[PATCH 0/3] phy: sun4i-usb: Support VBUS detection via power supply
This converts a hack (a virtual GPIO pin) to less of a hack (not-really a regulator), but at least it now supports the device tree. This series adds the consumer side. The new code won't do anything useful until the regulator driver is merged (which depends on the DM_PMIC driver), but it shouldn't hurt anything either.
Samuel Holland (3): phy: sun4i-usb: Remove a couple of debug messages phy: sun4i-usb: Refactor VBUS detection to match Linux phy: sun4i-usb: Support VBUS detection via power supply
drivers/phy/allwinner/Kconfig | 1 + drivers/phy/allwinner/phy-sun4i-usb.c | 34 ++++++++++++++------------- 2 files changed, 19 insertions(+), 16 deletions(-)
Both of these messages log the GPIO number of the ID detection GPIO, which is not terribly useful, especially in the VBUS detection function.
Signed-off-by: Samuel Holland samuel@sholland.org ---
drivers/phy/allwinner/phy-sun4i-usb.c | 4 ---- 1 file changed, 4 deletions(-)
diff --git a/drivers/phy/allwinner/phy-sun4i-usb.c b/drivers/phy/allwinner/phy-sun4i-usb.c index 82713b83815..5302b809ee6 100644 --- a/drivers/phy/allwinner/phy-sun4i-usb.c +++ b/drivers/phy/allwinner/phy-sun4i-usb.c @@ -393,8 +393,6 @@ int sun4i_usb_phy_vbus_detect(struct phy *phy) struct sun4i_usb_phy_plat *usb_phy = &data->usb_phy[phy->id]; int err, retries = 3;
- debug("%s: id_det = %d\n", __func__, usb_phy->gpio_id_det); - if (usb_phy->gpio_vbus_det < 0) return usb_phy->gpio_vbus_det;
@@ -417,8 +415,6 @@ int sun4i_usb_phy_id_detect(struct phy *phy) struct sun4i_usb_phy_data *data = dev_get_priv(phy->dev); struct sun4i_usb_phy_plat *usb_phy = &data->usb_phy[phy->id];
- debug("%s: id_det = %d\n", __func__, usb_phy->gpio_id_det); - if (usb_phy->gpio_id_det < 0) return usb_phy->gpio_id_det;
Reviewed-by: Andre Przywara andre.przywara@arm.com
Cheers, Andre
The Linux driver checks the VBUS detection GPIO first; then VBUS power supply; then finally assumes VBUS is present. When adding VBUS power supply support, we want to match that order, so we get the same behavior in case both a GPIO and a power supply are provided in the device tree.
So refactor the function a bit to remove the early return, and use the same "assume VBUS is present" final fallback.
drivers/phy/allwinner/phy-sun4i-usb.c | 25 ++++++++++++------------- 1 file changed, 12 insertions(+), 13 deletions(-)
diff --git a/drivers/phy/allwinner/phy-sun4i-usb.c b/drivers/phy/allwinner/phy-sun4i-usb.c index 5302b809ee6..827ecd70f27 100644 --- a/drivers/phy/allwinner/phy-sun4i-usb.c +++ b/drivers/phy/allwinner/phy-sun4i-usb.c @@ -391,20 +391,19 @@ int sun4i_usb_phy_vbus_detect(struct phy *phy) { struct sun4i_usb_phy_data *data = dev_get_priv(phy->dev); struct sun4i_usb_phy_plat *usb_phy = &data->usb_phy[phy->id]; - int err, retries = 3; - - if (usb_phy->gpio_vbus_det < 0) - return usb_phy->gpio_vbus_det; - - err = gpio_get_value(usb_phy->gpio_vbus_det); - /* - * Vbus may have been provided by the board and just been turned of - * some milliseconds ago on reset, what we're measuring then is a - * residual charge on Vbus, sleep a bit and try again. - */ - while (err > 0 && retries--) { - mdelay(100); + int err = 1, retries = 3; + + if (usb_phy->gpio_vbus_det >= 0) { err = gpio_get_value(usb_phy->gpio_vbus_det); + /* + * Vbus may have been provided by the board and just turned off + * some milliseconds ago on reset. What we're measuring then is + * a residual charge on Vbus. Sleep a bit and try again. + */ + while (err > 0 && retries--) { + mdelay(100); + err = gpio_get_value(usb_phy->gpio_vbus_det); + } }
return err;
Let's see if testing reveals any subtle issues ;-)
Acked-by: Andre Przywara andre.przywara@arm.com
Cheers, Andre
mdelay(100);
mdelay(100);
return err;
The device tree binding provides for getting VBUS state from a device referenced by phandle, as an optional alternative to using a GPIO. In U-Boot, where there is no power supply class, this VBUS detection will be implemented using a regulator device and its get_enable method. Let's hook this up to the PHY driver.
drivers/phy/allwinner/Kconfig | 1 + drivers/phy/allwinner/phy-sun4i-usb.c | 7 +++++++ 2 files changed, 8 insertions(+)
diff --git a/drivers/phy/allwinner/Kconfig b/drivers/phy/allwinner/Kconfig index dba3bae61c4..aa9d0e7e6a5 100644 --- a/drivers/phy/allwinner/Kconfig +++ b/drivers/phy/allwinner/Kconfig @@ -4,6 +4,7 @@ config PHY_SUN4I_USB bool "Allwinner Sun4I USB PHY driver" depends on ARCH_SUNXI + select DM_REGULATOR select PHY help Enable this to support the transceiver that is part of Allwinner diff --git a/drivers/phy/allwinner/phy-sun4i-usb.c b/drivers/phy/allwinner/phy-sun4i-usb.c index 827ecd70f27..ab2a5d17fcf 100644 --- a/drivers/phy/allwinner/phy-sun4i-usb.c +++ b/drivers/phy/allwinner/phy-sun4i-usb.c @@ -26,6 +26,7 @@ #include <linux/bitops.h> #include <linux/delay.h> #include <linux/err.h> +#include <power/regulator.h>
#define REG_ISCR 0x00 #define REG_PHYCTL_A10 0x04 @@ -137,6 +138,7 @@ struct sun4i_usb_phy_data { void __iomem *base; const struct sun4i_usb_phy_cfg *cfg; struct sun4i_usb_phy_plat *usb_phy; + struct udevice *vbus_power_supply; };
static int initial_usb_scan_delay = CONFIG_INITIAL_USB_SCAN_DELAY; @@ -404,6 +406,8 @@ int sun4i_usb_phy_vbus_detect(struct phy *phy) mdelay(100); err = gpio_get_value(usb_phy->gpio_vbus_det); } + } else if (data->vbus_power_supply) { + err = regulator_get_enable(data->vbus_power_supply); }
return err; @@ -447,6 +451,9 @@ static int sun4i_usb_phy_probe(struct udevice *dev) if (IS_ERR(data->base)) return PTR_ERR(data->base);
+ device_get_supply_regulator(dev, "usb0_vbus_power-supply", + &data->vbus_power_supply); + data->usb_phy = plat; for (i = 0; i < data->cfg->num_phys; i++) { struct sun4i_usb_phy_plat *phy = &plat[i];
Looks good, but curious if that works on all those boards ...
Cheers, Andre
- select DM_REGULATOR select PHY help Enable this to support the transceiver that is part of Allwinner
- struct udevice *vbus_power_supply;
return err;
- device_get_supply_regulator(dev, "usb0_vbus_power-supply",
- data->usb_phy = plat; for (i = 0; i < data->cfg->num_phys; i++) { struct sun4i_usb_phy_plat *phy = &plat[i];
Andre Przywara
Samuel Holland
