[PATCH v2 0/4] Broadcom BCMBCA nand updates
These are ports of upstream Linux patches to U-Boot.
Remove device specific nand driver files as they are now replaced by a common driver bcmbca_nand.c
Make use of OF_UPSTREAM which uses Linux dts.
Implement a minimal set of defconfig options to enable basic NAND functionality. Tested on: 47622 63146 63158 63178 6813
Set parameter_page_big_endian to zero for bcmbca.
Update log level messages so that more critical messages can be logged to console and help the troubleshooting with field devices.
https://lore.kernel.org/linux-mtd/20240223034758.13753-4-william.zhang@broad...
Changes in v2: - Set parameter_page_big_endian to zero for bcmbca instead of using an extra bit of endian translation code.
david regan (4): mtd: nand: brcmnand: remove device specific nand driver files arm: dts: Use upstream dts mtd: rawnand: brcmnand: Default bcmbca parameter_page_big_endian to zero mtd: rawnand: brcmnand: update log level messages
arch/arm/dts/bcm47622.dtsi | 126 -------- arch/arm/dts/bcm4912.dtsi | 128 -------- arch/arm/dts/bcm63146.dtsi | 110 ------- arch/arm/dts/bcm63158.dtsi | 278 ------------------ arch/arm/dts/bcm63178.dtsi | 120 -------- arch/arm/dts/bcm6756.dtsi | 130 -------- arch/arm/dts/bcm6813.dtsi | 128 -------- arch/arm/dts/bcm6855.dtsi | 257 ---------------- arch/arm/dts/bcm6856.dtsi | 253 ---------------- arch/arm/dts/bcm6858.dtsi | 272 ----------------- arch/arm/dts/bcm6878.dtsi | 111 ------- arch/arm/dts/bcm947622.dts | 30 -- arch/arm/dts/bcm94912.dts | 30 -- arch/arm/dts/bcm963146.dts | 30 -- arch/arm/dts/bcm963158.dts | 30 -- arch/arm/dts/bcm963178.dts | 30 -- arch/arm/dts/bcm96756.dts | 30 -- arch/arm/dts/bcm96813.dts | 30 -- arch/arm/dts/bcm96855.dts | 30 -- arch/arm/dts/bcm96856.dts | 30 -- arch/arm/dts/bcm96858.dts | 30 -- arch/arm/dts/bcm96878.dts | 30 -- arch/arm/mach-bcmbca/bcm47622/Kconfig | 1 + arch/arm/mach-bcmbca/bcm4912/Kconfig | 1 + arch/arm/mach-bcmbca/bcm63146/Kconfig | 1 + arch/arm/mach-bcmbca/bcm63158/Kconfig | 1 + arch/arm/mach-bcmbca/bcm63178/Kconfig | 1 + arch/arm/mach-bcmbca/bcm6756/Kconfig | 1 + arch/arm/mach-bcmbca/bcm6813/Kconfig | 1 + arch/arm/mach-bcmbca/bcm6855/Kconfig | 1 + arch/arm/mach-bcmbca/bcm6856/Kconfig | 1 + arch/arm/mach-bcmbca/bcm6858/Kconfig | 1 + arch/arm/mach-bcmbca/bcm6878/Kconfig | 1 + configs/bcm947622_defconfig | 11 +- configs/bcm94912_defconfig | 11 +- configs/bcm963146_defconfig | 11 +- configs/bcm963158_defconfig | 11 +- configs/bcm963178_defconfig | 11 +- configs/bcm96756_defconfig | 11 +- configs/bcm96813_defconfig | 11 +- configs/bcm96855_defconfig | 11 +- configs/bcm96856_defconfig | 11 +- configs/bcm96858_defconfig | 11 +- configs/bcm96878_defconfig | 11 +- drivers/mtd/nand/raw/Kconfig | 24 -- drivers/mtd/nand/raw/brcmnand/Makefile | 4 - drivers/mtd/nand/raw/brcmnand/bcm63158_nand.c | 125 -------- drivers/mtd/nand/raw/brcmnand/bcm6753_nand.c | 123 -------- drivers/mtd/nand/raw/brcmnand/bcm68360_nand.c | 124 -------- drivers/mtd/nand/raw/brcmnand/bcm6858_nand.c | 125 -------- drivers/mtd/nand/raw/brcmnand/brcmnand.c | 14 +- 51 files changed, 132 insertions(+), 2782 deletions(-) delete mode 100644 arch/arm/dts/bcm47622.dtsi delete mode 100644 arch/arm/dts/bcm4912.dtsi delete mode 100644 arch/arm/dts/bcm63146.dtsi delete mode 100644 arch/arm/dts/bcm63158.dtsi delete mode 100644 arch/arm/dts/bcm63178.dtsi delete mode 100644 arch/arm/dts/bcm6756.dtsi delete mode 100644 arch/arm/dts/bcm6813.dtsi delete mode 100644 arch/arm/dts/bcm6855.dtsi delete mode 100644 arch/arm/dts/bcm6856.dtsi delete mode 100644 arch/arm/dts/bcm6858.dtsi delete mode 100644 arch/arm/dts/bcm6878.dtsi delete mode 100644 arch/arm/dts/bcm947622.dts delete mode 100644 arch/arm/dts/bcm94912.dts delete mode 100644 arch/arm/dts/bcm963146.dts delete mode 100644 arch/arm/dts/bcm963158.dts delete mode 100644 arch/arm/dts/bcm963178.dts delete mode 100644 arch/arm/dts/bcm96756.dts delete mode 100644 arch/arm/dts/bcm96813.dts delete mode 100644 arch/arm/dts/bcm96855.dts delete mode 100644 arch/arm/dts/bcm96856.dts delete mode 100644 arch/arm/dts/bcm96858.dts delete mode 100644 arch/arm/dts/bcm96878.dts delete mode 100644 drivers/mtd/nand/raw/brcmnand/bcm63158_nand.c delete mode 100644 drivers/mtd/nand/raw/brcmnand/bcm6753_nand.c delete mode 100644 drivers/mtd/nand/raw/brcmnand/bcm68360_nand.c delete mode 100644 drivers/mtd/nand/raw/brcmnand/bcm6858_nand.c
These device specific nand driver files can be removed because they are now replaced by a common driver bcmbca_nand.c
Signed-off-by: david regan dregan@broadcom.com Reviewed-by: Linus Walleij linus.walleij@linaro.org Reviewed-by: William Zhang william.zhang@broadcom.com Reviewed-by: Anand Gore anand.gore@broadcom.com --- drivers/mtd/nand/raw/Kconfig | 24 ---- drivers/mtd/nand/raw/brcmnand/Makefile | 4 - drivers/mtd/nand/raw/brcmnand/bcm63158_nand.c | 125 ------------------ drivers/mtd/nand/raw/brcmnand/bcm6753_nand.c | 123 ----------------- drivers/mtd/nand/raw/brcmnand/bcm68360_nand.c | 124 ----------------- drivers/mtd/nand/raw/brcmnand/bcm6858_nand.c | 125 ------------------ 6 files changed, 525 deletions(-) delete mode 100644 drivers/mtd/nand/raw/brcmnand/bcm63158_nand.c delete mode 100644 drivers/mtd/nand/raw/brcmnand/bcm6753_nand.c delete mode 100644 drivers/mtd/nand/raw/brcmnand/bcm68360_nand.c delete mode 100644 drivers/mtd/nand/raw/brcmnand/bcm6858_nand.c
diff --git a/drivers/mtd/nand/raw/Kconfig b/drivers/mtd/nand/raw/Kconfig index c345fc1f1fba..609bdffbf779 100644 --- a/drivers/mtd/nand/raw/Kconfig +++ b/drivers/mtd/nand/raw/Kconfig @@ -133,36 +133,12 @@ config NAND_BRCMNAND_6368 help Enable support for broadcom nand driver on bcm6368.
-config NAND_BRCMNAND_6753 - bool "Support Broadcom NAND controller on bcm6753" - depends on NAND_BRCMNAND && BCM6855 - help - Enable support for broadcom nand driver on bcm6753. - -config NAND_BRCMNAND_68360 - bool "Support Broadcom NAND controller on bcm68360" - depends on NAND_BRCMNAND && BCM6856 - help - Enable support for broadcom nand driver on bcm68360. - config NAND_BRCMNAND_6838 bool "Support Broadcom NAND controller on bcm6838" depends on NAND_BRCMNAND && ARCH_BMIPS && SOC_BMIPS_BCM6838 help Enable support for broadcom nand driver on bcm6838.
-config NAND_BRCMNAND_6858 - bool "Support Broadcom NAND controller on bcm6858" - depends on NAND_BRCMNAND && BCM6858 - help - Enable support for broadcom nand driver on bcm6858. - -config NAND_BRCMNAND_63158 - bool "Support Broadcom NAND controller on bcm63158" - depends on NAND_BRCMNAND && BCM63158 - help - Enable support for broadcom nand driver on bcm63158. - config NAND_BRCMNAND_IPROC bool "Support Broadcom NAND controller on the iproc family" depends on NAND_BRCMNAND diff --git a/drivers/mtd/nand/raw/brcmnand/Makefile b/drivers/mtd/nand/raw/brcmnand/Makefile index 24d0d5684490..4fba5c1c7e3d 100644 --- a/drivers/mtd/nand/raw/brcmnand/Makefile +++ b/drivers/mtd/nand/raw/brcmnand/Makefile @@ -1,11 +1,7 @@ # SPDX-License-Identifier: GPL-2.0+
obj-$(CONFIG_NAND_BRCMNAND_6368) += bcm6368_nand.o -obj-$(CONFIG_NAND_BRCMNAND_63158) += bcm63158_nand.o -obj-$(CONFIG_NAND_BRCMNAND_6753) += bcm6753_nand.o -obj-$(CONFIG_NAND_BRCMNAND_68360) += bcm68360_nand.o obj-$(CONFIG_NAND_BRCMNAND_6838) += bcm6838_nand.o -obj-$(CONFIG_NAND_BRCMNAND_6858) += bcm6858_nand.o obj-$(CONFIG_NAND_BRCMNAND_BCMBCA) += bcmbca_nand.o obj-$(CONFIG_NAND_BRCMNAND_IPROC) += iproc_nand.o obj-$(CONFIG_NAND_BRCMNAND) += brcmnand.o diff --git a/drivers/mtd/nand/raw/brcmnand/bcm63158_nand.c b/drivers/mtd/nand/raw/brcmnand/bcm63158_nand.c deleted file mode 100644 index 3f59fbbbb8f1..000000000000 --- a/drivers/mtd/nand/raw/brcmnand/bcm63158_nand.c +++ /dev/null @@ -1,125 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ - -#include <asm/io.h> -#include <memalign.h> -#include <nand.h> -#include <linux/bitops.h> -#include <linux/err.h> -#include <linux/errno.h> -#include <linux/io.h> -#include <linux/ioport.h> -#include <dm.h> -#include <linux/printk.h> - -#include "brcmnand.h" - -struct bcm63158_nand_soc { - struct brcmnand_soc soc; - void __iomem *base; -}; - -#define BCM63158_NAND_INT 0x00 -#define BCM63158_NAND_STATUS_SHIFT 0 -#define BCM63158_NAND_STATUS_MASK (0xfff << BCM63158_NAND_STATUS_SHIFT) - -#define BCM63158_NAND_INT_EN 0x04 -#define BCM63158_NAND_ENABLE_SHIFT 0 -#define BCM63158_NAND_ENABLE_MASK (0xffff << BCM63158_NAND_ENABLE_SHIFT) - -enum { - BCM63158_NP_READ = BIT(0), - BCM63158_BLOCK_ERASE = BIT(1), - BCM63158_COPY_BACK = BIT(2), - BCM63158_PAGE_PGM = BIT(3), - BCM63158_CTRL_READY = BIT(4), - BCM63158_DEV_RBPIN = BIT(5), - BCM63158_ECC_ERR_UNC = BIT(6), - BCM63158_ECC_ERR_CORR = BIT(7), -}; - -static bool bcm63158_nand_intc_ack(struct brcmnand_soc *soc) -{ - struct bcm63158_nand_soc *priv = - container_of(soc, struct bcm63158_nand_soc, soc); - void __iomem *mmio = priv->base + BCM63158_NAND_INT; - u32 val = brcmnand_readl(mmio); - - if (val & (BCM63158_CTRL_READY << BCM63158_NAND_STATUS_SHIFT)) { - /* Ack interrupt */ - val &= ~BCM63158_NAND_STATUS_MASK; - val |= BCM63158_CTRL_READY << BCM63158_NAND_STATUS_SHIFT; - brcmnand_writel(val, mmio); - return true; - } - - return false; -} - -static void bcm63158_nand_intc_set(struct brcmnand_soc *soc, bool en) -{ - struct bcm63158_nand_soc *priv = - container_of(soc, struct bcm63158_nand_soc, soc); - void __iomem *mmio = priv->base + BCM63158_NAND_INT_EN; - u32 val = brcmnand_readl(mmio); - - /* Don't ack any interrupts */ - val &= ~BCM63158_NAND_STATUS_MASK; - - if (en) - val |= BCM63158_CTRL_READY << BCM63158_NAND_ENABLE_SHIFT; - else - val &= ~(BCM63158_CTRL_READY << BCM63158_NAND_ENABLE_SHIFT); - - brcmnand_writel(val, mmio); -} - -static int bcm63158_nand_probe(struct udevice *dev) -{ - struct udevice *pdev = dev; - struct bcm63158_nand_soc *priv = dev_get_priv(dev); - struct brcmnand_soc *soc; - struct resource res; - - soc = &priv->soc; - - dev_read_resource_byname(pdev, "nand-int-base", &res); - priv->base = devm_ioremap(dev, res.start, resource_size(&res)); - if (IS_ERR(priv->base)) - return PTR_ERR(priv->base); - - soc->ctlrdy_ack = bcm63158_nand_intc_ack; - soc->ctlrdy_set_enabled = bcm63158_nand_intc_set; - - /* Disable and ack all interrupts */ - brcmnand_writel(0, priv->base + BCM63158_NAND_INT_EN); - brcmnand_writel(0, priv->base + BCM63158_NAND_INT); - - return brcmnand_probe(pdev, soc); -} - -static const struct udevice_id bcm63158_nand_dt_ids[] = { - { - .compatible = "brcm,nand-bcm63158", - }, - { /* sentinel */ } -}; - -U_BOOT_DRIVER(bcm63158_nand) = { - .name = "bcm63158-nand", - .id = UCLASS_MTD, - .of_match = bcm63158_nand_dt_ids, - .probe = bcm63158_nand_probe, - .priv_auto = sizeof(struct bcm63158_nand_soc), -}; - -void board_nand_init(void) -{ - struct udevice *dev; - int ret; - - ret = uclass_get_device_by_driver(UCLASS_MTD, - DM_DRIVER_GET(bcm63158_nand), &dev); - if (ret && ret != -ENODEV) - pr_err("Failed to initialize %s. (error %d)\n", dev->name, - ret); -} diff --git a/drivers/mtd/nand/raw/brcmnand/bcm6753_nand.c b/drivers/mtd/nand/raw/brcmnand/bcm6753_nand.c deleted file mode 100644 index a101222a28fa..000000000000 --- a/drivers/mtd/nand/raw/brcmnand/bcm6753_nand.c +++ /dev/null @@ -1,123 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ - -#include <asm/io.h> -#include <memalign.h> -#include <nand.h> -#include <linux/bitops.h> -#include <linux/errno.h> -#include <linux/io.h> -#include <linux/ioport.h> -#include <dm.h> - -#include "brcmnand.h" - -struct bcm6753_nand_soc { - struct brcmnand_soc soc; - void __iomem *base; -}; - -#define BCM6753_NAND_INT 0x00 -#define BCM6753_NAND_STATUS_SHIFT 0 -#define BCM6753_NAND_STATUS_MASK (0xfff << BCM6753_NAND_STATUS_SHIFT) - -#define BCM6753_NAND_INT_EN 0x04 -#define BCM6753_NAND_ENABLE_SHIFT 0 -#define BCM6753_NAND_ENABLE_MASK (0xffff << BCM6753_NAND_ENABLE_SHIFT) - -enum { - BCM6753_NP_READ = BIT(0), - BCM6753_BLOCK_ERASE = BIT(1), - BCM6753_COPY_BACK = BIT(2), - BCM6753_PAGE_PGM = BIT(3), - BCM6753_CTRL_READY = BIT(4), - BCM6753_DEV_RBPIN = BIT(5), - BCM6753_ECC_ERR_UNC = BIT(6), - BCM6753_ECC_ERR_CORR = BIT(7), -}; - -static bool bcm6753_nand_intc_ack(struct brcmnand_soc *soc) -{ - struct bcm6753_nand_soc *priv = - container_of(soc, struct bcm6753_nand_soc, soc); - void __iomem *mmio = priv->base + BCM6753_NAND_INT; - u32 val = brcmnand_readl(mmio); - - if (val & (BCM6753_CTRL_READY << BCM6753_NAND_STATUS_SHIFT)) { - /* Ack interrupt */ - val &= ~BCM6753_NAND_STATUS_MASK; - val |= BCM6753_CTRL_READY << BCM6753_NAND_STATUS_SHIFT; - brcmnand_writel(val, mmio); - return true; - } - - return false; -} - -static void bcm6753_nand_intc_set(struct brcmnand_soc *soc, bool en) -{ - struct bcm6753_nand_soc *priv = - container_of(soc, struct bcm6753_nand_soc, soc); - void __iomem *mmio = priv->base + BCM6753_NAND_INT_EN; - u32 val = brcmnand_readl(mmio); - - /* Don't ack any interrupts */ - val &= ~BCM6753_NAND_STATUS_MASK; - - if (en) - val |= BCM6753_CTRL_READY << BCM6753_NAND_ENABLE_SHIFT; - else - val &= ~(BCM6753_CTRL_READY << BCM6753_NAND_ENABLE_SHIFT); - - brcmnand_writel(val, mmio); -} - -static int bcm6753_nand_probe(struct udevice *dev) -{ - struct udevice *pdev = dev; - struct bcm6753_nand_soc *priv = dev_get_priv(dev); - struct brcmnand_soc *soc; - struct resource res; - - soc = &priv->soc; - - dev_read_resource_byname(pdev, "nand-int-base", &res); - priv->base = devm_ioremap(dev, res.start, resource_size(&res)); - if (IS_ERR(priv->base)) - return PTR_ERR(priv->base); - - soc->ctlrdy_ack = bcm6753_nand_intc_ack; - soc->ctlrdy_set_enabled = bcm6753_nand_intc_set; - - /* Disable and ack all interrupts */ - brcmnand_writel(0, priv->base + BCM6753_NAND_INT_EN); - brcmnand_writel(0, priv->base + BCM6753_NAND_INT); - - return brcmnand_probe(pdev, soc); -} - -static const struct udevice_id bcm6753_nand_dt_ids[] = { - { - .compatible = "brcm,nand-bcm6753", - }, - { /* sentinel */ } -}; - -U_BOOT_DRIVER(bcm6753_nand) = { - .name = "bcm6753-nand", - .id = UCLASS_MTD, - .of_match = bcm6753_nand_dt_ids, - .probe = bcm6753_nand_probe, - .priv_auto = sizeof(struct bcm6753_nand_soc), -}; - -void board_nand_init(void) -{ - struct udevice *dev; - int ret; - - ret = uclass_get_device_by_driver(UCLASS_MTD, - DM_DRIVER_GET(bcm6753_nand), &dev); - if (ret && ret != -ENODEV) - pr_err("Failed to initialize %s. (error %d)\n", dev->name, - ret); -} diff --git a/drivers/mtd/nand/raw/brcmnand/bcm68360_nand.c b/drivers/mtd/nand/raw/brcmnand/bcm68360_nand.c deleted file mode 100644 index 385642d0c091..000000000000 --- a/drivers/mtd/nand/raw/brcmnand/bcm68360_nand.c +++ /dev/null @@ -1,124 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ - -#include <asm/io.h> -#include <memalign.h> -#include <nand.h> -#include <linux/bitops.h> -#include <linux/errno.h> -#include <linux/io.h> -#include <linux/ioport.h> -#include <dm.h> -#include <linux/printk.h> - -#include "brcmnand.h" - -struct bcm68360_nand_soc { - struct brcmnand_soc soc; - void __iomem *base; -}; - -#define BCM68360_NAND_INT 0x00 -#define BCM68360_NAND_STATUS_SHIFT 0 -#define BCM68360_NAND_STATUS_MASK (0xfff << BCM68360_NAND_STATUS_SHIFT) - -#define BCM68360_NAND_INT_EN 0x04 -#define BCM68360_NAND_ENABLE_SHIFT 0 -#define BCM68360_NAND_ENABLE_MASK (0xffff << BCM68360_NAND_ENABLE_SHIFT) - -enum { - BCM68360_NP_READ = BIT(0), - BCM68360_BLOCK_ERASE = BIT(1), - BCM68360_COPY_BACK = BIT(2), - BCM68360_PAGE_PGM = BIT(3), - BCM68360_CTRL_READY = BIT(4), - BCM68360_DEV_RBPIN = BIT(5), - BCM68360_ECC_ERR_UNC = BIT(6), - BCM68360_ECC_ERR_CORR = BIT(7), -}; - -static bool bcm68360_nand_intc_ack(struct brcmnand_soc *soc) -{ - struct bcm68360_nand_soc *priv = - container_of(soc, struct bcm68360_nand_soc, soc); - void __iomem *mmio = priv->base + BCM68360_NAND_INT; - u32 val = brcmnand_readl(mmio); - - if (val & (BCM68360_CTRL_READY << BCM68360_NAND_STATUS_SHIFT)) { - /* Ack interrupt */ - val &= ~BCM68360_NAND_STATUS_MASK; - val |= BCM68360_CTRL_READY << BCM68360_NAND_STATUS_SHIFT; - brcmnand_writel(val, mmio); - return true; - } - - return false; -} - -static void bcm68360_nand_intc_set(struct brcmnand_soc *soc, bool en) -{ - struct bcm68360_nand_soc *priv = - container_of(soc, struct bcm68360_nand_soc, soc); - void __iomem *mmio = priv->base + BCM68360_NAND_INT_EN; - u32 val = brcmnand_readl(mmio); - - /* Don't ack any interrupts */ - val &= ~BCM68360_NAND_STATUS_MASK; - - if (en) - val |= BCM68360_CTRL_READY << BCM68360_NAND_ENABLE_SHIFT; - else - val &= ~(BCM68360_CTRL_READY << BCM68360_NAND_ENABLE_SHIFT); - - brcmnand_writel(val, mmio); -} - -static int bcm68360_nand_probe(struct udevice *dev) -{ - struct udevice *pdev = dev; - struct bcm68360_nand_soc *priv = dev_get_priv(dev); - struct brcmnand_soc *soc; - struct resource res; - - soc = &priv->soc; - - dev_read_resource_byname(pdev, "nand-int-base", &res); - priv->base = devm_ioremap(dev, res.start, resource_size(&res)); - if (IS_ERR(priv->base)) - return PTR_ERR(priv->base); - - soc->ctlrdy_ack = bcm68360_nand_intc_ack; - soc->ctlrdy_set_enabled = bcm68360_nand_intc_set; - - /* Disable and ack all interrupts */ - brcmnand_writel(0, priv->base + BCM68360_NAND_INT_EN); - brcmnand_writel(0, priv->base + BCM68360_NAND_INT); - - return brcmnand_probe(pdev, soc); -} - -static const struct udevice_id bcm68360_nand_dt_ids[] = { - { - .compatible = "brcm,nand-bcm68360", - }, - { /* sentinel */ } -}; - -U_BOOT_DRIVER(bcm68360_nand) = { - .name = "bcm68360-nand", - .id = UCLASS_MTD, - .of_match = bcm68360_nand_dt_ids, - .probe = bcm68360_nand_probe, - .priv_auto = sizeof(struct bcm68360_nand_soc), -}; - -void board_nand_init(void) -{ - struct udevice *dev; - int ret; - - ret = uclass_get_device_by_driver(UCLASS_MTD, - DM_DRIVER_GET(bcm68360_nand), &dev); - if (ret && ret != -ENODEV) - pr_err("Failed to initialize %s. (error %d)\n", dev->name, - ret); -} diff --git a/drivers/mtd/nand/raw/brcmnand/bcm6858_nand.c b/drivers/mtd/nand/raw/brcmnand/bcm6858_nand.c deleted file mode 100644 index 564c678c9ef2..000000000000 --- a/drivers/mtd/nand/raw/brcmnand/bcm6858_nand.c +++ /dev/null @@ -1,125 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ - -#include <asm/io.h> -#include <memalign.h> -#include <nand.h> -#include <linux/bitops.h> -#include <linux/err.h> -#include <linux/errno.h> -#include <linux/io.h> -#include <linux/ioport.h> -#include <dm.h> -#include <linux/printk.h> - -#include "brcmnand.h" - -struct bcm6858_nand_soc { - struct brcmnand_soc soc; - void __iomem *base; -}; - -#define BCM6858_NAND_INT 0x00 -#define BCM6858_NAND_STATUS_SHIFT 0 -#define BCM6858_NAND_STATUS_MASK (0xfff << BCM6858_NAND_STATUS_SHIFT) - -#define BCM6858_NAND_INT_EN 0x04 -#define BCM6858_NAND_ENABLE_SHIFT 0 -#define BCM6858_NAND_ENABLE_MASK (0xffff << BCM6858_NAND_ENABLE_SHIFT) - -enum { - BCM6858_NP_READ = BIT(0), - BCM6858_BLOCK_ERASE = BIT(1), - BCM6858_COPY_BACK = BIT(2), - BCM6858_PAGE_PGM = BIT(3), - BCM6858_CTRL_READY = BIT(4), - BCM6858_DEV_RBPIN = BIT(5), - BCM6858_ECC_ERR_UNC = BIT(6), - BCM6858_ECC_ERR_CORR = BIT(7), -}; - -static bool bcm6858_nand_intc_ack(struct brcmnand_soc *soc) -{ - struct bcm6858_nand_soc *priv = - container_of(soc, struct bcm6858_nand_soc, soc); - void __iomem *mmio = priv->base + BCM6858_NAND_INT; - u32 val = brcmnand_readl(mmio); - - if (val & (BCM6858_CTRL_READY << BCM6858_NAND_STATUS_SHIFT)) { - /* Ack interrupt */ - val &= ~BCM6858_NAND_STATUS_MASK; - val |= BCM6858_CTRL_READY << BCM6858_NAND_STATUS_SHIFT; - brcmnand_writel(val, mmio); - return true; - } - - return false; -} - -static void bcm6858_nand_intc_set(struct brcmnand_soc *soc, bool en) -{ - struct bcm6858_nand_soc *priv = - container_of(soc, struct bcm6858_nand_soc, soc); - void __iomem *mmio = priv->base + BCM6858_NAND_INT_EN; - u32 val = brcmnand_readl(mmio); - - /* Don't ack any interrupts */ - val &= ~BCM6858_NAND_STATUS_MASK; - - if (en) - val |= BCM6858_CTRL_READY << BCM6858_NAND_ENABLE_SHIFT; - else - val &= ~(BCM6858_CTRL_READY << BCM6858_NAND_ENABLE_SHIFT); - - brcmnand_writel(val, mmio); -} - -static int bcm6858_nand_probe(struct udevice *dev) -{ - struct udevice *pdev = dev; - struct bcm6858_nand_soc *priv = dev_get_priv(dev); - struct brcmnand_soc *soc; - struct resource res; - - soc = &priv->soc; - - dev_read_resource_byname(pdev, "nand-int-base", &res); - priv->base = devm_ioremap(dev, res.start, resource_size(&res)); - if (IS_ERR(priv->base)) - return PTR_ERR(priv->base); - - soc->ctlrdy_ack = bcm6858_nand_intc_ack; - soc->ctlrdy_set_enabled = bcm6858_nand_intc_set; - - /* Disable and ack all interrupts */ - brcmnand_writel(0, priv->base + BCM6858_NAND_INT_EN); - brcmnand_writel(0, priv->base + BCM6858_NAND_INT); - - return brcmnand_probe(pdev, soc); -} - -static const struct udevice_id bcm6858_nand_dt_ids[] = { - { - .compatible = "brcm,nand-bcm6858", - }, - { /* sentinel */ } -}; - -U_BOOT_DRIVER(bcm6858_nand) = { - .name = "bcm6858-nand", - .id = UCLASS_MTD, - .of_match = bcm6858_nand_dt_ids, - .probe = bcm6858_nand_probe, - .priv_auto = sizeof(struct bcm6858_nand_soc), -}; - -void board_nand_init(void) -{ - struct udevice *dev; - int ret; - - ret = uclass_get_device_by_driver(UCLASS_MTD, - DM_DRIVER_GET(bcm6858_nand), &dev); - if (ret && ret != -ENODEV) - pr_err("Failed to initialize %s. (error %d)\n", dev->name, - ret); -}
Signed-off-by: david regan dregan@broadcom.com Reviewed-by: Linus Walleij linus.walleij@linaro.org Reviewed-by: Sumit Garg sumit.garg@linaro.org Reviewed-by: William Zhang william.zhang@broadcom.com Reviewed-by: Anand Gore anand.gore@broadcom.com --- arch/arm/dts/bcm47622.dtsi | 126 ------------ arch/arm/dts/bcm4912.dtsi | 128 ------------ arch/arm/dts/bcm63146.dtsi | 110 ---------- arch/arm/dts/bcm63158.dtsi | 278 -------------------------- arch/arm/dts/bcm63178.dtsi | 120 ----------- arch/arm/dts/bcm6756.dtsi | 130 ------------ arch/arm/dts/bcm6813.dtsi | 128 ------------ arch/arm/dts/bcm6855.dtsi | 257 ------------------------ arch/arm/dts/bcm6856.dtsi | 253 ----------------------- arch/arm/dts/bcm6858.dtsi | 272 ------------------------- arch/arm/dts/bcm6878.dtsi | 111 ---------- arch/arm/dts/bcm947622.dts | 30 --- arch/arm/dts/bcm94912.dts | 30 --- arch/arm/dts/bcm963146.dts | 30 --- arch/arm/dts/bcm963158.dts | 30 --- arch/arm/dts/bcm963178.dts | 30 --- arch/arm/dts/bcm96756.dts | 30 --- arch/arm/dts/bcm96813.dts | 30 --- arch/arm/dts/bcm96855.dts | 30 --- arch/arm/dts/bcm96856.dts | 30 --- arch/arm/dts/bcm96858.dts | 30 --- arch/arm/dts/bcm96878.dts | 30 --- arch/arm/mach-bcmbca/bcm47622/Kconfig | 1 + arch/arm/mach-bcmbca/bcm4912/Kconfig | 1 + arch/arm/mach-bcmbca/bcm63146/Kconfig | 1 + arch/arm/mach-bcmbca/bcm63158/Kconfig | 1 + arch/arm/mach-bcmbca/bcm63178/Kconfig | 1 + arch/arm/mach-bcmbca/bcm6756/Kconfig | 1 + arch/arm/mach-bcmbca/bcm6813/Kconfig | 1 + arch/arm/mach-bcmbca/bcm6855/Kconfig | 1 + arch/arm/mach-bcmbca/bcm6856/Kconfig | 1 + arch/arm/mach-bcmbca/bcm6858/Kconfig | 1 + arch/arm/mach-bcmbca/bcm6878/Kconfig | 1 + configs/bcm947622_defconfig | 11 +- configs/bcm94912_defconfig | 11 +- configs/bcm963146_defconfig | 11 +- configs/bcm963158_defconfig | 11 +- configs/bcm963178_defconfig | 11 +- configs/bcm96756_defconfig | 11 +- configs/bcm96813_defconfig | 11 +- configs/bcm96855_defconfig | 11 +- configs/bcm96856_defconfig | 11 +- configs/bcm96858_defconfig | 11 +- configs/bcm96878_defconfig | 11 +- 44 files changed, 121 insertions(+), 2254 deletions(-) delete mode 100644 arch/arm/dts/bcm47622.dtsi delete mode 100644 arch/arm/dts/bcm4912.dtsi delete mode 100644 arch/arm/dts/bcm63146.dtsi delete mode 100644 arch/arm/dts/bcm63158.dtsi delete mode 100644 arch/arm/dts/bcm63178.dtsi delete mode 100644 arch/arm/dts/bcm6756.dtsi delete mode 100644 arch/arm/dts/bcm6813.dtsi delete mode 100644 arch/arm/dts/bcm6855.dtsi delete mode 100644 arch/arm/dts/bcm6856.dtsi delete mode 100644 arch/arm/dts/bcm6858.dtsi delete mode 100644 arch/arm/dts/bcm6878.dtsi delete mode 100644 arch/arm/dts/bcm947622.dts delete mode 100644 arch/arm/dts/bcm94912.dts delete mode 100644 arch/arm/dts/bcm963146.dts delete mode 100644 arch/arm/dts/bcm963158.dts delete mode 100644 arch/arm/dts/bcm963178.dts delete mode 100644 arch/arm/dts/bcm96756.dts delete mode 100644 arch/arm/dts/bcm96813.dts delete mode 100644 arch/arm/dts/bcm96855.dts delete mode 100644 arch/arm/dts/bcm96856.dts delete mode 100644 arch/arm/dts/bcm96858.dts delete mode 100644 arch/arm/dts/bcm96878.dts
diff --git a/arch/arm/dts/bcm47622.dtsi b/arch/arm/dts/bcm47622.dtsi deleted file mode 100644 index c016e12b7372..000000000000 --- a/arch/arm/dts/bcm47622.dtsi +++ /dev/null @@ -1,126 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright 2022 Broadcom Ltd. - */ - -#include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/interrupt-controller/irq.h> - -/ { - compatible = "brcm,bcm47622", "brcm,bcmbca"; - #address-cells = <1>; - #size-cells = <1>; - - interrupt-parent = <&gic>; - - cpus { - #address-cells = <1>; - #size-cells = <0>; - - CA7_0: cpu@0 { - device_type = "cpu"; - compatible = "arm,cortex-a7"; - reg = <0x0>; - next-level-cache = <&L2_0>; - enable-method = "psci"; - }; - - CA7_1: cpu@1 { - device_type = "cpu"; - compatible = "arm,cortex-a7"; - reg = <0x1>; - next-level-cache = <&L2_0>; - enable-method = "psci"; - }; - CA7_2: cpu@2 { - device_type = "cpu"; - compatible = "arm,cortex-a7"; - reg = <0x2>; - next-level-cache = <&L2_0>; - enable-method = "psci"; - }; - CA7_3: cpu@3 { - device_type = "cpu"; - compatible = "arm,cortex-a7"; - reg = <0x3>; - next-level-cache = <&L2_0>; - enable-method = "psci"; - }; - L2_0: l2-cache0 { - compatible = "cache"; - }; - }; - - timer { - compatible = "arm,armv7-timer"; - interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, - <GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, - <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, - <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>; - arm,cpu-registers-not-fw-configured; - }; - - pmu: pmu { - compatible = "arm,cortex-a7-pmu"; - interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>; - interrupt-affinity = <&CA7_0>, <&CA7_1>, - <&CA7_2>, <&CA7_3>; - }; - - clocks: clocks { - periph_clk: periph-clk { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <200000000>; - }; - uart_clk: uart-clk { - compatible = "fixed-factor-clock"; - #clock-cells = <0>; - clocks = <&periph_clk>; - clock-div = <4>; - clock-mult = <1>; - }; - }; - - psci { - compatible = "arm,psci-0.2"; - method = "smc"; - cpu_off = <1>; - cpu_on = <2>; - }; - - axi@81000000 { - compatible = "simple-bus"; - #address-cells = <1>; - #size-cells = <1>; - ranges = <0 0x81000000 0x818000>; - - gic: interrupt-controller@1000 { - compatible = "arm,cortex-a7-gic"; - #interrupt-cells = <3>; - #address-cells = <0>; - interrupt-controller; - reg = <0x1000 0x1000>, - <0x2000 0x2000>; - }; - }; - - bus@ff800000 { - compatible = "simple-bus"; - #address-cells = <1>; - #size-cells = <1>; - ranges = <0 0xff800000 0x800000>; - - uart0: serial@12000 { - compatible = "arm,pl011", "arm,primecell"; - reg = <0x12000 0x1000>; - interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&uart_clk>, <&uart_clk>; - clock-names = "uartclk", "apb_pclk"; - status = "disabled"; - }; - }; -}; diff --git a/arch/arm/dts/bcm4912.dtsi b/arch/arm/dts/bcm4912.dtsi deleted file mode 100644 index 3d016c2ce675..000000000000 --- a/arch/arm/dts/bcm4912.dtsi +++ /dev/null @@ -1,128 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright 2022 Broadcom Ltd. - */ - -#include <dt-bindings/interrupt-controller/irq.h> -#include <dt-bindings/interrupt-controller/arm-gic.h> - -/ { - compatible = "brcm,bcm4912", "brcm,bcmbca"; - #address-cells = <2>; - #size-cells = <2>; - - interrupt-parent = <&gic>; - - cpus { - #address-cells = <2>; - #size-cells = <0>; - - B53_0: cpu@0 { - compatible = "brcm,brahma-b53"; - device_type = "cpu"; - reg = <0x0 0x0>; - next-level-cache = <&L2_0>; - enable-method = "psci"; - }; - - B53_1: cpu@1 { - compatible = "brcm,brahma-b53"; - device_type = "cpu"; - reg = <0x0 0x1>; - next-level-cache = <&L2_0>; - enable-method = "psci"; - }; - - B53_2: cpu@2 { - compatible = "brcm,brahma-b53"; - device_type = "cpu"; - reg = <0x0 0x2>; - next-level-cache = <&L2_0>; - enable-method = "psci"; - }; - - B53_3: cpu@3 { - compatible = "brcm,brahma-b53"; - device_type = "cpu"; - reg = <0x0 0x3>; - next-level-cache = <&L2_0>; - enable-method = "psci"; - }; - - L2_0: l2-cache0 { - compatible = "cache"; - }; - }; - - timer { - compatible = "arm,armv8-timer"; - interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, - <GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, - <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, - <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>; - }; - - pmu: pmu { - compatible = "arm,cortex-a53-pmu"; - interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>; - interrupt-affinity = <&B53_0>, <&B53_1>, - <&B53_2>, <&B53_3>; - }; - - clocks: clocks { - periph_clk: periph-clk { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <200000000>; - }; - uart_clk: uart-clk { - compatible = "fixed-factor-clock"; - #clock-cells = <0>; - clocks = <&periph_clk>; - clock-div = <4>; - clock-mult = <1>; - }; - }; - - psci { - compatible = "arm,psci-0.2"; - method = "smc"; - }; - - axi@81000000 { - compatible = "simple-bus"; - #address-cells = <1>; - #size-cells = <1>; - ranges = <0x0 0x0 0x81000000 0x8000>; - - gic: interrupt-controller@1000 { - compatible = "arm,gic-400"; - #interrupt-cells = <3>; - interrupt-controller; - interrupts = <GIC_PPI 9 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>; - reg = <0x1000 0x1000>, - <0x2000 0x2000>, - <0x4000 0x2000>, - <0x6000 0x2000>; - }; - }; - - bus@ff800000 { - compatible = "simple-bus"; - #address-cells = <1>; - #size-cells = <1>; - ranges = <0x0 0x0 0xff800000 0x800000>; - - uart0: serial@12000 { - compatible = "arm,pl011", "arm,primecell"; - reg = <0x12000 0x1000>; - interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&uart_clk>, <&uart_clk>; - clock-names = "uartclk", "apb_pclk"; - status = "disabled"; - }; - }; -}; diff --git a/arch/arm/dts/bcm63146.dtsi b/arch/arm/dts/bcm63146.dtsi deleted file mode 100644 index 04de96bd0a03..000000000000 --- a/arch/arm/dts/bcm63146.dtsi +++ /dev/null @@ -1,110 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright 2022 Broadcom Ltd. - */ - -#include <dt-bindings/interrupt-controller/irq.h> -#include <dt-bindings/interrupt-controller/arm-gic.h> - -/ { - compatible = "brcm,bcm63146", "brcm,bcmbca"; - #address-cells = <2>; - #size-cells = <2>; - - interrupt-parent = <&gic>; - - cpus { - #address-cells = <2>; - #size-cells = <0>; - - B53_0: cpu@0 { - compatible = "brcm,brahma-b53"; - device_type = "cpu"; - reg = <0x0 0x0>; - next-level-cache = <&L2_0>; - enable-method = "psci"; - }; - - B53_1: cpu@1 { - compatible = "brcm,brahma-b53"; - device_type = "cpu"; - reg = <0x0 0x1>; - next-level-cache = <&L2_0>; - enable-method = "psci"; - }; - - L2_0: l2-cache0 { - compatible = "cache"; - }; - }; - - timer { - compatible = "arm,armv8-timer"; - interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, - <GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, - <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, - <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>; - }; - - pmu: pmu { - compatible = "arm,cortex-a53-pmu"; - interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>; - interrupt-affinity = <&B53_0>, <&B53_1>; - }; - - clocks: clocks { - periph_clk: periph-clk { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <200000000>; - }; - uart_clk: uart-clk { - compatible = "fixed-factor-clock"; - #clock-cells = <0>; - clocks = <&periph_clk>; - clock-div = <4>; - clock-mult = <1>; - }; - }; - - psci { - compatible = "arm,psci-0.2"; - method = "smc"; - }; - - axi@81000000 { - compatible = "simple-bus"; - #address-cells = <1>; - #size-cells = <1>; - ranges = <0x0 0x0 0x81000000 0x8000>; - - gic: interrupt-controller@1000 { - compatible = "arm,gic-400"; - #interrupt-cells = <3>; - interrupt-controller; - reg = <0x1000 0x1000>, - <0x2000 0x2000>, - <0x4000 0x2000>, - <0x6000 0x2000>; - interrupts = <GIC_PPI 9 (GIC_CPU_MASK_SIMPLE(2) | - IRQ_TYPE_LEVEL_HIGH)>; - }; - }; - - bus@ff800000 { - compatible = "simple-bus"; - #address-cells = <1>; - #size-cells = <1>; - ranges = <0x0 0x0 0xff800000 0x800000>; - - uart0: serial@12000 { - compatible = "arm,pl011", "arm,primecell"; - reg = <0x12000 0x1000>; - interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&uart_clk>, <&uart_clk>; - clock-names = "uartclk", "apb_pclk"; - status = "disabled"; - }; - }; -}; diff --git a/arch/arm/dts/bcm63158.dtsi b/arch/arm/dts/bcm63158.dtsi deleted file mode 100644 index 4bed1f914a9b..000000000000 --- a/arch/arm/dts/bcm63158.dtsi +++ /dev/null @@ -1,278 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright (C) 2019 Philippe Reynes philippe.reynes@softathome.com - * Copyright 2022 Broadcom Ltd. - */ - -#include <dt-bindings/interrupt-controller/irq.h> -#include <dt-bindings/interrupt-controller/arm-gic.h> - -/ { - compatible = "brcm,bcm63158", "brcm,bcmbca"; - #address-cells = <2>; - #size-cells = <2>; - - interrupt-parent = <&gic>; - - cpus { - #address-cells = <2>; - #size-cells = <0>; - - B53_0: cpu@0 { - compatible = "brcm,brahma-b53"; - device_type = "cpu"; - reg = <0x0 0x0>; - next-level-cache = <&L2_0>; - enable-method = "psci"; - }; - - B53_1: cpu@1 { - compatible = "brcm,brahma-b53"; - device_type = "cpu"; - reg = <0x0 0x1>; - next-level-cache = <&L2_0>; - enable-method = "psci"; - }; - - B53_2: cpu@2 { - compatible = "brcm,brahma-b53"; - device_type = "cpu"; - reg = <0x0 0x2>; - next-level-cache = <&L2_0>; - enable-method = "psci"; - }; - - B53_3: cpu@3 { - compatible = "brcm,brahma-b53"; - device_type = "cpu"; - reg = <0x0 0x3>; - next-level-cache = <&L2_0>; - enable-method = "psci"; - }; - - L2_0: l2-cache0 { - compatible = "cache"; - }; - }; - - timer { - compatible = "arm,armv8-timer"; - interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, - <GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, - <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, - <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>; - }; - - pmu: pmu { - compatible = "arm,cortex-a53-pmu"; - interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>; - interrupt-affinity = <&B53_0>, <&B53_1>, - <&B53_2>, <&B53_3>; - }; - - clocks { - bootph-all; - periph_clk: periph-clk { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <200000000>; - }; - - hsspi_pll: hsspi-pll { - compatible = "fixed-factor-clock"; - #clock-cells = <0>; - clocks = <&periph_clk>; - clock-mult = <2>; - clock-div = <1>; - }; - - uart_clk: uart-clk { - compatible = "fixed-factor-clock"; - #clock-cells = <0>; - clocks = <&periph_clk>; - clock-div = <4>; - clock-mult = <1>; - }; - - wdt_clk: wdt-clk { - compatible = "fixed-factor-clock"; - #clock-cells = <0>; - clocks = <&periph_clk>; - clock-div = <4>; - clock-mult = <1>; - }; - }; - - psci { - compatible = "arm,psci-0.2"; - method = "smc"; - }; - - axi@81000000 { - compatible = "simple-bus"; - #address-cells = <1>; - #size-cells = <1>; - ranges = <0x0 0x0 0x81000000 0x8000>; - - gic: interrupt-controller@1000 { - compatible = "arm,gic-400"; - #interrupt-cells = <3>; - interrupt-controller; - interrupts = <GIC_PPI 9 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>; - reg = <0x1000 0x1000>, - <0x2000 0x2000>, - <0x4000 0x2000>, - <0x6000 0x2000>; - }; - }; - - bus@ff800000 { - compatible = "simple-bus"; - #address-cells = <1>; - #size-cells = <1>; - ranges = <0x0 0x0 0xff800000 0x800000>; - bootph-all; - - uart0: serial@12000 { - compatible = "arm,pl011", "arm,primecell"; - reg = <0x12000 0x1000>; - interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&uart_clk>, <&uart_clk>; - clock-names = "uartclk", "apb_pclk"; - status = "disabled"; - }; - - leds: led-controller@800 { - compatible = "brcm,bcm6858-leds"; - reg = <0x800 0xe4>; - - status = "disabled"; - }; - - wdt1: watchdog@480 { - compatible = "brcm,bcm6345-wdt"; - reg = <0x480 0x14>; - clocks = <&wdt_clk>; - }; - - wdt2: watchdog@4c0 { - compatible = "brcm,bcm6345-wdt"; - reg = <0x4c0 0x14>; - clocks = <&wdt_clk>; - }; - - wdt-reboot { - compatible = "wdt-reboot"; - wdt = <&wdt1>; - }; - - gpio0: gpio-controller@500 { - compatible = "brcm,bcm6345-gpio"; - reg = <0x500 0x4>, - <0x520 0x4>; - gpio-controller; - #gpio-cells = <2>; - - status = "disabled"; - }; - - gpio1: gpio-controller@504 { - compatible = "brcm,bcm6345-gpio"; - reg = <0x504 0x4>, - <0x524 0x4>; - gpio-controller; - #gpio-cells = <2>; - - status = "disabled"; - }; - - gpio2: gpio-controller@508 { - compatible = "brcm,bcm6345-gpio"; - reg = <0x508 0x4>, - <0x528 0x4>; - gpio-controller; - #gpio-cells = <2>; - - status = "disabled"; - }; - - gpio3: gpio-controller@50c { - compatible = "brcm,bcm6345-gpio"; - reg = <0x50c 0x4>, - <0x52c 0x4>; - gpio-controller; - #gpio-cells = <2>; - - status = "disabled"; - }; - - gpio4: gpio-controller@510 { - compatible = "brcm,bcm6345-gpio"; - reg = <0x510 0x4>, - <0x530 0x4>; - gpio-controller; - #gpio-cells = <2>; - - status = "disabled"; - }; - - gpio5: gpio-controller@514 { - compatible = "brcm,bcm6345-gpio"; - reg = <0x514 0x4>, - <0x534 0x4>; - gpio-controller; - #gpio-cells = <2>; - - status = "disabled"; - }; - - gpio6: gpio-controller@518 { - compatible = "brcm,bcm6345-gpio"; - reg = <0x518 0x4>, - <0x538 0x4>; - gpio-controller; - #gpio-cells = <2>; - - status = "disabled"; - }; - - gpio7: gpio-controller@51c { - compatible = "brcm,bcm6345-gpio"; - reg = <0x51c 0x4>, - <0x53c 0x4>; - gpio-controller; - #gpio-cells = <2>; - - status = "disabled"; - }; - - hsspi: spi-controller@1000 { - compatible = "brcm,bcm6328-hsspi"; - #address-cells = <1>; - #size-cells = <0>; - reg = <0x1000 0x600>; - clocks = <&hsspi_pll>, <&hsspi_pll>; - clock-names = "hsspi", "pll"; - spi-max-frequency = <100000000>; - num-cs = <8>; - - status = "disabled"; - }; - - nand: nand-controller@1800 { - compatible = "brcm,nand-bcm63158", - "brcm,brcmnand-v5.0", - "brcm,brcmnand"; - reg-names = "nand", "nand-int-base", "nand-cache"; - reg = <0x1800 0x180>, - <0x2000 0x10>, - <0x1c00 0x200>; - parameter-page-big-endian = <0>; - - status = "disabled"; - }; - }; -}; diff --git a/arch/arm/dts/bcm63178.dtsi b/arch/arm/dts/bcm63178.dtsi deleted file mode 100644 index cbd094dde6d0..000000000000 --- a/arch/arm/dts/bcm63178.dtsi +++ /dev/null @@ -1,120 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright 2022 Broadcom Ltd. - */ - -#include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/interrupt-controller/irq.h> - -/ { - compatible = "brcm,bcm63178", "brcm,bcmbca"; - #address-cells = <1>; - #size-cells = <1>; - - interrupt-parent = <&gic>; - - cpus { - #address-cells = <1>; - #size-cells = <0>; - - CA7_0: cpu@0 { - device_type = "cpu"; - compatible = "arm,cortex-a7"; - reg = <0x0>; - next-level-cache = <&L2_0>; - enable-method = "psci"; - }; - - CA7_1: cpu@1 { - device_type = "cpu"; - compatible = "arm,cortex-a7"; - reg = <0x1>; - next-level-cache = <&L2_0>; - enable-method = "psci"; - }; - - CA7_2: cpu@2 { - device_type = "cpu"; - compatible = "arm,cortex-a7"; - reg = <0x2>; - next-level-cache = <&L2_0>; - enable-method = "psci"; - }; - - L2_0: l2-cache0 { - compatible = "cache"; - }; - }; - - timer { - compatible = "arm,armv7-timer"; - interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(3) | IRQ_TYPE_LEVEL_LOW)>, - <GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(3) | IRQ_TYPE_LEVEL_LOW)>, - <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(3) | IRQ_TYPE_LEVEL_LOW)>, - <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(3) | IRQ_TYPE_LEVEL_LOW)>; - arm,cpu-registers-not-fw-configured; - }; - - pmu: pmu { - compatible = "arm,cortex-a7-pmu"; - interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>; - interrupt-affinity = <&CA7_0>, <&CA7_1>, - <&CA7_2>; - }; - - clocks: clocks { - periph_clk: periph-clk { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <200000000>; - }; - uart_clk: uart-clk { - compatible = "fixed-factor-clock"; - #clock-cells = <0>; - clocks = <&periph_clk>; - clock-div = <4>; - clock-mult = <1>; - }; - }; - - psci { - compatible = "arm,psci-0.2"; - method = "smc"; - }; - - axi@81000000 { - compatible = "simple-bus"; - #address-cells = <1>; - #size-cells = <1>; - ranges = <0 0x81000000 0x8000>; - - gic: interrupt-controller@1000 { - compatible = "arm,cortex-a7-gic"; - #interrupt-cells = <3>; - interrupt-controller; - interrupts = <GIC_PPI 9 (GIC_CPU_MASK_SIMPLE(3) | IRQ_TYPE_LEVEL_HIGH)>; - reg = <0x1000 0x1000>, - <0x2000 0x2000>, - <0x4000 0x2000>, - <0x6000 0x2000>; - }; - }; - - bus@ff800000 { - compatible = "simple-bus"; - #address-cells = <1>; - #size-cells = <1>; - ranges = <0 0xff800000 0x800000>; - - uart0: serial@12000 { - compatible = "arm,pl011", "arm,primecell"; - reg = <0x12000 0x1000>; - interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&uart_clk>, <&uart_clk>; - clock-names = "uartclk", "apb_pclk"; - status = "disabled"; - }; - }; -}; diff --git a/arch/arm/dts/bcm6756.dtsi b/arch/arm/dts/bcm6756.dtsi deleted file mode 100644 index ce1b59faf800..000000000000 --- a/arch/arm/dts/bcm6756.dtsi +++ /dev/null @@ -1,130 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright 2022 Broadcom Ltd. - */ - -#include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/interrupt-controller/irq.h> - -/ { - compatible = "brcm,bcm6756", "brcm,bcmbca"; - #address-cells = <1>; - #size-cells = <1>; - - interrupt-parent = <&gic>; - - cpus { - #address-cells = <1>; - #size-cells = <0>; - - CA7_0: cpu@0 { - device_type = "cpu"; - compatible = "arm,cortex-a7"; - reg = <0x0>; - next-level-cache = <&L2_0>; - enable-method = "psci"; - }; - - CA7_1: cpu@1 { - device_type = "cpu"; - compatible = "arm,cortex-a7"; - reg = <0x1>; - next-level-cache = <&L2_0>; - enable-method = "psci"; - }; - - CA7_2: cpu@2 { - device_type = "cpu"; - compatible = "arm,cortex-a7"; - reg = <0x2>; - next-level-cache = <&L2_0>; - enable-method = "psci"; - }; - - CA7_3: cpu@3 { - device_type = "cpu"; - compatible = "arm,cortex-a7"; - reg = <0x3>; - next-level-cache = <&L2_0>; - enable-method = "psci"; - }; - - L2_0: l2-cache0 { - compatible = "cache"; - }; - }; - - timer { - compatible = "arm,armv7-timer"; - interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, - <GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, - <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, - <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>; - arm,cpu-registers-not-fw-configured; - }; - - pmu: pmu { - compatible = "arm,cortex-a7-pmu"; - interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>; - interrupt-affinity = <&CA7_0>, <&CA7_1>, - <&CA7_2>, <&CA7_3>; - }; - - clocks: clocks { - periph_clk: periph-clk { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <200000000>; - }; - - uart_clk: uart-clk { - compatible = "fixed-factor-clock"; - #clock-cells = <0>; - clocks = <&periph_clk>; - clock-div = <4>; - clock-mult = <1>; - }; - }; - - psci { - compatible = "arm,psci-0.2"; - method = "smc"; - }; - - axi@81000000 { - compatible = "simple-bus"; - #address-cells = <1>; - #size-cells = <1>; - ranges = <0 0x81000000 0x8000>; - - gic: interrupt-controller@1000 { - compatible = "arm,cortex-a7-gic"; - #interrupt-cells = <3>; - interrupt-controller; - interrupts = <GIC_PPI 9 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>; - reg = <0x1000 0x1000>, - <0x2000 0x2000>, - <0x4000 0x2000>, - <0x6000 0x2000>; - }; - }; - - bus@ff800000 { - compatible = "simple-bus"; - #address-cells = <1>; - #size-cells = <1>; - ranges = <0 0xff800000 0x800000>; - - uart0: serial@12000 { - compatible = "arm,pl011", "arm,primecell"; - reg = <0x12000 0x1000>; - interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&uart_clk>, <&uart_clk>; - clock-names = "uartclk", "apb_pclk"; - status = "disabled"; - }; - }; -}; diff --git a/arch/arm/dts/bcm6813.dtsi b/arch/arm/dts/bcm6813.dtsi deleted file mode 100644 index c3e6197be808..000000000000 --- a/arch/arm/dts/bcm6813.dtsi +++ /dev/null @@ -1,128 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright 2022 Broadcom Ltd. - */ - -#include <dt-bindings/interrupt-controller/irq.h> -#include <dt-bindings/interrupt-controller/arm-gic.h> - -/ { - compatible = "brcm,bcm6813", "brcm,bcmbca"; - #address-cells = <2>; - #size-cells = <2>; - - interrupt-parent = <&gic>; - - cpus { - #address-cells = <2>; - #size-cells = <0>; - - B53_0: cpu@0 { - compatible = "brcm,brahma-b53"; - device_type = "cpu"; - reg = <0x0 0x0>; - next-level-cache = <&L2_0>; - enable-method = "psci"; - }; - - B53_1: cpu@1 { - compatible = "brcm,brahma-b53"; - device_type = "cpu"; - reg = <0x0 0x1>; - next-level-cache = <&L2_0>; - enable-method = "psci"; - }; - - B53_2: cpu@2 { - compatible = "brcm,brahma-b53"; - device_type = "cpu"; - reg = <0x0 0x2>; - next-level-cache = <&L2_0>; - enable-method = "psci"; - }; - - B53_3: cpu@3 { - compatible = "brcm,brahma-b53"; - device_type = "cpu"; - reg = <0x0 0x3>; - next-level-cache = <&L2_0>; - enable-method = "psci"; - }; - - L2_0: l2-cache0 { - compatible = "cache"; - }; - }; - - timer { - compatible = "arm,armv8-timer"; - interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, - <GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, - <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, - <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>; - }; - - pmu: pmu { - compatible = "arm,cortex-a53-pmu"; - interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>; - interrupt-affinity = <&B53_0>, <&B53_1>, - <&B53_2>, <&B53_3>; - }; - - clocks: clocks { - periph_clk: periph-clk { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <200000000>; - }; - uart_clk: uart-clk { - compatible = "fixed-factor-clock"; - #clock-cells = <0>; - clocks = <&periph_clk>; - clock-div = <4>; - clock-mult = <1>; - }; - }; - - psci { - compatible = "arm,psci-0.2"; - method = "smc"; - }; - - axi@81000000 { - compatible = "simple-bus"; - #address-cells = <1>; - #size-cells = <1>; - ranges = <0x0 0x0 0x81000000 0x8000>; - - gic: interrupt-controller@1000 { - compatible = "arm,gic-400"; - #interrupt-cells = <3>; - interrupt-controller; - interrupts = <GIC_PPI 9 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>; - reg = <0x1000 0x1000>, - <0x2000 0x2000>, - <0x4000 0x2000>, - <0x6000 0x2000>; - }; - }; - - bus@ff800000 { - compatible = "simple-bus"; - #address-cells = <1>; - #size-cells = <1>; - ranges = <0x0 0x0 0xff800000 0x800000>; - - uart0: serial@12000 { - compatible = "arm,pl011", "arm,primecell"; - reg = <0x12000 0x1000>; - interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&uart_clk>, <&uart_clk>; - clock-names = "uartclk", "apb_pclk"; - status = "disabled"; - }; - }; -}; diff --git a/arch/arm/dts/bcm6855.dtsi b/arch/arm/dts/bcm6855.dtsi deleted file mode 100644 index 10c003a57c95..000000000000 --- a/arch/arm/dts/bcm6855.dtsi +++ /dev/null @@ -1,257 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (C) 2022 Philippe Reynes philippe.reynes@softathome.com - * Copyright 2022 Broadcom Ltd. - */ - -#include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/interrupt-controller/irq.h> - -/ { - compatible = "brcm,bcm6855", "brcm,bcmbca"; - #address-cells = <1>; - #size-cells = <1>; - - interrupt-parent = <&gic>; - - cpus { - #address-cells = <1>; - #size-cells = <0>; - - CA7_0: cpu@0 { - device_type = "cpu"; - compatible = "arm,cortex-a7"; - reg = <0x0>; - next-level-cache = <&L2_0>; - enable-method = "psci"; - }; - - CA7_1: cpu@1 { - device_type = "cpu"; - compatible = "arm,cortex-a7"; - reg = <0x1>; - next-level-cache = <&L2_0>; - enable-method = "psci"; - }; - - CA7_2: cpu@2 { - device_type = "cpu"; - compatible = "arm,cortex-a7"; - reg = <0x2>; - next-level-cache = <&L2_0>; - enable-method = "psci"; - }; - - L2_0: l2-cache0 { - compatible = "cache"; - }; - }; - - timer { - compatible = "arm,armv7-timer"; - interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(3) | IRQ_TYPE_LEVEL_LOW)>, - <GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(3) | IRQ_TYPE_LEVEL_LOW)>, - <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(3) | IRQ_TYPE_LEVEL_LOW)>, - <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(3) | IRQ_TYPE_LEVEL_LOW)>; - arm,cpu-registers-not-fw-configured; - }; - - pmu: pmu { - compatible = "arm,cortex-a7-pmu"; - interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>; - interrupt-affinity = <&CA7_0>, <&CA7_1>, <&CA7_2>; - }; - - clocks: clocks { - bootph-all; - - periph_clk: periph-clk { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <200000000>; - }; - - uart_clk: uart-clk { - compatible = "fixed-factor-clock"; - #clock-cells = <0>; - clocks = <&periph_clk>; - clock-div = <4>; - clock-mult = <1>; - }; - - hsspi_pll: hsspi-pll { - compatible = "fixed-factor-clock"; - #clock-cells = <0>; - clocks = <&periph_clk>; - clock-mult = <2>; - clock-div = <1>; - }; - - wdt_clk: wdt-clk { - compatible = "fixed-factor-clock"; - #clock-cells = <0>; - clocks = <&periph_clk>; - clock-div = <4>; - clock-mult = <1>; - }; - }; - - psci { - compatible = "arm,psci-0.2"; - method = "smc"; - }; - - axi@81000000 { - compatible = "simple-bus"; - #address-cells = <1>; - #size-cells = <1>; - ranges = <0 0x81000000 0x8000>; - - gic: interrupt-controller@1000 { - compatible = "arm,cortex-a7-gic"; - #interrupt-cells = <3>; - interrupt-controller; - interrupts = <GIC_PPI 9 (GIC_CPU_MASK_SIMPLE(3) | IRQ_TYPE_LEVEL_HIGH)>; - reg = <0x1000 0x1000>, - <0x2000 0x2000>, - <0x4000 0x2000>, - <0x6000 0x2000>; - }; - }; - - bus@ff800000 { - compatible = "simple-bus"; - #address-cells = <1>; - #size-cells = <1>; - ranges = <0 0xff800000 0x800000>; - bootph-all; - - uart0: serial@12000 { - compatible = "arm,pl011", "arm,primecell"; - reg = <0x12000 0x1000>; - interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&uart_clk>, <&uart_clk>; - clock-names = "uartclk", "apb_pclk"; - status = "disabled"; - }; - - wdt1: watchdog@480 { - compatible = "brcm,bcm6345-wdt"; - reg = <0x480 0x14>; - clocks = <&wdt_clk>; - }; - - wdt2: watchdog@4c0 { - compatible = "brcm,bcm6345-wdt"; - reg = <0x4c0 0x14>; - clocks = <&wdt_clk>; - }; - - wdt-reboot { - compatible = "wdt-reboot"; - wdt = <&wdt1>; - }; - - gpio0: gpio-controller@500 { - compatible = "brcm,bcm6345-gpio"; - reg = <0x500 0x4>, - <0x520 0x4>; - gpio-controller; - #gpio-cells = <2>; - - status = "disabled"; - }; - - gpio1: gpio-controller@504 { - compatible = "brcm,bcm6345-gpio"; - reg = <0x504 0x4>, - <0x524 0x4>; - gpio-controller; - #gpio-cells = <2>; - - status = "disabled"; - }; - - gpio2: gpio-controller@508 { - compatible = "brcm,bcm6345-gpio"; - reg = <0x508 0x4>, - <0x528 0x4>; - gpio-controller; - #gpio-cells = <2>; - - status = "disabled"; - }; - - gpio3: gpio-controller@50c { - compatible = "brcm,bcm6345-gpio"; - reg = <0x50c 0x4>, - <0x52c 0x4>; - gpio-controller; - #gpio-cells = <2>; - - status = "disabled"; - }; - - gpio4: gpio-controller@510 { - compatible = "brcm,bcm6345-gpio"; - reg = <0x510 0x4>, - <0x530 0x4>; - gpio-controller; - #gpio-cells = <2>; - - status = "disabled"; - }; - - gpio5: gpio-controller@514 { - compatible = "brcm,bcm6345-gpio"; - reg = <0x514 0x4>, - <0x534 0x4>; - gpio-controller; - #gpio-cells = <2>; - - status = "disabled"; - }; - - gpio6: gpio-controller@518 { - compatible = "brcm,bcm6345-gpio"; - reg = <0x518 0x4>, - <0x538 0x4>; - gpio-controller; - #gpio-cells = <2>; - - status = "disabled"; - }; - - gpio7: gpio-controller@51c { - compatible = "brcm,bcm6345-gpio"; - reg = <0x51c 0x4>, - <0x53c 0x4>; - gpio-controller; - #gpio-cells = <2>; - - status = "disabled"; - }; - - nand: nand-controller@1800 { - compatible = "brcm,nand-bcm6753", - "brcm,brcmnand-v5.0", - "brcm,brcmnand"; - reg-names = "nand", "nand-int-base", "nand-cache"; - reg = <0x1800 0x180>, - <0x2000 0x10>, - <0x1c00 0x200>; - parameter-page-big-endian = <0>; - - status = "disabled"; - }; - - leds: led-controller@3000 { - compatible = "brcm,bcm6753-leds"; - reg = <0x3000 0x3480>; - - status = "disabled"; - }; - }; -}; diff --git a/arch/arm/dts/bcm6856.dtsi b/arch/arm/dts/bcm6856.dtsi deleted file mode 100644 index 38c88f8399bb..000000000000 --- a/arch/arm/dts/bcm6856.dtsi +++ /dev/null @@ -1,253 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (C) 2020 Philippe Reynes philippe.reynes@softathome.com - * Copyright 2022 Broadcom Ltd. - */ - -#include <dt-bindings/interrupt-controller/irq.h> -#include <dt-bindings/interrupt-controller/arm-gic.h> - -/ { - compatible = "brcm,bcm6856", "brcm,bcmbca"; - #address-cells = <2>; - #size-cells = <2>; - - interrupt-parent = <&gic>; - - cpus { - #address-cells = <2>; - #size-cells = <0>; - - B53_0: cpu@0 { - compatible = "brcm,brahma-b53"; - device_type = "cpu"; - reg = <0x0 0x0>; - next-level-cache = <&L2_0>; - enable-method = "psci"; - }; - - B53_1: cpu@1 { - compatible = "brcm,brahma-b53"; - device_type = "cpu"; - reg = <0x0 0x1>; - next-level-cache = <&L2_0>; - enable-method = "psci"; - }; - - L2_0: l2-cache0 { - compatible = "cache"; - }; - }; - - timer { - compatible = "arm,armv8-timer"; - interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, - <GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, - <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, - <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>; - }; - - pmu: pmu { - compatible = "arm,cortex-a53-pmu"; - interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>; - interrupt-affinity = <&B53_0>, <&B53_1>; - }; - - clocks: clocks { - bootph-all; - - periph_clk:periph-clk { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <200000000>; - }; - - hsspi_pll: hsspi-pll { - compatible = "fixed-factor-clock"; - #clock-cells = <0>; - clocks = <&periph_clk>; - clock-mult = <2>; - clock-div = <1>; - }; - - wdt_clk: wdt-clk { - compatible = "fixed-factor-clock"; - #clock-cells = <0>; - clocks = <&periph_clk>; - clock-div = <4>; - clock-mult = <1>; - }; - }; - - psci { - compatible = "arm,psci-0.2"; - method = "smc"; - }; - - axi@81000000 { - compatible = "simple-bus"; - #address-cells = <1>; - #size-cells = <1>; - ranges = <0x0 0x0 0x81000000 0x8000>; - - gic: interrupt-controller@1000 { - compatible = "arm,gic-400"; - #interrupt-cells = <3>; - interrupt-controller; - reg = <0x1000 0x1000>, /* GICD */ - <0x2000 0x2000>, /* GICC */ - <0x4000 0x2000>, /* GICH */ - <0x6000 0x2000>; /* GICV */ - interrupts = <GIC_PPI 9 (GIC_CPU_MASK_SIMPLE(2) | - IRQ_TYPE_LEVEL_HIGH)>; - }; - }; - - bus@ff800000 { - compatible = "simple-bus"; - #address-cells = <1>; - #size-cells = <1>; - ranges = <0x0 0x0 0xff800000 0x800000>; - bootph-all; - - uart0: serial@640 { - compatible = "brcm,bcm6345-uart"; - reg = <0x640 0x18>; - interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&periph_clk>; - clock-names = "refclk"; - status = "disabled"; - }; - - wdt1: watchdog@480 { - compatible = "brcm,bcm6345-wdt"; - reg = <0x480 0x14>; - clocks = <&wdt_clk>; - }; - - wdt2: watchdog@4c0 { - compatible = "brcm,bcm6345-wdt"; - reg = <0x4c0 0x14>; - clocks = <&wdt_clk>; - }; - - wdt-reboot { - compatible = "wdt-reboot"; - wdt = <&wdt1>; - }; - - leds: led-controller@800 { - compatible = "brcm,bcm6858-leds"; - reg = <0x800 0xe4>; - - status = "disabled"; - }; - - gpio0: gpio-controller@500 { - compatible = "brcm,bcm6345-gpio"; - reg = <0x500 0x4>, - <0x520 0x4>; - gpio-controller; - #gpio-cells = <2>; - - status = "disabled"; - }; - - gpio1: gpio-controller@504 { - compatible = "brcm,bcm6345-gpio"; - reg = <0x504 0x4>, - <0x524 0x4>; - gpio-controller; - #gpio-cells = <2>; - - status = "disabled"; - }; - - gpio2: gpio-controller@508 { - compatible = "brcm,bcm6345-gpio"; - reg = <0x508 0x4>, - <0x528 0x4>; - gpio-controller; - #gpio-cells = <2>; - - status = "disabled"; - }; - - gpio3: gpio-controller@50c { - compatible = "brcm,bcm6345-gpio"; - reg = <0x50c 0x4>, - <0x52c 0x4>; - gpio-controller; - #gpio-cells = <2>; - - status = "disabled"; - }; - - gpio4: gpio-controller@510 { - compatible = "brcm,bcm6345-gpio"; - reg = <0x510 0x4>, - <0x530 0x4>; - gpio-controller; - #gpio-cells = <2>; - - status = "disabled"; - }; - - gpio5: gpio-controller@514 { - compatible = "brcm,bcm6345-gpio"; - reg = <0x514 0x4>, - <0x534 0x4>; - gpio-controller; - #gpio-cells = <2>; - - status = "disabled"; - }; - - gpio6: gpio-controller@518 { - compatible = "brcm,bcm6345-gpio"; - reg = <0x518 0x4>, - <0x538 0x4>; - gpio-controller; - #gpio-cells = <2>; - - status = "disabled"; - }; - - gpio7: gpio-controller@51c { - compatible = "brcm,bcm6345-gpio"; - reg = <0x51c 0x4>, - <0x53c 0x4>; - gpio-controller; - #gpio-cells = <2>; - - status = "disabled"; - }; - - hsspi: spi-controller@1000 { - compatible = "brcm,bcm6328-hsspi"; - #address-cells = <1>; - #size-cells = <0>; - reg = <0x1000 0x600>; - clocks = <&hsspi_pll>, <&hsspi_pll>; - clock-names = "hsspi", "pll"; - spi-max-frequency = <100000000>; - num-cs = <8>; - - status = "disabled"; - }; - - nand: nand-controller@1800 { - compatible = "brcm,nand-bcm68360", - "brcm,brcmnand-v5.0", - "brcm,brcmnand"; - reg-names = "nand", "nand-int-base", "nand-cache"; - reg = <0x1800 0x180>, - <0x2000 0x10>, - <0x1c00 0x200>; - parameter-page-big-endian = <0>; - - status = "disabled"; - }; - }; -}; diff --git a/arch/arm/dts/bcm6858.dtsi b/arch/arm/dts/bcm6858.dtsi deleted file mode 100644 index dc95047a2659..000000000000 --- a/arch/arm/dts/bcm6858.dtsi +++ /dev/null @@ -1,272 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright (C) 2018 Philippe Reynes philippe.reynes@softathome.com - * Copyright 2022 Broadcom Ltd. - */ - -#include <dt-bindings/interrupt-controller/irq.h> -#include <dt-bindings/interrupt-controller/arm-gic.h> - -/ { - compatible = "brcm,bcm6858", "brcm,bcmbca"; - #address-cells = <2>; - #size-cells = <2>; - - interrupt-parent = <&gic>; - - cpus { - #address-cells = <2>; - #size-cells = <0>; - - B53_0: cpu@0 { - compatible = "brcm,brahma-b53"; - device_type = "cpu"; - reg = <0x0 0x0>; - next-level-cache = <&L2_0>; - enable-method = "psci"; - }; - - B53_1: cpu@1 { - compatible = "brcm,brahma-b53"; - device_type = "cpu"; - reg = <0x0 0x1>; - next-level-cache = <&L2_0>; - enable-method = "psci"; - }; - - B53_2: cpu@2 { - compatible = "brcm,brahma-b53"; - device_type = "cpu"; - reg = <0x0 0x2>; - next-level-cache = <&L2_0>; - enable-method = "psci"; - }; - - B53_3: cpu@3 { - compatible = "brcm,brahma-b53"; - device_type = "cpu"; - reg = <0x0 0x3>; - next-level-cache = <&L2_0>; - enable-method = "psci"; - }; - - L2_0: l2-cache0 { - compatible = "cache"; - }; - }; - - timer { - compatible = "arm,armv8-timer"; - interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, - <GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, - <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, - <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>; - }; - - pmu: pmu { - compatible = "arm,armv8-pmuv3"; - interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>; - interrupt-affinity = <&B53_0>, <&B53_1>, - <&B53_2>, <&B53_3>; - }; - - clocks { - bootph-all; - - periph_clk: periph_clk { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <200000000>; - }; - - hsspi_pll: hsspi-pll { - compatible = "fixed-factor-clock"; - #clock-cells = <0>; - clocks = <&periph_clk>; - clock-mult = <2>; - clock-div = <1>; - }; - - wdt_clk: wdt-clk { - compatible = "fixed-factor-clock"; - #clock-cells = <0>; - clocks = <&periph_clk>; - clock-div = <4>; - clock-mult = <1>; - }; - }; - - psci { - compatible = "arm,psci-0.2"; - method = "smc"; - }; - - axi@81000000 { - compatible = "simple-bus"; - #address-cells = <1>; - #size-cells = <1>; - ranges = <0x0 0x0 0x81000000 0x8000>; - - gic: interrupt-controller@1000 { - compatible = "arm,gic-400"; - #interrupt-cells = <3>; - interrupt-controller; - reg = <0x1000 0x1000>, /* GICD */ - <0x2000 0x2000>, /* GICC */ - <0x4000 0x2000>, /* GICH */ - <0x6000 0x2000>; /* GICV */ - interrupts = <GIC_PPI 9 (GIC_CPU_MASK_SIMPLE(4) | - IRQ_TYPE_LEVEL_HIGH)>; - }; - }; - - bus@ff800000 { - compatible = "simple-bus"; - #address-cells = <1>; - #size-cells = <1>; - ranges = <0x0 0x0 0xff800000 0x800000>; - bootph-all; - - uart0: serial@640 { - compatible = "brcm,bcm6345-uart"; - reg = <0x640 0x18>; - interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&periph_clk>; - clock-names = "refclk"; - status = "disabled"; - }; - - leds: led-controller@800 { - compatible = "brcm,bcm6858-leds"; - reg = <0x800 0xe4>; - - status = "disabled"; - }; - - wdt1: watchdog@2780 { - compatible = "brcm,bcm6345-wdt"; - reg = <0x2780 0x14>; - clocks = <&wdt_clk>; - }; - - wdt2: watchdog@27c0 { - compatible = "brcm,bcm6345-wdt"; - reg = <0x27c0 0x14>; - clocks = <&wdt_clk>; - }; - - wdt-reboot { - compatible = "wdt-reboot"; - wdt = <&wdt1>; - }; - - gpio0: gpio-controller@500 { - compatible = "brcm,bcm6345-gpio"; - reg = <0x500 0x4>, - <0x520 0x4>; - gpio-controller; - #gpio-cells = <2>; - - status = "disabled"; - }; - - gpio1: gpio-controller@504 { - compatible = "brcm,bcm6345-gpio"; - reg = <0x504 0x4>, - <0x524 0x4>; - gpio-controller; - #gpio-cells = <2>; - - status = "disabled"; - }; - - gpio2: gpio-controller@508 { - compatible = "brcm,bcm6345-gpio"; - reg = <0x508 0x4>, - <0x528 0x4>; - gpio-controller; - #gpio-cells = <2>; - - status = "disabled"; - }; - - gpio3: gpio-controller@50c { - compatible = "brcm,bcm6345-gpio"; - reg = <0x50c 0x4>, - <0x52c 0x4>; - gpio-controller; - #gpio-cells = <2>; - - status = "disabled"; - }; - - gpio4: gpio-controller@510 { - compatible = "brcm,bcm6345-gpio"; - reg = <0x510 0x4>, - <0x530 0x4>; - gpio-controller; - #gpio-cells = <2>; - - status = "disabled"; - }; - - gpio5: gpio-controller@514 { - compatible = "brcm,bcm6345-gpio"; - reg = <0x514 0x4>, - <0x534 0x4>; - gpio-controller; - #gpio-cells = <2>; - - status = "disabled"; - }; - - gpio6: gpio-controller@518 { - compatible = "brcm,bcm6345-gpio"; - reg = <0x518 0x4>, - <0x538 0x4>; - gpio-controller; - #gpio-cells = <2>; - - status = "disabled"; - }; - - gpio7: gpio-controller@51c { - compatible = "brcm,bcm6345-gpio"; - reg = <0x51c 0x4>, - <0x53c 0x4>; - gpio-controller; - #gpio-cells = <2>; - - status = "disabled"; - }; - - hsspi: spi-controller@1000 { - compatible = "brcm,bcm6328-hsspi"; - #address-cells = <1>; - #size-cells = <0>; - reg = <0x1000 0x600>; - clocks = <&hsspi_pll>, <&hsspi_pll>; - clock-names = "hsspi", "pll"; - spi-max-frequency = <100000000>; - num-cs = <8>; - - status = "disabled"; - }; - - nand: nand-controller@1800 { - compatible = "brcm,nand-bcm6858", - "brcm,brcmnand-v5.0", - "brcm,brcmnand"; - reg-names = "nand", "nand-int-base", "nand-cache"; - reg = <0x1800 0x180>, - <0x2000 0x10>, - <0x1c00 0x200>; - parameter-page-big-endian = <0>; - - status = "disabled"; - }; - }; -}; diff --git a/arch/arm/dts/bcm6878.dtsi b/arch/arm/dts/bcm6878.dtsi deleted file mode 100644 index 1e8b5fa96c25..000000000000 --- a/arch/arm/dts/bcm6878.dtsi +++ /dev/null @@ -1,111 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright 2022 Broadcom Ltd. - */ - -#include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/interrupt-controller/irq.h> - -/ { - compatible = "brcm,bcm6878", "brcm,bcmbca"; - #address-cells = <1>; - #size-cells = <1>; - - interrupt-parent = <&gic>; - - cpus { - #address-cells = <1>; - #size-cells = <0>; - - CA7_0: cpu@0 { - device_type = "cpu"; - compatible = "arm,cortex-a7"; - reg = <0x0>; - next-level-cache = <&L2_0>; - enable-method = "psci"; - }; - - CA7_1: cpu@1 { - device_type = "cpu"; - compatible = "arm,cortex-a7"; - reg = <0x1>; - next-level-cache = <&L2_0>; - enable-method = "psci"; - }; - - L2_0: l2-cache0 { - compatible = "cache"; - }; - }; - - timer { - compatible = "arm,armv7-timer"; - interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, - <GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, - <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, - <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>; - arm,cpu-registers-not-fw-configured; - }; - - pmu: pmu { - compatible = "arm,cortex-a7-pmu"; - interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>; - interrupt-affinity = <&CA7_0>, <&CA7_1>; - }; - - clocks: clocks { - periph_clk: periph-clk { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <200000000>; - }; - uart_clk: uart-clk { - compatible = "fixed-factor-clock"; - #clock-cells = <0>; - clocks = <&periph_clk>; - clock-div = <4>; - clock-mult = <1>; - }; - }; - - psci { - compatible = "arm,psci-0.2"; - method = "smc"; - }; - - axi@81000000 { - compatible = "simple-bus"; - #address-cells = <1>; - #size-cells = <1>; - ranges = <0 0x81000000 0x8000>; - - gic: interrupt-controller@1000 { - compatible = "arm,cortex-a7-gic"; - #interrupt-cells = <3>; - interrupt-controller; - reg = <0x1000 0x1000>, - <0x2000 0x2000>, - <0x4000 0x2000>, - <0x6000 0x2000>; - interrupts = <GIC_PPI 9 (GIC_CPU_MASK_SIMPLE(2) | - IRQ_TYPE_LEVEL_HIGH)>; - }; - }; - - bus@ff800000 { - compatible = "simple-bus"; - #address-cells = <1>; - #size-cells = <1>; - ranges = <0 0xff800000 0x800000>; - - uart0: serial@12000 { - compatible = "arm,pl011", "arm,primecell"; - reg = <0x12000 0x1000>; - interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&uart_clk>, <&uart_clk>; - clock-names = "uartclk", "apb_pclk"; - status = "disabled"; - }; - }; -}; diff --git a/arch/arm/dts/bcm947622.dts b/arch/arm/dts/bcm947622.dts deleted file mode 100644 index 6f083724ab8e..000000000000 --- a/arch/arm/dts/bcm947622.dts +++ /dev/null @@ -1,30 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright 2019 Broadcom Ltd. - */ - -/dts-v1/; - -#include "bcm47622.dtsi" - -/ { - model = "Broadcom BCM947622 Reference Board"; - compatible = "brcm,bcm947622", "brcm,bcm47622", "brcm,bcmbca"; - - aliases { - serial0 = &uart0; - }; - - chosen { - stdout-path = "serial0:115200n8"; - }; - - memory@0 { - device_type = "memory"; - reg = <0x0 0x08000000>; - }; -}; - -&uart0 { - status = "okay"; -}; diff --git a/arch/arm/dts/bcm94912.dts b/arch/arm/dts/bcm94912.dts deleted file mode 100644 index a3623e6f6919..000000000000 --- a/arch/arm/dts/bcm94912.dts +++ /dev/null @@ -1,30 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright 2022 Broadcom Ltd. - */ - -/dts-v1/; - -#include "bcm4912.dtsi" - -/ { - model = "Broadcom BCM94912 Reference Board"; - compatible = "brcm,bcm94912", "brcm,bcm4912", "brcm,bcmbca"; - - aliases { - serial0 = &uart0; - }; - - chosen { - stdout-path = "serial0:115200n8"; - }; - - memory@0 { - device_type = "memory"; - reg = <0x0 0x0 0x0 0x08000000>; - }; -}; - -&uart0 { - status = "okay"; -}; diff --git a/arch/arm/dts/bcm963146.dts b/arch/arm/dts/bcm963146.dts deleted file mode 100644 index e39f1e6d4774..000000000000 --- a/arch/arm/dts/bcm963146.dts +++ /dev/null @@ -1,30 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright 2022 Broadcom Ltd. - */ - -/dts-v1/; - -#include "bcm63146.dtsi" - -/ { - model = "Broadcom BCM963146 Reference Board"; - compatible = "brcm,bcm963146", "brcm,bcm63146", "brcm,bcmbca"; - - aliases { - serial0 = &uart0; - }; - - chosen { - stdout-path = "serial0:115200n8"; - }; - - memory@0 { - device_type = "memory"; - reg = <0x0 0x0 0x0 0x08000000>; - }; -}; - -&uart0 { - status = "okay"; -}; diff --git a/arch/arm/dts/bcm963158.dts b/arch/arm/dts/bcm963158.dts deleted file mode 100644 index eba07e0b1ca6..000000000000 --- a/arch/arm/dts/bcm963158.dts +++ /dev/null @@ -1,30 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright 2022 Broadcom Ltd. - */ - -/dts-v1/; - -#include "bcm63158.dtsi" - -/ { - model = "Broadcom BCM963158 Reference Board"; - compatible = "brcm,bcm963158", "brcm,bcm63158", "brcm,bcmbca"; - - aliases { - serial0 = &uart0; - }; - - chosen { - stdout-path = "serial0:115200n8"; - }; - - memory@0 { - device_type = "memory"; - reg = <0x0 0x0 0x0 0x08000000>; - }; -}; - -&uart0 { - status = "okay"; -}; diff --git a/arch/arm/dts/bcm963178.dts b/arch/arm/dts/bcm963178.dts deleted file mode 100644 index fa096e9cde23..000000000000 --- a/arch/arm/dts/bcm963178.dts +++ /dev/null @@ -1,30 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright 2019 Broadcom Ltd. - */ - -/dts-v1/; - -#include "bcm63178.dtsi" - -/ { - model = "Broadcom BCM963178 Reference Board"; - compatible = "brcm,bcm963178", "brcm,bcm63178", "brcm,bcmbca"; - - aliases { - serial0 = &uart0; - }; - - chosen { - stdout-path = "serial0:115200n8"; - }; - - memory@0 { - device_type = "memory"; - reg = <0x0 0x08000000>; - }; -}; - -&uart0 { - status = "okay"; -}; diff --git a/arch/arm/dts/bcm96756.dts b/arch/arm/dts/bcm96756.dts deleted file mode 100644 index 9a4a87ba9c8a..000000000000 --- a/arch/arm/dts/bcm96756.dts +++ /dev/null @@ -1,30 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright 2019 Broadcom Ltd. - */ - -/dts-v1/; - -#include "bcm6756.dtsi" - -/ { - model = "Broadcom BCM96756 Reference Board"; - compatible = "brcm,bcm96756", "brcm,bcm6756", "brcm,bcmbca"; - - aliases { - serial0 = &uart0; - }; - - chosen { - stdout-path = "serial0:115200n8"; - }; - - memory@0 { - device_type = "memory"; - reg = <0x0 0x08000000>; - }; -}; - -&uart0 { - status = "okay"; -}; diff --git a/arch/arm/dts/bcm96813.dts b/arch/arm/dts/bcm96813.dts deleted file mode 100644 index af17091ae764..000000000000 --- a/arch/arm/dts/bcm96813.dts +++ /dev/null @@ -1,30 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright 2022 Broadcom Ltd. - */ - -/dts-v1/; - -#include "bcm6813.dtsi" - -/ { - model = "Broadcom BCM96813 Reference Board"; - compatible = "brcm,bcm96813", "brcm,bcm6813", "brcm,bcmbca"; - - aliases { - serial0 = &uart0; - }; - - chosen { - stdout-path = "serial0:115200n8"; - }; - - memory@0 { - device_type = "memory"; - reg = <0x0 0x0 0x0 0x08000000>; - }; -}; - -&uart0 { - status = "okay"; -}; diff --git a/arch/arm/dts/bcm96855.dts b/arch/arm/dts/bcm96855.dts deleted file mode 100644 index e4e740c73e97..000000000000 --- a/arch/arm/dts/bcm96855.dts +++ /dev/null @@ -1,30 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright 2022 Broadcom Ltd. - */ - -/dts-v1/; - -#include "bcm6855.dtsi" - -/ { - model = "Broadcom BCM96855 Reference Board"; - compatible = "brcm,bcm96855", "brcm,bcm6855", "brcm,bcmbca"; - - aliases { - serial0 = &uart0; - }; - - chosen { - stdout-path = "serial0:115200n8"; - }; - - memory@0 { - device_type = "memory"; - reg = <0x0 0x08000000>; - }; -}; - -&uart0 { - status = "okay"; -}; diff --git a/arch/arm/dts/bcm96856.dts b/arch/arm/dts/bcm96856.dts deleted file mode 100644 index 032aeb75c983..000000000000 --- a/arch/arm/dts/bcm96856.dts +++ /dev/null @@ -1,30 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright 2022 Broadcom Ltd. - */ - -/dts-v1/; - -#include "bcm6856.dtsi" - -/ { - model = "Broadcom BCM96856 Reference Board"; - compatible = "brcm,bcm96856", "brcm,bcm6856", "brcm,bcmbca"; - - aliases { - serial0 = &uart0; - }; - - chosen { - stdout-path = "serial0:115200n8"; - }; - - memory@0 { - device_type = "memory"; - reg = <0x0 0x0 0x0 0x08000000>; - }; -}; - -&uart0 { - status = "okay"; -}; diff --git a/arch/arm/dts/bcm96858.dts b/arch/arm/dts/bcm96858.dts deleted file mode 100644 index 0cbf582f5d54..000000000000 --- a/arch/arm/dts/bcm96858.dts +++ /dev/null @@ -1,30 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright 2022 Broadcom Ltd. - */ - -/dts-v1/; - -#include "bcm6858.dtsi" - -/ { - model = "Broadcom BCM96858 Reference Board"; - compatible = "brcm,bcm96858", "brcm,bcm6858", "brcm,bcmbca"; - - aliases { - serial0 = &uart0; - }; - - chosen { - stdout-path = "serial0:115200n8"; - }; - - memory@0 { - device_type = "memory"; - reg = <0x0 0x0 0x0 0x08000000>; - }; -}; - -&uart0 { - status = "okay"; -}; diff --git a/arch/arm/dts/bcm96878.dts b/arch/arm/dts/bcm96878.dts deleted file mode 100644 index 8fbc175cb452..000000000000 --- a/arch/arm/dts/bcm96878.dts +++ /dev/null @@ -1,30 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright 2019 Broadcom Ltd. - */ - -/dts-v1/; - -#include "bcm6878.dtsi" - -/ { - model = "Broadcom BCM96878 Reference Board"; - compatible = "brcm,bcm96878", "brcm,bcm6878", "brcm,bcmbca"; - - aliases { - serial0 = &uart0; - }; - - chosen { - stdout-path = "serial0:115200n8"; - }; - - memory@0 { - device_type = "memory"; - reg = <0x0 0x08000000>; - }; -}; - -&uart0 { - status = "okay"; -}; diff --git a/arch/arm/mach-bcmbca/bcm47622/Kconfig b/arch/arm/mach-bcmbca/bcm47622/Kconfig index bce30892e35d..56ce280a1cde 100644 --- a/arch/arm/mach-bcmbca/bcm47622/Kconfig +++ b/arch/arm/mach-bcmbca/bcm47622/Kconfig @@ -8,6 +8,7 @@ if BCM47622 config TARGET_BCM947622 bool "Broadcom 47622 Reference Board" depends on ARCH_BCMBCA + imply OF_UPSTREAM
config SYS_SOC default "bcm47622" diff --git a/arch/arm/mach-bcmbca/bcm4912/Kconfig b/arch/arm/mach-bcmbca/bcm4912/Kconfig index b8c14d1dc1a1..9844ddeb8b8b 100644 --- a/arch/arm/mach-bcmbca/bcm4912/Kconfig +++ b/arch/arm/mach-bcmbca/bcm4912/Kconfig @@ -8,6 +8,7 @@ if BCM4912 config TARGET_BCM94912 bool "Broadcom 4912 Reference Board" depends on ARCH_BCMBCA + imply OF_UPSTREAM
config SYS_SOC default "bcm4912" diff --git a/arch/arm/mach-bcmbca/bcm63146/Kconfig b/arch/arm/mach-bcmbca/bcm63146/Kconfig index 690cbf1eb20a..7c26742e4742 100644 --- a/arch/arm/mach-bcmbca/bcm63146/Kconfig +++ b/arch/arm/mach-bcmbca/bcm63146/Kconfig @@ -8,6 +8,7 @@ if BCM63146 config TARGET_BCM963146 bool "Broadcom 63146 Reference Board" depends on ARCH_BCMBCA + imply OF_UPSTREAM
config SYS_SOC default "bcm63146" diff --git a/arch/arm/mach-bcmbca/bcm63158/Kconfig b/arch/arm/mach-bcmbca/bcm63158/Kconfig index b77444369ec9..6db7b36aa327 100644 --- a/arch/arm/mach-bcmbca/bcm63158/Kconfig +++ b/arch/arm/mach-bcmbca/bcm63158/Kconfig @@ -8,6 +8,7 @@ if BCM63158 config TARGET_BCM963158 bool "Broadcom 63158 Reference Board" depends on ARCH_BCMBCA + imply OF_UPSTREAM
config SYS_SOC default "bcm63158" diff --git a/arch/arm/mach-bcmbca/bcm63178/Kconfig b/arch/arm/mach-bcmbca/bcm63178/Kconfig index 73ac46284b2c..167acfff2c9d 100644 --- a/arch/arm/mach-bcmbca/bcm63178/Kconfig +++ b/arch/arm/mach-bcmbca/bcm63178/Kconfig @@ -8,6 +8,7 @@ if BCM63178 config TARGET_BCM963178 bool "Broadcom 63178 Reference Board" depends on ARCH_BCMBCA + imply OF_UPSTREAM
config SYS_SOC default "bcm63178" diff --git a/arch/arm/mach-bcmbca/bcm6756/Kconfig b/arch/arm/mach-bcmbca/bcm6756/Kconfig index c83dcd0f3e2b..bbaa45eaab0a 100644 --- a/arch/arm/mach-bcmbca/bcm6756/Kconfig +++ b/arch/arm/mach-bcmbca/bcm6756/Kconfig @@ -8,6 +8,7 @@ if BCM6756 config TARGET_BCM96756 bool "Broadcom 6756 Reference Board" depends on ARCH_BCMBCA + imply OF_UPSTREAM
config SYS_SOC default "bcm6756" diff --git a/arch/arm/mach-bcmbca/bcm6813/Kconfig b/arch/arm/mach-bcmbca/bcm6813/Kconfig index 25a4221bef9c..0cda69cb43ee 100644 --- a/arch/arm/mach-bcmbca/bcm6813/Kconfig +++ b/arch/arm/mach-bcmbca/bcm6813/Kconfig @@ -8,6 +8,7 @@ if BCM6813 config TARGET_BCM96813 bool "Broadcom 6813 Reference Board" depends on ARCH_BCMBCA + imply OF_UPSTREAM
config SYS_SOC default "bcm6813" diff --git a/arch/arm/mach-bcmbca/bcm6855/Kconfig b/arch/arm/mach-bcmbca/bcm6855/Kconfig index 78087c7dd59d..31eaaed7ca24 100644 --- a/arch/arm/mach-bcmbca/bcm6855/Kconfig +++ b/arch/arm/mach-bcmbca/bcm6855/Kconfig @@ -8,6 +8,7 @@ if BCM6855 config TARGET_BCM96855 bool "Broadcom 6855 Reference Board" depends on ARCH_BCMBCA + imply OF_UPSTREAM
config SYS_SOC default "bcm6855" diff --git a/arch/arm/mach-bcmbca/bcm6856/Kconfig b/arch/arm/mach-bcmbca/bcm6856/Kconfig index 6ac75cb84095..7b09a1577bb1 100644 --- a/arch/arm/mach-bcmbca/bcm6856/Kconfig +++ b/arch/arm/mach-bcmbca/bcm6856/Kconfig @@ -8,6 +8,7 @@ if BCM6856 config TARGET_BCM96856 bool "Broadcom 6856 Reference Board" depends on ARCH_BCMBCA + imply OF_UPSTREAM
config SYS_SOC default "bcm6856" diff --git a/arch/arm/mach-bcmbca/bcm6858/Kconfig b/arch/arm/mach-bcmbca/bcm6858/Kconfig index a6504bae1f18..d32107a17a89 100644 --- a/arch/arm/mach-bcmbca/bcm6858/Kconfig +++ b/arch/arm/mach-bcmbca/bcm6858/Kconfig @@ -8,6 +8,7 @@ if BCM6858 config TARGET_BCM96858 bool "Broadcom 6858 Reference Board" depends on ARCH_BCMBCA + imply OF_UPSTREAM
config SYS_SOC default "bcm6858" diff --git a/arch/arm/mach-bcmbca/bcm6878/Kconfig b/arch/arm/mach-bcmbca/bcm6878/Kconfig index 43f8942c9b1d..2365cfde6ec2 100644 --- a/arch/arm/mach-bcmbca/bcm6878/Kconfig +++ b/arch/arm/mach-bcmbca/bcm6878/Kconfig @@ -8,6 +8,7 @@ if BCM6878 config TARGET_BCM96878 bool "Broadcom 6878 Reference Board" depends on ARCH_BCMBCA + imply OF_UPSTREAM
config SYS_SOC default "bcm6878" diff --git a/configs/bcm947622_defconfig b/configs/bcm947622_defconfig index 71057f1dc042..cf0651c65023 100644 --- a/configs/bcm947622_defconfig +++ b/configs/bcm947622_defconfig @@ -8,7 +8,7 @@ CONFIG_TARGET_BCM947622=y CONFIG_NR_DRAM_BANKS=1 CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x2000000 -CONFIG_DEFAULT_DEVICE_TREE="bcm947622" +CONFIG_DEFAULT_DEVICE_TREE="broadcom/bcm947622" CONFIG_SYS_BOOTM_LEN=0x2000000 CONFIG_SYS_LOAD_ADDR=0x01000000 CONFIG_IDENT_STRING=" Broadcom BCM47622" @@ -16,6 +16,15 @@ CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_NAND=y CONFIG_CMD_CACHE=y +CONFIG_OF_CONTROL=y +CONFIG_OF_UPSTREAM=y CONFIG_OF_EMBED=y +CONFIG_DM=y CONFIG_CLK=y +CONFIG_MTD=y +CONFIG_DM_MTD=y +CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_BRCMNAND=y +CONFIG_NAND_BRCMNAND_BCMBCA=y diff --git a/configs/bcm94912_defconfig b/configs/bcm94912_defconfig index 5b6de30cd8b5..bce823b90418 100644 --- a/configs/bcm94912_defconfig +++ b/configs/bcm94912_defconfig @@ -9,13 +9,22 @@ CONFIG_TARGET_BCM94912=y CONFIG_NR_DRAM_BANKS=2 CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x2000000 -CONFIG_DEFAULT_DEVICE_TREE="bcm94912" +CONFIG_DEFAULT_DEVICE_TREE="broadcom/bcmbca/bcm94912" CONFIG_SYS_LOAD_ADDR=0x01000000 CONFIG_IDENT_STRING=" Broadcom BCM4912" CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_NAND=y CONFIG_CMD_CACHE=y +CONFIG_OF_CONTROL=y +CONFIG_OF_UPSTREAM=y CONFIG_OF_EMBED=y +CONFIG_DM=y CONFIG_CLK=y +CONFIG_MTD=y +CONFIG_DM_MTD=y +CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_BRCMNAND=y +CONFIG_NAND_BRCMNAND_BCMBCA=y diff --git a/configs/bcm963146_defconfig b/configs/bcm963146_defconfig index 5033b069d7d3..691d055e310c 100644 --- a/configs/bcm963146_defconfig +++ b/configs/bcm963146_defconfig @@ -9,13 +9,22 @@ CONFIG_TARGET_BCM963146=y CONFIG_NR_DRAM_BANKS=2 CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x2000000 -CONFIG_DEFAULT_DEVICE_TREE="bcm963146" +CONFIG_DEFAULT_DEVICE_TREE="broadcom/bcmbca/bcm963146" CONFIG_SYS_LOAD_ADDR=0x01000000 CONFIG_IDENT_STRING=" Broadcom BCM63146" CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_NAND=y CONFIG_CMD_CACHE=y +CONFIG_OF_CONTROL=y +CONFIG_OF_UPSTREAM=y CONFIG_OF_EMBED=y +CONFIG_DM=y CONFIG_CLK=y +CONFIG_MTD=y +CONFIG_DM_MTD=y +CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_BRCMNAND=y +CONFIG_NAND_BRCMNAND_BCMBCA=y diff --git a/configs/bcm963158_defconfig b/configs/bcm963158_defconfig index c3010d979085..6e4a85ec3a3c 100644 --- a/configs/bcm963158_defconfig +++ b/configs/bcm963158_defconfig @@ -9,13 +9,22 @@ CONFIG_TARGET_BCM963158=y CONFIG_NR_DRAM_BANKS=2 CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x2000000 -CONFIG_DEFAULT_DEVICE_TREE="bcm963158" +CONFIG_DEFAULT_DEVICE_TREE="broadcom/bcmbca/bcm963158" CONFIG_SYS_LOAD_ADDR=0x01000000 CONFIG_IDENT_STRING=" Broadcom BCM63158" CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_NAND=y CONFIG_CMD_CACHE=y +CONFIG_OF_CONTROL=y +CONFIG_OF_UPSTREAM=y CONFIG_OF_EMBED=y +CONFIG_DM=y CONFIG_CLK=y +CONFIG_MTD=y +CONFIG_DM_MTD=y +CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_BRCMNAND=y +CONFIG_NAND_BRCMNAND_BCMBCA=y diff --git a/configs/bcm963178_defconfig b/configs/bcm963178_defconfig index 1409febae14f..60a198719a35 100644 --- a/configs/bcm963178_defconfig +++ b/configs/bcm963178_defconfig @@ -9,7 +9,7 @@ CONFIG_TARGET_BCM963178=y CONFIG_NR_DRAM_BANKS=1 CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x2000000 -CONFIG_DEFAULT_DEVICE_TREE="bcm963178" +CONFIG_DEFAULT_DEVICE_TREE="broadcom/bcm963178" CONFIG_SYS_BOOTM_LEN=0x4000000 CONFIG_SYS_LOAD_ADDR=0x01000000 CONFIG_IDENT_STRING=" Broadcom BCM63178" @@ -17,6 +17,15 @@ CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_NAND=y CONFIG_CMD_CACHE=y +CONFIG_OF_CONTROL=y +CONFIG_OF_UPSTREAM=y CONFIG_OF_EMBED=y +CONFIG_DM=y CONFIG_CLK=y +CONFIG_MTD=y +CONFIG_DM_MTD=y +CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_BRCMNAND=y +CONFIG_NAND_BRCMNAND_BCMBCA=y diff --git a/configs/bcm96756_defconfig b/configs/bcm96756_defconfig index 96a9a311037a..4b1fa991a04d 100644 --- a/configs/bcm96756_defconfig +++ b/configs/bcm96756_defconfig @@ -9,7 +9,7 @@ CONFIG_TARGET_BCM96756=y CONFIG_NR_DRAM_BANKS=1 CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x2000000 -CONFIG_DEFAULT_DEVICE_TREE="bcm96756" +CONFIG_DEFAULT_DEVICE_TREE="broadcom/bcm96756" CONFIG_SYS_BOOTM_LEN=0x4000000 CONFIG_SYS_LOAD_ADDR=0x01000000 CONFIG_IDENT_STRING=" Broadcom BCM6756" @@ -17,6 +17,15 @@ CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_NAND=y CONFIG_CMD_CACHE=y +CONFIG_OF_CONTROL=y +CONFIG_OF_UPSTREAM=y CONFIG_OF_EMBED=y +CONFIG_DM=y CONFIG_CLK=y +CONFIG_MTD=y +CONFIG_DM_MTD=y +CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_BRCMNAND=y +CONFIG_NAND_BRCMNAND_BCMBCA=y diff --git a/configs/bcm96813_defconfig b/configs/bcm96813_defconfig index eadcb6374c64..553bdc148b28 100644 --- a/configs/bcm96813_defconfig +++ b/configs/bcm96813_defconfig @@ -9,13 +9,22 @@ CONFIG_TARGET_BCM96813=y CONFIG_NR_DRAM_BANKS=2 CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x2000000 -CONFIG_DEFAULT_DEVICE_TREE="bcm96813" +CONFIG_DEFAULT_DEVICE_TREE="broadcom/bcmbca/bcm96813" CONFIG_SYS_LOAD_ADDR=0x01000000 CONFIG_IDENT_STRING=" Broadcom BCM6813" CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_NAND=y CONFIG_CMD_CACHE=y +CONFIG_OF_CONTROL=y +CONFIG_OF_UPSTREAM=y CONFIG_OF_EMBED=y +CONFIG_DM=y CONFIG_CLK=y +CONFIG_MTD=y +CONFIG_DM_MTD=y +CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_BRCMNAND=y +CONFIG_NAND_BRCMNAND_BCMBCA=y diff --git a/configs/bcm96855_defconfig b/configs/bcm96855_defconfig index 6ffae45faa2d..ff6dff0fca63 100644 --- a/configs/bcm96855_defconfig +++ b/configs/bcm96855_defconfig @@ -9,7 +9,7 @@ CONFIG_TARGET_BCM96855=y CONFIG_NR_DRAM_BANKS=1 CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x2000000 -CONFIG_DEFAULT_DEVICE_TREE="bcm96855" +CONFIG_DEFAULT_DEVICE_TREE="broadcom/bcm96855" CONFIG_SYS_BOOTM_LEN=0x4000000 CONFIG_SYS_LOAD_ADDR=0x01000000 CONFIG_IDENT_STRING=" Broadcom BCM6855" @@ -17,6 +17,15 @@ CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_NAND=y CONFIG_CMD_CACHE=y +CONFIG_OF_CONTROL=y +CONFIG_OF_UPSTREAM=y CONFIG_OF_EMBED=y +CONFIG_DM=y CONFIG_CLK=y +CONFIG_MTD=y +CONFIG_DM_MTD=y +CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_BRCMNAND=y +CONFIG_NAND_BRCMNAND_BCMBCA=y diff --git a/configs/bcm96856_defconfig b/configs/bcm96856_defconfig index f926b3770f0c..7c6fba29abf6 100644 --- a/configs/bcm96856_defconfig +++ b/configs/bcm96856_defconfig @@ -9,13 +9,22 @@ CONFIG_TARGET_BCM96856=y CONFIG_NR_DRAM_BANKS=2 CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x2000000 -CONFIG_DEFAULT_DEVICE_TREE="bcm96856" +CONFIG_DEFAULT_DEVICE_TREE="broadcom/bcmbca/bcm96856" CONFIG_SYS_LOAD_ADDR=0x01000000 CONFIG_IDENT_STRING=" Broadcom BCM6856" CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_NAND=y CONFIG_CMD_CACHE=y +CONFIG_OF_CONTROL=y +CONFIG_OF_UPSTREAM=y CONFIG_OF_EMBED=y +CONFIG_DM=y CONFIG_CLK=y +CONFIG_MTD=y +CONFIG_DM_MTD=y +CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_BRCMNAND=y +CONFIG_NAND_BRCMNAND_BCMBCA=y diff --git a/configs/bcm96858_defconfig b/configs/bcm96858_defconfig index cc6069fe794f..3e11b4012601 100644 --- a/configs/bcm96858_defconfig +++ b/configs/bcm96858_defconfig @@ -9,13 +9,22 @@ CONFIG_TARGET_BCM96858=y CONFIG_NR_DRAM_BANKS=2 CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x2000000 -CONFIG_DEFAULT_DEVICE_TREE="bcm96858" +CONFIG_DEFAULT_DEVICE_TREE="broadcom/bcmbca/bcm96858" CONFIG_SYS_LOAD_ADDR=0x01000000 CONFIG_IDENT_STRING=" Broadcom BCM6858" CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_NAND=y CONFIG_CMD_CACHE=y +CONFIG_OF_CONTROL=y +CONFIG_OF_UPSTREAM=y CONFIG_OF_EMBED=y +CONFIG_DM=y CONFIG_CLK=y +CONFIG_MTD=y +CONFIG_DM_MTD=y +CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_BRCMNAND=y +CONFIG_NAND_BRCMNAND_BCMBCA=y diff --git a/configs/bcm96878_defconfig b/configs/bcm96878_defconfig index 7d1cd6c944f9..52c869aab9b6 100644 --- a/configs/bcm96878_defconfig +++ b/configs/bcm96878_defconfig @@ -9,7 +9,7 @@ CONFIG_TARGET_BCM96878=y CONFIG_NR_DRAM_BANKS=1 CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x2000000 -CONFIG_DEFAULT_DEVICE_TREE="bcm96878" +CONFIG_DEFAULT_DEVICE_TREE="broadcom/bcm96878" CONFIG_SYS_BOOTM_LEN=0x4000000 CONFIG_SYS_LOAD_ADDR=0x01000000 CONFIG_IDENT_STRING=" Broadcom BCM6878" @@ -17,6 +17,15 @@ CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_NAND=y CONFIG_CMD_CACHE=y +CONFIG_OF_CONTROL=y +CONFIG_OF_UPSTREAM=y CONFIG_OF_EMBED=y +CONFIG_DM=y CONFIG_CLK=y +CONFIG_MTD=y +CONFIG_DM_MTD=y +CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_BRCMNAND=y +CONFIG_NAND_BRCMNAND_BCMBCA=y
Set parameter_page_big_endian to zero for bcmbca
Signed-off-by: david regan dregan@broadcom.com Reviewed-by: William Zhang william.zhang@broadcom.com Reviewed-by: Anand Gore anand.gore@broadcom.com --- drivers/mtd/nand/raw/brcmnand/brcmnand.c | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/drivers/mtd/nand/raw/brcmnand/brcmnand.c b/drivers/mtd/nand/raw/brcmnand/brcmnand.c index 749553c9df90..7fd9e1855d1e 100644 --- a/drivers/mtd/nand/raw/brcmnand/brcmnand.c +++ b/drivers/mtd/nand/raw/brcmnand/brcmnand.c @@ -2793,9 +2793,17 @@ int brcmnand_probe(struct udevice *dev, struct brcmnand_soc *soc) nand_hw_control_init(&ctrl->controller); INIT_LIST_HEAD(&ctrl->host_list);
+#ifdef CONFIG_NAND_BRCMNAND_BCMBCA + /* + * BCMBCA platform does not use non-linux parameter-page-big-endian dts property, + * param page data is little endian + */ + ctrl->parameter_page_big_endian = 0; +#else /* Is parameter page in big endian ? */ ctrl->parameter_page_big_endian = dev_read_u32_default(dev, "parameter-page-big-endian", 1); +#endif
/* NAND register range */ #ifndef __UBOOT__
Reviewed-by: Linus Walleij linus.walleij@linaro.org
Yours, Linus Walleij
Update log level messages so that more critical messages can be logged to console and help the troubleshooting with field devices.
This is a port of the upstream Linux patch to U-Boot.
https://lore.kernel.org/linux-mtd/20240223034758.13753-4-william.zhang@broad...
Signed-off-by: david regan dregan@broadcom.com Reviewed-by: Linus Walleij linus.walleij@linaro.org Reviewed-by: William Zhang william.zhang@broadcom.com Reviewed-by: Anand Gore anand.gore@broadcom.com --- drivers/mtd/nand/raw/brcmnand/brcmnand.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/mtd/nand/raw/brcmnand/brcmnand.c b/drivers/mtd/nand/raw/brcmnand/brcmnand.c index 7fd9e1855d1e..ef492e6db320 100644 --- a/drivers/mtd/nand/raw/brcmnand/brcmnand.c +++ b/drivers/mtd/nand/raw/brcmnand/brcmnand.c @@ -1071,8 +1071,8 @@ static int bcmnand_ctrl_poll_status(struct brcmnand_controller *ctrl, if ((val & mask) == expected_val) return 0;
- dev_warn(ctrl->dev, "timeout on status poll (expected %x got %x)\n", - expected_val, val & mask); + dev_err(ctrl->dev, "timeout on status poll (expected %x got %x)\n", + expected_val, val & mask);
return -ETIMEDOUT; } @@ -2032,7 +2032,7 @@ try_dmaread: return err; }
- dev_dbg(ctrl->dev, "uncorrectable error at 0x%llx\n", + dev_err(ctrl->dev, "uncorrectable error at 0x%llx\n", (unsigned long long)err_addr); mtd->ecc_stats.failed++; /* NAND layer expects zero on ECC errors */
HI
These are ports of upstream Linux patches to U-Boot.
Remove device specific nand driver files as they are now replaced by a common driver bcmbca_nand.c
Make use of OF_UPSTREAM which uses Linux dts.
Implement a minimal set of defconfig options to enable basic NAND functionality. Tested on: 47622 63146 63158 63178 6813
Set parameter_page_big_endian to zero for bcmbca.
I get all the review I need so I will send on CI today and send on next merge request
Michael
Changes in v2:
- Set parameter_page_big_endian to zero for bcmbca instead of using an extra bit of endian translation code.
david regan (4): mtd: nand: brcmnand: remove device specific nand driver files arm: dts: Use upstream dts mtd: rawnand: brcmnand: Default bcmbca parameter_page_big_endian to zero mtd: rawnand: brcmnand: update log level messages
arch/arm/dts/bcm47622.dtsi | 126 -------- arch/arm/dts/bcm4912.dtsi | 128 -------- arch/arm/dts/bcm63146.dtsi | 110 ------- arch/arm/dts/bcm63158.dtsi | 278 ------------------ arch/arm/dts/bcm63178.dtsi | 120 -------- arch/arm/dts/bcm6756.dtsi | 130 -------- arch/arm/dts/bcm6813.dtsi | 128 -------- arch/arm/dts/bcm6855.dtsi | 257 ---------------- arch/arm/dts/bcm6856.dtsi | 253 ---------------- arch/arm/dts/bcm6858.dtsi | 272 ----------------- arch/arm/dts/bcm6878.dtsi | 111 ------- arch/arm/dts/bcm947622.dts | 30 -- arch/arm/dts/bcm94912.dts | 30 -- arch/arm/dts/bcm963146.dts | 30 -- arch/arm/dts/bcm963158.dts | 30 -- arch/arm/dts/bcm963178.dts | 30 -- arch/arm/dts/bcm96756.dts | 30 -- arch/arm/dts/bcm96813.dts | 30 -- arch/arm/dts/bcm96855.dts | 30 -- arch/arm/dts/bcm96856.dts | 30 -- arch/arm/dts/bcm96858.dts | 30 -- arch/arm/dts/bcm96878.dts | 30 -- arch/arm/mach-bcmbca/bcm47622/Kconfig | 1 + arch/arm/mach-bcmbca/bcm4912/Kconfig | 1 + arch/arm/mach-bcmbca/bcm63146/Kconfig | 1 + arch/arm/mach-bcmbca/bcm63158/Kconfig | 1 + arch/arm/mach-bcmbca/bcm63178/Kconfig | 1 + arch/arm/mach-bcmbca/bcm6756/Kconfig | 1 + arch/arm/mach-bcmbca/bcm6813/Kconfig | 1 + arch/arm/mach-bcmbca/bcm6855/Kconfig | 1 + arch/arm/mach-bcmbca/bcm6856/Kconfig | 1 + arch/arm/mach-bcmbca/bcm6858/Kconfig | 1 + arch/arm/mach-bcmbca/bcm6878/Kconfig | 1 + configs/bcm947622_defconfig | 11 +- configs/bcm94912_defconfig | 11 +- configs/bcm963146_defconfig | 11 +- configs/bcm963158_defconfig | 11 +- configs/bcm963178_defconfig | 11 +- configs/bcm96756_defconfig | 11 +- configs/bcm96813_defconfig | 11 +- configs/bcm96855_defconfig | 11 +- configs/bcm96856_defconfig | 11 +- configs/bcm96858_defconfig | 11 +- configs/bcm96878_defconfig | 11 +- drivers/mtd/nand/raw/Kconfig | 24 -- drivers/mtd/nand/raw/brcmnand/Makefile | 4 - drivers/mtd/nand/raw/brcmnand/bcm63158_nand.c | 125 -------- drivers/mtd/nand/raw/brcmnand/bcm6753_nand.c | 123 -------- drivers/mtd/nand/raw/brcmnand/bcm68360_nand.c | 124 -------- drivers/mtd/nand/raw/brcmnand/bcm6858_nand.c | 125 -------- drivers/mtd/nand/raw/brcmnand/brcmnand.c | 14 +- 51 files changed, 132 insertions(+), 2782 deletions(-) delete mode 100644 arch/arm/dts/bcm47622.dtsi delete mode 100644 arch/arm/dts/bcm4912.dtsi delete mode 100644 arch/arm/dts/bcm63146.dtsi delete mode 100644 arch/arm/dts/bcm63158.dtsi delete mode 100644 arch/arm/dts/bcm63178.dtsi delete mode 100644 arch/arm/dts/bcm6756.dtsi delete mode 100644 arch/arm/dts/bcm6813.dtsi delete mode 100644 arch/arm/dts/bcm6855.dtsi delete mode 100644 arch/arm/dts/bcm6856.dtsi delete mode 100644 arch/arm/dts/bcm6858.dtsi delete mode 100644 arch/arm/dts/bcm6878.dtsi delete mode 100644 arch/arm/dts/bcm947622.dts delete mode 100644 arch/arm/dts/bcm94912.dts delete mode 100644 arch/arm/dts/bcm963146.dts delete mode 100644 arch/arm/dts/bcm963158.dts delete mode 100644 arch/arm/dts/bcm963178.dts delete mode 100644 arch/arm/dts/bcm96756.dts delete mode 100644 arch/arm/dts/bcm96813.dts delete mode 100644 arch/arm/dts/bcm96855.dts delete mode 100644 arch/arm/dts/bcm96856.dts delete mode 100644 arch/arm/dts/bcm96858.dts delete mode 100644 arch/arm/dts/bcm96878.dts delete mode 100644 drivers/mtd/nand/raw/brcmnand/bcm63158_nand.c delete mode 100644 drivers/mtd/nand/raw/brcmnand/bcm6753_nand.c delete mode 100644 drivers/mtd/nand/raw/brcmnand/bcm68360_nand.c delete mode 100644 drivers/mtd/nand/raw/brcmnand/bcm6858_nand.c
-- 2.37.3
david regan
Linus Walleij
Michael Nazzareno Trimarchi
