[U-Boot] Using MinGW gcc cross-compiling host tools for Windows broken
Hi Peter,
I noticed that you were the first one that added support to build native Win32 tools using MinGW GCC via:
commit 2f8d396b9302eddcd8d552648e101a46b7a80acd Author: Peter Tyser ptyser@xes-inc.com Date: Fri Mar 13 18:54:51 2009 -0500
Add support for building native win32 tools
Add support for compiling the host tools in the tools directory using the MinGW toolchain. This produces executables which can be used on standard Windows computers without requiring cygwin.
One must specify the MinGW compiler and strip utilities as if they were the host toolchain in order to build win32 executables, eg:
make HOSTCC=i586-mingw32msvc-gcc HOSTSTRIP=i586-mingw32msvc-strip tools
Signed-off-by: Peter Tyser ptyser@xes-inc.com
There are also several follow-up commits that fixed the build errors from time to time:
commit 8b6a4952e6064dc558cb7d5d375990b17491f26f Author: Vladimir Yakovlev nagos@inbox.ru Date: Sat Jul 7 10:05:06 2012 +0000
tools: Fix mingw tools build
mkenvimage does not build due to missed os_support.o and unsupported file modes S_IRGRP S_IWGRP. Tested with mingw 4.2.1 on ubuntu 12.04.
Signed-off-by: Vladimir Yakovlev nagos@inbox.ru
commit b050c72d52c4e30d5b978ab6758f8dcdbe5c690c Author: Mike Frysinger vapier@gentoo.org Date: Tue Apr 20 05:49:30 2010 -0400
compiler.h: add uint typedef
Recent crc changes started using the "uint" type in headers that are used on the build system. This subsequently broke mingw targets as they do not provide such a type. So add this basic typedef to compiler.h so that we do not have to worry about this breaking again in the future.
Signed-off-by: Mike Frysinger vapier@gentoo.org
commit faf36c1437c95e4a86835633d9801c5f6396a3c7 Author: Remy Bohmer linux@bohmer.net Date: Wed Oct 28 22:13:36 2009 +0100
mkimage does not build due to missing strtok_r() and getline() implementation
Signed-off-by: Remy Bohmer linux@bohmer.net
Today I tried to build the Windows tools by following the README, and got build errors.
$ make HOSTCC=/usr/bin/x86_64-w64-mingw32-gcc tools
note: I am running this from Linux. It's not clear to me whether we should run this from Windows natively or cross-compile on Linux.
It seems that this MinGW Windows build has been broken for quite a long time.
Will you address this? Thanks!
Regards, Bin
Hi Bin,
----- Original Message -----
From: "Bin Meng" bmeng.cn@gmail.com To: "ptyser" ptyser@xes-inc.com, "Vladimir Yakovlev" nagos@inbox.ru, "Mike Frysinger" vapier@gentoo.org, "Remy Bohmer" linux@bohmer.net, "U-Boot Mailing List" u-boot@lists.denx.de Cc: "Tom Rini" trini@konsulko.com Sent: Monday, October 14, 2019 4:46:16 AM Subject: Using MinGW gcc cross-compiling host tools for Windows broken
Hi Peter,
It was intended to be cross-compiled on a Linux box.
I had a quick look at getting compilation working, and my vote is to remove support for the MinGW compilation. - It can't be too popular since the compilation issues haven't been flagged for a long time.
- The motivation 10 years ago was to support customers that used Windows as their OS development environment, mostly for VxWorks. Development under a 100% Windows environment seems a lot less common nowadays. Virtual machines and Windows Subsystem for Linux also make it much easier to run Linux apps in a Windows development environment. My company hasn't been distributing the MinGW binary for a number of years now as a data point.
- The feature set of some of the U-Boot tools has increased quite a bit which makes it non-trivial to support with MinGW. For example mkimage links with libssl and libcrypto.
I'm guessing more duct tape on the make system would be needed to get MinGW working, and my thought is that ugliness isn't worth the benefit anymore.
I'm happy to gin up a patch if others agree and think removing MinGW support makes sense.
Regards, Peter
Hi Peter,
On Tue, Oct 15, 2019 at 10:44 AM Peter Tyser ptyser@xes-inc.com wrote:
Hi Bin,
Hi Peter,
Thanks for looking at this.
Ah, I was going to investigate building a complete Windows U-Boot host tools for VxWorks as well :-)
The reason I was looking at MinGW first is because I think we can benefit from GitLab-CI to cross-build Windows host tools for us to make sure it won't be broken any more in the future.
I agree. Let's drop the support. I will have to seek for other solutions.
Regards, Bin
I had used native mkenvimage for board deployment, but since it was replaced by python script. We had some bugs with cross compiled tools, which was not present in native linux tools.
Python script like this to make unique mac addresses.
ENV_SIZE = 131072 d = env_template % mac_address d = d.replace("\n", "\0") for i in range(ENV_SIZE - len(d) - 4 - 1): d += "\xff" crc = binascii.crc32(d) % (1<<32) f = open("out.env", "wb+") crc_buf = struct.pack("I", crc) f.write(crc_buf) f.write("\x01") f.write(d) f.close()
вт, 15 окт. 2019 г. в 10:54, Bin Meng bmeng.cn@gmail.com:
Hi Peter,
Hi Bin,
Bohmer" linux@bohmer.net, "U-Boot Mailing List" <
u-boot@lists.denx.de>
Hi Peter,
using
tools
are used
do not
that we
long time.
remove
as
a
machines
apps
distributing
links
Regards, Bin
Bin Meng
Peter Tyser
Vladimir Yakovlev
