[U-Boot] [PATCH v2] armv8/ls2080a: configure PMU's PCTBENR to enable WDT
The SP805-WDT module on LS2080A and LS2085A, requires configuration of PMU's PCTBENR register to enable watchdog counter decrement and reset signal generation. In order not to affect the sp805wdt driver frame, we enable the watchdog clk in advance.
Signed-off-by: Yunhui Cui yunhui.cui@nxp.com --- arch/arm/cpu/armv8/fsl-layerscape/soc.c | 17 +++++++++++++++++ arch/arm/include/asm/arch-fsl-layerscape/config.h | 4 ++++ arch/arm/include/asm/arch-fsl-layerscape/soc.h | 1 + board/freescale/ls2080aqds/ls2080aqds.c | 2 ++ board/freescale/ls2080ardb/ls2080ardb.c | 2 ++ 5 files changed, 26 insertions(+)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/soc.c b/arch/arm/cpu/armv8/fsl-layerscape/soc.c index a76447e..e6f3566 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/soc.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/soc.c @@ -17,6 +17,23 @@ #endif
DECLARE_GLOBAL_DATA_PTR; +#if defined(CONFIG_LS2080A) || defined(CONFIG_LS2085A) +/* + * There are eight SP805 watchdog units on ls2080a/ls2085a,So + * Set PMU-Physical Core Time Base Enable Register (PCTBENR) + * low eight bits to enable clocks to eight Cortext-A57 cores + * timebase, which allows the WDT counter to decrement and raise + * a reset request (if configured in the WDTCONTROL register). + */ +void enable_watchdog_clk(void) +{ + u32 pmu_val; + + pmu_val = *(u32 *)(FSL_PMU_REG_BASE + FSL_PMU_PCTBENR_OFFSET); + *(u32 *)(FSL_PMU_REG_BASE + FSL_PMU_PCTBENR_OFFSET) = pmu_val | 0xff; +} +#endif +
#if defined(CONFIG_LS2080A) || defined(CONFIG_LS2085A) /* diff --git a/arch/arm/include/asm/arch-fsl-layerscape/config.h b/arch/arm/include/asm/arch-fsl-layerscape/config.h index ceefe43..b9656d7 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/config.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/config.h @@ -148,6 +148,10 @@ #define CONFIG_ARM_ERRATA_829520 #define CONFIG_ARM_ERRATA_833471
+/* PMU-Physical Core Time Base Enable Register */ +#define FSL_PMU_REG_BASE 0x1E30000 +#define FSL_PMU_PCTBENR_OFFSET 0x8A0 + #elif defined(CONFIG_LS1043A) #define CONFIG_MAX_CPUS 4 #define CONFIG_SYS_CACHELINE_SIZE 64 diff --git a/arch/arm/include/asm/arch-fsl-layerscape/soc.h b/arch/arm/include/asm/arch-fsl-layerscape/soc.h index 56989e1..32c9185 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/soc.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/soc.h @@ -91,6 +91,7 @@ void fsl_lsch2_early_init_f(void); #endif
void cpu_name(char *name); +void enable_watchdog_clk(void); #ifdef CONFIG_SYS_FSL_ERRATUM_A009635 void erratum_a009635(void); #endif diff --git a/board/freescale/ls2080aqds/ls2080aqds.c b/board/freescale/ls2080aqds/ls2080aqds.c index e1a521d..8ebc96a 100644 --- a/board/freescale/ls2080aqds/ls2080aqds.c +++ b/board/freescale/ls2080aqds/ls2080aqds.c @@ -213,6 +213,8 @@ int board_init(void) select_i2c_ch_pca9547(I2C_MUX_CH_DEFAULT); rtc_enable_32khz_output();
+ enable_watchdog_clk(); + return 0; }
diff --git a/board/freescale/ls2080ardb/ls2080ardb.c b/board/freescale/ls2080ardb/ls2080ardb.c index 8201048..ad8324a 100644 --- a/board/freescale/ls2080ardb/ls2080ardb.c +++ b/board/freescale/ls2080ardb/ls2080ardb.c @@ -181,6 +181,8 @@ int board_init(void) /* invert AQR405 IRQ pins polarity */ out_le32(irq_ccsr + IRQCR_OFFSET / 4, AQR405_IRQ_MASK);
Yunhui Cui
