) + dcache_disable();
atf_entry(bl31_params, (void *)fdt_addr); }
This causes a hang, so disable it. Unfortunately the RAM-size fix does not resolve the problem and I am unsure what is wrong. As soon as the cache is enabled the board appears to hang.
Fixes: 6d8cdfd1536 ("rockchip: spl: Enable caches to speed up checksum validation")
configs/chromebook_bob_defconfig | 1 + configs/chromebook_kevin_defconfig | 1 + 2 files changed, 2 insertions(+)
diff --git a/configs/chromebook_bob_defconfig b/configs/chromebook_bob_defconfig index acfe3934104..b2ecfa6050c 100644 --- a/configs/chromebook_bob_defconfig +++ b/configs/chromebook_bob_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_SPL_SYS_DCACHE_OFF=y CONFIG_COUNTER_FREQUENCY=24000000 CONFIG_ARCH_ROCKCHIP=y CONFIG_TEXT_BASE=0x00200000 diff --git a/configs/chromebook_kevin_defconfig b/configs/chromebook_kevin_defconfig index 95fdb418d82..da748e4f022 100644 --- a/configs/chromebook_kevin_defconfig +++ b/configs/chromebook_kevin_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_COUNTER_FREQUENCY=24000000 CONFIG_ARCH_ROCKCHIP=y +CONFIG_SPL_SYS_DCACHE_OFF=y CONFIG_TEXT_BASE=0x00200000 CONFIG_SPL_GPIO=y CONFIG_NR_DRAM_BANKS=1
Now that am335x_evm boots OK on the Beaglebone black, drop the latter and update the docs to cover the change.
Also add a few updates about 'make fit' and drop the note about the security review, as U-Boot's verified boot has had quite extensive review now.
Changes in v4: - Fix 'stating' typo - Move Binman size feature to a separate series
Changes in v2: - Drop patch "regulator: rk8xx: Fix incorrect parameter" - Rewrite boneblack patch to onstead drop the target and update docs
board/ti/am335x/MAINTAINERS | 1 - configs/am335x_boneblack_vboot_defconfig | 94 ------------------------ configs/am335x_evm_defconfig | 3 +- doc/usage/fit/beaglebone_vboot.rst | 21 +++--- 4 files changed, 12 insertions(+), 107 deletions(-) delete mode 100644 configs/am335x_boneblack_vboot_defconfig
diff --git a/board/ti/am335x/MAINTAINERS b/board/ti/am335x/MAINTAINERS index 219c8715bf1..ed8800a2663 100644 --- a/board/ti/am335x/MAINTAINERS +++ b/board/ti/am335x/MAINTAINERS @@ -3,6 +3,5 @@ M: Tom Rini trini@konsulko.com S: Maintained F: board/ti/am335x/ F: include/configs/am335x_evm.h -F: configs/am335x_boneblack_vboot_defconfig F: configs/am335x_evm_defconfig F: configs/am335x_evm_spiboot_defconfig diff --git a/configs/am335x_boneblack_vboot_defconfig b/configs/am335x_boneblack_vboot_defconfig deleted file mode 100644 index d473a1a793b..00000000000 --- a/configs/am335x_boneblack_vboot_defconfig +++ /dev/null @@ -1,94 +0,0 @@ -CONFIG_ARM=y -CONFIG_ARCH_CPU_INIT=y -# CONFIG_SPL_USE_ARCH_MEMCPY is not set -# CONFIG_SPL_USE_ARCH_MEMSET is not set -CONFIG_ARCH_OMAP2PLUS=y -CONFIG_TI_COMMON_CMD_OPTIONS=y -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4030ff00 -CONFIG_SF_DEFAULT_SPEED=24000000 -CONFIG_DEFAULT_DEVICE_TREE="am335x-boneblack" -CONFIG_AM33XX=y -CONFIG_CLOCK_SYNTHESIZER=y -CONFIG_SPL=y -CONFIG_ENV_OFFSET_REDUND=0x280000 -CONFIG_TIMESTAMP=y -CONFIG_FIT_SIGNATURE=y -CONFIG_FIT_VERBOSE=y -CONFIG_SYS_BOOTM_LEN=0x1000000 -CONFIG_DISTRO_DEFAULTS=y -CONFIG_AUTOBOOT_KEYED=y -CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" -CONFIG_AUTOBOOT_DELAY_STR="d" -CONFIG_AUTOBOOT_STOP_STR=" " -CONFIG_BOOTCOMMAND="run findfdt; run init_console; run finduuid; run distro_bootcmd" -CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_ARCH_MISC_INIT=y -CONFIG_SPL_SYS_MALLOC=y -CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 -CONFIG_SPL_MUSB_NEW=y -# CONFIG_SPL_NAND_SUPPORT is not set -CONFIG_SPL_NET=y -CONFIG_SPL_NET_VCI_STRING="AM33xx U-Boot SPL" -CONFIG_SPL_OS_BOOT=y -CONFIG_SPL_FALCON_BOOT_MMCSD=y -CONFIG_SYS_MMCSD_RAW_MODE_KERNEL_SECTOR=0x1700 -CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTOR=0x1500 -CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTORS=0x200 -CONFIG_CMD_SPL=y -CONFIG_SYS_I2C_EEPROM_ADDR_LEN=2 -# CONFIG_CMD_SETEXPR is not set -CONFIG_BOOTP_DNS2=y -CONFIG_OF_CONTROL=y -CONFIG_SPL_OF_CONTROL=y -CONFIG_ENV_OVERWRITE=y -CONFIG_ENV_IS_IN_MMC=y -CONFIG_SYS_REDUNDAND_ENVIRONMENT=y -CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_SYS_MMC_ENV_DEV=1 -CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y -CONFIG_VERSION_VARIABLE=y -CONFIG_NET_RETRY_COUNT=10 -CONFIG_BOOTP_SEND_HOSTNAME=y -# CONFIG_SPL_BLK is not set -CONFIG_BOOTCOUNT_LIMIT=y -CONFIG_SYS_BOOTCOUNT_BE=y -CONFIG_DFU_MMC=y -CONFIG_DFU_RAM=y -CONFIG_USB_FUNCTION_FASTBOOT=y -CONFIG_DM_I2C=y -CONFIG_MISC=y -CONFIG_SYS_I2C_EEPROM_ADDR=0x50 -# CONFIG_SPL_DM_MMC is not set -CONFIG_MMC_OMAP_HS=y -CONFIG_MTD=y -CONFIG_DM_SPI_FLASH=y -CONFIG_SPI_FLASH_WINBOND=y -CONFIG_PHY_ATHEROS=y -CONFIG_PHY_SMSC=y -CONFIG_PHY_GIGE=y -CONFIG_MII=y -CONFIG_DRIVER_TI_CPSW=y -CONFIG_DM_PMIC=y -# CONFIG_SPL_DM_PMIC is not set -CONFIG_PMIC_TPS65217=y -CONFIG_SPL_POWER_TPS65910=y -CONFIG_SPI=y -CONFIG_DM_SPI=y -CONFIG_OMAP3_SPI=y -CONFIG_TIMER=y -CONFIG_OMAP_TIMER=y -CONFIG_USB=y -CONFIG_DM_USB_GADGET=y -CONFIG_SPL_DM_USB_GADGET=y -CONFIG_USB_MUSB_HOST=y -CONFIG_USB_MUSB_GADGET=y -CONFIG_USB_MUSB_TI=y -CONFIG_USB_GADGET=y -CONFIG_SPL_USB_GADGET=y -CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" -CONFIG_USB_GADGET_VENDOR_NUM=0x0451 -CONFIG_USB_GADGET_PRODUCT_NUM=0xd022 -CONFIG_USB_ETHER=y -CONFIG_SPL_USB_ETHER=y -CONFIG_LZO=y diff --git a/configs/am335x_evm_defconfig b/configs/am335x_evm_defconfig index d243cb16e72..cabc181460a 100644 --- a/configs/am335x_evm_defconfig +++ b/configs/am335x_evm_defconfig @@ -13,6 +13,8 @@ CONFIG_AM335X_USB0_PERIPHERAL=y CONFIG_AM335X_USB1=y CONFIG_SPL=y CONFIG_TIMESTAMP=y +CONFIG_FIT_SIGNATURE=y +CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y CONFIG_SYS_BOOTM_LEN=0x1000000 CONFIG_DISTRO_DEFAULTS=y @@ -119,5 +121,4 @@ CONFIG_SPL_USB_ETHER=y CONFIG_WDT=y # CONFIG_SPL_WDT is not set CONFIG_DYNAMIC_CRC_TABLE=y -CONFIG_RSA=y CONFIG_LZO=y diff --git a/doc/usage/fit/beaglebone_vboot.rst b/doc/usage/fit/beaglebone_vboot.rst index cd6bb141910..1298ba1ae08 100644 --- a/doc/usage/fit/beaglebone_vboot.rst +++ b/doc/usage/fit/beaglebone_vboot.rst @@ -67,18 +67,20 @@ a. Set up the environment variable to point to your toolchain. You will need
export CROSS_COMPILE=arm-linux-gnueabi-
-b. Configure and build U-Boot with verified boot enabled:: +b. Configure and build U-Boot with verified boot enabled. Note that we use the +am335x_evm target since it covers all boards based on the AM335x evaluation +board::
export UBOOT=/path/to/u-boot cd $UBOOT # You can add -j10 if you have 10 CPUs to make it faster - make O=b/am335x_boneblack_vboot am335x_boneblack_vboot_config all - export UOUT=$UBOOT/b/am335x_boneblack_vboot + make O=b/am335x_evm am335x_evm_config all + export UOUT=$UBOOT/b/am335x_evm
c. You will now have a U-Boot image::
- file b/am335x_boneblack_vboot/u-boot-dtb.img - b/am335x_boneblack_vboot/u-boot-dtb.img: u-boot legacy uImage, + file b/am335x_evm/u-boot-dtb.img + b/am335x_evm/u-boot-dtb.img: u-boot legacy uImage, U-Boot 2014.07-rc2-00065-g2f69f8, Firmware/ARM, Firmware Image (Not compressed), 395375 bytes, Sat May 31 16:19:04 2014, Load Address: 0x80800000, Entry Point: 0x00000000, @@ -466,7 +468,7 @@ the private key that you signed with so that it can verify any kernels that you sign::
cd $UBOOT - make O=b/am335x_boneblack_vboot EXT_DTB=${WORK}/am335x-boneblack-pubkey.dtb + make O=b/am335x_evm EXT_DTB=${WORK}/am335x-boneblack-pubkey.dtb
Here we are overriding the normal device tree file with our one, which contains the public key. @@ -597,14 +599,11 @@ Further Improvements
Several of the steps here can be easily automated. In particular it would be capital if signing and packaging a kernel were easy, perhaps a simple make -target in the kernel. +target in the kernel. A starting point for this is the 'make image.fit' target +for ARM64 in Linux from v6.9 onwards.
Some mention of how to use multiple .dtb files in a FIT might be useful.
-U-Boot's verified boot mechanism has not had a robust and independent security -review. Such a review should look at the implementation and its resistance to -attacks. - Perhaps the verified boot feature could be integrated into the Amstrom distribution.
