[U-Boot] [PATCH] thermal: imx_thermal: increase critical temperature threshold
The CPU temperature grade from OTP is now used to define the critical threshold at which point we busyloop until we are below, however this threshold is still too low.
Instead of 20C below the max CPU temperature, change it to 5C defined now by TEMPERATURE_HOT_DETLA for clarity. Rename 'passive' to 'critical' as that better defines our use case here. Additionally change the output of the busyloop message to show the max CPU temperature as well as current.
Before: CPU Temperature is 101 C, too hot to boot, waiting... CPU Temperature is 101 C, too hot to boot, waiting...
After: CPU Temperature (101C) too close to max (105C) waiting... CPU Temperature (101C) too close to max (105C) waiting...
Cc: Stefan Roese sr@denx.de Cc: Eric Nelson eric.nelson@boundarydevices.com Cc: Heiko Schocher hs@denx.de Cc: Nikita Kiryanov nikita@compulab.co.il Cc: Jon Nettleton jon.nettleton@gmail.com Cc: Jason Liu r64343@freescale.com Cc: Ye Li b37916@freescale.com Cc: Fabio Estevam fabio.estevam@freescale.com Cc: Christian Gmeiner christian.gmeiner@gmail.com Cc: Markus Niebel Markus.Niebel@tq-group.com Cc: Peng Fan b51431@freescale.com Signed-off-by: Tim Harvey tharvey@gateworks.com --- drivers/thermal/imx_thermal.c | 15 +++++++++------ 1 file changed, 9 insertions(+), 6 deletions(-)
diff --git a/drivers/thermal/imx_thermal.c b/drivers/thermal/imx_thermal.c index b5dab63..0d893c9 100644 --- a/drivers/thermal/imx_thermal.c +++ b/drivers/thermal/imx_thermal.c @@ -19,6 +19,8 @@ #include <thermal.h> #include <imx_thermal.h>
+/* board will busyloop until this many degrees C below CPU max temperature */ +#define TEMPERATURE_HOT_DELTA 5 /* CPU maxT - 5C */ #define FACTOR0 10000000 #define FACTOR1 15976 #define FACTOR2 4297157 @@ -34,7 +36,7 @@
struct thermal_data { unsigned int fuse; - int passive; + int critical; int minc; int maxc; }; @@ -129,9 +131,10 @@ int imx_thermal_get_temp(struct udevice *dev, int *temp)
cpu_tmp = read_cpu_temperature(dev); while (cpu_tmp > priv->minc && cpu_tmp < priv->maxc) { - if (cpu_tmp >= priv->passive) { - printf("CPU Temperature is %d C, too hot to boot, waiting...\n", - cpu_tmp); + if (cpu_tmp >= priv->critical) { + printf("CPU Temperature (%dC) too close to max (%dC)", + cpu_tmp, priv->maxc); + puts(" waiting...\n"); udelay(5000000); cpu_tmp = read_cpu_temperature(dev); } else { @@ -164,9 +167,9 @@ static int imx_thermal_probe(struct udevice *dev) return -EPERM; }
- /* set passive cooling temp to max - 20C */ + /* set critical cooling temp */ get_cpu_temp_grade(&priv->minc, &priv->maxc); - priv->passive = priv->maxc - 20; + priv->critical = priv->maxc - TEMPERATURE_HOT_DELTA; priv->fuse = fuse;
enable_thermal_clk();
________________________________________ From: Tim Harvey tharvey@gateworks.com Sent: Thursday, May 21, 2015 11:40 PM To: Stefano Babic Cc: u-boot@lists.denx.de; Stefan Roese; Eric Nelson; Heiko Schocher; Nikita Kiryanov; Jon Nettleton; Liu Hui-R64343; Li Ye-B37916; Estevam Fabio-R49496; Christian Gmeiner; Markus Niebel; Fan Peng-B51431 Subject: [U-Boot] [PATCH] thermal: imx_thermal: increase critical temperature threshold
Looks good to me, thus:
Acked-by: Jason Liu r64343@freescale.com
Jason Liu
enable_thermal_clk(); -- 1.9.1
- int passive;
- int critical; int minc; int maxc;
cpu_tmp);
} else {puts(" waiting...\n"); udelay(5000000); cpu_tmp = read_cpu_temperature(dev);
- /* set critical cooling temp */ get_cpu_temp_grade(&priv->minc, &priv->maxc);
Applied to u-boot-imx, thanks!
Best regards, Stefano Babic
Liu Jason
Stefano Babic
Tim Harvey
