[U-Boot] [PATCH v2 00/17] rockchip: ram: add common code for sdram driver
The sdram drivers for Rockchip SoCs was all separate, some of the SoCs has similar hardware controller and phy, so we have a change to share the flow and some of the functions between different SoCs. This patch set implement a first version common code based on PX30, other SoCs has similar hardware can migrate to this common code, eg. rk3328 and rk3399 can use this common code.
This patch set also fix some bug for rk3399 by sync code from latest rockchip vendor code.
Changes in v2: - Split the patches into multi smaller patches for easy to maintain, review and test; - Keep the DRAM_ROCKCHIP_DEBUG macro and enable it by default; - Update the rockchip_sdram_size to support sys_reg3;
Kever Yang (13): ram: rockchip: rename sdram.h to sdram_rk3288.h ram: rockchip: rename sdram_common.c/h to sdram.c rockchip: sdram: move cap structure and debug function to sdram_common.h rockchip: sdram: extend to use sys_reg3 for capacity info rockchip: sdram: update the sys_reg to sys_reg2 ram: rockchip: add common code for sdram driver ram: rockchip: move sdram_debug function into sdram_common ram: rockchip: add controller code for PX30 ram: rockchip: add phy driver code for PX30 ram: rockchip: add common msch reg definition ram: rockchip: update lpddr4 timing for rk3399 ram: rk3399: Sync the io setting from Rockchip vendor code ram: rk3399: update calculate_stride
YouMin Chen (4): ram: px30: add sdram driver ram: rk3328: use common sdram driver ram: rk3399: use common sdram driver ram: rk3399: Sync code from rockchip vendor code
arch/arm/dts/rk3328-sdram-ddr3-666.dtsi | 4 + arch/arm/dts/rk3328-sdram-lpddr3-1600.dtsi | 4 + arch/arm/dts/rk3328-sdram-lpddr3-666.dtsi | 4 + arch/arm/dts/rk3399-sdram-ddr3-1333.dtsi | 4 + arch/arm/dts/rk3399-sdram-ddr3-1600.dtsi | 4 + arch/arm/dts/rk3399-sdram-ddr3-1866.dtsi | 4 + .../arm/dts/rk3399-sdram-lpddr3-2GB-1600.dtsi | 4 + .../arm/dts/rk3399-sdram-lpddr3-4GB-1600.dtsi | 4 + .../rk3399-sdram-lpddr3-samsung-4GB-1866.dtsi | 4 + arch/arm/dts/rk3399-sdram-lpddr4-100.dtsi | 4 + arch/arm/include/asm/arch-rockchip/sdram.h | 168 ++- .../include/asm/arch-rockchip/sdram_common.h | 116 +- .../include/asm/arch-rockchip/sdram_msch.h | 85 ++ .../asm/arch-rockchip/sdram_pctl_px30.h | 139 ++ .../asm/arch-rockchip/sdram_phy_px30.h | 62 + .../arch-rockchip/sdram_phy_ron_rtt_px30.h | 59 + .../include/asm/arch-rockchip/sdram_px30.h | 212 +++ .../include/asm/arch-rockchip/sdram_rk3288.h | 102 ++ .../include/asm/arch-rockchip/sdram_rk3328.h | 420 ++---- .../include/asm/arch-rockchip/sdram_rk3399.h | 98 +- arch/arm/mach-rockchip/Kconfig | 2 + arch/arm/mach-rockchip/Makefile | 2 +- arch/arm/mach-rockchip/rk3036/rk3036.c | 2 +- arch/arm/mach-rockchip/rk3288/rk3288.c | 2 +- .../mach-rockchip/{sdram_common.c => sdram.c} | 85 +- arch/arm/mach-rockchip/spl.c | 1 - configs/evb-rk3328_defconfig | 2 +- configs/rock64-rk3328_defconfig | 2 +- drivers/ram/rockchip/Kconfig | 23 +- drivers/ram/rockchip/Makefile | 7 +- drivers/ram/rockchip/dmc-rk3368.c | 2 +- .../rockchip/sdram-px30-ddr3-detect-333.inc | 72 + .../rockchip/sdram-px30-ddr4-detect-333.inc | 75 + drivers/ram/rockchip/sdram-px30-ddr_skew.inc | 121 ++ .../rockchip/sdram-px30-lpddr2-detect-333.inc | 73 + .../rockchip/sdram-px30-lpddr3-detect-333.inc | 74 + .../ram/rockchip/sdram-rk3399-lpddr4-400.inc | 28 +- .../ram/rockchip/sdram-rk3399-lpddr4-800.inc | 28 +- drivers/ram/rockchip/sdram_common.c | 429 ++++++ drivers/ram/rockchip/sdram_debug.c | 2 +- drivers/ram/rockchip/sdram_pctl_px30.c | 205 +++ drivers/ram/rockchip/sdram_phy_px30.c | 205 +++ drivers/ram/rockchip/sdram_px30.c | 669 +++++++++ drivers/ram/rockchip/sdram_rk3128.c | 2 +- drivers/ram/rockchip/sdram_rk3188.c | 2 +- drivers/ram/rockchip/sdram_rk322x.c | 2 +- drivers/ram/rockchip/sdram_rk3288.c | 2 +- drivers/ram/rockchip/sdram_rk3328.c | 765 +++-------- drivers/ram/rockchip/sdram_rk3399.c | 1213 +++++++++++------ 49 files changed, 4040 insertions(+), 1558 deletions(-) create mode 100644 arch/arm/include/asm/arch-rockchip/sdram_msch.h create mode 100644 arch/arm/include/asm/arch-rockchip/sdram_pctl_px30.h create mode 100644 arch/arm/include/asm/arch-rockchip/sdram_phy_px30.h create mode 100644 arch/arm/include/asm/arch-rockchip/sdram_phy_ron_rtt_px30.h create mode 100644 arch/arm/include/asm/arch-rockchip/sdram_px30.h create mode 100644 arch/arm/include/asm/arch-rockchip/sdram_rk3288.h rename arch/arm/mach-rockchip/{sdram_common.c => sdram.c} (60%) create mode 100644 drivers/ram/rockchip/sdram-px30-ddr3-detect-333.inc create mode 100644 drivers/ram/rockchip/sdram-px30-ddr4-detect-333.inc create mode 100644 drivers/ram/rockchip/sdram-px30-ddr_skew.inc create mode 100644 drivers/ram/rockchip/sdram-px30-lpddr2-detect-333.inc create mode 100644 drivers/ram/rockchip/sdram-px30-lpddr3-detect-333.inc create mode 100644 drivers/ram/rockchip/sdram_common.c create mode 100644 drivers/ram/rockchip/sdram_pctl_px30.c create mode 100644 drivers/ram/rockchip/sdram_phy_px30.c create mode 100644 drivers/ram/rockchip/sdram_px30.c
The header file sdram.h is used for rk3288 and similar SoCs, rename it to make it more understandable.
Signed-off-by: YouMin Chen cym@rock-chips.com Signed-off-by: Kever Yang kever.yang@rock-chips.com ---
Changes in v2: None
arch/arm/include/asm/arch-rockchip/{sdram.h => sdram_rk3288.h} | 0 arch/arm/mach-rockchip/spl.c | 1 - drivers/ram/rockchip/dmc-rk3368.c | 2 +- drivers/ram/rockchip/sdram_rk3188.c | 2 +- drivers/ram/rockchip/sdram_rk3288.c | 2 +- 5 files changed, 3 insertions(+), 4 deletions(-) rename arch/arm/include/asm/arch-rockchip/{sdram.h => sdram_rk3288.h} (100%)
diff --git a/arch/arm/include/asm/arch-rockchip/sdram.h b/arch/arm/include/asm/arch-rockchip/sdram_rk3288.h similarity index 100% rename from arch/arm/include/asm/arch-rockchip/sdram.h rename to arch/arm/include/asm/arch-rockchip/sdram_rk3288.h diff --git a/arch/arm/mach-rockchip/spl.c b/arch/arm/mach-rockchip/spl.c index 33137cc5ef..1c091295b4 100644 --- a/arch/arm/mach-rockchip/spl.c +++ b/arch/arm/mach-rockchip/spl.c @@ -9,7 +9,6 @@ #include <ram.h> #include <spl.h> #include <asm/arch-rockchip/bootrom.h> -#include <asm/arch-rockchip/sdram.h> #include <asm/io.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/drivers/ram/rockchip/dmc-rk3368.c b/drivers/ram/rockchip/dmc-rk3368.c index e52fc3baad..16d170adf8 100644 --- a/drivers/ram/rockchip/dmc-rk3368.c +++ b/drivers/ram/rockchip/dmc-rk3368.c @@ -16,7 +16,7 @@ #include <asm/arch-rockchip/cru_rk3368.h> #include <asm/arch-rockchip/grf_rk3368.h> #include <asm/arch-rockchip/ddr_rk3368.h> -#include <asm/arch-rockchip/sdram.h> +#include <asm/arch-rockchip/sdram_rk3288.h> #include <asm/arch-rockchip/sdram_common.h>
struct dram_info { diff --git a/drivers/ram/rockchip/sdram_rk3188.c b/drivers/ram/rockchip/sdram_rk3188.c index 00e52ec949..03e34331e1 100644 --- a/drivers/ram/rockchip/sdram_rk3188.c +++ b/drivers/ram/rockchip/sdram_rk3188.c @@ -20,7 +20,7 @@ #include <asm/arch-rockchip/ddr_rk3188.h> #include <asm/arch-rockchip/grf_rk3188.h> #include <asm/arch-rockchip/pmu_rk3188.h> -#include <asm/arch-rockchip/sdram.h> +#include <asm/arch-rockchip/sdram_rk3288.h> #include <asm/arch-rockchip/sdram_common.h> #include <linux/err.h>
diff --git a/drivers/ram/rockchip/sdram_rk3288.c b/drivers/ram/rockchip/sdram_rk3288.c index 5775254007..3b6c4a050d 100644 --- a/drivers/ram/rockchip/sdram_rk3288.c +++ b/drivers/ram/rockchip/sdram_rk3288.c @@ -20,7 +20,7 @@ #include <asm/arch-rockchip/ddr_rk3288.h> #include <asm/arch-rockchip/grf_rk3288.h> #include <asm/arch-rockchip/pmu_rk3288.h> -#include <asm/arch-rockchip/sdram.h> +#include <asm/arch-rockchip/sdram_rk3288.h> #include <asm/arch-rockchip/sdram_common.h> #include <linux/err.h> #include <power/regulator.h>
rename sdram_common.c in arch/arm/mach-rockchip to sdram.c; so that we can use the file name sdram_common.c in dram driver for better understand the code; clean the related file who has use the header file at the same time.
Changes in v2: None
.../arm/include/asm/arch-rockchip/{sdram_common.h => sdram.h} | 4 ++-- arch/arm/mach-rockchip/Makefile | 2 +- arch/arm/mach-rockchip/rk3036/rk3036.c | 2 +- arch/arm/mach-rockchip/rk3288/rk3288.c | 2 +- arch/arm/mach-rockchip/{sdram_common.c => sdram.c} | 2 +- drivers/ram/rockchip/dmc-rk3368.c | 2 +- drivers/ram/rockchip/sdram_debug.c | 2 +- drivers/ram/rockchip/sdram_rk3128.c | 2 +- drivers/ram/rockchip/sdram_rk3188.c | 2 +- drivers/ram/rockchip/sdram_rk322x.c | 2 +- drivers/ram/rockchip/sdram_rk3288.c | 2 +- drivers/ram/rockchip/sdram_rk3328.c | 2 +- drivers/ram/rockchip/sdram_rk3399.c | 2 +- 13 files changed, 14 insertions(+), 14 deletions(-) rename arch/arm/include/asm/arch-rockchip/{sdram_common.h => sdram.h} (98%) rename arch/arm/mach-rockchip/{sdram_common.c => sdram.c} (99%)
diff --git a/arch/arm/include/asm/arch-rockchip/sdram_common.h b/arch/arm/include/asm/arch-rockchip/sdram.h similarity index 98% rename from arch/arm/include/asm/arch-rockchip/sdram_common.h rename to arch/arm/include/asm/arch-rockchip/sdram.h index 8027b53636..f3933f3598 100644 --- a/arch/arm/include/asm/arch-rockchip/sdram_common.h +++ b/arch/arm/include/asm/arch-rockchip/sdram.h @@ -3,8 +3,8 @@ * Copyright (C) 2017 Rockchip Electronics Co., Ltd. */
-#ifndef _ASM_ARCH_SDRAM_COMMON_H -#define _ASM_ARCH_SDRAM_COMMON_H +#ifndef _ASM_ARCH_SDRAM_H +#define _ASM_ARCH_SDRAM_H
enum { DDR4 = 0, diff --git a/arch/arm/mach-rockchip/Makefile b/arch/arm/mach-rockchip/Makefile index 45d9b06233..a9563ade4f 100644 --- a/arch/arm/mach-rockchip/Makefile +++ b/arch/arm/mach-rockchip/Makefile @@ -25,7 +25,7 @@ obj-$(CONFIG_ROCKCHIP_COMMON_BOARD) += board.o obj-$(CONFIG_MISC_INIT_R) += misc.o endif
-obj-$(CONFIG_$(SPL_TPL_)RAM) += sdram_common.o +obj-$(CONFIG_$(SPL_TPL_)RAM) += sdram.o
obj-$(CONFIG_ROCKCHIP_RK3036) += rk3036/ obj-$(CONFIG_ROCKCHIP_RK3128) += rk3128/ diff --git a/arch/arm/mach-rockchip/rk3036/rk3036.c b/arch/arm/mach-rockchip/rk3036/rk3036.c index be458cfb64..e9ada6dea3 100644 --- a/arch/arm/mach-rockchip/rk3036/rk3036.c +++ b/arch/arm/mach-rockchip/rk3036/rk3036.c @@ -43,7 +43,7 @@ void board_debug_uart_init(void) #if !CONFIG_IS_ENABLED(RAM) /* * When CONFIG_RAM is enabled, the dram_init() function is implemented - * in sdram_common.c. + * in sdram.c. */ int dram_init(void) { diff --git a/arch/arm/mach-rockchip/rk3288/rk3288.c b/arch/arm/mach-rockchip/rk3288/rk3288.c index 057ce92080..3e84523379 100644 --- a/arch/arm/mach-rockchip/rk3288/rk3288.c +++ b/arch/arm/mach-rockchip/rk3288/rk3288.c @@ -15,7 +15,7 @@ #include <asm/arch-rockchip/grf_rk3288.h> #include <asm/arch-rockchip/pmu_rk3288.h> #include <asm/arch-rockchip/qos_rk3288.h> -#include <asm/arch-rockchip/sdram_common.h> +#include <asm/arch-rockchip/sdram.h>
diff --git a/arch/arm/mach-rockchip/sdram_common.c b/arch/arm/mach-rockchip/sdram.c similarity index 99% rename from arch/arm/mach-rockchip/sdram_common.c rename to arch/arm/mach-rockchip/sdram.c index 22a4aca940..acb1af765e 100644 --- a/arch/arm/mach-rockchip/sdram_common.c +++ b/arch/arm/mach-rockchip/sdram.c @@ -7,7 +7,7 @@ #include <dm.h> #include <ram.h> #include <asm/io.h> -#include <asm/arch-rockchip/sdram_common.h> +#include <asm/arch-rockchip/sdram.h> #include <dm/uclass-internal.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/drivers/ram/rockchip/dmc-rk3368.c b/drivers/ram/rockchip/dmc-rk3368.c index 16d170adf8..9df8f8f4af 100644 --- a/drivers/ram/rockchip/dmc-rk3368.c +++ b/drivers/ram/rockchip/dmc-rk3368.c @@ -16,8 +16,8 @@ #include <asm/arch-rockchip/cru_rk3368.h> #include <asm/arch-rockchip/grf_rk3368.h> #include <asm/arch-rockchip/ddr_rk3368.h> +#include <asm/arch-rockchip/sdram.h> #include <asm/arch-rockchip/sdram_rk3288.h> -#include <asm/arch-rockchip/sdram_common.h>
struct dram_info { struct ram_info info; diff --git a/drivers/ram/rockchip/sdram_debug.c b/drivers/ram/rockchip/sdram_debug.c index 9cf662675b..133d1938d5 100644 --- a/drivers/ram/rockchip/sdram_debug.c +++ b/drivers/ram/rockchip/sdram_debug.c @@ -7,7 +7,7 @@
#include <common.h> #include <debug_uart.h> -#include <asm/arch-rockchip/sdram_common.h> +#include <asm/arch-rockchip/sdram.h>
void sdram_print_dram_type(unsigned char dramtype) { diff --git a/drivers/ram/rockchip/sdram_rk3128.c b/drivers/ram/rockchip/sdram_rk3128.c index bfabc22a7d..8486653c6f 100644 --- a/drivers/ram/rockchip/sdram_rk3128.c +++ b/drivers/ram/rockchip/sdram_rk3128.c @@ -9,7 +9,7 @@ #include <syscon.h> #include <asm/arch-rockchip/clock.h> #include <asm/arch-rockchip/grf_rk3128.h> -#include <asm/arch-rockchip/sdram_common.h> +#include <asm/arch-rockchip/sdram.h>
struct dram_info { struct ram_info info; diff --git a/drivers/ram/rockchip/sdram_rk3188.c b/drivers/ram/rockchip/sdram_rk3188.c index 03e34331e1..d3e4316ef0 100644 --- a/drivers/ram/rockchip/sdram_rk3188.c +++ b/drivers/ram/rockchip/sdram_rk3188.c @@ -20,8 +20,8 @@ #include <asm/arch-rockchip/ddr_rk3188.h> #include <asm/arch-rockchip/grf_rk3188.h> #include <asm/arch-rockchip/pmu_rk3188.h> +#include <asm/arch-rockchip/sdram.h> #include <asm/arch-rockchip/sdram_rk3288.h> -#include <asm/arch-rockchip/sdram_common.h> #include <linux/err.h>
struct chan_info { diff --git a/drivers/ram/rockchip/sdram_rk322x.c b/drivers/ram/rockchip/sdram_rk322x.c index 94893e17cf..223f048161 100644 --- a/drivers/ram/rockchip/sdram_rk322x.c +++ b/drivers/ram/rockchip/sdram_rk322x.c @@ -17,7 +17,7 @@ #include <asm/arch-rockchip/hardware.h> #include <asm/arch-rockchip/sdram_rk322x.h> #include <asm/arch-rockchip/uart.h> -#include <asm/arch-rockchip/sdram_common.h> +#include <asm/arch-rockchip/sdram.h> #include <asm/types.h> #include <linux/err.h>
diff --git a/drivers/ram/rockchip/sdram_rk3288.c b/drivers/ram/rockchip/sdram_rk3288.c index 3b6c4a050d..690751d074 100644 --- a/drivers/ram/rockchip/sdram_rk3288.c +++ b/drivers/ram/rockchip/sdram_rk3288.c @@ -20,8 +20,8 @@ #include <asm/arch-rockchip/ddr_rk3288.h> #include <asm/arch-rockchip/grf_rk3288.h> #include <asm/arch-rockchip/pmu_rk3288.h> +#include <asm/arch-rockchip/sdram.h> #include <asm/arch-rockchip/sdram_rk3288.h> -#include <asm/arch-rockchip/sdram_common.h> #include <linux/err.h> #include <power/regulator.h> #include <power/rk8xx_pmic.h> diff --git a/drivers/ram/rockchip/sdram_rk3328.c b/drivers/ram/rockchip/sdram_rk3328.c index e84c9be6a2..e7919337ea 100644 --- a/drivers/ram/rockchip/sdram_rk3328.c +++ b/drivers/ram/rockchip/sdram_rk3328.c @@ -14,7 +14,7 @@ #include <asm/arch-rockchip/clock.h> #include <asm/arch-rockchip/cru_rk3328.h> #include <asm/arch-rockchip/grf_rk3328.h> -#include <asm/arch-rockchip/sdram_common.h> +#include <asm/arch-rockchip/sdram.h> #include <asm/arch-rockchip/sdram_rk3328.h> #include <asm/arch-rockchip/uart.h>
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index ed70137ce7..9b7de4ae41 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -18,7 +18,7 @@ #include <asm/arch-rockchip/grf_rk3399.h> #include <asm/arch-rockchip/pmu_rk3399.h> #include <asm/arch-rockchip/hardware.h> -#include <asm/arch-rockchip/sdram_common.h> +#include <asm/arch-rockchip/sdram.h> #include <asm/arch-rockchip/sdram_rk3399.h> #include <linux/err.h> #include <time.h>
The sdram.h suppose to be helper file for sdram.c which including dram size decode and some u-boot related dram init interface, and all structure and function for dram driver move to sdram_common.h
Changes in v2: None
arch/arm/include/asm/arch-rockchip/sdram.h | 48 --------------- .../include/asm/arch-rockchip/sdram_common.h | 59 +++++++++++++++++++ .../include/asm/arch-rockchip/sdram_rk3328.h | 1 + .../include/asm/arch-rockchip/sdram_rk3399.h | 1 + 4 files changed, 61 insertions(+), 48 deletions(-) create mode 100644 arch/arm/include/asm/arch-rockchip/sdram_common.h
diff --git a/arch/arm/include/asm/arch-rockchip/sdram.h b/arch/arm/include/asm/arch-rockchip/sdram.h index f3933f3598..01fc353d81 100644 --- a/arch/arm/include/asm/arch-rockchip/sdram.h +++ b/arch/arm/include/asm/arch-rockchip/sdram.h @@ -15,34 +15,6 @@ enum { UNUSED = 0xFF };
-struct sdram_cap_info { - unsigned int rank; - /* dram column number, 0 means this channel is invalid */ - unsigned int col; - /* dram bank number, 3:8bank, 2:4bank */ - unsigned int bk; - /* channel buswidth, 2:32bit, 1:16bit, 0:8bit */ - unsigned int bw; - /* die buswidth, 2:32bit, 1:16bit, 0:8bit */ - unsigned int dbw; - /* - * row_3_4 = 1: 6Gb or 12Gb die - * row_3_4 = 0: normal die, power of 2 - */ - unsigned int row_3_4; - unsigned int cs0_row; - unsigned int cs1_row; - unsigned int ddrconfig; -}; - -struct sdram_base_params { - unsigned int ddr_freq; - unsigned int dramtype; - unsigned int num_channels; - unsigned int stride; - unsigned int odt; -}; - /* * sys_reg bitfield struct * [31] row_3_4_ch1 @@ -124,24 +96,4 @@ size_t rockchip_sdram_size(phys_addr_t reg); /* Called by U-Boot board_init_r for Rockchip SoCs */ int dram_init(void);
-#if !defined(CONFIG_RAM_ROCKCHIP_DEBUG) -inline void sdram_print_dram_type(unsigned char dramtype) -{ -} - -inline void sdram_print_ddr_info(struct sdram_cap_info *cap_info, - struct sdram_base_params *base) -{ -} - -inline void sdram_print_stride(unsigned int stride) -{ -} -#else -void sdram_print_dram_type(unsigned char dramtype); -void sdram_print_ddr_info(struct sdram_cap_info *cap_info, - struct sdram_base_params *base); -void sdram_print_stride(unsigned int stride); -#endif /* CONFIG_RAM_ROCKCHIP_DEBUG */ - #endif diff --git a/arch/arm/include/asm/arch-rockchip/sdram_common.h b/arch/arm/include/asm/arch-rockchip/sdram_common.h new file mode 100644 index 0000000000..8d771ce16f --- /dev/null +++ b/arch/arm/include/asm/arch-rockchip/sdram_common.h @@ -0,0 +1,59 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2018 Rockchip Electronics Co., Ltd + */ + +#ifndef _ASM_ARCH_SDRAM_COMMON_H +#define _ASM_ARCH_SDRAM_COMMON_H + +struct sdram_cap_info { + unsigned int rank; + /* dram column number, 0 means this channel is invalid */ + unsigned int col; + /* dram bank number, 3:8bank, 2:4bank */ + unsigned int bk; + /* channel buswidth, 2:32bit, 1:16bit, 0:8bit */ + unsigned int bw; + /* die buswidth, 2:32bit, 1:16bit, 0:8bit */ + unsigned int dbw; + /* + * row_3_4 = 1: 6Gb or 12Gb die + * row_3_4 = 0: normal die, power of 2 + */ + unsigned int row_3_4; + unsigned int cs0_row; + unsigned int cs1_row; + unsigned int cs0_high16bit_row; + unsigned int cs1_high16bit_row; + unsigned int ddrconfig; +}; + +struct sdram_base_params { + unsigned int ddr_freq; + unsigned int dramtype; + unsigned int num_channels; + unsigned int stride; + unsigned int odt; +}; + +#if !defined(CONFIG_RAM_ROCKCHIP_DEBUG) +inline void sdram_print_dram_type(unsigned char dramtype) +{ +} + +inline void sdram_print_ddr_info(struct sdram_cap_info *cap_info, + struct sdram_base_params *base) +{ +} + +inline void sdram_print_stride(unsigned int stride) +{ +} +#else +void sdram_print_dram_type(unsigned char dramtype); +void sdram_print_ddr_info(struct sdram_cap_info *cap_info, + struct sdram_base_params *base); +void sdram_print_stride(unsigned int stride); +#endif /* CONFIG_RAM_ROCKCHIP_DEBUG */ + +#endif diff --git a/arch/arm/include/asm/arch-rockchip/sdram_rk3328.h b/arch/arm/include/asm/arch-rockchip/sdram_rk3328.h index 11411ead10..c747b461a1 100644 --- a/arch/arm/include/asm/arch-rockchip/sdram_rk3328.h +++ b/arch/arm/include/asm/arch-rockchip/sdram_rk3328.h @@ -6,6 +6,7 @@
#ifndef _ASM_ARCH_SDRAM_RK3328_H #define _ASM_ARCH_SDRAM_RK3328_H +#include <asm/arch-rockchip/sdram_common.h>
#define SR_IDLE 93 #define PD_IDLE 13 diff --git a/arch/arm/include/asm/arch-rockchip/sdram_rk3399.h b/arch/arm/include/asm/arch-rockchip/sdram_rk3399.h index dc65ae7924..485bb3d889 100644 --- a/arch/arm/include/asm/arch-rockchip/sdram_rk3399.h +++ b/arch/arm/include/asm/arch-rockchip/sdram_rk3399.h @@ -5,6 +5,7 @@
#ifndef _ASM_ARCH_SDRAM_RK3399_H #define _ASM_ARCH_SDRAM_RK3399_H +#include <asm/arch-rockchip/sdram_common.h>
struct rk3399_ddr_pctl_regs { u32 denali_ctl[332];
Since we have new DRAM type and to support different DRAM size in different CS, we need more bits, so introduce sys_reg3 to record the info. Note that the info in sys_reg3 is extension to sys_reg2 and the info in sys_reg2 is the same as before. We define the DRAM_INFO with sys_reg3 as VERSION2. All the ENC macro are moved to sdram_common.h since the sdram.c only need to do the info decode.
Changes in v2: None
arch/arm/include/asm/arch-rockchip/sdram.h | 61 +++++++--------- .../include/asm/arch-rockchip/sdram_common.h | 69 +++++++++++++++++++ arch/arm/mach-rockchip/sdram.c | 69 ++++++++++++++++--- 3 files changed, 152 insertions(+), 47 deletions(-)
diff --git a/arch/arm/include/asm/arch-rockchip/sdram.h b/arch/arm/include/asm/arch-rockchip/sdram.h index 01fc353d81..cf2a7b7d10 100644 --- a/arch/arm/include/asm/arch-rockchip/sdram.h +++ b/arch/arm/include/asm/arch-rockchip/sdram.h @@ -16,79 +16,66 @@ enum { };
/* - * sys_reg bitfield struct + * sys_reg2 bitfield struct * [31] row_3_4_ch1 * [30] row_3_4_ch0 * [29:28] chinfo * [27] rank_ch1 * [26:25] col_ch1 * [24] bk_ch1 - * [23:22] cs0_row_ch1 - * [21:20] cs1_row_ch1 + * [23:22] low bits of cs0_row_ch1 + * [21:20] low bits of cs1_row_ch1 * [19:18] bw_ch1 * [17:16] dbw_ch1; * [15:13] ddrtype * [12] channelnum * [11] rank_ch0 - * [10:9] col_ch0 + * [10:9] col_ch0, * [8] bk_ch0 - * [7:6] cs0_row_ch0 - * [5:4] cs1_row_ch0 + * [7:6] low bits of cs0_row_ch0 + * [5:4] low bits of cs1_row_ch0 * [3:2] bw_ch0 * [1:0] dbw_ch0 -*/ + */ #define SYS_REG_DDRTYPE_SHIFT 13 -#define DDR_SYS_REG_VERSION 2 #define SYS_REG_DDRTYPE_MASK 7 #define SYS_REG_NUM_CH_SHIFT 12 #define SYS_REG_NUM_CH_MASK 1 #define SYS_REG_ROW_3_4_SHIFT(ch) (30 + (ch)) #define SYS_REG_ROW_3_4_MASK 1 -#define SYS_REG_ENC_ROW_3_4(n, ch) ((n) << (30 + (ch))) #define SYS_REG_CHINFO_SHIFT(ch) (28 + (ch)) -#define SYS_REG_ENC_CHINFO(ch) (1 << SYS_REG_CHINFO_SHIFT(ch)) -#define SYS_REG_ENC_DDRTYPE(n) ((n) << SYS_REG_DDRTYPE_SHIFT) -#define SYS_REG_ENC_NUM_CH(n) (((n) - SYS_REG_NUM_CH_MASK) << \ - SYS_REG_NUM_CH_SHIFT) #define SYS_REG_RANK_SHIFT(ch) (11 + (ch) * 16) #define SYS_REG_RANK_MASK 1 -#define SYS_REG_ENC_RANK(n, ch) (((n) - SYS_REG_RANK_MASK) << \ - SYS_REG_RANK_SHIFT(ch)) #define SYS_REG_COL_SHIFT(ch) (9 + (ch) * 16) #define SYS_REG_COL_MASK 3 -#define SYS_REG_ENC_COL(n, ch) (((n) - 9) << SYS_REG_COL_SHIFT(ch)) #define SYS_REG_BK_SHIFT(ch) (8 + (ch) * 16) #define SYS_REG_BK_MASK 1 -#define SYS_REG_ENC_BK(n, ch) (((n) == 3 ? 0 : 1) << \ - SYS_REG_BK_SHIFT(ch)) #define SYS_REG_CS0_ROW_SHIFT(ch) (6 + (ch) * 16) #define SYS_REG_CS0_ROW_MASK 3 #define SYS_REG_CS1_ROW_SHIFT(ch) (4 + (ch) * 16) #define SYS_REG_CS1_ROW_MASK 3 #define SYS_REG_BW_SHIFT(ch) (2 + (ch) * 16) #define SYS_REG_BW_MASK 3 -#define SYS_REG_ENC_BW(n, ch) ((2 >> (n)) << SYS_REG_BW_SHIFT(ch)) #define SYS_REG_DBW_SHIFT(ch) ((ch) * 16) #define SYS_REG_DBW_MASK 3 -#define SYS_REG_ENC_DBW(n, ch) ((2 >> (n)) << SYS_REG_DBW_SHIFT(ch)) - -#define SYS_REG_ENC_VERSION(n) ((n) << 28) -#define SYS_REG_ENC_CS0_ROW(n, os_reg2, os_reg3, ch) do { \ - (os_reg2) |= (((n) - 13) & 0x3) << (6 + 16 * (ch)); \ - (os_reg3) |= ((((n) - 13) & 0x4) >> 2) << \ - (5 + 2 * (ch)); \ - } while (0) - -#define SYS_REG_ENC_CS1_ROW(n, os_reg2, os_reg3, ch) do { \ - (os_reg2) &= (~(0x3 << (4 + 16 * (ch)))); \ - (os_reg3) &= (~(0x1 << (4 + 2 * (ch)))); \ - (os_reg2) |= (((n) - 13) & 0x3) << (4 + 16 * (ch)); \ - (os_reg3) |= ((((n) - 13) & 0x4) >> 2) << \ - (4 + 2 * (ch)); \ - } while (0)
-#define SYS_REG_CS1_COL_SHIFT(ch) (0 + 2 * (ch)) -#define SYS_REG_ENC_CS1_COL(n, ch) (((n) - 9) << SYS_REG_CS1_COL_SHIFT(ch)) +/* + * sys_reg3 bitfield struct + * [7] high bit of cs0_row_ch1 + * [6] high bit of cs1_row_ch1 + * [5] high bit of cs0_row_ch0 + * [4] high bit of cs1_row_ch0 + * [3:2] cs1_col_ch1 + * [1:0] cs1_col_ch0 + */ +#define SYS_REG_VERSION_SHIFT 28 +#define SYS_REG_VERSION_MASK 0xf +#define SYS_REG_EXTEND_CS0_ROW_SHIFT(ch) (5 + (ch) * 2) +#define SYS_REG_EXTEND_CS0_ROW_MASK 1 +#define SYS_REG_EXTEND_CS1_ROW_SHIFT(ch) (4 + (ch) * 2) +#define SYS_REG_EXTEND_CS1_ROW_MASK 1 +#define SYS_REG_CS1_COL_SHIFT(ch) (0 + (ch) * 2) +#define SYS_REG_CS1_COL_MASK 3
/* Get sdram size decode from reg */ size_t rockchip_sdram_size(phys_addr_t reg); diff --git a/arch/arm/include/asm/arch-rockchip/sdram_common.h b/arch/arm/include/asm/arch-rockchip/sdram_common.h index 8d771ce16f..cd3d7f97d8 100644 --- a/arch/arm/include/asm/arch-rockchip/sdram_common.h +++ b/arch/arm/include/asm/arch-rockchip/sdram_common.h @@ -36,6 +36,75 @@ struct sdram_base_params { unsigned int odt; };
+#define DDR_SYS_REG_VERSION (0x2) +/* + * sys_reg2 bitfield struct + * [31] row_3_4_ch1 + * [30] row_3_4_ch0 + * [29:28] chinfo + * [27] rank_ch1 + * [26:25] col_ch1 + * [24] bk_ch1 + * [23:22] cs0_row_ch1 + * [21:20] cs1_row_ch1 + * [19:18] bw_ch1 + * [17:16] dbw_ch1; + * [15:13] ddrtype + * [12] channelnum + * [11] rank_ch0 + * [10:9] col_ch0 + * [8] bk_ch0 + * [7:6] cs0_row_ch0 + * [5:4] cs1_row_ch0 + * [3:2] bw_ch0 + * [1:0] dbw_ch0 + */ +#define SYS_REG_ENC_ROW_3_4(n, ch) ((n) << (30 + (ch))) +#define SYS_REG_DEC_ROW_3_4(n, ch) (((n) >> (30 + (ch))) & 0x1) +#define SYS_REG_ENC_CHINFO(ch) (1 << (28 + (ch))) +#define SYS_REG_ENC_DDRTYPE(n) ((n) << 13) +#define SYS_REG_DEC_DDRTYPE(n) (((n) >> 13) & 0x7) +#define SYS_REG_ENC_NUM_CH(n) (((n) - 1) << 12) +#define SYS_REG_DEC_NUM_CH(n) (1 + (((n) >> 12) & 0x1)) +#define SYS_REG_ENC_RANK(n, ch) (((n) - 1) << (11 + ((ch) * 16))) +#define SYS_REG_DEC_RANK(n, ch) (1 + (((n) >> (11 + 16 * (ch))) & 0x1)) +#define SYS_REG_ENC_COL(n, ch) (((n) - 9) << (9 + ((ch) * 16))) +#define SYS_REG_DEC_COL(n, ch) (9 + (((n) >> (9 + 16 * (ch))) & 0x3)) +#define SYS_REG_ENC_BK(n, ch) (((n) == 3 ? 0 : 1) << \ + (8 + ((ch) * 16))) +#define SYS_REG_DEC_BK(n, ch) (3 - (((n) >> (8 + 16 * (ch))) & 0x1)) +#define SYS_REG_ENC_BW(n, ch) ((2 >> (n)) << (2 + ((ch) * 16))) +#define SYS_REG_DEC_BW(n, ch) (2 >> (((n) >> (2 + 16 * (ch))) & 0x3)) +#define SYS_REG_ENC_DBW(n, ch) ((2 >> (n)) << (0 + ((ch) * 16))) +#define SYS_REG_DEC_DBW(n, ch) (2 >> (((n) >> (0 + 16 * (ch))) & 0x3)) +/* sys reg 3 */ +#define SYS_REG_ENC_VERSION(n) ((n) << 28) +#define SYS_REG_DEC_VERSION(n) (((n) >> 28) & 0xf) +#define SYS_REG_ENC_CS0_ROW(n, os_reg2, os_reg3, ch) do { \ + (os_reg2) |= (((n) - 13) & 0x3) << (6 + 16 * (ch)); \ + (os_reg3) |= ((((n) - 13) & 0x4) >> 2) << \ + (5 + 2 * (ch)); \ + } while (0) + +#define SYS_REG_DEC_CS0_ROW(os_reg2, os_reg3, ch) \ + ((((((os_reg2) >> (6 + 16 * (ch)) & 0x3) | \ + ((((os_reg3) >> (5 + 2 * (ch))) & 0x1) << 2)) + 1) & 0x7) + 12) + +#define SYS_REG_ENC_CS1_ROW(n, os_reg2, os_reg3, ch) do { \ + (os_reg2) &= (~(0x3 << (4 + 16 * (ch)))); \ + (os_reg3) &= (~(0x1 << (4 + 2 * (ch)))); \ + (os_reg2) |= (((n) - 13) & 0x3) << (4 + 16 * (ch)); \ + (os_reg3) |= ((((n) - 13) & 0x4) >> 2) << \ + (4 + 2 * (ch)); \ + } while (0) + +#define SYS_REG_DEC_CS1_ROW(os_reg2, os_reg3, ch) \ + ((((((os_reg2) >> (4 + 16 * (ch)) & 0x3) | \ + ((((os_reg3) >> (4 + 2 * (ch))) & 0x1) << 2)) + 1) & 0x7) + 12) + +#define SYS_REG_ENC_CS1_COL(n, ch) (((n) - 9) << (0 + 2 * (ch))) +#define SYS_REG_DEC_CS1_COL(n, ch) (9 + (((n) >> (0 + 2 * (ch))) & 0x3)) + #if !defined(CONFIG_RAM_ROCKCHIP_DEBUG) inline void sdram_print_dram_type(unsigned char dramtype) { diff --git a/arch/arm/mach-rockchip/sdram.c b/arch/arm/mach-rockchip/sdram.c index acb1af765e..8e5a572dba 100644 --- a/arch/arm/mach-rockchip/sdram.c +++ b/arch/arm/mach-rockchip/sdram.c @@ -76,39 +76,88 @@ int dram_init_banksize(void)
size_t rockchip_sdram_size(phys_addr_t reg) { - u32 rank, col, bk, cs0_row, cs1_row, bw, row_3_4; + u32 rank, cs0_col, bk, cs0_row, cs1_row, bw, row_3_4; size_t chipsize_mb = 0; size_t size_mb = 0; u32 ch; - + u32 cs1_col = 0; + u32 bg = 0; + u32 dbw, dram_type; u32 sys_reg = readl(reg); + u32 sys_reg3 = readl(reg + 4); u32 ch_num = 1 + ((sys_reg >> SYS_REG_NUM_CH_SHIFT) & SYS_REG_NUM_CH_MASK);
+ dram_type = (sys_reg >> SYS_REG_DDRTYPE_SHIFT) & SYS_REG_DDRTYPE_MASK; debug("%s %x %x\n", __func__, (u32)reg, sys_reg); for (ch = 0; ch < ch_num; ch++) { rank = 1 + (sys_reg >> SYS_REG_RANK_SHIFT(ch) & SYS_REG_RANK_MASK); - col = 9 + (sys_reg >> SYS_REG_COL_SHIFT(ch) & SYS_REG_COL_MASK); + cs0_col = 9 + (sys_reg >> SYS_REG_COL_SHIFT(ch) & + SYS_REG_COL_MASK); + cs1_col = cs0_col; bk = 3 - ((sys_reg >> SYS_REG_BK_SHIFT(ch)) & SYS_REG_BK_MASK); - cs0_row = 13 + (sys_reg >> SYS_REG_CS0_ROW_SHIFT(ch) & + if ((sys_reg3 >> SYS_REG_VERSION_SHIFT & + SYS_REG_VERSION_MASK) == 0x2) { + cs1_col = 9 + (sys_reg3 >> SYS_REG_CS1_COL_SHIFT(ch) & + SYS_REG_CS1_COL_MASK); + if (((sys_reg3 >> SYS_REG_EXTEND_CS0_ROW_SHIFT(ch) & + SYS_REG_EXTEND_CS0_ROW_MASK) << 2) + (sys_reg >> + SYS_REG_CS0_ROW_SHIFT(ch) & + SYS_REG_CS0_ROW_MASK) == 7) + cs0_row = 12; + else + cs0_row = 13 + (sys_reg >> + SYS_REG_CS0_ROW_SHIFT(ch) & + SYS_REG_CS0_ROW_MASK) + + ((sys_reg3 >> + SYS_REG_EXTEND_CS0_ROW_SHIFT(ch) & + SYS_REG_EXTEND_CS0_ROW_MASK) << 2); + if (((sys_reg3 >> SYS_REG_EXTEND_CS1_ROW_SHIFT(ch) & + SYS_REG_EXTEND_CS1_ROW_MASK) << 2) + (sys_reg >> + SYS_REG_CS1_ROW_SHIFT(ch) & + SYS_REG_CS1_ROW_MASK) == 7) + cs1_row = 12; + else + cs1_row = 13 + (sys_reg >> + SYS_REG_CS1_ROW_SHIFT(ch) & + SYS_REG_CS1_ROW_MASK) + + ((sys_reg3 >> + SYS_REG_EXTEND_CS1_ROW_SHIFT(ch) & + SYS_REG_EXTEND_CS1_ROW_MASK) << 2); + } else { + cs0_row = 13 + (sys_reg >> SYS_REG_CS0_ROW_SHIFT(ch) & SYS_REG_CS0_ROW_MASK); - cs1_row = 13 + (sys_reg >> SYS_REG_CS1_ROW_SHIFT(ch) & + cs1_row = 13 + (sys_reg >> SYS_REG_CS1_ROW_SHIFT(ch) & SYS_REG_CS1_ROW_MASK); + } bw = (2 >> ((sys_reg >> SYS_REG_BW_SHIFT(ch)) & SYS_REG_BW_MASK)); row_3_4 = sys_reg >> SYS_REG_ROW_3_4_SHIFT(ch) & SYS_REG_ROW_3_4_MASK; - - chipsize_mb = (1 << (cs0_row + col + bk + bw - 20)); + if (dram_type == DDR4) { + dbw = (sys_reg >> SYS_REG_DBW_SHIFT(ch)) & + SYS_REG_DBW_MASK; + bg = (dbw == 2) ? 2 : 1; + } + chipsize_mb = (1 << (cs0_row + cs0_col + bk + bg + bw - 20));
if (rank > 1) - chipsize_mb += chipsize_mb >> (cs0_row - cs1_row); + chipsize_mb += chipsize_mb >> ((cs0_row - cs1_row) + + (cs0_col - cs1_col)); if (row_3_4) chipsize_mb = chipsize_mb * 3 / 4; size_mb += chipsize_mb; - debug("rank %d col %d bk %d cs0_row %d bw %d row_3_4 %d\n", - rank, col, bk, cs0_row, bw, row_3_4); + if (rank > 1) + debug("rank %d cs0_col %d cs1_col %d bk %d cs0_row %d\ + cs1_row %d bw %d row_3_4 %d\n", + rank, cs0_col, cs1_col, bk, cs0_row, + cs1_row, bw, row_3_4); + else + debug("rank %d cs0_col %d bk %d cs0_row %d\ + bw %d row_3_4 %d\n", + rank, cs0_col, bk, cs0_row, + bw, row_3_4); }
We are using sys_reg2 and sys_reg3 as ddr cap info, sync the variable name to what we real use to avoid confuse people.
Changes in v2: None
arch/arm/mach-rockchip/sdram.c | 32 ++++++++++++++++---------------- 1 file changed, 16 insertions(+), 16 deletions(-)
diff --git a/arch/arm/mach-rockchip/sdram.c b/arch/arm/mach-rockchip/sdram.c index 8e5a572dba..af00a6b637 100644 --- a/arch/arm/mach-rockchip/sdram.c +++ b/arch/arm/mach-rockchip/sdram.c @@ -83,60 +83,60 @@ size_t rockchip_sdram_size(phys_addr_t reg) u32 cs1_col = 0; u32 bg = 0; u32 dbw, dram_type; - u32 sys_reg = readl(reg); + u32 sys_reg2 = readl(reg); u32 sys_reg3 = readl(reg + 4); - u32 ch_num = 1 + ((sys_reg >> SYS_REG_NUM_CH_SHIFT) + u32 ch_num = 1 + ((sys_reg2 >> SYS_REG_NUM_CH_SHIFT) & SYS_REG_NUM_CH_MASK);
- dram_type = (sys_reg >> SYS_REG_DDRTYPE_SHIFT) & SYS_REG_DDRTYPE_MASK; - debug("%s %x %x\n", __func__, (u32)reg, sys_reg); + dram_type = (sys_reg2 >> SYS_REG_DDRTYPE_SHIFT) & SYS_REG_DDRTYPE_MASK; + debug("%s %x %x\n", __func__, (u32)reg, sys_reg2); for (ch = 0; ch < ch_num; ch++) { - rank = 1 + (sys_reg >> SYS_REG_RANK_SHIFT(ch) & + rank = 1 + (sys_reg2 >> SYS_REG_RANK_SHIFT(ch) & SYS_REG_RANK_MASK); - cs0_col = 9 + (sys_reg >> SYS_REG_COL_SHIFT(ch) & + cs0_col = 9 + (sys_reg2 >> SYS_REG_COL_SHIFT(ch) & SYS_REG_COL_MASK); cs1_col = cs0_col; - bk = 3 - ((sys_reg >> SYS_REG_BK_SHIFT(ch)) & SYS_REG_BK_MASK); + bk = 3 - ((sys_reg2 >> SYS_REG_BK_SHIFT(ch)) & SYS_REG_BK_MASK); if ((sys_reg3 >> SYS_REG_VERSION_SHIFT & SYS_REG_VERSION_MASK) == 0x2) { cs1_col = 9 + (sys_reg3 >> SYS_REG_CS1_COL_SHIFT(ch) & SYS_REG_CS1_COL_MASK); if (((sys_reg3 >> SYS_REG_EXTEND_CS0_ROW_SHIFT(ch) & - SYS_REG_EXTEND_CS0_ROW_MASK) << 2) + (sys_reg >> + SYS_REG_EXTEND_CS0_ROW_MASK) << 2) + (sys_reg2 >> SYS_REG_CS0_ROW_SHIFT(ch) & SYS_REG_CS0_ROW_MASK) == 7) cs0_row = 12; else - cs0_row = 13 + (sys_reg >> + cs0_row = 13 + (sys_reg2 >> SYS_REG_CS0_ROW_SHIFT(ch) & SYS_REG_CS0_ROW_MASK) + ((sys_reg3 >> SYS_REG_EXTEND_CS0_ROW_SHIFT(ch) & SYS_REG_EXTEND_CS0_ROW_MASK) << 2); if (((sys_reg3 >> SYS_REG_EXTEND_CS1_ROW_SHIFT(ch) & - SYS_REG_EXTEND_CS1_ROW_MASK) << 2) + (sys_reg >> + SYS_REG_EXTEND_CS1_ROW_MASK) << 2) + (sys_reg2 >> SYS_REG_CS1_ROW_SHIFT(ch) & SYS_REG_CS1_ROW_MASK) == 7) cs1_row = 12; else - cs1_row = 13 + (sys_reg >> + cs1_row = 13 + (sys_reg2 >> SYS_REG_CS1_ROW_SHIFT(ch) & SYS_REG_CS1_ROW_MASK) + ((sys_reg3 >> SYS_REG_EXTEND_CS1_ROW_SHIFT(ch) & SYS_REG_EXTEND_CS1_ROW_MASK) << 2); } else { - cs0_row = 13 + (sys_reg >> SYS_REG_CS0_ROW_SHIFT(ch) & + cs0_row = 13 + (sys_reg2 >> SYS_REG_CS0_ROW_SHIFT(ch) & SYS_REG_CS0_ROW_MASK); - cs1_row = 13 + (sys_reg >> SYS_REG_CS1_ROW_SHIFT(ch) & + cs1_row = 13 + (sys_reg2 >> SYS_REG_CS1_ROW_SHIFT(ch) & SYS_REG_CS1_ROW_MASK); } - bw = (2 >> ((sys_reg >> SYS_REG_BW_SHIFT(ch)) & + bw = (2 >> ((sys_reg2 >> SYS_REG_BW_SHIFT(ch)) & SYS_REG_BW_MASK)); - row_3_4 = sys_reg >> SYS_REG_ROW_3_4_SHIFT(ch) & + row_3_4 = sys_reg2 >> SYS_REG_ROW_3_4_SHIFT(ch) & SYS_REG_ROW_3_4_MASK; if (dram_type == DDR4) { - dbw = (sys_reg >> SYS_REG_DBW_SHIFT(ch)) & + dbw = (sys_reg2 >> SYS_REG_DBW_SHIFT(ch)) & SYS_REG_DBW_MASK; bg = (dbw == 2) ? 2 : 1; }
There are some function like os_reg setting, capacity detect functions, can be used as common code for different Rockchip SoCs, add a sdram_common.c for all these functions.
Changes in v2: None
.../include/asm/arch-rockchip/sdram_common.h | 31 ++ drivers/ram/rockchip/Kconfig | 6 + drivers/ram/rockchip/Makefile | 2 +- drivers/ram/rockchip/sdram_common.c | 285 ++++++++++++++++++ 4 files changed, 323 insertions(+), 1 deletion(-) create mode 100644 drivers/ram/rockchip/sdram_common.c
diff --git a/arch/arm/include/asm/arch-rockchip/sdram_common.h b/arch/arm/include/asm/arch-rockchip/sdram_common.h index cd3d7f97d8..36d31156be 100644 --- a/arch/arm/include/asm/arch-rockchip/sdram_common.h +++ b/arch/arm/include/asm/arch-rockchip/sdram_common.h @@ -6,6 +6,15 @@ #ifndef _ASM_ARCH_SDRAM_COMMON_H #define _ASM_ARCH_SDRAM_COMMON_H
+#ifndef MHZ +#define MHZ (1000 * 1000) +#endif + +#define PATTERN (0x5aa5f00f) + +#define MIN(a, b) (((a) > (b)) ? (b) : (a)) +#define MAX(a, b) (((a) > (b)) ? (a) : (b)) + struct sdram_cap_info { unsigned int rank; /* dram column number, 0 means this channel is invalid */ @@ -125,4 +134,26 @@ void sdram_print_ddr_info(struct sdram_cap_info *cap_info, void sdram_print_stride(unsigned int stride); #endif /* CONFIG_RAM_ROCKCHIP_DEBUG */
+void sdram_org_config(struct sdram_cap_info *cap_info, + struct sdram_base_params *base, + u32 *p_os_reg2, u32 *p_os_reg3, u32 channel); + +int sdram_detect_bw(struct sdram_cap_info *cap_info); +int sdram_detect_cs(struct sdram_cap_info *cap_info); +int sdram_detect_col(struct sdram_cap_info *cap_info, + u32 coltmp); +int sdram_detect_bank(struct sdram_cap_info *cap_info, + u32 coltmp, u32 bktmp); +int sdram_detect_bg(struct sdram_cap_info *cap_info, + u32 coltmp); +int sdram_detect_dbw(struct sdram_cap_info *cap_info, u32 dram_type); +int sdram_detect_row(struct sdram_cap_info *cap_info, + u32 coltmp, u32 bktmp, u32 rowtmp); +int sdram_detect_row_3_4(struct sdram_cap_info *cap_info, + u32 coltmp, u32 bktmp); +int sdram_detect_high_row(struct sdram_cap_info *cap_info); +int sdram_detect_cs1_row(struct sdram_cap_info *cap_info, u32 dram_type); +u64 sdram_get_cs_cap(struct sdram_cap_info *cap_info, u32 cs, u32 dram_type); +void sdram_copy_to_reg(u32 *dest, const u32 *src, u32 n); + #endif diff --git a/drivers/ram/rockchip/Kconfig b/drivers/ram/rockchip/Kconfig index 4f274e01b3..dcc06b3fd3 100644 --- a/drivers/ram/rockchip/Kconfig +++ b/drivers/ram/rockchip/Kconfig @@ -5,6 +5,12 @@ config RAM_ROCKCHIP help This enables support for ram drivers Rockchip SoCs.
+config ROCKCHIP_SDRAM_COMMON + bool "Enable rockchip sdram common driver" + depends on TPL_RAM || SPL_RAM + help + This enable sdram common driver + if RAM_ROCKCHIP
config RAM_ROCKCHIP_DEBUG diff --git a/drivers/ram/rockchip/Makefile b/drivers/ram/rockchip/Makefile index feb1f82d00..3d4f2f4ebf 100644 --- a/drivers/ram/rockchip/Makefile +++ b/drivers/ram/rockchip/Makefile @@ -2,7 +2,7 @@ # # Copyright (c) 2017 Theobroma Systems Design und Consulting GmbH # - +obj-$(CONFIG_ROCKCHIP_SDRAM_COMMON) += sdram_common.o obj-$(CONFIG_RAM_ROCKCHIP_DEBUG) += sdram_debug.o obj-$(CONFIG_ROCKCHIP_RK3368) = dmc-rk3368.o obj-$(CONFIG_ROCKCHIP_RK3128) = sdram_rk3128.o diff --git a/drivers/ram/rockchip/sdram_common.c b/drivers/ram/rockchip/sdram_common.c new file mode 100644 index 0000000000..3f0e1d9a42 --- /dev/null +++ b/drivers/ram/rockchip/sdram_common.c @@ -0,0 +1,285 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * (C) Copyright 2018 Rockchip Electronics Co., Ltd. + */ + +#include <common.h> +#include <debug_uart.h> +#include <ram.h> +#include <asm/io.h> +#include <asm/arch-rockchip/sdram.h> +#include <asm/arch-rockchip/sdram_common.h> + +/* n: Unit bytes */ +void sdram_copy_to_reg(u32 *dest, const u32 *src, u32 n) +{ + int i; + + for (i = 0; i < n / sizeof(u32); i++) { + writel(*src, dest); + src++; + dest++; + } +} + +void sdram_org_config(struct sdram_cap_info *cap_info, + struct sdram_base_params *base, + u32 *p_os_reg2, u32 *p_os_reg3, u32 channel) +{ + *p_os_reg2 |= SYS_REG_ENC_DDRTYPE(base->dramtype); + *p_os_reg2 |= SYS_REG_ENC_NUM_CH(base->num_channels); + + *p_os_reg2 |= SYS_REG_ENC_ROW_3_4(cap_info->row_3_4, channel); + *p_os_reg2 |= SYS_REG_ENC_CHINFO(channel); + *p_os_reg2 |= SYS_REG_ENC_RANK(cap_info->rank, channel); + *p_os_reg2 |= SYS_REG_ENC_COL(cap_info->col, channel); + *p_os_reg2 |= SYS_REG_ENC_BK(cap_info->bk, channel); + *p_os_reg2 |= SYS_REG_ENC_BW(cap_info->bw, channel); + *p_os_reg2 |= SYS_REG_ENC_DBW(cap_info->dbw, channel); + + SYS_REG_ENC_CS0_ROW(cap_info->cs0_row, *p_os_reg2, *p_os_reg3, channel); + if (cap_info->cs1_row) + SYS_REG_ENC_CS1_ROW(cap_info->cs1_row, *p_os_reg2, + *p_os_reg3, channel); + *p_os_reg3 |= SYS_REG_ENC_CS1_COL(cap_info->col, channel); + *p_os_reg3 |= SYS_REG_ENC_VERSION(DDR_SYS_REG_VERSION); +} + +int sdram_detect_bw(struct sdram_cap_info *cap_info) +{ + return 0; +} + +int sdram_detect_cs(struct sdram_cap_info *cap_info) +{ + return 0; +} + +int sdram_detect_col(struct sdram_cap_info *cap_info, + u32 coltmp) +{ + void __iomem *test_addr; + u32 col; + u32 bw = cap_info->bw; + + for (col = coltmp; col >= 9; col -= 1) { + writel(0, CONFIG_SYS_SDRAM_BASE); + test_addr = (void __iomem *)(CONFIG_SYS_SDRAM_BASE + + (1ul << (col + bw - 1ul))); + writel(PATTERN, test_addr); + if ((readl(test_addr) == PATTERN) && + (readl(CONFIG_SYS_SDRAM_BASE) == 0)) + break; + } + if (col == 8) { + printascii("col error\n"); + return -1; + } + + cap_info->col = col; + + return 0; +} + +int sdram_detect_bank(struct sdram_cap_info *cap_info, + u32 coltmp, u32 bktmp) +{ + void __iomem *test_addr; + u32 bk; + u32 bw = cap_info->bw; + + test_addr = (void __iomem *)(CONFIG_SYS_SDRAM_BASE + + (1ul << (coltmp + bktmp + bw - 1ul))); + writel(0, CONFIG_SYS_SDRAM_BASE); + writel(PATTERN, test_addr); + if ((readl(test_addr) == PATTERN) && + (readl(CONFIG_SYS_SDRAM_BASE) == 0)) + bk = 3; + else + bk = 2; + + cap_info->bk = bk; + + return 0; +} + +/* detect bg for ddr4 */ +int sdram_detect_bg(struct sdram_cap_info *cap_info, + u32 coltmp) +{ + void __iomem *test_addr; + u32 dbw; + u32 bw = cap_info->bw; + + test_addr = (void __iomem *)(CONFIG_SYS_SDRAM_BASE + + (1ul << (coltmp + bw + 1ul))); + writel(0, CONFIG_SYS_SDRAM_BASE); + writel(PATTERN, test_addr); + if ((readl(test_addr) == PATTERN) && + (readl(CONFIG_SYS_SDRAM_BASE) == 0)) + dbw = 0; + else + dbw = 1; + + cap_info->dbw = dbw; + + return 0; +} + +/* detect dbw for ddr3,lpddr2,lpddr3,lpddr4 */ +int sdram_detect_dbw(struct sdram_cap_info *cap_info, u32 dram_type) +{ + u32 row, col, bk, bw, cs_cap, cs; + u32 die_bw_0 = 0, die_bw_1 = 0; + + if (dram_type == DDR3 || dram_type == LPDDR4) { + cap_info->dbw = 1; + } else if (dram_type == LPDDR3 || dram_type == LPDDR2) { + row = cap_info->cs0_row; + col = cap_info->col; + bk = cap_info->bk; + cs = cap_info->rank; + bw = cap_info->bw; + cs_cap = (1 << (row + col + bk + bw - 20)); + if (bw == 2) { + if (cs_cap <= 0x2000000) /* 256Mb */ + die_bw_0 = (col < 9) ? 2 : 1; + else if (cs_cap <= 0x10000000) /* 2Gb */ + die_bw_0 = (col < 10) ? 2 : 1; + else if (cs_cap <= 0x40000000) /* 8Gb */ + die_bw_0 = (col < 11) ? 2 : 1; + else + die_bw_0 = (col < 12) ? 2 : 1; + if (cs > 1) { + row = cap_info->cs1_row; + cs_cap = (1 << (row + col + bk + bw - 20)); + if (cs_cap <= 0x2000000) /* 256Mb */ + die_bw_0 = (col < 9) ? 2 : 1; + else if (cs_cap <= 0x10000000) /* 2Gb */ + die_bw_0 = (col < 10) ? 2 : 1; + else if (cs_cap <= 0x40000000) /* 8Gb */ + die_bw_0 = (col < 11) ? 2 : 1; + else + die_bw_0 = (col < 12) ? 2 : 1; + } + } else { + die_bw_1 = 1; + die_bw_0 = 1; + } + cap_info->dbw = (die_bw_0 > die_bw_1) ? die_bw_0 : die_bw_1; + } + + return 0; +} + +int sdram_detect_row(struct sdram_cap_info *cap_info, + u32 coltmp, u32 bktmp, u32 rowtmp) +{ + u32 row; + u32 bw = cap_info->bw; + void __iomem *test_addr; + + for (row = rowtmp; row > 12; row--) { + writel(0, CONFIG_SYS_SDRAM_BASE); + test_addr = (void __iomem *)(CONFIG_SYS_SDRAM_BASE + + (1ul << (row + bktmp + coltmp + bw - 1ul))); + writel(PATTERN, test_addr); + if ((readl(test_addr) == PATTERN) && + (readl(CONFIG_SYS_SDRAM_BASE) == 0)) + break; + } + if (row == 12) { + printascii("row error"); + return -1; + } + + cap_info->cs0_row = row; + + return 0; +} + +int sdram_detect_row_3_4(struct sdram_cap_info *cap_info, + u32 coltmp, u32 bktmp) +{ + u32 row_3_4; + u32 bw = cap_info->bw; + u32 row = cap_info->cs0_row; + void __iomem *test_addr, *test_addr1; + + test_addr = CONFIG_SYS_SDRAM_BASE; + test_addr1 = (void __iomem *)(CONFIG_SYS_SDRAM_BASE + + (0x3ul << (row + bktmp + coltmp + bw - 1ul - 1ul))); + + writel(0, test_addr); + writel(PATTERN, test_addr1); + if ((readl(test_addr) == 0) && (readl(test_addr1) == PATTERN)) + row_3_4 = 0; + else + row_3_4 = 1; + + cap_info->row_3_4 = row_3_4; + + return 0; +} + +int sdram_detect_high_row(struct sdram_cap_info *cap_info) +{ + cap_info->cs0_high16bit_row = cap_info->cs0_row; + cap_info->cs1_high16bit_row = cap_info->cs1_row; + + return 0; +} + +int sdram_detect_cs1_row(struct sdram_cap_info *cap_info, u32 dram_type) +{ + void __iomem *test_addr; + u32 row = 0, bktmp, coltmp, bw; + ulong cs0_cap; + u32 byte_mask; + + if (cap_info->rank == 2) { + cs0_cap = sdram_get_cs_cap(cap_info, 0, dram_type); + + if (dram_type == DDR4) { + if (cap_info->dbw == 0) + bktmp = cap_info->bk + 2; + else + bktmp = cap_info->bk + 1; + } else { + bktmp = cap_info->bk; + } + bw = cap_info->bw; + coltmp = cap_info->col; + + /* + * because px30 support axi split,min bandwidth + * is 8bit. if cs0 is 32bit, cs1 may 32bit or 16bit + * so we check low 16bit data when detect cs1 row. + * if cs0 is 16bit/8bit, we check low 8bit data. + */ + if (bw == 2) + byte_mask = 0xFFFF; + else + byte_mask = 0xFF; + + /* detect cs1 row */ + for (row = cap_info->cs0_row; row > 12; row--) { + test_addr = (void __iomem *)(CONFIG_SYS_SDRAM_BASE + + cs0_cap + + (1ul << (row + bktmp + coltmp + bw - 1ul))); + writel(0, CONFIG_SYS_SDRAM_BASE + cs0_cap); + writel(PATTERN, test_addr); + + if (((readl(test_addr) & byte_mask) == + (PATTERN & byte_mask)) && + ((readl(CONFIG_SYS_SDRAM_BASE + cs0_cap) & + byte_mask) == 0)) { + break; + } + } + } + + cap_info->cs1_row = row; + + return 0; +}
The functions for dram info print are part of common code.
Changes in v2: None
drivers/ram/rockchip/Makefile | 1 - drivers/ram/rockchip/sdram_common.c | 144 +++++++++++++++++++++++++++ drivers/ram/rockchip/sdram_debug.c | 147 ---------------------------- 3 files changed, 144 insertions(+), 148 deletions(-) delete mode 100644 drivers/ram/rockchip/sdram_debug.c
diff --git a/drivers/ram/rockchip/Makefile b/drivers/ram/rockchip/Makefile index 3d4f2f4ebf..483660e570 100644 --- a/drivers/ram/rockchip/Makefile +++ b/drivers/ram/rockchip/Makefile @@ -3,7 +3,6 @@ # Copyright (c) 2017 Theobroma Systems Design und Consulting GmbH # obj-$(CONFIG_ROCKCHIP_SDRAM_COMMON) += sdram_common.o -obj-$(CONFIG_RAM_ROCKCHIP_DEBUG) += sdram_debug.o obj-$(CONFIG_ROCKCHIP_RK3368) = dmc-rk3368.o obj-$(CONFIG_ROCKCHIP_RK3128) = sdram_rk3128.o obj-$(CONFIG_ROCKCHIP_RK3188) = sdram_rk3188.o diff --git a/drivers/ram/rockchip/sdram_common.c b/drivers/ram/rockchip/sdram_common.c index 3f0e1d9a42..6bc51572b2 100644 --- a/drivers/ram/rockchip/sdram_common.c +++ b/drivers/ram/rockchip/sdram_common.c @@ -10,6 +10,150 @@ #include <asm/arch-rockchip/sdram.h> #include <asm/arch-rockchip/sdram_common.h>
+#ifdef CONFIG_RAM_ROCKCHIP_DEBUG +void sdram_print_dram_type(unsigned char dramtype) +{ + switch (dramtype) { + case DDR3: + printascii("DDR3"); + break; + case DDR4: + printascii("DDR4"); + break; + case LPDDR2: + printascii("LPDDR2"); + break; + case LPDDR3: + printascii("LPDDR3"); + break; + case LPDDR4: + printascii("LPDDR4"); + break; + default: + printascii("Unknown Device"); + break; + } +} + +void sdram_print_ddr_info(struct sdram_cap_info *cap_info, + struct sdram_base_params *base) +{ + u64 cap; + u32 bg; + + bg = (cap_info->dbw == 0) ? 2 : 1; + + sdram_print_dram_type(base->dramtype); + + printascii(", "); + printdec(base->ddr_freq); + printascii("MHz\n"); + + printascii("BW="); + printdec(8 << cap_info->bw); + printascii(" Col="); + printdec(cap_info->col); + printascii(" Bk="); + printdec(0x1 << cap_info->bk); + if (base->dramtype == DDR4) { + printascii(" BG="); + printdec(1 << bg); + } + printascii(" CS0 Row="); + printdec(cap_info->cs0_row); + if (cap_info->cs0_high16bit_row != + cap_info->cs0_row) { + printascii("/"); + printdec(cap_info->cs0_high16bit_row); + } + if (cap_info->rank > 1) { + printascii(" CS1 Row="); + printdec(cap_info->cs1_row); + if (cap_info->cs1_high16bit_row != + cap_info->cs1_row) { + printascii("/"); + printdec(cap_info->cs1_high16bit_row); + } + } + printascii(" CS="); + printdec(cap_info->rank); + printascii(" Die BW="); + printdec(8 << cap_info->dbw); + + cap = sdram_get_cs_cap(cap_info, 3, base->dramtype); + if (cap_info->row_3_4) + cap = cap * 3 / 4; + + printascii(" Size="); + printdec(cap >> 20); + printascii("MB\n"); +} + +void sdram_print_stride(unsigned int stride) +{ + switch (stride) { + case 0xc: + printf("128B stride\n"); + break; + case 5: + case 9: + case 0xd: + case 0x11: + case 0x19: + printf("256B stride\n"); + break; + case 0xa: + case 0xe: + case 0x12: + printf("512B stride\n"); + break; + case 0xf: + printf("4K stride\n"); + break; + case 0x1f: + printf("32MB + 256B stride\n"); + break; + default: + printf("no stride\n"); + } +} +#endif + +/* + * cs: 0:cs0 + * 1:cs1 + * else cs0+cs1 + * note: it didn't consider about row_3_4 + */ +u64 sdram_get_cs_cap(struct sdram_cap_info *cap_info, u32 cs, u32 dram_type) +{ + u32 bg; + u64 cap[2]; + + if (dram_type == DDR4) + /* DDR4 8bit dram BG = 2(4bank groups), + * 16bit dram BG = 1 (2 bank groups) + */ + bg = (cap_info->dbw == 0) ? 2 : 1; + else + bg = 0; + cap[0] = 1llu << (cap_info->bw + cap_info->col + + bg + cap_info->bk + cap_info->cs0_row); + + if (cap_info->rank == 2) + cap[1] = 1llu << (cap_info->bw + cap_info->col + + bg + cap_info->bk + cap_info->cs1_row); + else + cap[1] = 0; + + if (cs == 0) + return cap[0]; + else if (cs == 1) + return cap[1]; + else + return (cap[0] + cap[1]); +} + /* n: Unit bytes */ void sdram_copy_to_reg(u32 *dest, const u32 *src, u32 n) { diff --git a/drivers/ram/rockchip/sdram_debug.c b/drivers/ram/rockchip/sdram_debug.c deleted file mode 100644 index 133d1938d5..0000000000 --- a/drivers/ram/rockchip/sdram_debug.c +++ /dev/null @@ -1,147 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * (C) Copyright 2019 Rockchip Electronics Co., Ltd - * (C) Copyright 2019 Amarula Solutions. - * Author: Jagan Teki jagan@amarulasolutions.com - */ - -#include <common.h> -#include <debug_uart.h> -#include <asm/arch-rockchip/sdram.h> - -void sdram_print_dram_type(unsigned char dramtype) -{ - switch (dramtype) { - case DDR3: - printascii("DDR3"); - break; - case DDR4: - printascii("DDR4"); - break; - case LPDDR2: - printascii("LPDDR2"); - break; - case LPDDR3: - printascii("LPDDR3"); - break; - case LPDDR4: - printascii("LPDDR4"); - break; - default: - printascii("Unknown Device"); - break; - } -} - -/** - * cs = 0, cs0 - * cs = 1, cs1 - * cs => 2, cs0+cs1 - * note: it didn't consider about row_3_4 - */ -u64 sdram_get_cs_cap(struct sdram_cap_info *cap_info, u32 cs, u32 dram_type) -{ - u32 bg; - u64 cap[2]; - - if (dram_type == DDR4) - /* DDR4 8bit dram BG = 2(4bank groups), - * 16bit dram BG = 1 (2 bank groups) - */ - bg = (cap_info->dbw == 0) ? 2 : 1; - else - bg = 0; - - cap[0] = 1llu << (cap_info->bw + cap_info->col + - bg + cap_info->bk + cap_info->cs0_row); - - if (cap_info->rank == 2) - cap[1] = 1llu << (cap_info->bw + cap_info->col + - bg + cap_info->bk + cap_info->cs1_row); - else - cap[1] = 0; - - if (cs == 0) - return cap[0]; - else if (cs == 1) - return cap[1]; - else - return (cap[0] + cap[1]); -} - -void sdram_print_ddr_info(struct sdram_cap_info *cap_info, - struct sdram_base_params *base) -{ - u32 bg, cap; - - bg = (cap_info->dbw == 0) ? 2 : 1; - - sdram_print_dram_type(base->dramtype); - - printascii(", "); - printdec(base->ddr_freq); - printascii("MHz\n"); - - printascii("BW="); - printdec(8 << cap_info->bw); - - printascii(" Col="); - printdec(cap_info->col); - - printascii(" Bk="); - printdec(0x1 << cap_info->bk); - if (base->dramtype == DDR4) { - printascii(" BG="); - printdec(1 << bg); - } - - printascii(" CS0 Row="); - printdec(cap_info->cs0_row); - if (cap_info->rank > 1) { - printascii(" CS1 Row="); - printdec(cap_info->cs1_row); - } - - printascii(" CS="); - printdec(cap_info->rank); - - printascii(" Die BW="); - printdec(8 << cap_info->dbw); - - cap = sdram_get_cs_cap(cap_info, 3, base->dramtype); - if (cap_info->row_3_4) - cap = cap * 3 / 4; - - printascii(" Size="); - printdec(cap >> 20); - printascii("MB\n"); -} - -void sdram_print_stride(unsigned int stride) -{ - switch (stride) { - case 0xc: - printf("128B stride\n"); - break; - case 5: - case 9: - case 0xd: - case 0x11: - case 0x19: - printf("256B stride\n"); - break; - case 0xa: - case 0xe: - case 0x12: - printf("512B stride\n"); - break; - case 0xf: - printf("4K stride\n"); - break; - case 0x1f: - printf("32MB + 256B stride\n"); - break; - default: - printf("no stride\n"); - } -}
This sdram_pctl_px30.c is based on PX30 SoC, the functions are common for controller, other SoCs with similar hardware could re-use it.
Changes in v2: None
.../asm/arch-rockchip/sdram_pctl_px30.h | 139 ++++++++++++ drivers/ram/rockchip/sdram_pctl_px30.c | 205 ++++++++++++++++++ 2 files changed, 344 insertions(+) create mode 100644 arch/arm/include/asm/arch-rockchip/sdram_pctl_px30.h create mode 100644 drivers/ram/rockchip/sdram_pctl_px30.c
diff --git a/arch/arm/include/asm/arch-rockchip/sdram_pctl_px30.h b/arch/arm/include/asm/arch-rockchip/sdram_pctl_px30.h new file mode 100644 index 0000000000..9781881738 --- /dev/null +++ b/arch/arm/include/asm/arch-rockchip/sdram_pctl_px30.h @@ -0,0 +1,139 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2018 Rockchip Electronics Co., Ltd + */ + +#ifndef _ASM_ARCH_SDRAM_PCTL_PX30_H +#define _ASM_ARCH_SDRAM_PCTL_PX30_H +#include <asm/arch-rockchip/sdram_common.h> + +struct ddr_pctl_regs { + u32 pctl[30][2]; +}; + +/* ddr pctl registers define */ +#define DDR_PCTL2_MSTR 0x0 +#define DDR_PCTL2_STAT 0x4 +#define DDR_PCTL2_MSTR1 0x8 +#define DDR_PCTL2_MRCTRL0 0x10 +#define DDR_PCTL2_MRCTRL1 0x14 +#define DDR_PCTL2_MRSTAT 0x18 +#define DDR_PCTL2_MRCTRL2 0x1c +#define DDR_PCTL2_DERATEEN 0x20 +#define DDR_PCTL2_DERATEINT 0x24 +#define DDR_PCTL2_PWRCTL 0x30 +#define DDR_PCTL2_PWRTMG 0x34 +#define DDR_PCTL2_HWLPCTL 0x38 +#define DDR_PCTL2_RFSHCTL0 0x50 +#define DDR_PCTL2_RFSHCTL1 0x54 +#define DDR_PCTL2_RFSHCTL2 0x58 +#define DDR_PCTL2_RFSHCTL4 0x5c +#define DDR_PCTL2_RFSHCTL3 0x60 +#define DDR_PCTL2_RFSHTMG 0x64 +#define DDR_PCTL2_RFSHTMG1 0x68 +#define DDR_PCTL2_RFSHCTL5 0x6c +#define DDR_PCTL2_INIT0 0xd0 +#define DDR_PCTL2_INIT1 0xd4 +#define DDR_PCTL2_INIT2 0xd8 +#define DDR_PCTL2_INIT3 0xdc +#define DDR_PCTL2_INIT4 0xe0 +#define DDR_PCTL2_INIT5 0xe4 +#define DDR_PCTL2_INIT6 0xe8 +#define DDR_PCTL2_INIT7 0xec +#define DDR_PCTL2_DIMMCTL 0xf0 +#define DDR_PCTL2_RANKCTL 0xf4 +#define DDR_PCTL2_CHCTL 0xfc +#define DDR_PCTL2_DRAMTMG0 0x100 +#define DDR_PCTL2_DRAMTMG1 0x104 +#define DDR_PCTL2_DRAMTMG2 0x108 +#define DDR_PCTL2_DRAMTMG3 0x10c +#define DDR_PCTL2_DRAMTMG4 0x110 +#define DDR_PCTL2_DRAMTMG5 0x114 +#define DDR_PCTL2_DRAMTMG6 0x118 +#define DDR_PCTL2_DRAMTMG7 0x11c +#define DDR_PCTL2_DRAMTMG8 0x120 +#define DDR_PCTL2_DRAMTMG9 0x124 +#define DDR_PCTL2_DRAMTMG10 0x128 +#define DDR_PCTL2_DRAMTMG11 0x12c +#define DDR_PCTL2_DRAMTMG12 0x130 +#define DDR_PCTL2_DRAMTMG13 0x134 +#define DDR_PCTL2_DRAMTMG14 0x138 +#define DDR_PCTL2_DRAMTMG15 0x13c +#define DDR_PCTL2_DRAMTMG16 0x140 +#define DDR_PCTL2_ZQCTL0 0x180 +#define DDR_PCTL2_ZQCTL1 0x184 +#define DDR_PCTL2_ZQCTL2 0x188 +#define DDR_PCTL2_ZQSTAT 0x18c +#define DDR_PCTL2_DFITMG0 0x190 +#define DDR_PCTL2_DFITMG1 0x194 +#define DDR_PCTL2_DFILPCFG0 0x198 +#define DDR_PCTL2_DFILPCFG1 0x19c +#define DDR_PCTL2_DFIUPD0 0x1a0 +#define DDR_PCTL2_DFIUPD1 0x1a4 +#define DDR_PCTL2_DFIUPD2 0x1a8 +#define DDR_PCTL2_DFIMISC 0x1b0 +#define DDR_PCTL2_DFITMG2 0x1b4 +#define DDR_PCTL2_DFITMG3 0x1b8 +#define DDR_PCTL2_DFISTAT 0x1bc +#define DDR_PCTL2_DBICTL 0x1c0 +#define DDR_PCTL2_ADDRMAP0 0x200 +#define DDR_PCTL2_ADDRMAP1 0x204 +#define DDR_PCTL2_ADDRMAP2 0x208 +#define DDR_PCTL2_ADDRMAP3 0x20c +#define DDR_PCTL2_ADDRMAP4 0x210 +#define DDR_PCTL2_ADDRMAP5 0x214 +#define DDR_PCTL2_ADDRMAP6 0x218 +#define DDR_PCTL2_ADDRMAP7 0x21c +#define DDR_PCTL2_ADDRMAP8 0x220 +#define DDR_PCTL2_ADDRMAP9 0x224 +#define DDR_PCTL2_ADDRMAP10 0x228 +#define DDR_PCTL2_ADDRMAP11 0x22c +#define DDR_PCTL2_ODTCFG 0x240 +#define DDR_PCTL2_ODTMAP 0x244 +#define DDR_PCTL2_SCHED 0x250 +#define DDR_PCTL2_SCHED1 0x254 +#define DDR_PCTL2_PERFHPR1 0x25c +#define DDR_PCTL2_PERFLPR1 0x264 +#define DDR_PCTL2_PERFWR1 0x26c +#define DDR_PCTL2_DQMAP0 0x280 +#define DDR_PCTL2_DQMAP1 0x284 +#define DDR_PCTL2_DQMAP2 0x288 +#define DDR_PCTL2_DQMAP3 0x28c +#define DDR_PCTL2_DQMAP4 0x290 +#define DDR_PCTL2_DQMAP5 0x294 +#define DDR_PCTL2_DBG0 0x300 +#define DDR_PCTL2_DBG1 0x304 +#define DDR_PCTL2_DBGCAM 0x308 +#define DDR_PCTL2_DBGCMD 0x30c +#define DDR_PCTL2_DBGSTAT 0x310 +#define DDR_PCTL2_SWCTL 0x320 +#define DDR_PCTL2_SWSTAT 0x324 +#define DDR_PCTL2_POISONCFG 0x36c +#define DDR_PCTL2_POISONSTAT 0x370 +#define DDR_PCTL2_ADVECCINDEX 0x374 +#define DDR_PCTL2_ADVECCSTAT 0x378 +#define DDR_PCTL2_PSTAT 0x3fc +#define DDR_PCTL2_PCCFG 0x400 +#define DDR_PCTL2_PCFGR_n 0x404 +#define DDR_PCTL2_PCFGW_n 0x408 +#define DDR_PCTL2_PCTRL_n 0x490 + +/* PCTL2_MRSTAT */ +#define MR_WR_BUSY BIT(0) + +void pctl_read_mr(void __iomem *pctl_base, u32 rank, u32 mr_num); +int pctl_write_mr(void __iomem *pctl_base, u32 rank, u32 mr_num, u32 arg, + u32 dramtype); +int pctl_write_vrefdq(void __iomem *pctl_base, u32 rank, u32 vrefrate, + u32 dramtype); + +u32 pctl_dis_zqcs_aref(void __iomem *pctl_base); +void pctl_rest_zqcs_aref(void __iomem *pctl_base, u32 dis_auto_zq); + +u32 pctl_remodify_sdram_params(struct ddr_pctl_regs *pctl_regs, + struct sdram_cap_info *cap_info, + u32 dram_type); +int pctl_cfg(void __iomem *pctl_base, struct ddr_pctl_regs *pctl_regs, + u32 sr_idle, u32 pd_idle); + +#endif diff --git a/drivers/ram/rockchip/sdram_pctl_px30.c b/drivers/ram/rockchip/sdram_pctl_px30.c new file mode 100644 index 0000000000..1839cebb67 --- /dev/null +++ b/drivers/ram/rockchip/sdram_pctl_px30.c @@ -0,0 +1,205 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * (C) Copyright 2018 Rockchip Electronics Co., Ltd. + */ + +#include <common.h> +#include <ram.h> +#include <asm/io.h> +#include <asm/arch-rockchip/sdram.h> +#include <asm/arch-rockchip/sdram_pctl_px30.h> + +/* + * rank = 1: cs0 + * rank = 2: cs1 + */ +void pctl_read_mr(void __iomem *pctl_base, u32 rank, u32 mr_num) +{ + writel((rank << 4) | (1 << 0), pctl_base + DDR_PCTL2_MRCTRL0); + writel((mr_num << 8), pctl_base + DDR_PCTL2_MRCTRL1); + setbits_le32(pctl_base + DDR_PCTL2_MRCTRL0, 1u << 31); + while (readl(pctl_base + DDR_PCTL2_MRCTRL0) & (1u << 31)) + continue; + while (readl(pctl_base + DDR_PCTL2_MRSTAT) & MR_WR_BUSY) + continue; +} + +/* rank = 1: cs0 + * rank = 2: cs1 + * rank = 3: cs0 & cs1 + * note: be careful of keep mr original val + */ +int pctl_write_mr(void __iomem *pctl_base, u32 rank, u32 mr_num, u32 arg, + u32 dramtype) +{ + while (readl(pctl_base + DDR_PCTL2_MRSTAT) & MR_WR_BUSY) + continue; + if (dramtype == DDR3 || dramtype == DDR4) { + writel((mr_num << 12) | (rank << 4) | (0 << 0), + pctl_base + DDR_PCTL2_MRCTRL0); + writel(arg, pctl_base + DDR_PCTL2_MRCTRL1); + } else { + writel((rank << 4) | (0 << 0), + pctl_base + DDR_PCTL2_MRCTRL0); + writel((mr_num << 8) | (arg & 0xff), + pctl_base + DDR_PCTL2_MRCTRL1); + } + + setbits_le32(pctl_base + DDR_PCTL2_MRCTRL0, 1u << 31); + while (readl(pctl_base + DDR_PCTL2_MRCTRL0) & (1u << 31)) + continue; + while (readl(pctl_base + DDR_PCTL2_MRSTAT) & MR_WR_BUSY) + continue; + + return 0; +} + +/* + * rank : 1:cs0, 2:cs1, 3:cs0&cs1 + * vrefrate: 4500: 45%, + */ +int pctl_write_vrefdq(void __iomem *pctl_base, u32 rank, u32 vrefrate, + u32 dramtype) +{ + u32 tccd_l, value; + u32 dis_auto_zq = 0; + + if (dramtype != DDR4 || vrefrate < 4500 || + vrefrate > 9200) + return (-1); + + tccd_l = (readl(pctl_base + DDR_PCTL2_DRAMTMG4) >> 16) & 0xf; + tccd_l = (tccd_l - 4) << 10; + + if (vrefrate > 7500) { + /* range 1 */ + value = ((vrefrate - 6000) / 65) | tccd_l; + } else { + /* range 2 */ + value = ((vrefrate - 4500) / 65) | tccd_l | (1 << 6); + } + + dis_auto_zq = pctl_dis_zqcs_aref(pctl_base); + + /* enable vrefdq calibratin */ + pctl_write_mr(pctl_base, rank, 6, value | (1 << 7), dramtype); + udelay(1);/* tvrefdqe */ + /* write vrefdq value */ + pctl_write_mr(pctl_base, rank, 6, value | (1 << 7), dramtype); + udelay(1);/* tvref_time */ + pctl_write_mr(pctl_base, rank, 6, value | (0 << 7), dramtype); + udelay(1);/* tvrefdqx */ + + pctl_rest_zqcs_aref(pctl_base, dis_auto_zq); + + return 0; +} + +static int upctl2_update_ref_reg(void __iomem *pctl_base) +{ + u32 ret; + + ret = readl(pctl_base + DDR_PCTL2_RFSHCTL3) ^ (1 << 1); + writel(ret, pctl_base + DDR_PCTL2_RFSHCTL3); + + return 0; +} + +u32 pctl_dis_zqcs_aref(void __iomem *pctl_base) +{ + u32 dis_auto_zq = 0; + + /* disable zqcs */ + if (!(readl(pctl_base + DDR_PCTL2_ZQCTL0) & + (1ul << 31))) { + dis_auto_zq = 1; + setbits_le32(pctl_base + DDR_PCTL2_ZQCTL0, 1 << 31); + } + + /* disable auto refresh */ + setbits_le32(pctl_base + DDR_PCTL2_RFSHCTL3, 1); + + upctl2_update_ref_reg(pctl_base); + + return dis_auto_zq; +} + +void pctl_rest_zqcs_aref(void __iomem *pctl_base, u32 dis_auto_zq) +{ + /* restore zqcs */ + if (dis_auto_zq) + clrbits_le32(pctl_base + DDR_PCTL2_ZQCTL0, 1 << 31); + + /* restore auto refresh */ + clrbits_le32(pctl_base + DDR_PCTL2_RFSHCTL3, 1); + + upctl2_update_ref_reg(pctl_base); +} + +u32 pctl_remodify_sdram_params(struct ddr_pctl_regs *pctl_regs, + struct sdram_cap_info *cap_info, + u32 dram_type) +{ + u32 tmp = 0, tmp_adr = 0, i; + + for (i = 0; pctl_regs->pctl[i][0] != 0xFFFFFFFF; i++) { + if (pctl_regs->pctl[i][0] == 0) { + tmp = pctl_regs->pctl[i][1];/* MSTR */ + tmp_adr = i; + } + } + + tmp &= ~((3ul << 30) | (3ul << 24) | (3ul << 12)); + + switch (cap_info->dbw) { + case 2: + tmp |= (3ul << 30); + break; + case 1: + tmp |= (2ul << 30); + break; + case 0: + default: + tmp |= (1ul << 30); + break; + } + + /* + * If DDR3 or DDR4 MSTR.active_ranks=1, + * it will gate memory clock when enter power down. + * Force set active_ranks to 3 to workaround it. + */ + if (cap_info->rank == 2 || dram_type == DDR3 || + dram_type == DDR4) + tmp |= 3 << 24; + else + tmp |= 1 << 24; + + tmp |= (2 - cap_info->bw) << 12; + + pctl_regs->pctl[tmp_adr][1] = tmp; + + return 0; +} + +int pctl_cfg(void __iomem *pctl_base, struct ddr_pctl_regs *pctl_regs, + u32 sr_idle, u32 pd_idle) +{ + u32 i; + + for (i = 0; pctl_regs->pctl[i][0] != 0xFFFFFFFF; i++) { + writel(pctl_regs->pctl[i][1], + pctl_base + pctl_regs->pctl[i][0]); + } + clrsetbits_le32(pctl_base + DDR_PCTL2_PWRTMG, + (0xff << 16) | 0x1f, + ((sr_idle & 0xff) << 16) | (pd_idle & 0x1f)); + + clrsetbits_le32(pctl_base + DDR_PCTL2_HWLPCTL, + 0xfff << 16, + 5 << 16); + /* disable zqcs */ + setbits_le32(pctl_base + DDR_PCTL2_ZQCTL0, 1u << 31); + + return 0; +}
This sdram_phy_px30.c is based on PX30 SoC, the functions are common for phy, other SoCs with similar hardware could re-use it.
Changes in v2: None
.../asm/arch-rockchip/sdram_phy_px30.h | 62 ++++++ .../arch-rockchip/sdram_phy_ron_rtt_px30.h | 59 +++++ drivers/ram/rockchip/sdram_phy_px30.c | 205 ++++++++++++++++++ 3 files changed, 326 insertions(+) create mode 100644 arch/arm/include/asm/arch-rockchip/sdram_phy_px30.h create mode 100644 arch/arm/include/asm/arch-rockchip/sdram_phy_ron_rtt_px30.h create mode 100644 drivers/ram/rockchip/sdram_phy_px30.c
diff --git a/arch/arm/include/asm/arch-rockchip/sdram_phy_px30.h b/arch/arm/include/asm/arch-rockchip/sdram_phy_px30.h new file mode 100644 index 0000000000..c75a633c91 --- /dev/null +++ b/arch/arm/include/asm/arch-rockchip/sdram_phy_px30.h @@ -0,0 +1,62 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2018 Rockchip Electronics Co., Ltd + */ + +#ifndef _ASM_ARCH_SDRAM_PHY_PX30_H +#define _ASM_ARCH_SDRAM_PHY_PX30_H +#include <asm/arch-rockchip/sdram_common.h> +#include <asm/arch-rockchip/sdram_phy_ron_rtt_px30.h> + +struct ddr_phy_regs { + u32 phy[5][2]; +}; + +#define PHY_REG(base, n) ((base) + 4 * (n)) + +/* PHY_REG0 */ +#define DIGITAL_DERESET BIT(3) +#define ANALOG_DERESET BIT(2) +#define DIGITAL_RESET (0 << 3) +#define ANALOG_RESET (0 << 2) + +/* PHY_REG1 */ +#define PHY_DDR2 (0) +#define PHY_LPDDR2 (1) +#define PHY_DDR3 (2) +#define PHY_LPDDR3 (3) +#define PHY_DDR4 (4) +#define PHY_BL_4 (0 << 2) +#define PHY_BL_8 BIT(2) + +/* PHY_REG2 */ +#define PHY_DTT_EN BIT(0) +#define PHY_DTT_DISB (0 << 0) +#define PHY_WRITE_LEVELING_EN BIT(2) +#define PHY_WRITE_LEVELING_DISB (0 << 2) +#define PHY_SELECT_CS0 (2) +#define PHY_SELECT_CS1 (1) +#define PHY_SELECT_CS0_1 (0) +#define PHY_WRITE_LEVELING_SELECTCS(n) ((n) << 6) +#define PHY_DATA_TRAINING_SELECTCS(n) ((n) << 4) + +struct ddr_phy_skew { + u32 a0_a1_skew[15]; + u32 cs0_dm0_skew[11]; + u32 cs0_dm1_skew[11]; + u32 cs0_dm2_skew[11]; + u32 cs0_dm3_skew[11]; + u32 cs1_dm0_skew[11]; + u32 cs1_dm1_skew[11]; + u32 cs1_dm2_skew[11]; + u32 cs1_dm3_skew[11]; +}; + +void phy_soft_reset(void __iomem *phy_base); +void phy_dram_set_bw(void __iomem *phy_base, u32 bw); +void phy_cfg(void __iomem *phy_base, + struct ddr_phy_regs *phy_regs, struct ddr_phy_skew *skew, + struct sdram_base_params *base, u32 bw); +int phy_data_training(void __iomem *phy_base, u32 cs, u32 dramtype); + +#endif diff --git a/arch/arm/include/asm/arch-rockchip/sdram_phy_ron_rtt_px30.h b/arch/arm/include/asm/arch-rockchip/sdram_phy_ron_rtt_px30.h new file mode 100644 index 0000000000..9c15232047 --- /dev/null +++ b/arch/arm/include/asm/arch-rockchip/sdram_phy_ron_rtt_px30.h @@ -0,0 +1,59 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2018 Rockchip Electronics Co., Ltd + */ + +#ifndef _ASM_ARCH_SDRAM_PHY_RON_RTT_PX30_H +#define _ASM_ARCH_SDRAM_PHY_RON_RTT_PX30_H + +#define PHY_DDR3_RON_RTT_DISABLE (0) +#define PHY_DDR3_RON_RTT_451ohm (1) +#define PHY_DDR3_RON_RTT_225ohm (2) +#define PHY_DDR3_RON_RTT_150ohm (3) +#define PHY_DDR3_RON_RTT_112ohm (4) +#define PHY_DDR3_RON_RTT_90ohm (5) +#define PHY_DDR3_RON_RTT_75ohm (6) +#define PHY_DDR3_RON_RTT_64ohm (7) +#define PHY_DDR3_RON_RTT_56ohm (16) +#define PHY_DDR3_RON_RTT_50ohm (17) +#define PHY_DDR3_RON_RTT_45ohm (18) +#define PHY_DDR3_RON_RTT_41ohm (19) +#define PHY_DDR3_RON_RTT_37ohm (20) +#define PHY_DDR3_RON_RTT_34ohm (21) +#define PHY_DDR3_RON_RTT_33ohm (22) +#define PHY_DDR3_RON_RTT_30ohm (23) +#define PHY_DDR3_RON_RTT_28ohm (24) +#define PHY_DDR3_RON_RTT_26ohm (25) +#define PHY_DDR3_RON_RTT_25ohm (26) +#define PHY_DDR3_RON_RTT_23ohm (27) +#define PHY_DDR3_RON_RTT_22ohm (28) +#define PHY_DDR3_RON_RTT_21ohm (29) +#define PHY_DDR3_RON_RTT_20ohm (30) +#define PHY_DDR3_RON_RTT_19ohm (31) + +#define PHY_DDR4_LPDDR3_RON_RTT_DISABLE (0) +#define PHY_DDR4_LPDDR3_RON_RTT_480ohm (1) +#define PHY_DDR4_LPDDR3_RON_RTT_240ohm (2) +#define PHY_DDR4_LPDDR3_RON_RTT_160ohm (3) +#define PHY_DDR4_LPDDR3_RON_RTT_120ohm (4) +#define PHY_DDR4_LPDDR3_RON_RTT_96ohm (5) +#define PHY_DDR4_LPDDR3_RON_RTT_80ohm (6) +#define PHY_DDR4_LPDDR3_RON_RTT_68ohm (7) +#define PHY_DDR4_LPDDR3_RON_RTT_60ohm (16) +#define PHY_DDR4_LPDDR3_RON_RTT_53ohm (17) +#define PHY_DDR4_LPDDR3_RON_RTT_48ohm (18) +#define PHY_DDR4_LPDDR3_RON_RTT_43ohm (19) +#define PHY_DDR4_LPDDR3_RON_RTT_40ohm (20) +#define PHY_DDR4_LPDDR3_RON_RTT_37ohm (21) +#define PHY_DDR4_LPDDR3_RON_RTT_34ohm (22) +#define PHY_DDR4_LPDDR3_RON_RTT_32ohm (23) +#define PHY_DDR4_LPDDR3_RON_RTT_30ohm (24) +#define PHY_DDR4_LPDDR3_RON_RTT_28ohm (25) +#define PHY_DDR4_LPDDR3_RON_RTT_26ohm (26) +#define PHY_DDR4_LPDDR3_RON_RTT_25ohm (27) +#define PHY_DDR4_LPDDR3_RON_RTT_24ohm (28) +#define PHY_DDR4_LPDDR3_RON_RTT_22ohm (29) +#define PHY_DDR4_LPDDR3_RON_RTT_21ohm (30) +#define PHY_DDR4_LPDDR3_RON_RTT_20ohm (31) + +#endif diff --git a/drivers/ram/rockchip/sdram_phy_px30.c b/drivers/ram/rockchip/sdram_phy_px30.c new file mode 100644 index 0000000000..5de73770a8 --- /dev/null +++ b/drivers/ram/rockchip/sdram_phy_px30.c @@ -0,0 +1,205 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * (C) Copyright 2018 Rockchip Electronics Co., Ltd. + */ + +#include <common.h> +#include <ram.h> +#include <asm/io.h> +#include <asm/arch-rockchip/sdram.h> +#include <asm/arch-rockchip/sdram_common.h> +#include <asm/arch-rockchip/sdram_phy_px30.h> + +static void sdram_phy_dll_bypass_set(void __iomem *phy_base, u32 freq) +{ + u32 tmp; + u32 i, j; + u32 dqs_dll_freq; + + setbits_le32(PHY_REG(phy_base, 0x13), 1 << 4); + clrbits_le32(PHY_REG(phy_base, 0x14), 1 << 3); + for (i = 0; i < 4; i++) { + j = 0x26 + i * 0x10; + setbits_le32(PHY_REG(phy_base, j), 1 << 4); + clrbits_le32(PHY_REG(phy_base, j + 0x1), 1 << 3); + } + + if (freq <= 400) + /* DLL bypass */ + setbits_le32(PHY_REG(phy_base, 0xa4), 0x1f); + else + clrbits_le32(PHY_REG(phy_base, 0xa4), 0x1f); + + #ifdef CONFIG_ROCKCHIP_RK3328 + dqs_dll_freq = 680; + #else + dqs_dll_freq = 801; + #endif + + if (freq <= dqs_dll_freq) + tmp = 2; + else + tmp = 1; + + for (i = 0; i < 4; i++) { + j = 0x28 + i * 0x10; + writel(tmp, PHY_REG(phy_base, j)); + } +} + +static void sdram_phy_set_ds_odt(void __iomem *phy_base, + u32 dram_type) +{ + u32 cmd_drv, clk_drv, dqs_drv, dqs_odt; + u32 i, j; + + if (dram_type == DDR3) { + cmd_drv = PHY_DDR3_RON_RTT_34ohm; + clk_drv = PHY_DDR3_RON_RTT_45ohm; + dqs_drv = PHY_DDR3_RON_RTT_34ohm; + dqs_odt = PHY_DDR3_RON_RTT_225ohm; + } else { + cmd_drv = PHY_DDR4_LPDDR3_RON_RTT_34ohm; + clk_drv = PHY_DDR4_LPDDR3_RON_RTT_43ohm; + dqs_drv = PHY_DDR4_LPDDR3_RON_RTT_34ohm; + if (dram_type == LPDDR2) + dqs_odt = PHY_DDR4_LPDDR3_RON_RTT_DISABLE; + else + dqs_odt = PHY_DDR4_LPDDR3_RON_RTT_240ohm; + } + /* DS */ + writel(cmd_drv, PHY_REG(phy_base, 0x11)); + clrsetbits_le32(PHY_REG(phy_base, 0x12), 0x1f << 3, cmd_drv << 3); + writel(clk_drv, PHY_REG(phy_base, 0x16)); + writel(clk_drv, PHY_REG(phy_base, 0x18)); + + for (i = 0; i < 4; i++) { + j = 0x20 + i * 0x10; + writel(dqs_drv, PHY_REG(phy_base, j)); + writel(dqs_drv, PHY_REG(phy_base, j + 0xf)); + /* ODT */ + writel(dqs_odt, PHY_REG(phy_base, j + 0x1)); + writel(dqs_odt, PHY_REG(phy_base, j + 0xe)); + } +} + +void phy_soft_reset(void __iomem *phy_base) +{ + clrbits_le32(PHY_REG(phy_base, 0), 0x3 << 2); + udelay(1); + setbits_le32(PHY_REG(phy_base, 0), ANALOG_DERESET); + udelay(5); + setbits_le32(PHY_REG(phy_base, 0), DIGITAL_DERESET); + udelay(1); +} + +void phy_dram_set_bw(void __iomem *phy_base, u32 bw) +{ + if (bw == 2) { + clrsetbits_le32(PHY_REG(phy_base, 0), 0xf << 4, 0xf << 4); + setbits_le32(PHY_REG(phy_base, 0x46), 1 << 3); + setbits_le32(PHY_REG(phy_base, 0x56), 1 << 3); + } else if (bw == 1) { + clrsetbits_le32(PHY_REG(phy_base, 0), 0xf << 4, 3 << 4); + clrbits_le32(PHY_REG(phy_base, 0x46), 1 << 3); + clrbits_le32(PHY_REG(phy_base, 0x56), 1 << 3); + } else if (bw == 0) { + clrsetbits_le32(PHY_REG(phy_base, 0), 0xf << 4, 1 << 4); + clrbits_le32(PHY_REG(phy_base, 0x36), 1 << 3); + clrbits_le32(PHY_REG(phy_base, 0x46), 1 << 3); + clrbits_le32(PHY_REG(phy_base, 0x56), 1 << 3); + } + + phy_soft_reset(phy_base); +} + +int phy_data_training(void __iomem *phy_base, u32 cs, u32 dramtype) +{ + u32 ret; + u32 odt_val; + u32 i, j; + + odt_val = readl(PHY_REG(phy_base, 0x2e)); + + for (i = 0; i < 4; i++) { + j = 0x20 + i * 0x10; + writel(PHY_DDR3_RON_RTT_225ohm, PHY_REG(phy_base, j + 0x1)); + writel(0, PHY_REG(phy_base, j + 0xe)); + } + + if (dramtype == DDR4) { + clrsetbits_le32(PHY_REG(phy_base, 0x29), 0x3, 0); + clrsetbits_le32(PHY_REG(phy_base, 0x39), 0x3, 0); + clrsetbits_le32(PHY_REG(phy_base, 0x49), 0x3, 0); + clrsetbits_le32(PHY_REG(phy_base, 0x59), 0x3, 0); + } + /* choose training cs */ + clrsetbits_le32(PHY_REG(phy_base, 2), 0x33, (0x20 >> cs)); + /* enable gate training */ + clrsetbits_le32(PHY_REG(phy_base, 2), 0x33, (0x20 >> cs) | 1); + udelay(50); + ret = readl(PHY_REG(phy_base, 0xff)); + /* disable gate training */ + clrsetbits_le32(PHY_REG(phy_base, 2), 0x33, (0x20 >> cs) | 0); + #ifndef CONFIG_ROCKCHIP_RK3328 + clrbits_le32(PHY_REG(phy_base, 2), 0x30); + #endif + + if (dramtype == DDR4) { + clrsetbits_le32(PHY_REG(phy_base, 0x29), 0x3, 0x2); + clrsetbits_le32(PHY_REG(phy_base, 0x39), 0x3, 0x2); + clrsetbits_le32(PHY_REG(phy_base, 0x49), 0x3, 0x2); + clrsetbits_le32(PHY_REG(phy_base, 0x59), 0x3, 0x2); + } + + if (ret & 0x10) { + ret = -1; + } else { + ret = (ret & 0xf) ^ (readl(PHY_REG(phy_base, 0)) >> 4); + ret = (ret == 0) ? 0 : -1; + } + + for (i = 0; i < 4; i++) { + j = 0x20 + i * 0x10; + writel(odt_val, PHY_REG(phy_base, j + 0x1)); + writel(odt_val, PHY_REG(phy_base, j + 0xe)); + } + return ret; +} + +void phy_cfg(void __iomem *phy_base, + struct ddr_phy_regs *phy_regs, struct ddr_phy_skew *skew, + struct sdram_base_params *base, u32 bw) +{ + u32 i; + + sdram_phy_dll_bypass_set(phy_base, base->ddr_freq); + for (i = 0; phy_regs->phy[i][0] != 0xFFFFFFFF; i++) { + writel(phy_regs->phy[i][1], + phy_base + phy_regs->phy[i][0]); + } + if (bw == 2) { + clrsetbits_le32(PHY_REG(phy_base, 0), 0xf << 4, 0xf << 4); + } else if (bw == 1) { + clrsetbits_le32(PHY_REG(phy_base, 0), 0xf << 4, 3 << 4); + /* disable DQS2,DQS3 tx dll for saving power */ + clrbits_le32(PHY_REG(phy_base, 0x46), 1 << 3); + clrbits_le32(PHY_REG(phy_base, 0x56), 1 << 3); + } else { + clrsetbits_le32(PHY_REG(phy_base, 0), 0xf << 4, 1 << 4); + /* disable DQS2,DQS3 tx dll for saving power */ + clrbits_le32(PHY_REG(phy_base, 0x36), 1 << 3); + clrbits_le32(PHY_REG(phy_base, 0x46), 1 << 3); + clrbits_le32(PHY_REG(phy_base, 0x56), 1 << 3); + } + sdram_phy_set_ds_odt(phy_base, base->dramtype); + + /* deskew */ + setbits_le32(PHY_REG(phy_base, 2), 8); + sdram_copy_to_reg(PHY_REG(phy_base, 0xb0), + &skew->a0_a1_skew[0], 15 * 4); + sdram_copy_to_reg(PHY_REG(phy_base, 0x70), + &skew->cs0_dm0_skew[0], 44 * 4); + sdram_copy_to_reg(PHY_REG(phy_base, 0xc0), + &skew->cs1_dm0_skew[0], 44 * 4); +}
The noc register bit definition may be the same for different SoC while the offset of the register may be different, add the struction definition as common code.
Signed-off-by: YouMin Chen cym@rock-chips.com Signed-off-by: Kever Yang kever.yang@rock-chips.com ---
Changes in v2: None
.../include/asm/arch-rockchip/sdram_msch.h | 85 +++++++++++++++++++ 1 file changed, 85 insertions(+) create mode 100644 arch/arm/include/asm/arch-rockchip/sdram_msch.h
diff --git a/arch/arm/include/asm/arch-rockchip/sdram_msch.h b/arch/arm/include/asm/arch-rockchip/sdram_msch.h new file mode 100644 index 0000000000..cfb3d9cc86 --- /dev/null +++ b/arch/arm/include/asm/arch-rockchip/sdram_msch.h @@ -0,0 +1,85 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2019 Rockchip Electronics Co., Ltd + */ + +#ifndef _ASM_ARCH_SDRAM_MSCH_H +#define _ASM_ARCH_SDRAM_MSCH_H + +union noc_ddrtiminga0 { + u32 d32; + struct { + unsigned acttoact : 6; + unsigned reserved0 : 2; + unsigned rdtomiss : 6; + unsigned reserved1 : 2; + unsigned wrtomiss : 6; + unsigned reserved2 : 2; + unsigned readlatency : 8; + } b; +}; + +union noc_ddrtimingb0 { + u32 d32; + struct { + unsigned rdtowr : 5; + unsigned reserved0 : 3; + unsigned wrtord : 5; + unsigned reserved1 : 3; + unsigned rrd : 4; + unsigned reserved2 : 4; + unsigned faw : 6; + unsigned reserved3 : 2; + } b; +}; + +union noc_ddrtimingc0 { + u32 d32; + struct { + unsigned burstpenalty : 4; + unsigned reserved0 : 4; + unsigned wrtomwr : 6; + unsigned reserved1 : 18; + } b; +}; + +union noc_devtodev0 { + u32 d32; + struct { + unsigned busrdtord : 3; + unsigned reserved0 : 1; + unsigned busrdtowr : 3; + unsigned reserved1 : 1; + unsigned buswrtord : 3; + unsigned reserved2 : 1; + unsigned buswrtowr : 3; + unsigned reserved3 : 17; + } b; +}; + +union noc_ddrmode { + u32 d32; + struct { + unsigned autoprecharge : 1; + unsigned bypassfiltering : 1; + unsigned fawbank : 1; + unsigned burstsize : 2; + unsigned mwrsize : 2; + unsigned reserved2 : 1; + unsigned forceorder : 8; + unsigned forceorderstate : 8; + unsigned reserved3 : 8; + } b; +}; + +union noc_ddr4timing { + u32 d32; + struct { + unsigned ccdl : 3; + unsigned wrtordl : 5; + unsigned rrdl : 4; + unsigned reserved1 : 20; + } b; +}; + +#endif
Add the sdram driver for PX30 to support ddr3, ddr4, lpddr2 and lpddr3. The PX30 SoC support driver is suppose to follow up later.
Changes in v2: None
.../include/asm/arch-rockchip/sdram_px30.h | 212 ++++++ .../rockchip/sdram-px30-ddr3-detect-333.inc | 72 ++ .../rockchip/sdram-px30-ddr4-detect-333.inc | 75 ++ drivers/ram/rockchip/sdram-px30-ddr_skew.inc | 121 ++++ .../rockchip/sdram-px30-lpddr2-detect-333.inc | 73 ++ .../rockchip/sdram-px30-lpddr3-detect-333.inc | 74 ++ drivers/ram/rockchip/sdram_px30.c | 669 ++++++++++++++++++ 7 files changed, 1296 insertions(+) create mode 100644 arch/arm/include/asm/arch-rockchip/sdram_px30.h create mode 100644 drivers/ram/rockchip/sdram-px30-ddr3-detect-333.inc create mode 100644 drivers/ram/rockchip/sdram-px30-ddr4-detect-333.inc create mode 100644 drivers/ram/rockchip/sdram-px30-ddr_skew.inc create mode 100644 drivers/ram/rockchip/sdram-px30-lpddr2-detect-333.inc create mode 100644 drivers/ram/rockchip/sdram-px30-lpddr3-detect-333.inc create mode 100644 drivers/ram/rockchip/sdram_px30.c
diff --git a/arch/arm/include/asm/arch-rockchip/sdram_px30.h b/arch/arm/include/asm/arch-rockchip/sdram_px30.h new file mode 100644 index 0000000000..9b608a9224 --- /dev/null +++ b/arch/arm/include/asm/arch-rockchip/sdram_px30.h @@ -0,0 +1,212 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2018 Rockchip Electronics Co., Ltd + */ + +#ifndef _ASM_ARCH_SDRAM_PX30_H +#define _ASM_ARCH_SDRAM_PX30_H +#include <asm/arch-rockchip/sdram_common.h> +#include <asm/arch-rockchip/sdram_msch.h> +#include <asm/arch-rockchip/sdram_pctl_px30.h> +#include <asm/arch-rockchip/sdram_phy_px30.h> +#include <asm/arch-rockchip/sdram_phy_ron_rtt_px30.h> + +#define SR_IDLE 93 +#define PD_IDLE 13 + +/* PMUGRF */ +#define PMUGRF_OS_REG0 (0x200) +#define PMUGRF_OS_REG(n) (PMUGRF_OS_REG0 + (n) * 4) + +/* DDR GRF */ +#define DDR_GRF_CON(n) (0 + (n) * 4) +#define DDR_GRF_STATUS_BASE (0X100) +#define DDR_GRF_STATUS(n) (DDR_GRF_STATUS_BASE + (n) * 4) +#define DDR_GRF_LP_CON (0x20) + +#define SPLIT_MODE_32_L16_VALID (0) +#define SPLIT_MODE_32_H16_VALID (1) +#define SPLIT_MODE_16_L8_VALID (2) +#define SPLIT_MODE_16_H8_VALID (3) + +#define DDR_GRF_SPLIT_CON (0x8) +#define SPLIT_MODE_MASK (0x3) +#define SPLIT_MODE_OFFSET (9) +#define SPLIT_BYPASS_MASK (1) +#define SPLIT_BYPASS_OFFSET (8) +#define SPLIT_SIZE_MASK (0xff) +#define SPLIT_SIZE_OFFSET (0) + +/* CRU define */ +/* CRU_PLL_CON0 */ +#define PB(n) ((0x1 << (15 + 16)) | ((n) << 15)) +#define POSTDIV1(n) ((0x7 << (12 + 16)) | ((n) << 12)) +#define FBDIV(n) ((0xFFF << 16) | (n)) + +/* CRU_PLL_CON1 */ +#define RSTMODE(n) ((0x1 << (15 + 16)) | ((n) << 15)) +#define RST(n) ((0x1 << (14 + 16)) | ((n) << 14)) +#define PD(n) ((0x1 << (13 + 16)) | ((n) << 13)) +#define DSMPD(n) ((0x1 << (12 + 16)) | ((n) << 12)) +#define LOCK(n) (((n) >> 10) & 0x1) +#define POSTDIV2(n) ((0x7 << (6 + 16)) | ((n) << 6)) +#define REFDIV(n) ((0x3F << 16) | (n)) + +/* CRU_MODE */ +#define CLOCK_FROM_XIN_OSC (0) +#define CLOCK_FROM_PLL (1) +#define CLOCK_FROM_RTC_32K (2) +#define DPLL_MODE(n) ((0x3 << (4 + 16)) | ((n) << 4)) + +/* CRU_SOFTRESET_CON1 */ +#define upctl2_psrstn_req(n) (((0x1 << 6) << 16) | ((n) << 6)) +#define upctl2_asrstn_req(n) (((0x1 << 5) << 16) | ((n) << 5)) +#define upctl2_srstn_req(n) (((0x1 << 4) << 16) | ((n) << 4)) + +/* CRU_SOFTRESET_CON2 */ +#define ddrphy_psrstn_req(n) (((0x1 << 2) << 16) | ((n) << 2)) +#define ddrphy_srstn_req(n) (((0x1 << 0) << 16) | ((n) << 0)) + +/* CRU register */ +#define CRU_PLL_CON(pll_id, n) ((pll_id) * 0x20 + (n) * 4) +#define CRU_MODE (0xa0) +#define CRU_GLB_CNT_TH (0xb0) +#define CRU_CLKSEL_CON_BASE 0x100 +#define CRU_CLKSELS_CON(i) (CRU_CLKSEL_CON_BASE + ((i) * 4)) +#define CRU_CLKGATE_CON_BASE 0x200 +#define CRU_CLKGATE_CON(i) (CRU_CLKGATE_CON_BASE + ((i) * 4)) +#define CRU_CLKSFTRST_CON_BASE 0x300 +#define CRU_CLKSFTRST_CON(i) (CRU_CLKSFTRST_CON_BASE + ((i) * 4)) + +u8 ddr_cfg_2_rbc[] = { + /* + * [6:4] max row: 13+n + * [3] bank(0:4bank,1:8bank) + * [2:0] col(10+n) + */ + ((5 << 4) | (1 << 3) | 0), /* 0 */ + ((5 << 4) | (1 << 3) | 1), /* 1 */ + ((4 << 4) | (1 << 3) | 2), /* 2 */ + ((3 << 4) | (1 << 3) | 3), /* 3 */ + ((2 << 4) | (1 << 3) | 4), /* 4 */ + ((5 << 4) | (0 << 3) | 2), /* 5 */ + ((4 << 4) | (1 << 3) | 2), /* 6 */ + /*((0<<3)|3),*/ /* 12 for ddr4 */ + /*((1<<3)|1),*/ /* 13 B,C exchange for rkvdec */ +}; + +/* + * for ddr4 if ddrconfig=7, upctl should set 7 and noc should + * set to 1 for more efficient. + * noc ddrconf, upctl addrmap + * 1 7 + * 2 8 + * 3 9 + * 12 10 + * 5 11 + */ +u8 d4_rbc_2_d3_rbc[] = { + 1, /* 7 */ + 2, /* 8 */ + 3, /* 9 */ + 12, /* 10 */ + 5, /* 11 */ +}; + +/* + * row higher than cs should be disabled by set to 0xf + * rank addrmap calculate by real cap. + */ +u32 addrmap[][8] = { + /* map0 map1, map2, map3, map4, map5 + * map6, map7, map8 + * ------------------------------------------------------- + * bk2-0 col 5-2 col 9-6 col 11-10 row 11-0 + * row 15-12 row 17-16 bg1,0 + * ------------------------------------------------------- + * 4,3,2 5-2 9-6 6 + * 3,2 + */ + {0x00060606, 0x00000000, 0x1f1f0000, 0x00001f1f, 0x05050505, + 0x05050505, 0x00000505, 0x3f3f}, /* 0 */ + {0x00070707, 0x00000000, 0x1f000000, 0x00001f1f, 0x06060606, + 0x06060606, 0x06060606, 0x3f3f}, /* 1 */ + {0x00080808, 0x00000000, 0x00000000, 0x00001f1f, 0x07070707, + 0x07070707, 0x00000f07, 0x3f3f}, /* 2 */ + {0x00090909, 0x00000000, 0x00000000, 0x00001f00, 0x08080808, + 0x08080808, 0x00000f0f, 0x3f3f}, /* 3 */ + {0x000a0a0a, 0x00000000, 0x00000000, 0x00000000, 0x09090909, + 0x0f090909, 0x00000f0f, 0x3f3f}, /* 4 */ + {0x00080808, 0x00000000, 0x00000000, 0x00001f1f, 0x06060606, + 0x06060606, 0x00000606, 0x3f3f}, /* 5 */ + {0x00080808, 0x00000000, 0x00000000, 0x00001f1f, 0x07070707, + 0x07070707, 0x00000f0f, 0x3f3f}, /* 6 */ + {0x003f0808, 0x00000006, 0x1f1f0000, 0x00001f1f, 0x06060606, + 0x06060606, 0x00000606, 0x0600}, /* 7 */ + {0x003f0909, 0x00000007, 0x1f000000, 0x00001f1f, 0x07070707, + 0x07070707, 0x00000f07, 0x0700}, /* 8 */ + {0x003f0a0a, 0x01010100, 0x01010101, 0x00001f1f, 0x08080808, + 0x08080808, 0x00000f0f, 0x0801}, /* 9 */ + {0x003f0909, 0x01010100, 0x01010101, 0x00001f1f, 0x07070707, + 0x07070707, 0x00000f07, 0x3f01}, /* 10 */ + {0x003f0808, 0x00000007, 0x1f000000, 0x00001f1f, 0x06060606, + 0x06060606, 0x00000606, 0x3f00}, /* 11 */ + /* when ddr4 12 map to 10, when ddr3 12 unused */ + {0x003f0909, 0x01010100, 0x01010101, 0x00001f1f, 0x07070707, + 0x07070707, 0x00000f07, 0x3f01}, /* 10 */ + {0x00070706, 0x00000000, 0x1f010000, 0x00001f1f, 0x06060606, + 0x06060606, 0x00000606, 0x3f3f}, /* 13 */ +}; + +struct px30_ddr_grf_regs { + u32 ddr_grf_con[4]; + u32 reserved1[(0x20 - 0x10) / 4]; + u32 ddr_grf_lp_con; + u32 reserved2[(0x100 - 0x24) / 4]; + u32 ddr_grf_status[11]; +}; + +struct msch_regs { + u32 coreid; + u32 revisionid; + u32 deviceconf; + u32 devicesize; + u32 ddrtiminga0; + u32 ddrtimingb0; + u32 ddrtimingc0; + u32 devtodev0; + u32 reserved1[(0x110 - 0x20) / 4]; + u32 ddrmode; + u32 ddr4timing; + u32 reserved2[(0x1000 - 0x118) / 4]; + u32 agingx0; + u32 reserved3[(0x1040 - 0x1004) / 4]; + u32 aging0; + u32 aging1; + u32 aging2; + u32 aging3; +}; + +struct sdram_msch_timings { + union noc_ddrtiminga0 ddrtiminga0; + union noc_ddrtimingb0 ddrtimingb0; + union noc_ddrtimingc0 ddrtimingc0; + union noc_devtodev0 devtodev0; + union noc_ddrmode ddrmode; + union noc_ddr4timing ddr4timing; + u32 agingx0; +}; + +struct px30_sdram_channel { + struct sdram_cap_info cap_info; + struct sdram_msch_timings noc_timings; +}; + +struct px30_sdram_params { + struct px30_sdram_channel ch; + struct sdram_base_params base; + struct ddr_pctl_regs pctl_regs; + struct ddr_phy_regs phy_regs; + struct ddr_phy_skew *skew; +}; +#endif diff --git a/drivers/ram/rockchip/sdram-px30-ddr3-detect-333.inc b/drivers/ram/rockchip/sdram-px30-ddr3-detect-333.inc new file mode 100644 index 0000000000..76cd8dc1a5 --- /dev/null +++ b/drivers/ram/rockchip/sdram-px30-ddr3-detect-333.inc @@ -0,0 +1,72 @@ +{ + { + { + .rank = 0x1, + .col = 0xC, + .bk = 0x3, + .bw = 0x1, + .dbw = 0x0, + .row_3_4 = 0x0, + .cs0_row = 0x10, + .cs1_row = 0x10, + .cs0_high16bit_row = 0x10, + .cs1_high16bit_row = 0x10, + .ddrconfig = 0, + }, + { + {0x290b0609}, + {0x08020401}, + {0x00000002}, + {0x00001111}, + {0x0000000c}, + {0x00000222}, + 0x000000ff + } + }, + { + .ddr_freq = 333, + .dramtype = DDR3, + .num_channels = 1, + .stride = 0, + .odt = 0, + }, + { + { + {0x00000000, 0x43041001}, /* MSTR */ + {0x00000064, 0x0028003b}, /* RFSHTMG */ + {0x000000d0, 0x00020053}, /* INIT0 */ + {0x000000d4, 0x00020000}, /* INIT1 */ + {0x000000d8, 0x00000100}, /* INIT2 */ + {0x000000dc, 0x03200000}, /* INIT3 */ + {0x000000e0, 0x00000000}, /* INIT4 */ + {0x000000e4, 0x00090000}, /* INIT5 */ + {0x000000f4, 0x000f012f}, /* RANKCTL */ + {0x00000100, 0x07090b06}, /* DRAMTMG0 */ + {0x00000104, 0x00050209}, /* DRAMTMG1 */ + {0x00000108, 0x03030407}, /* DRAMTMG2 */ + {0x0000010c, 0x00202006}, /* DRAMTMG3 */ + {0x00000110, 0x03020204}, /* DRAMTMG4 */ + {0x00000114, 0x03030202}, /* DRAMTMG5 */ + {0x00000120, 0x00000903}, /* DRAMTMG8 */ + {0x00000180, 0x00800020}, /* ZQCTL0 */ + {0x00000184, 0x00000000}, /* ZQCTL1 */ + {0x00000190, 0x07010001}, /* DFITMG0 */ + {0x00000198, 0x07000101}, /* DFILPCFG0 */ + {0x000001a0, 0xc0400003}, /* DFIUPD0 */ + {0x00000240, 0x06000604}, /* ODTCFG */ + {0x00000244, 0x00000201}, /* ODTMAP */ + {0x00000250, 0x00001f00}, /* SCHED */ + {0x00000490, 0x00000001}, /* PCTRL_0 */ + {0xffffffff, 0xffffffff} + } + }, + { + { + {0x00000004, 0x0000000a}, /* PHYREG01 */ + {0x00000028, 0x00000006}, /* PHYREG0A */ + {0x0000002c, 0x00000000}, /* PHYREG0B */ + {0x00000030, 0x00000005}, /* PHYREG0C */ + {0xffffffff, 0xffffffff} + } + } +}, diff --git a/drivers/ram/rockchip/sdram-px30-ddr4-detect-333.inc b/drivers/ram/rockchip/sdram-px30-ddr4-detect-333.inc new file mode 100644 index 0000000000..f804d28393 --- /dev/null +++ b/drivers/ram/rockchip/sdram-px30-ddr4-detect-333.inc @@ -0,0 +1,75 @@ +{ + { + { + .rank = 0x1, + .col = 0xA, + .bk = 0x2, + .bw = 0x1, + .dbw = 0x0, + .row_3_4 = 0x0, + .cs0_row = 0x11, + .cs1_row = 0x0, + .cs0_high16bit_row = 0x11, + .cs1_high16bit_row = 0x0, + .ddrconfig = 0, + }, + { + {0x4d110a08}, + {0x06020501}, + {0x00000002}, + {0x00001111}, + {0x0000000c}, + {0x0000022a}, + 0x000000ff + } + }, + { + .ddr_freq = 333, + .dramtype = DDR4, + .num_channels = 1, + .stride = 0, + .odt = 0, + }, + { + { + {0x00000000, 0x43049010}, /* MSTR */ + {0x00000064, 0x0028003b}, /* RFSHTMG */ + {0x000000d0, 0x00020053}, /* INIT0 */ + {0x000000d4, 0x00220000}, /* INIT1 */ + {0x000000d8, 0x00000100}, /* INIT2 */ + {0x000000dc, 0x00040000}, /* INIT3 */ + {0x000000e0, 0x00000000}, /* INIT4 */ + {0x000000e4, 0x00110000}, /* INIT5 */ + {0x000000e8, 0x00000420}, /* INIT6 */ + {0x000000ec, 0x00000400}, /* INIT7 */ + {0x000000f4, 0x000f012f}, /* RANKCTL */ + {0x00000100, 0x09060b06}, /* DRAMTMG0 */ + {0x00000104, 0x00020209}, /* DRAMTMG1 */ + {0x00000108, 0x0505040a}, /* DRAMTMG2 */ + {0x0000010c, 0x0040400c}, /* DRAMTMG3 */ + {0x00000110, 0x05030206}, /* DRAMTMG4 */ + {0x00000114, 0x03030202}, /* DRAMTMG5 */ + {0x00000120, 0x03030b03}, /* DRAMTMG8 */ + {0x00000124, 0x00020208}, /* DRAMTMG9 */ + {0x00000180, 0x01000040}, /* ZQCTL0 */ + {0x00000184, 0x00000000}, /* ZQCTL1 */ + {0x00000190, 0x07030003}, /* DFITMG0 */ + {0x00000198, 0x07000101}, /* DFILPCFG0 */ + {0x000001a0, 0xc0400003}, /* DFIUPD0 */ + {0x00000240, 0x06000604}, /* ODTCFG */ + {0x00000244, 0x00000201}, /* ODTMAP */ + {0x00000250, 0x00001f00}, /* SCHED */ + {0x00000490, 0x00000001}, /* PCTRL_0 */ + {0xffffffff, 0xffffffff} + } + }, + { + { + {0x00000004, 0x0000000c}, /* PHYREG01 */ + {0x00000028, 0x0000000a}, /* PHYREG0A */ + {0x0000002c, 0x00000000}, /* PHYREG0B */ + {0x00000030, 0x00000009}, /* PHYREG0C */ + {0xffffffff, 0xffffffff} + } + } +}, \ No newline at end of file diff --git a/drivers/ram/rockchip/sdram-px30-ddr_skew.inc b/drivers/ram/rockchip/sdram-px30-ddr_skew.inc new file mode 100644 index 0000000000..f24343dda1 --- /dev/null +++ b/drivers/ram/rockchip/sdram-px30-ddr_skew.inc @@ -0,0 +1,121 @@ + { + 0x77, + 0x88, + 0x79, + 0x79, + 0x87, + 0x97, + 0x87, + 0x78, + 0x77, + 0x78, + 0x87, + 0x88, + 0x87, + 0x87, + 0x77 + }, + { + 0x78, + 0x78, + 0x78, + 0x78, + 0x78, + 0x78, + 0x78, + 0x78, + 0x78, + 0x69, + 0x9, + }, + { + 0x77, + 0x78, + 0x77, + 0x78, + 0x77, + 0x78, + 0x77, + 0x78, + 0x77, + 0x79, + 0x9, + }, + { + 0x78, + 0x78, + 0x78, + 0x78, + 0x78, + 0x78, + 0x78, + 0x78, + 0x78, + 0x69, + 0x9, + }, + { + 0x77, + 0x78, + 0x77, + 0x77, + 0x77, + 0x77, + 0x77, + 0x77, + 0x77, + 0x79, + 0x9, + }, + { + 0x78, + 0x78, + 0x78, + 0x78, + 0x78, + 0x78, + 0x78, + 0x78, + 0x78, + 0x69, + 0x9, + }, + { + 0x77, + 0x78, + 0x77, + 0x78, + 0x77, + 0x78, + 0x77, + 0x78, + 0x77, + 0x79, + 0x9, + }, + { + 0x78, + 0x78, + 0x78, + 0x78, + 0x78, + 0x78, + 0x78, + 0x78, + 0x78, + 0x69, + 0x9, + }, + { + 0x77, + 0x78, + 0x77, + 0x77, + 0x77, + 0x77, + 0x77, + 0x77, + 0x77, + 0x79, + 0x9, + } diff --git a/drivers/ram/rockchip/sdram-px30-lpddr2-detect-333.inc b/drivers/ram/rockchip/sdram-px30-lpddr2-detect-333.inc new file mode 100644 index 0000000000..948ade483b --- /dev/null +++ b/drivers/ram/rockchip/sdram-px30-lpddr2-detect-333.inc @@ -0,0 +1,73 @@ +{ + { + { + .rank = 0x1, + .col = 0xC, + .bk = 0x3, + .bw = 0x1, + .dbw = 0x0, + .row_3_4 = 0x0, + .cs0_row = 0xF, + .cs1_row = 0xF, + .cs0_high16bit_row = 0xF, + .cs1_high16bit_row = 0xF, + .ddrconfig = 0, + }, + { + {0x2b0c070a}, + {0x08020303}, + {0x00000002}, + {0x00001111}, + {0x0000000c}, + {0x00000219}, + 0x000000ff + } + }, + { + .ddr_freq = 333, + .dramtype = LPDDR2, + .num_channels = 1, + .stride = 0, + .odt = 0, + }, + { + { + {0x00000000, 0x41041004}, /* MSTR */ + {0x00000064, 0x00140023}, /* RFSHTMG */ + {0x000000d0, 0x00220002}, /* INIT0 */ + {0x000000d4, 0x00010000}, /* INIT1 */ + {0x000000d8, 0x00000703}, /* INIT2 */ + {0x000000dc, 0x00630005}, /* INIT3 */ + {0x000000e0, 0x00010000}, /* INIT4 */ + {0x000000e4, 0x00070003}, /* INIT5 */ + {0x000000f4, 0x000f012f}, /* RANKCTL */ + {0x00000100, 0x07090b07}, /* DRAMTMG0 */ + {0x00000104, 0x0002010b}, /* DRAMTMG1 */ + {0x00000108, 0x02040506}, /* DRAMTMG2 */ + {0x0000010c, 0x00303000}, /* DRAMTMG3 */ + {0x00000110, 0x04010204}, /* DRAMTMG4 */ + {0x00000114, 0x01010303}, /* DRAMTMG5 */ + {0x00000118, 0x02020003}, /* DRAMTMG6 */ + {0x00000120, 0x00000303}, /* DRAMTMG8 */ + {0x00000138, 0x00000025}, /* DRAMTMG14 */ + {0x00000180, 0x003c000f}, /* ZQCTL0 */ + {0x00000184, 0x00900000}, /* ZQCTL1 */ + {0x00000190, 0x07020001}, /* DFITMG0 */ + {0x00000198, 0x07000101}, /* DFILPCFG0 */ + {0x000001a0, 0xc0400003}, /* DFIUPD0 */ + {0x00000240, 0x07030718}, /* ODTCFG */ + {0x00000250, 0x00001f00}, /* SCHED */ + {0x00000490, 0x00000001}, /* PCTRL_0 */ + {0xffffffff, 0xffffffff} + } + }, + { + { + {0x00000004, 0x00000009}, /* PHYREG01 */ + {0x00000028, 0x00000007}, /* PHYREG0A */ + {0x0000002c, 0x00000000}, /* PHYREG0B */ + {0x00000030, 0x00000004}, /* PHYREG0C */ + {0xffffffff, 0xffffffff} + } + } +}, diff --git a/drivers/ram/rockchip/sdram-px30-lpddr3-detect-333.inc b/drivers/ram/rockchip/sdram-px30-lpddr3-detect-333.inc new file mode 100644 index 0000000000..f694a0e5b0 --- /dev/null +++ b/drivers/ram/rockchip/sdram-px30-lpddr3-detect-333.inc @@ -0,0 +1,74 @@ +{ + { + { + .rank = 0x1, + .col = 0xC, + .bk = 0x3, + .bw = 0x1, + .dbw = 0x0, + .row_3_4 = 0x0, + .cs0_row = 0x10, + .cs1_row = 0x10, + .cs0_high16bit_row = 0x10, + .cs1_high16bit_row = 0x10, + .ddrconfig = 0, + }, + { + {0x290a060a}, + {0x08020303}, + {0x00000002}, + {0x00001111}, + {0x0000000c}, + {0x0000021a}, + 0x000000ff + } + }, + { + .ddr_freq = 333, + .dramtype = LPDDR3, + .num_channels = 1, + .stride = 0, + .odt = 0, + }, + { + { + {0x00000000, 0x43041008}, /* MSTR */ + {0x00000064, 0x00140023}, /* RFSHTMG */ + {0x000000d0, 0x00220002}, /* INIT0 */ + {0x000000d4, 0x00010000}, /* INIT1 */ + {0x000000d8, 0x00000703}, /* INIT2 */ + {0x000000dc, 0x00830004}, /* INIT3 */ + {0x000000e0, 0x00010000}, /* INIT4 */ + {0x000000e4, 0x00070003}, /* INIT5 */ + {0x000000f4, 0x000f012f}, /* RANKCTL */ + {0x00000100, 0x06090b07}, /* DRAMTMG0 */ + {0x00000104, 0x0002020b}, /* DRAMTMG1 */ + {0x00000108, 0x02030506}, /* DRAMTMG2 */ + {0x0000010c, 0x00505000}, /* DRAMTMG3 */ + {0x00000110, 0x03020204}, /* DRAMTMG4 */ + {0x00000114, 0x01010303}, /* DRAMTMG5 */ + {0x00000118, 0x02020003}, /* DRAMTMG6 */ + {0x00000120, 0x00000303}, /* DRAMTMG8 */ + {0x00000138, 0x00000025}, /* DRAMTMG14 */ + {0x00000180, 0x003c000f}, /* ZQCTL0 */ + {0x00000184, 0x00900000}, /* ZQCTL1 */ + {0x00000190, 0x07020000}, /* DFITMG0 */ + {0x00000198, 0x07000101}, /* DFILPCFG0 */ + {0x000001a0, 0xc0400003}, /* DFIUPD0 */ + {0x00000240, 0x0900090c}, /* ODTCFG */ + {0x00000244, 0x00000101}, /* ODTMAP */ + {0x00000250, 0x00001f00}, /* SCHED */ + {0x00000490, 0x00000001}, /* PCTRL_0 */ + {0xffffffff, 0xffffffff} + } + }, + { + { + {0x00000004, 0x0000000b}, /* PHYREG01 */ + {0x00000028, 0x00000006}, /* PHYREG0A */ + {0x0000002c, 0x00000000}, /* PHYREG0B */ + {0x00000030, 0x00000003}, /* PHYREG0C */ + {0xffffffff, 0xffffffff} + } + } +}, diff --git a/drivers/ram/rockchip/sdram_px30.c b/drivers/ram/rockchip/sdram_px30.c new file mode 100644 index 0000000000..c4641c2aba --- /dev/null +++ b/drivers/ram/rockchip/sdram_px30.c @@ -0,0 +1,669 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * (C) Copyright 2018 Rockchip Electronics Co., Ltd. + */ + +#include <common.h> +#include <debug_uart.h> +#include <dm.h> +#include <ram.h> +#include <syscon.h> +#include <asm/io.h> +#include <asm/arch-rockchip/clock.h> +#include <asm/arch-rockchip/cru_px30.h> +#include <asm/arch-rockchip/grf_px30.h> +#include <asm/arch-rockchip/hardware.h> +#include <asm/arch-rockchip/sdram.h> +#include <asm/arch-rockchip/sdram_px30.h> + +/* + * Because px30 sram size is small, so need define CONFIG_TPL_TINY_FRAMEWORK + * to reduce TPL size when build TPL firmware. + */ +#ifdef CONFIG_TPL_BUILD +#ifndef CONFIG_TPL_TINY_FRAMEWORK +#error please defined CONFIG_TPL_TINY_FRAMEWORK for px30 !!! +#endif +#endif + +#ifdef CONFIG_TPL_BUILD + +struct dram_info { + struct ddr_pctl_regs *pctl; + struct ddr_phy_regs *phy; + struct px30_cru *cru; + struct msch_regs *msch; + struct px30_ddr_grf_regs *ddr_grf; + struct px30_grf *grf; + struct ram_info info; + struct px30_pmugrf *pmugrf; +}; + +#define PMUGRF_BASE_ADDR 0xFF010000 +#define CRU_BASE_ADDR 0xFF2B0000 +#define GRF_BASE_ADDR 0xFF140000 +#define DDRC_BASE_ADDR 0xFF600000 +#define DDR_PHY_BASE_ADDR 0xFF2A0000 +#define SERVER_MSCH0_BASE_ADDR 0xFF530000 +#define DDR_GRF_BASE_ADDR 0xff630000 + +struct dram_info dram_info; + +struct px30_sdram_params sdram_configs[] = { +#include "sdram-px30-ddr3-detect-333.inc" +}; + +struct ddr_phy_skew skew = { +#include "sdram-px30-ddr_skew.inc" +}; + +static void rkclk_ddr_reset(struct dram_info *dram, + u32 ctl_srstn, u32 ctl_psrstn, + u32 phy_srstn, u32 phy_psrstn) +{ + writel(upctl2_srstn_req(ctl_srstn) | upctl2_psrstn_req(ctl_psrstn) | + upctl2_asrstn_req(ctl_srstn), + &dram->cru->softrst_con[1]); + writel(ddrphy_srstn_req(phy_srstn) | ddrphy_psrstn_req(phy_psrstn), + &dram->cru->softrst_con[2]); +} + +static void rkclk_set_dpll(struct dram_info *dram, unsigned int hz) +{ + unsigned int refdiv, postdiv1, postdiv2, fbdiv; + int delay = 1000; + u32 mhz = hz / MHz; + + refdiv = 1; + if (mhz <= 300) { + postdiv1 = 4; + postdiv2 = 2; + } else if (mhz <= 400) { + postdiv1 = 6; + postdiv2 = 1; + } else if (mhz <= 600) { + postdiv1 = 4; + postdiv2 = 1; + } else if (mhz <= 800) { + postdiv1 = 3; + postdiv2 = 1; + } else if (mhz <= 1600) { + postdiv1 = 2; + postdiv2 = 1; + } else { + postdiv1 = 1; + postdiv2 = 1; + } + fbdiv = (mhz * refdiv * postdiv1 * postdiv2) / 24; + + writel(DPLL_MODE(CLOCK_FROM_XIN_OSC), &dram->cru->mode); + + writel(POSTDIV1(postdiv1) | FBDIV(fbdiv), &dram->cru->pll[1].con0); + writel(DSMPD(1) | POSTDIV2(postdiv2) | REFDIV(refdiv), + &dram->cru->pll[1].con1); + + while (delay > 0) { + udelay(1); + if (LOCK(readl(&dram->cru->pll[1].con1))) + break; + delay--; + } + + writel(DPLL_MODE(CLOCK_FROM_PLL), &dram->cru->mode); +} + +static void rkclk_configure_ddr(struct dram_info *dram, + struct px30_sdram_params *sdram_params) +{ + /* for inno ddr phy need 2*freq */ + rkclk_set_dpll(dram, sdram_params->base.ddr_freq * MHz * 2); +} + +/* return ddrconfig value + * (-1), find ddrconfig fail + * other, the ddrconfig value + * only support cs0_row >= cs1_row + */ +static unsigned int calculate_ddrconfig(struct px30_sdram_params *sdram_params) +{ + struct sdram_cap_info *cap_info = &sdram_params->ch.cap_info; + u32 bw, die_bw, col, bank; + u32 i, tmp; + u32 ddrconf = -1; + + bw = cap_info->bw; + die_bw = cap_info->dbw; + col = cap_info->col; + bank = cap_info->bk; + + if (sdram_params->base.dramtype == DDR4) { + if (die_bw == 0) + ddrconf = 7 + bw; + else + ddrconf = 12 - bw; + ddrconf = d4_rbc_2_d3_rbc[ddrconf - 7]; + } else { + tmp = ((bank - 2) << 3) | (col + bw - 10); + for (i = 0; i < 7; i++) + if ((ddr_cfg_2_rbc[i] & 0xf) == tmp) { + ddrconf = i; + break; + } + if (i > 6) + printascii("calculate ddrconfig error\n"); + } + + return ddrconf; +} + +/* + * calculate controller dram address map, and setting to register. + * argument sdram_params->ch.ddrconf must be right value before + * call this function. + */ +static void set_ctl_address_map(struct dram_info *dram, + struct px30_sdram_params *sdram_params) +{ + struct sdram_cap_info *cap_info = &sdram_params->ch.cap_info; + void __iomem *pctl_base = dram->pctl; + u32 cs_pst, bg, max_row, ddrconf; + u32 i; + + if (sdram_params->base.dramtype == DDR4) + /* + * DDR4 8bit dram BG = 2(4bank groups), + * 16bit dram BG = 1 (2 bank groups) + */ + bg = (cap_info->dbw == 0) ? 2 : 1; + else + bg = 0; + + cs_pst = cap_info->bw + cap_info->col + + bg + cap_info->bk + cap_info->cs0_row; + if (cs_pst >= 32 || cap_info->rank == 1) + writel(0x1f, pctl_base + DDR_PCTL2_ADDRMAP0); + else + writel(cs_pst - 8, pctl_base + DDR_PCTL2_ADDRMAP0); + + ddrconf = cap_info->ddrconfig; + if (sdram_params->base.dramtype == DDR4) { + for (i = 0; i < ARRAY_SIZE(d4_rbc_2_d3_rbc); i++) { + if (d4_rbc_2_d3_rbc[i] == ddrconf) { + ddrconf = 7 + i; + break; + } + } + } + + sdram_copy_to_reg((u32 *)(pctl_base + DDR_PCTL2_ADDRMAP1), + &addrmap[ddrconf][0], 8 * 4); + max_row = cs_pst - 1 - 8 - (addrmap[ddrconf][5] & 0xf); + + if (max_row < 12) + printascii("set addrmap fail\n"); + /* need to disable row ahead of rank by set to 0xf */ + for (i = 17; i > max_row; i--) + clrsetbits_le32(pctl_base + DDR_PCTL2_ADDRMAP6 + + ((i - 12) * 8 / 32) * 4, + 0xf << ((i - 12) * 8 % 32), + 0xf << ((i - 12) * 8 % 32)); + + if ((sdram_params->base.dramtype == LPDDR3 || + sdram_params->base.dramtype == LPDDR2) && + cap_info->row_3_4) + setbits_le32(pctl_base + DDR_PCTL2_ADDRMAP6, 1 << 31); + if (sdram_params->base.dramtype == DDR4 && cap_info->bw != 0x2) + setbits_le32(pctl_base + DDR_PCTL2_PCCFG, 1 << 8); +} + +/* + * rank = 1: cs0 + * rank = 2: cs1 + */ +int read_mr(struct dram_info *dram, u32 rank, u32 mr_num) +{ + void __iomem *ddr_grf_base = dram->ddr_grf; + + pctl_read_mr(dram->pctl, rank, mr_num); + + return (readl(ddr_grf_base + DDR_GRF_STATUS(0)) & 0xff); +} + +#define MIN(a, b) (((a) > (b)) ? (b) : (a)) +#define MAX(a, b) (((a) > (b)) ? (a) : (b)) +static u32 check_rd_gate(struct dram_info *dram) +{ + void __iomem *phy_base = dram->phy; + + u32 max_val = 0; + u32 min_val = 0xff; + u32 gate[4]; + u32 i, bw; + + bw = (readl(PHY_REG(phy_base, 0x0)) >> 4) & 0xf; + switch (bw) { + case 0x1: + bw = 1; + break; + case 0x3: + bw = 2; + break; + case 0xf: + default: + bw = 4; + break; + } + + for (i = 0; i < bw; i++) { + gate[i] = readl(PHY_REG(phy_base, 0xfb + i)); + max_val = MAX(max_val, gate[i]); + min_val = MIN(min_val, gate[i]); + } + + if (max_val > 0x80 || min_val < 0x20) + return -1; + else + return 0; +} + +static int data_training(struct dram_info *dram, u32 cs, u32 dramtype) +{ + void __iomem *pctl_base = dram->pctl; + u32 dis_auto_zq = 0; + u32 pwrctl; + u32 ret; + + /* disable auto low-power */ + pwrctl = readl(pctl_base + DDR_PCTL2_PWRCTL); + writel(0, pctl_base + DDR_PCTL2_PWRCTL); + + dis_auto_zq = pctl_dis_zqcs_aref(dram->pctl); + + ret = phy_data_training(dram->phy, cs, dramtype); + + pctl_rest_zqcs_aref(dram->pctl, dis_auto_zq); + + /* restore auto low-power */ + writel(pwrctl, pctl_base + DDR_PCTL2_PWRCTL); + + return ret; +} + +static void dram_set_bw(struct dram_info *dram, u32 bw) +{ + phy_dram_set_bw(dram->phy, bw); +} + +static void set_ddrconfig(struct dram_info *dram, u32 ddrconfig) +{ + writel(ddrconfig | (ddrconfig << 8), &dram->msch->deviceconf); + rk_clrsetreg(&dram->grf->soc_noc_con[1], 0x3 << 14, 0 << 14); +} + +static void sdram_msch_config(struct msch_regs *msch, + struct sdram_msch_timings *noc_timings, + struct sdram_cap_info *cap_info, + struct sdram_base_params *base) +{ + u64 cs_cap[2]; + + cs_cap[0] = sdram_get_cs_cap(cap_info, 0, base->dramtype); + cs_cap[1] = sdram_get_cs_cap(cap_info, 1, base->dramtype); + writel(((((cs_cap[1] >> 20) / 64) & 0xff) << 8) | + (((cs_cap[0] >> 20) / 64) & 0xff), + &msch->devicesize); + + writel(noc_timings->ddrtiminga0.d32, + &msch->ddrtiminga0); + writel(noc_timings->ddrtimingb0.d32, + &msch->ddrtimingb0); + writel(noc_timings->ddrtimingc0.d32, + &msch->ddrtimingc0); + writel(noc_timings->devtodev0.d32, + &msch->devtodev0); + writel(noc_timings->ddrmode.d32, &msch->ddrmode); + writel(noc_timings->ddr4timing.d32, + &msch->ddr4timing); + writel(noc_timings->agingx0, &msch->agingx0); + writel(noc_timings->agingx0, &msch->aging0); + writel(noc_timings->agingx0, &msch->aging1); + writel(noc_timings->agingx0, &msch->aging2); + writel(noc_timings->agingx0, &msch->aging3); +} + +static void dram_all_config(struct dram_info *dram, + struct px30_sdram_params *sdram_params) +{ + struct sdram_cap_info *cap_info = &sdram_params->ch.cap_info; + u32 sys_reg2 = 0; + u32 sys_reg3 = 0; + + set_ddrconfig(dram, cap_info->ddrconfig); + sdram_org_config(cap_info, &sdram_params->base, &sys_reg2, + &sys_reg3, 0); + writel(sys_reg2, &dram->pmugrf->os_reg[2]); + writel(sys_reg3, &dram->pmugrf->os_reg[3]); + sdram_msch_config(dram->msch, &sdram_params->ch.noc_timings, cap_info, + &sdram_params->base); +} + +static void enable_low_power(struct dram_info *dram, + struct px30_sdram_params *sdram_params) +{ + void __iomem *pctl_base = dram->pctl; + void __iomem *phy_base = dram->phy; + void __iomem *ddr_grf_base = dram->ddr_grf; + u32 grf_lp_con; + + /* + * bit0: grf_upctl_axi_cg_en = 1 enable upctl2 axi clk auto gating + * bit1: grf_upctl_apb_cg_en = 1 ungated axi,core clk for apb access + * bit2: grf_upctl_core_cg_en = 1 enable upctl2 core clk auto gating + * bit3: grf_selfref_type2_en = 0 disable core clk gating when type2 sr + * bit4: grf_upctl_syscreq_cg_en = 1 + * ungating coreclk when c_sysreq assert + * bit8-11: grf_auto_sr_dly = 6 + */ + writel(0x1f1f0617, &dram->ddr_grf->ddr_grf_con[1]); + + if (sdram_params->base.dramtype == DDR4) + grf_lp_con = (0x7 << 16) | (1 << 1); + else if (sdram_params->base.dramtype == DDR3) + grf_lp_con = (0x7 << 16) | (1 << 0); + else + grf_lp_con = (0x7 << 16) | (1 << 2); + + /* en lpckdis_en */ + grf_lp_con = grf_lp_con | (0x1 << (9 + 16)) | (0x1 << 9); + writel(grf_lp_con, ddr_grf_base + DDR_GRF_LP_CON); + + /* off digit module clock when enter power down */ + setbits_le32(PHY_REG(phy_base, 7), 1 << 7); + + /* enable sr, pd */ + if (PD_IDLE == 0) + clrbits_le32(pctl_base + DDR_PCTL2_PWRCTL, (1 << 1)); + else + setbits_le32(pctl_base + DDR_PCTL2_PWRCTL, (1 << 1)); + if (SR_IDLE == 0) + clrbits_le32(pctl_base + DDR_PCTL2_PWRCTL, 1); + else + setbits_le32(pctl_base + DDR_PCTL2_PWRCTL, 1); + setbits_le32(pctl_base + DDR_PCTL2_PWRCTL, (1 << 3)); +} + +/* + * pre_init: 0: pre init for dram cap detect + * 1: detect correct cap(except cs1 row)info, than reinit + * 2: after reinit, we detect cs1_row, if cs1_row not equal + * to cs0_row and cs is in middle on ddrconf map, we need + * to reinit dram, than set the correct ddrconf. + */ +static int sdram_init_(struct dram_info *dram, + struct px30_sdram_params *sdram_params, u32 pre_init) +{ + struct sdram_cap_info *cap_info = &sdram_params->ch.cap_info; + void __iomem *pctl_base = dram->pctl; + + rkclk_ddr_reset(dram, 1, 1, 1, 1); + udelay(10); + /* + * dereset ddr phy psrstn to config pll, + * if using phy pll psrstn must be dereset + * before config pll + */ + rkclk_ddr_reset(dram, 1, 1, 1, 0); + rkclk_configure_ddr(dram, sdram_params); + + /* release phy srst to provide clk to ctrl */ + rkclk_ddr_reset(dram, 1, 1, 0, 0); + udelay(10); + phy_soft_reset(dram->phy); + /* release ctrl presetn, and config ctl registers */ + rkclk_ddr_reset(dram, 1, 0, 0, 0); + pctl_cfg(dram->pctl, &sdram_params->pctl_regs, SR_IDLE, PD_IDLE); + cap_info->ddrconfig = calculate_ddrconfig(sdram_params); + set_ctl_address_map(dram, sdram_params); + phy_cfg(dram->phy, &sdram_params->phy_regs, sdram_params->skew, + &sdram_params->base, cap_info->bw); + + /* enable dfi_init_start to init phy after ctl srstn deassert */ + setbits_le32(pctl_base + DDR_PCTL2_DFIMISC, (1 << 5) | (1 << 4)); + + rkclk_ddr_reset(dram, 0, 0, 0, 0); + /* wait for dfi_init_done and dram init complete */ + while ((readl(pctl_base + DDR_PCTL2_STAT) & 0x7) == 0) + continue; + + if (sdram_params->base.dramtype == LPDDR3) + pctl_write_mr(dram->pctl, 3, 11, 3, LPDDR3); + + /* do ddr gate training */ +redo_cs0_training: + if (data_training(dram, 0, sdram_params->base.dramtype) != 0) { + if (pre_init != 0) + printascii("DTT cs0 error\n"); + return -1; + } + if (check_rd_gate(dram)) { + printascii("re training cs0"); + goto redo_cs0_training; + } + + if (sdram_params->base.dramtype == LPDDR3) { + if ((read_mr(dram, 1, 8) & 0x3) != 0x3) + return -1; + } else if (sdram_params->base.dramtype == LPDDR2) { + if ((read_mr(dram, 1, 8) & 0x3) != 0x0) + return -1; + } + /* for px30: when 2cs, both 2 cs should be training */ + if (pre_init != 0 && cap_info->rank == 2) { +redo_cs1_training: + if (data_training(dram, 1, sdram_params->base.dramtype) != 0) { + printascii("DTT cs1 error\n"); + return -1; + } + if (check_rd_gate(dram)) { + printascii("re training cs1"); + goto redo_cs1_training; + } + } + + if (sdram_params->base.dramtype == DDR4) + pctl_write_vrefdq(dram->pctl, 0x3, 5670, + sdram_params->base.dramtype); + + dram_all_config(dram, sdram_params); + enable_low_power(dram, sdram_params); + + return 0; +} + +static int dram_detect_cap(struct dram_info *dram, + struct px30_sdram_params *sdram_params, + unsigned char channel) +{ + struct sdram_cap_info *cap_info = &sdram_params->ch.cap_info; + + /* + * for ddr3: ddrconf = 3 + * for ddr4: ddrconf = 12 + * for lpddr3: ddrconf = 3 + * default bw = 1 + */ + u32 bk, bktmp; + u32 col, coltmp; + u32 rowtmp; + u32 cs; + u32 bw = 1; + u32 dram_type = sdram_params->base.dramtype; + + if (dram_type != DDR4) { + /* detect col and bk for ddr3/lpddr3 */ + coltmp = 12; + bktmp = 3; + if (dram_type == LPDDR2) + rowtmp = 15; + else + rowtmp = 16; + + if (sdram_detect_col(cap_info, coltmp) != 0) + goto cap_err; + sdram_detect_bank(cap_info, coltmp, bktmp); + sdram_detect_dbw(cap_info, dram_type); + } else { + /* detect bg for ddr4 */ + coltmp = 10; + bktmp = 4; + rowtmp = 17; + + col = 10; + bk = 2; + cap_info->col = col; + cap_info->bk = bk; + sdram_detect_bg(cap_info, coltmp); + } + + /* detect row */ + if (sdram_detect_row(cap_info, coltmp, bktmp, rowtmp) != 0) + goto cap_err; + + /* detect row_3_4 */ + sdram_detect_row_3_4(cap_info, coltmp, bktmp); + + /* bw and cs detect using data training */ + if (data_training(dram, 1, dram_type) == 0) + cs = 1; + else + cs = 0; + cap_info->rank = cs + 1; + + dram_set_bw(dram, 2); + if (data_training(dram, 0, dram_type) == 0) + bw = 2; + else + bw = 1; + cap_info->bw = bw; + + cap_info->cs0_high16bit_row = cap_info->cs0_row; + if (cs) { + cap_info->cs1_row = cap_info->cs0_row; + cap_info->cs1_high16bit_row = cap_info->cs0_row; + } else { + cap_info->cs1_row = 0; + cap_info->cs1_high16bit_row = 0; + } + + return 0; +cap_err: + return -1; +} + +void get_ddr_param(struct px30_sdram_params *sdram_params, + struct ddr_param *ddr_param) +{ + struct sdram_cap_info *cap_info = &sdram_params->ch.cap_info; + u32 dram_type = sdram_params->base.dramtype; + u64 cs_cap[2]; + + cs_cap[0] = sdram_get_cs_cap(cap_info, 0, dram_type); + cs_cap[1] = sdram_get_cs_cap(cap_info, 1, dram_type); + + if (cap_info->row_3_4) { + cs_cap[0] = cs_cap[0] * 3 / 4; + cs_cap[1] = cs_cap[1] * 3 / 4; + } + + if (cap_info->row_3_4 && cap_info->rank == 2) { + ddr_param->count = 2; + ddr_param->para[0] = 0; + ddr_param->para[1] = cs_cap[0] * 4 / 3; + ddr_param->para[2] = cs_cap[0]; + ddr_param->para[3] = cs_cap[1]; + } else { + ddr_param->count = 1; + ddr_param->para[0] = 0; + ddr_param->para[1] = (u64)cs_cap[0] + (u64)cs_cap[1]; + } +} + +/* return: 0 = success, other = fail */ +static int sdram_init_detect(struct dram_info *dram, + struct px30_sdram_params *sdram_params) +{ + struct sdram_cap_info *cap_info = &sdram_params->ch.cap_info; + u32 ret; + u32 sys_reg = 0; + u32 sys_reg3 = 0; + + if (sdram_init_(dram, sdram_params, 0) != 0) + return -1; + + if (dram_detect_cap(dram, sdram_params, 0) != 0) + return -1; + + /* modify bw, cs related timing */ + pctl_remodify_sdram_params(&sdram_params->pctl_regs, cap_info, + sdram_params->base.dramtype); + /* reinit sdram by real dram cap */ + ret = sdram_init_(dram, sdram_params, 1); + if (ret != 0) + goto out; + + /* redetect cs1 row */ + sdram_detect_cs1_row(cap_info, sdram_params->base.dramtype); + if (cap_info->cs1_row) { + sys_reg = readl(&dram->pmugrf->os_reg[2]); + sys_reg3 = readl(&dram->pmugrf->os_reg[3]); + SYS_REG_ENC_CS1_ROW(cap_info->cs1_row, + sys_reg, sys_reg3, 0); + writel(sys_reg, &dram->pmugrf->os_reg[2]); + writel(sys_reg3, &dram->pmugrf->os_reg[3]); + } + + ret = sdram_detect_high_row(cap_info); + +out: + return ret; +} + +struct px30_sdram_params + *get_default_sdram_config(void) +{ + sdram_configs[0].skew = &skew; + + return &sdram_configs[0]; +} + +/* return: 0 = success, other = fail */ +int sdram_init(void) +{ + struct px30_sdram_params *sdram_params; + int ret = 0; + struct ddr_param ddr_param; + + dram_info.phy = (void *)DDR_PHY_BASE_ADDR; + dram_info.pctl = (void *)DDRC_BASE_ADDR; + dram_info.grf = (void *)GRF_BASE_ADDR; + dram_info.cru = (void *)CRU_BASE_ADDR; + dram_info.msch = (void *)SERVER_MSCH0_BASE_ADDR; + dram_info.ddr_grf = (void *)DDR_GRF_BASE_ADDR; + dram_info.pmugrf = (void *)PMUGRF_BASE_ADDR; + + sdram_params = get_default_sdram_config(); + ret = sdram_init_detect(&dram_info, sdram_params); + + if (ret) + goto error; + + get_ddr_param(sdram_params, &ddr_param); + rockchip_setup_ddr_param(&ddr_param); + sdram_print_ddr_info(&sdram_params->ch.cap_info, &sdram_params->base); + + printascii("out\n"); + return ret; +error: + return (-1); +} +#endif /* CONFIG_TPL_BUILD */
RK3328 has a similar controller and phy with PX30, so we can use the common driver for it and remove the duplicate codes.
Changes in v2: None
arch/arm/dts/rk3328-sdram-ddr3-666.dtsi | 4 + arch/arm/dts/rk3328-sdram-lpddr3-1600.dtsi | 4 + arch/arm/dts/rk3328-sdram-lpddr3-666.dtsi | 4 + .../include/asm/arch-rockchip/sdram_rk3328.h | 419 +++------- arch/arm/mach-rockchip/Kconfig | 1 + configs/evb-rk3328_defconfig | 2 +- configs/rock64-rk3328_defconfig | 2 +- drivers/ram/rockchip/Makefile | 2 +- drivers/ram/rockchip/sdram_rk3328.c | 763 ++++-------------- 9 files changed, 295 insertions(+), 906 deletions(-)
diff --git a/arch/arm/dts/rk3328-sdram-ddr3-666.dtsi b/arch/arm/dts/rk3328-sdram-ddr3-666.dtsi index d99e7e0352..3e88ed443b 100644 --- a/arch/arm/dts/rk3328-sdram-ddr3-666.dtsi +++ b/arch/arm/dts/rk3328-sdram-ddr3-666.dtsi @@ -14,6 +14,8 @@ 0x0 0x10 0x10 + 0x10 + 0x10 0
0x9028b189 @@ -26,6 +28,8 @@
333 3 + 1 + 0 0
0x00000000 diff --git a/arch/arm/dts/rk3328-sdram-lpddr3-1600.dtsi b/arch/arm/dts/rk3328-sdram-lpddr3-1600.dtsi index cc0011cf7b..d63c761a02 100644 --- a/arch/arm/dts/rk3328-sdram-lpddr3-1600.dtsi +++ b/arch/arm/dts/rk3328-sdram-lpddr3-1600.dtsi @@ -14,6 +14,8 @@ 0x0 0x10 0x10 + 0x10 + 0x10 0
0x98899459 @@ -27,6 +29,8 @@ 800 6 1 + 0 + 1
0x00000000 0x43041008 diff --git a/arch/arm/dts/rk3328-sdram-lpddr3-666.dtsi b/arch/arm/dts/rk3328-sdram-lpddr3-666.dtsi index 62d809e833..b9d3b3b948 100644 --- a/arch/arm/dts/rk3328-sdram-lpddr3-666.dtsi +++ b/arch/arm/dts/rk3328-sdram-lpddr3-666.dtsi @@ -14,6 +14,8 @@ 0x0 0x10 0x10 + 0x10 + 0x10 0
0x0c48a18a @@ -26,6 +28,8 @@
333 6 + 1 + 0 0
0x00000000 diff --git a/arch/arm/include/asm/arch-rockchip/sdram_rk3328.h b/arch/arm/include/asm/arch-rockchip/sdram_rk3328.h index c747b461a1..10923505d6 100644 --- a/arch/arm/include/asm/arch-rockchip/sdram_rk3328.h +++ b/arch/arm/include/asm/arch-rockchip/sdram_rk3328.h @@ -7,197 +7,13 @@ #ifndef _ASM_ARCH_SDRAM_RK3328_H #define _ASM_ARCH_SDRAM_RK3328_H #include <asm/arch-rockchip/sdram_common.h> +#include <asm/arch-rockchip/sdram_pctl_px30.h> +#include <asm/arch-rockchip/sdram_phy_px30.h> +#include <asm/arch-rockchip/sdram_phy_ron_rtt_px30.h>
#define SR_IDLE 93 #define PD_IDLE 13 #define SDRAM_ADDR 0x00000000 -#define PATTERN (0x5aa5f00f) - -/* ddr pctl registers define */ -#define DDR_PCTL2_MSTR 0x0 -#define DDR_PCTL2_STAT 0x4 -#define DDR_PCTL2_MSTR1 0x8 -#define DDR_PCTL2_MRCTRL0 0x10 -#define DDR_PCTL2_MRCTRL1 0x14 -#define DDR_PCTL2_MRSTAT 0x18 -#define DDR_PCTL2_MRCTRL2 0x1c -#define DDR_PCTL2_DERATEEN 0x20 -#define DDR_PCTL2_DERATEINT 0x24 -#define DDR_PCTL2_PWRCTL 0x30 -#define DDR_PCTL2_PWRTMG 0x34 -#define DDR_PCTL2_HWLPCTL 0x38 -#define DDR_PCTL2_RFSHCTL0 0x50 -#define DDR_PCTL2_RFSHCTL1 0x54 -#define DDR_PCTL2_RFSHCTL2 0x58 -#define DDR_PCTL2_RFSHCTL4 0x5c -#define DDR_PCTL2_RFSHCTL3 0x60 -#define DDR_PCTL2_RFSHTMG 0x64 -#define DDR_PCTL2_RFSHTMG1 0x68 -#define DDR_PCTL2_RFSHCTL5 0x6c -#define DDR_PCTL2_INIT0 0xd0 -#define DDR_PCTL2_INIT1 0xd4 -#define DDR_PCTL2_INIT2 0xd8 -#define DDR_PCTL2_INIT3 0xdc -#define DDR_PCTL2_INIT4 0xe0 -#define DDR_PCTL2_INIT5 0xe4 -#define DDR_PCTL2_INIT6 0xe8 -#define DDR_PCTL2_INIT7 0xec -#define DDR_PCTL2_DIMMCTL 0xf0 -#define DDR_PCTL2_RANKCTL 0xf4 -#define DDR_PCTL2_CHCTL 0xfc -#define DDR_PCTL2_DRAMTMG0 0x100 -#define DDR_PCTL2_DRAMTMG1 0x104 -#define DDR_PCTL2_DRAMTMG2 0x108 -#define DDR_PCTL2_DRAMTMG3 0x10c -#define DDR_PCTL2_DRAMTMG4 0x110 -#define DDR_PCTL2_DRAMTMG5 0x114 -#define DDR_PCTL2_DRAMTMG6 0x118 -#define DDR_PCTL2_DRAMTMG7 0x11c -#define DDR_PCTL2_DRAMTMG8 0x120 -#define DDR_PCTL2_DRAMTMG9 0x124 -#define DDR_PCTL2_DRAMTMG10 0x128 -#define DDR_PCTL2_DRAMTMG11 0x12c -#define DDR_PCTL2_DRAMTMG12 0x130 -#define DDR_PCTL2_DRAMTMG13 0x134 -#define DDR_PCTL2_DRAMTMG14 0x138 -#define DDR_PCTL2_DRAMTMG15 0x13c -#define DDR_PCTL2_DRAMTMG16 0x140 -#define DDR_PCTL2_ZQCTL0 0x180 -#define DDR_PCTL2_ZQCTL1 0x184 -#define DDR_PCTL2_ZQCTL2 0x188 -#define DDR_PCTL2_ZQSTAT 0x18c -#define DDR_PCTL2_DFITMG0 0x190 -#define DDR_PCTL2_DFITMG1 0x194 -#define DDR_PCTL2_DFILPCFG0 0x198 -#define DDR_PCTL2_DFILPCFG1 0x19c -#define DDR_PCTL2_DFIUPD0 0x1a0 -#define DDR_PCTL2_DFIUPD1 0x1a4 -#define DDR_PCTL2_DFIUPD2 0x1a8 -#define DDR_PCTL2_DFIMISC 0x1b0 -#define DDR_PCTL2_DFITMG2 0x1b4 -#define DDR_PCTL2_DFITMG3 0x1b8 -#define DDR_PCTL2_DFISTAT 0x1bc -#define DDR_PCTL2_DBICTL 0x1c0 -#define DDR_PCTL2_ADDRMAP0 0x200 -#define DDR_PCTL2_ADDRMAP1 0x204 -#define DDR_PCTL2_ADDRMAP2 0x208 -#define DDR_PCTL2_ADDRMAP3 0x20c -#define DDR_PCTL2_ADDRMAP4 0x210 -#define DDR_PCTL2_ADDRMAP5 0x214 -#define DDR_PCTL2_ADDRMAP6 0x218 -#define DDR_PCTL2_ADDRMAP7 0x21c -#define DDR_PCTL2_ADDRMAP8 0x220 -#define DDR_PCTL2_ADDRMAP9 0x224 -#define DDR_PCTL2_ADDRMAP10 0x228 -#define DDR_PCTL2_ADDRMAP11 0x22c -#define DDR_PCTL2_ODTCFG 0x240 -#define DDR_PCTL2_ODTMAP 0x244 -#define DDR_PCTL2_SCHED 0x250 -#define DDR_PCTL2_SCHED1 0x254 -#define DDR_PCTL2_PERFHPR1 0x25c -#define DDR_PCTL2_PERFLPR1 0x264 -#define DDR_PCTL2_PERFWR1 0x26c -#define DDR_PCTL2_DQMAP0 0x280 -#define DDR_PCTL2_DQMAP1 0x284 -#define DDR_PCTL2_DQMAP2 0x288 -#define DDR_PCTL2_DQMAP3 0x28c -#define DDR_PCTL2_DQMAP4 0x290 -#define DDR_PCTL2_DQMAP5 0x294 -#define DDR_PCTL2_DBG0 0x300 -#define DDR_PCTL2_DBG1 0x304 -#define DDR_PCTL2_DBGCAM 0x308 -#define DDR_PCTL2_DBGCMD 0x30c -#define DDR_PCTL2_DBGSTAT 0x310 -#define DDR_PCTL2_SWCTL 0x320 -#define DDR_PCTL2_SWSTAT 0x324 -#define DDR_PCTL2_POISONCFG 0x36c -#define DDR_PCTL2_POISONSTAT 0x370 -#define DDR_PCTL2_ADVECCINDEX 0x374 -#define DDR_PCTL2_ADVECCSTAT 0x378 -#define DDR_PCTL2_PSTAT 0x3fc -#define DDR_PCTL2_PCCFG 0x400 -#define DDR_PCTL2_PCFGR_n 0x404 -#define DDR_PCTL2_PCFGW_n 0x408 -#define DDR_PCTL2_PCTRL_n 0x490 - -/* PCTL2_MRSTAT */ -#define MR_WR_BUSY BIT(0) - -/* PHY_REG0 */ -#define DIGITAL_DERESET BIT(3) -#define ANALOG_DERESET BIT(2) -#define DIGITAL_RESET (0 << 3) -#define ANALOG_RESET (0 << 2) - -/* PHY_REG1 */ -#define PHY_DDR2 (0) -#define PHY_LPDDR2 (1) -#define PHY_DDR3 (2) -#define PHY_LPDDR3 (3) -#define PHY_DDR4 (4) -#define PHY_BL_4 (0 << 2) -#define PHY_BL_8 BIT(2) - -/* PHY_REG2 */ -#define PHY_DTT_EN BIT(0) -#define PHY_DTT_DISB (0 << 0) -#define PHY_WRITE_LEVELING_EN BIT(2) -#define PHY_WRITE_LEVELING_DISB (0 << 2) -#define PHY_SELECT_CS0 (2) -#define PHY_SELECT_CS1 (1) -#define PHY_SELECT_CS0_1 (0) -#define PHY_WRITE_LEVELING_SELECTCS(n) (n << 6) -#define PHY_DATA_TRAINING_SELECTCS(n) (n << 4) - -#define PHY_DDR3_RON_RTT_DISABLE (0) -#define PHY_DDR3_RON_RTT_451ohm (1) -#define PHY_DDR3_RON_RTT_225ohm (2) -#define PHY_DDR3_RON_RTT_150ohm (3) -#define PHY_DDR3_RON_RTT_112ohm (4) -#define PHY_DDR3_RON_RTT_90ohm (5) -#define PHY_DDR3_RON_RTT_75ohm (6) -#define PHY_DDR3_RON_RTT_64ohm (7) -#define PHY_DDR3_RON_RTT_56ohm (16) -#define PHY_DDR3_RON_RTT_50ohm (17) -#define PHY_DDR3_RON_RTT_45ohm (18) -#define PHY_DDR3_RON_RTT_41ohm (19) -#define PHY_DDR3_RON_RTT_37ohm (20) -#define PHY_DDR3_RON_RTT_34ohm (21) -#define PHY_DDR3_RON_RTT_33ohm (22) -#define PHY_DDR3_RON_RTT_30ohm (23) -#define PHY_DDR3_RON_RTT_28ohm (24) -#define PHY_DDR3_RON_RTT_26ohm (25) -#define PHY_DDR3_RON_RTT_25ohm (26) -#define PHY_DDR3_RON_RTT_23ohm (27) -#define PHY_DDR3_RON_RTT_22ohm (28) -#define PHY_DDR3_RON_RTT_21ohm (29) -#define PHY_DDR3_RON_RTT_20ohm (30) -#define PHY_DDR3_RON_RTT_19ohm (31) - -#define PHY_DDR4_LPDDR3_RON_RTT_DISABLE (0) -#define PHY_DDR4_LPDDR3_RON_RTT_480ohm (1) -#define PHY_DDR4_LPDDR3_RON_RTT_240ohm (2) -#define PHY_DDR4_LPDDR3_RON_RTT_160ohm (3) -#define PHY_DDR4_LPDDR3_RON_RTT_120ohm (4) -#define PHY_DDR4_LPDDR3_RON_RTT_96ohm (5) -#define PHY_DDR4_LPDDR3_RON_RTT_80ohm (6) -#define PHY_DDR4_LPDDR3_RON_RTT_68ohm (7) -#define PHY_DDR4_LPDDR3_RON_RTT_60ohm (16) -#define PHY_DDR4_LPDDR3_RON_RTT_53ohm (17) -#define PHY_DDR4_LPDDR3_RON_RTT_48ohm (18) -#define PHY_DDR4_LPDDR3_RON_RTT_43ohm (19) -#define PHY_DDR4_LPDDR3_RON_RTT_40ohm (20) -#define PHY_DDR4_LPDDR3_RON_RTT_37ohm (21) -#define PHY_DDR4_LPDDR3_RON_RTT_34ohm (22) -#define PHY_DDR4_LPDDR3_RON_RTT_32ohm (23) -#define PHY_DDR4_LPDDR3_RON_RTT_30ohm (24) -#define PHY_DDR4_LPDDR3_RON_RTT_28ohm (25) -#define PHY_DDR4_LPDDR3_RON_RTT_26ohm (26) -#define PHY_DDR4_LPDDR3_RON_RTT_25ohm (27) -#define PHY_DDR4_LPDDR3_RON_RTT_24ohm (28) -#define PHY_DDR4_LPDDR3_RON_RTT_22ohm (29) -#define PHY_DDR4_LPDDR3_RON_RTT_21ohm (30) -#define PHY_DDR4_LPDDR3_RON_RTT_20ohm (31)
/* noc registers define */ #define DDRCONF 0x8 @@ -220,16 +36,16 @@ #define DDR_GRF_STATUS(n) (DDR_GRF_STATUS_BASE + (n) * 4)
/* CRU_SOFTRESET_CON5 */ -#define ddrphy_psrstn_req(n) (((0x1 << 15) << 16) | (n << 15)) -#define ddrphy_srstn_req(n) (((0x1 << 14) << 16) | (n << 14)) -#define ddrctrl_psrstn_req(n) (((0x1 << 13) << 16) | (n << 13)) -#define ddrctrl_srstn_req(n) (((0x1 << 12) << 16) | (n << 12)) -#define ddrmsch_srstn_req(n) (((0x1 << 11) << 16) | (n << 11)) -#define msch_srstn_req(n) (((0x1 << 9) << 16) | (n << 9)) -#define dfimon_srstn_req(n) (((0x1 << 8) << 16) | (n << 8)) -#define grf_ddr_srstn_req(n) (((0x1 << 7) << 16) | (n << 7)) +#define ddrphy_psrstn_req(n) (((0x1 << 15) << 16) | ((n) << 15)) +#define ddrphy_srstn_req(n) (((0x1 << 14) << 16) | ((n) << 14)) +#define ddrctrl_psrstn_req(n) (((0x1 << 13) << 16) | ((n) << 13)) +#define ddrctrl_srstn_req(n) (((0x1 << 12) << 16) | ((n) << 12)) +#define ddrmsch_srstn_req(n) (((0x1 << 11) << 16) | ((n) << 11)) +#define msch_srstn_req(n) (((0x1 << 9) << 16) | ((n) << 9)) +#define dfimon_srstn_req(n) (((0x1 << 8) << 16) | ((n) << 8)) +#define grf_ddr_srstn_req(n) (((0x1 << 7) << 16) | ((n) << 7)) /* CRU_SOFTRESET_CON9 */ -#define ddrctrl_asrstn_req(n) (((0x1 << 9) << 16) | (n << 9)) +#define ddrctrl_asrstn_req(n) (((0x1 << 9) << 16) | ((n) << 9))
/* CRU register */ #define CRU_PLL_CON(pll_id, n) ((pll_id) * 0x20 + (n) * 4) @@ -256,56 +72,46 @@ #define POSTDIV2(n) ((0x7 << (6 + 16)) | ((n) << 6)) #define REFDIV(n) ((0x3F << 16) | (n))
-union noc_ddrtiming { - u32 d32; - struct { - unsigned acttoact:6; - unsigned rdtomiss:6; - unsigned wrtomiss:6; - unsigned burstlen:3; - unsigned rdtowr:5; - unsigned wrtord:5; - unsigned bwratio:1; - } b; -} NOC_TIMING_T; - -union noc_activate { - u32 d32; - struct { - unsigned rrd:4; - unsigned faw:6; - unsigned fawbank:1; - unsigned reserved1:21; - } b; -}; - -union noc_devtodev { - u32 d32; - struct { - unsigned busrdtord:2; - unsigned busrdtowr:2; - unsigned buswrtord:2; - unsigned reserved2:26; - } b; -}; - -union noc_ddr4timing { - u32 d32; - struct { - unsigned ccdl:3; - unsigned wrtordl:5; - unsigned rrdl:4; - unsigned reserved2:20; - } b; +u16 ddr_cfg_2_rbc[] = { + /* + * [5:4] row(13+n) + * [3] cs(0:0 cs, 1:2 cs) + * [2] bank(0:0bank,1:8bank) + * [1:0] col(11+n) + */ + /* row, cs, bank, col */ + ((3 << 4) | (0 << 3) | (1 << 2) | 0), + ((3 << 4) | (0 << 3) | (1 << 2) | 1), + ((2 << 4) | (0 << 3) | (1 << 2) | 2), + ((3 << 4) | (0 << 3) | (1 << 2) | 2), + ((2 << 4) | (0 << 3) | (1 << 2) | 3), + ((3 << 4) | (1 << 3) | (1 << 2) | 0), + ((3 << 4) | (1 << 3) | (1 << 2) | 1), + ((2 << 4) | (1 << 3) | (1 << 2) | 2), + ((3 << 4) | (0 << 3) | (0 << 2) | 1), + ((2 << 4) | (0 << 3) | (1 << 2) | 1), };
-union noc_ddrmode { - u32 d32; - struct { - unsigned autoprecharge:1; - unsigned bwratioextended:1; - unsigned reserved3:30; - } b; +u16 ddr4_cfg_2_rbc[] = { + /*************************** + * [6] cs 0:0cs 1:2 cs + * [5:3] row(13+n) + * [2] cs(0:0 cs, 1:2 cs) + * [1] bw 0: 16bit 1:32bit + * [0] diebw 0:8bit 1:16bit + ***************************/ + /* cs, row, cs, bw, diebw */ + ((0 << 6) | (3 << 3) | (0 << 2) | (1 << 1) | 0), + ((1 << 6) | (2 << 3) | (0 << 2) | (1 << 1) | 0), + ((0 << 6) | (4 << 3) | (0 << 2) | (0 << 1) | 0), + ((1 << 6) | (3 << 3) | (0 << 2) | (0 << 1) | 0), + ((0 << 6) | (4 << 3) | (0 << 2) | (1 << 1) | 1), + ((1 << 6) | (3 << 3) | (0 << 2) | (1 << 1) | 1), + ((1 << 6) | (4 << 3) | (0 << 2) | (0 << 1) | 1), + ((0 << 6) | (2 << 3) | (1 << 2) | (1 << 1) | 0), + ((0 << 6) | (3 << 3) | (1 << 2) | (0 << 1) | 0), + ((0 << 6) | (3 << 3) | (1 << 2) | (1 << 1) | 1), + ((0 << 6) | (4 << 3) | (1 << 2) | (0 << 1) | 1), };
u32 addrmap[21][9] = { @@ -356,17 +162,65 @@ u32 addrmap[21][9] = { 0x07070707, 0x00000f07, 0x3f00} };
-struct rk3328_msch_timings { - union noc_ddrtiming ddrtiming; - union noc_ddrmode ddrmode; - u32 readlatency; - union noc_activate activate; - union noc_devtodev devtodev; - union noc_ddr4timing ddr4timing; - u32 agingx0; +struct rk3328_ddr_grf_regs { + u32 ddr_grf_con[4]; + u32 reserved[(0x100 - 0x10) / 4]; + u32 ddr_grf_status[11]; };
-struct rk3328_msch_regs { +union noc_ddrtiming { + u32 d32; + struct { + unsigned acttoact:6; + unsigned rdtomiss:6; + unsigned wrtomiss:6; + unsigned burstlen:3; + unsigned rdtowr:5; + unsigned wrtord:5; + unsigned bwratio:1; + } b; +}; + +union noc_activate { + u32 d32; + struct { + unsigned rrd:4; + unsigned faw:6; + unsigned fawbank:1; + unsigned reserved1:21; + } b; +}; + +union noc_devtodev { + u32 d32; + struct { + unsigned busrdtord:2; + unsigned busrdtowr:2; + unsigned buswrtord:2; + unsigned reserved2:26; + } b; +}; + +union noc_ddr4timing { + u32 d32; + struct { + unsigned ccdl:3; + unsigned wrtordl:5; + unsigned rrdl:4; + unsigned reserved2:20; + } b; +}; + +union noc_ddrmode { + u32 d32; + struct { + unsigned autoprecharge:1; + unsigned bwratioextended:1; + unsigned reserved3:30; + } b; +}; + +struct msch_regs { u32 coreid; u32 revisionid; u32 ddrconf; @@ -385,58 +239,27 @@ struct rk3328_msch_regs { u32 ddr4_timing; };
-struct rk3328_ddr_grf_regs { - u32 ddr_grf_con[4]; - u32 reserved[(0x100 - 0x10) / 4]; - u32 ddr_grf_status[11]; -}; - -struct rk3328_ddr_pctl_regs { - u32 pctl[30][2]; -}; - -struct rk3328_ddr_phy_regs { - u32 phy[5][2]; -}; - -struct rk3328_ddr_skew { - u32 a0_a1_skew[15]; - u32 cs0_dm0_skew[11]; - u32 cs0_dm1_skew[11]; - u32 cs0_dm2_skew[11]; - u32 cs0_dm3_skew[11]; - u32 cs1_dm0_skew[11]; - u32 cs1_dm1_skew[11]; - u32 cs1_dm2_skew[11]; - u32 cs1_dm3_skew[11]; +struct sdram_msch_timings { + union noc_ddrtiming ddrtiming; + union noc_ddrmode ddrmode; + u32 readlatency; + union noc_activate activate; + union noc_devtodev devtodev; + union noc_ddr4timing ddr4timing; + u32 agingx0; };
struct rk3328_sdram_channel { - unsigned int rank; - unsigned int col; - /* 3:8bank, 2:4bank */ - unsigned int bk; - /* channel buswidth, 2:32bit, 1:16bit, 0:8bit */ - unsigned int bw; - /* die buswidth, 2:32bit, 1:16bit, 0:8bit */ - unsigned int dbw; - unsigned int row_3_4; - unsigned int cs0_row; - unsigned int cs1_row; - unsigned int ddrconfig; - struct rk3328_msch_timings noc_timings; + struct sdram_cap_info cap_info; + struct sdram_msch_timings noc_timings; };
struct rk3328_sdram_params { struct rk3328_sdram_channel ch; - unsigned int ddr_freq; - unsigned int dramtype; - unsigned int odt; - struct rk3328_ddr_pctl_regs pctl_regs; - struct rk3328_ddr_phy_regs phy_regs; - struct rk3328_ddr_skew skew; + struct sdram_base_params base; + struct ddr_pctl_regs pctl_regs; + struct ddr_phy_regs phy_regs; + struct ddr_phy_skew skew; };
-#define PHY_REG(base, n) (base + 4 * (n)) - #endif diff --git a/arch/arm/mach-rockchip/Kconfig b/arch/arm/mach-rockchip/Kconfig index f5a80b4f0c..5f1ad51cac 100644 --- a/arch/arm/mach-rockchip/Kconfig +++ b/arch/arm/mach-rockchip/Kconfig @@ -115,6 +115,7 @@ config ROCKCHIP_RK3328 select TPL_NEEDS_SEPARATE_TEXT_BASE if TPL select TPL_NEEDS_SEPARATE_STACK if TPL imply ROCKCHIP_COMMON_BOARD + imply ROCKCHIP_SDRAM_COMMON imply SPL_ROCKCHIP_COMMON_BOARD imply SPL_SERIAL_SUPPORT imply TPL_SERIAL_SUPPORT diff --git a/configs/evb-rk3328_defconfig b/configs/evb-rk3328_defconfig index 37610774c1..fdabee842d 100644 --- a/configs/evb-rk3328_defconfig +++ b/configs/evb-rk3328_defconfig @@ -46,7 +46,6 @@ CONFIG_SPL_SYSCON=y CONFIG_TPL_SYSCON=y CONFIG_CLK=y CONFIG_SPL_CLK=y -CONFIG_TPL_CLK=y CONFIG_FASTBOOT_BUF_ADDR=0x800800 CONFIG_FASTBOOT_FLASH=y CONFIG_FASTBOOT_FLASH_MMC_DEV=1 @@ -77,6 +76,7 @@ CONFIG_DEBUG_UART_SHIFT=2 CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_DEBUG_UART_SKIP_INIT=y CONFIG_SYSRESET=y +# CONFIG_TPL_SYSRESET is not set CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y diff --git a/configs/rock64-rk3328_defconfig b/configs/rock64-rk3328_defconfig index 3ab0af1158..0fb4b42c6e 100644 --- a/configs/rock64-rk3328_defconfig +++ b/configs/rock64-rk3328_defconfig @@ -49,7 +49,6 @@ CONFIG_SPL_SYSCON=y CONFIG_TPL_SYSCON=y CONFIG_CLK=y CONFIG_SPL_CLK=y -CONFIG_TPL_CLK=y CONFIG_FASTBOOT_BUF_ADDR=0x800800 CONFIG_FASTBOOT_FLASH=y CONFIG_FASTBOOT_FLASH_MMC_DEV=1 @@ -79,6 +78,7 @@ CONFIG_DM_RESET=y CONFIG_BAUDRATE=1500000 CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYSRESET=y +# CONFIG_TPL_SYSRESET is not set CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y diff --git a/drivers/ram/rockchip/Makefile b/drivers/ram/rockchip/Makefile index 483660e570..b42ef91c21 100644 --- a/drivers/ram/rockchip/Makefile +++ b/drivers/ram/rockchip/Makefile @@ -8,5 +8,5 @@ obj-$(CONFIG_ROCKCHIP_RK3128) = sdram_rk3128.o obj-$(CONFIG_ROCKCHIP_RK3188) = sdram_rk3188.o obj-$(CONFIG_ROCKCHIP_RK322X) = sdram_rk322x.o obj-$(CONFIG_ROCKCHIP_RK3288) = sdram_rk3288.o -obj-$(CONFIG_ROCKCHIP_RK3328) = sdram_rk3328.o +obj-$(CONFIG_ROCKCHIP_RK3328) += sdram_rk3328.o sdram_pctl_px30.o sdram_phy_px30.o obj-$(CONFIG_RAM_RK3399) += sdram_rk3399.o diff --git a/drivers/ram/rockchip/sdram_rk3328.c b/drivers/ram/rockchip/sdram_rk3328.c index e7919337ea..69521cef69 100644 --- a/drivers/ram/rockchip/sdram_rk3328.c +++ b/drivers/ram/rockchip/sdram_rk3328.c @@ -20,11 +20,11 @@
struct dram_info { #ifdef CONFIG_TPL_BUILD - struct rk3328_ddr_pctl_regs *pctl; - struct rk3328_ddr_phy_regs *phy; + struct ddr_pctl_regs *pctl; + struct ddr_phy_regs *phy; struct clk ddr_clk; struct rk3328_cru *cru; - struct rk3328_msch_regs *msch; + struct msch_regs *msch; struct rk3328_ddr_grf_regs *ddr_grf; #endif struct ram_info info; @@ -71,10 +71,11 @@ static void rkclk_ddr_reset(struct dram_info *dram, writel(ddrctrl_asrstn_req(ctl_srstn), &dram->cru->softrst_con[9]); }
-static void rkclk_set_dpll(struct dram_info *dram, unsigned int mhz) +static void rkclk_set_dpll(struct dram_info *dram, unsigned int hz) { unsigned int refdiv, postdiv1, postdiv2, fbdiv; int delay = 1000; + u32 mhz = hz / MHZ;
refdiv = 1; if (mhz <= 300) { @@ -122,52 +123,7 @@ static void rkclk_configure_ddr(struct dram_info *dram, clrbits_le32(PHY_REG(phy_base, 0xef), 1 << 7);
/* for inno ddr phy need 2*freq */ - rkclk_set_dpll(dram, sdram_params->ddr_freq * 2); -} - -static void phy_soft_reset(struct dram_info *dram) -{ - void __iomem *phy_base = dram->phy; - - clrbits_le32(PHY_REG(phy_base, 0), 0x3 << 2); - udelay(1); - setbits_le32(PHY_REG(phy_base, 0), ANALOG_DERESET); - udelay(5); - setbits_le32(PHY_REG(phy_base, 0), DIGITAL_DERESET); - udelay(1); -} - -static int pctl_cfg(struct dram_info *dram, - struct rk3328_sdram_params *sdram_params) -{ - u32 i; - void __iomem *pctl_base = dram->pctl; - - for (i = 0; sdram_params->pctl_regs.pctl[i][0] != 0xFFFFFFFF; i++) { - writel(sdram_params->pctl_regs.pctl[i][1], - pctl_base + sdram_params->pctl_regs.pctl[i][0]); - } - clrsetbits_le32(pctl_base + DDR_PCTL2_PWRTMG, - (0xff << 16) | 0x1f, - ((SR_IDLE & 0xff) << 16) | (PD_IDLE & 0x1f)); - /* - * dfi_lp_en_pd=1,dfi_lp_wakeup_pd=2 - * hw_lp_idle_x32=1 - */ - if (sdram_params->dramtype == LPDDR3) { - setbits_le32(pctl_base + DDR_PCTL2_DFILPCFG0, 1); - clrsetbits_le32(pctl_base + DDR_PCTL2_DFILPCFG0, - 0xf << 4, - 2 << 4); - } - clrsetbits_le32(pctl_base + DDR_PCTL2_HWLPCTL, - 0xfff << 16, - 1 << 16); - /* disable zqcs */ - setbits_le32(pctl_base + DDR_PCTL2_ZQCTL0, 1u << 31); - setbits_le32(pctl_base + 0x2000 + DDR_PCTL2_ZQCTL0, 1u << 31); - - return 0; + rkclk_set_dpll(dram, sdram_params->base.ddr_freq * MHZ * 2); }
/* return ddrconfig value @@ -175,62 +131,39 @@ static int pctl_cfg(struct dram_info *dram, * other, the ddrconfig value * only support cs0_row >= cs1_row */ -static unsigned int calculate_ddrconfig(struct rk3328_sdram_params *sdram_params) +static u32 calculate_ddrconfig(struct rk3328_sdram_params *sdram_params) { - static const u16 ddr_cfg_2_rbc[] = { - /*************************** - * [5:4] row(13+n) - * [3] cs(0:0 cs, 1:2 cs) - * [2] bank(0:0bank,1:8bank) - * [1:0] col(11+n) - ****************************/ - /* row, cs, bank, col */ - ((3 << 4) | (0 << 3) | (1 << 2) | 0), - ((3 << 4) | (0 << 3) | (1 << 2) | 1), - ((2 << 4) | (0 << 3) | (1 << 2) | 2), - ((3 << 4) | (0 << 3) | (1 << 2) | 2), - ((2 << 4) | (0 << 3) | (1 << 2) | 3), - ((3 << 4) | (1 << 3) | (1 << 2) | 0), - ((3 << 4) | (1 << 3) | (1 << 2) | 1), - ((2 << 4) | (1 << 3) | (1 << 2) | 2), - ((3 << 4) | (0 << 3) | (0 << 2) | 1), - ((2 << 4) | (0 << 3) | (1 << 2) | 1), - }; - - static const u16 ddr4_cfg_2_rbc[] = { - /*************************** - * [6] cs 0:0cs 1:2 cs - * [5:3] row(13+n) - * [2] cs(0:0 cs, 1:2 cs) - * [1] bw 0: 16bit 1:32bit - * [0] diebw 0:8bit 1:16bit - ***************************/ - /* cs, row, cs, bw, diebw */ - ((0 << 6) | (3 << 3) | (0 << 2) | (1 << 1) | 0), - ((1 << 6) | (2 << 3) | (0 << 2) | (1 << 1) | 0), - ((0 << 6) | (4 << 3) | (0 << 2) | (0 << 1) | 0), - ((1 << 6) | (3 << 3) | (0 << 2) | (0 << 1) | 0), - ((0 << 6) | (4 << 3) | (0 << 2) | (1 << 1) | 1), - ((1 << 6) | (3 << 3) | (0 << 2) | (1 << 1) | 1), - ((1 << 6) | (4 << 3) | (0 << 2) | (0 << 1) | 1), - ((0 << 6) | (2 << 3) | (1 << 2) | (1 << 1) | 0), - ((0 << 6) | (3 << 3) | (1 << 2) | (0 << 1) | 0), - ((0 << 6) | (3 << 3) | (1 << 2) | (1 << 1) | 1), - ((0 << 6) | (4 << 3) | (1 << 2) | (0 << 1) | 1), - }; - + struct sdram_cap_info *cap_info = &sdram_params->ch.cap_info; u32 cs, bw, die_bw, col, row, bank; + u32 cs1_row; u32 i, tmp; u32 ddrconf = -1;
- cs = sdram_ch.rank; - bw = sdram_ch.bw; - die_bw = sdram_ch.dbw; - col = sdram_ch.col; - row = sdram_ch.cs0_row; - bank = sdram_ch.bk; + cs = cap_info->rank; + bw = cap_info->bw; + die_bw = cap_info->dbw; + col = cap_info->col; + row = cap_info->cs0_row; + cs1_row = cap_info->cs1_row; + bank = cap_info->bk; + + if (sdram_params->base.dramtype == DDR4) { + /* when DDR_TEST, CS always at MSB position for easy test */ + if (cs == 2 && row == cs1_row) { + /* include 2cs cap both 2^n or both (2^n - 2^(n-2)) */ + tmp = ((row - 13) << 3) | (1 << 2) | (bw & 0x2) | + die_bw; + for (i = 17; i < 21; i++) { + if (((tmp & 0x7) == + (ddr4_cfg_2_rbc[i - 10] & 0x7)) && + ((tmp & 0x3c) <= + (ddr4_cfg_2_rbc[i - 10] & 0x3c))) { + ddrconf = i; + goto out; + } + } + }
- if (sdram_params->dramtype == DDR4) { tmp = ((cs - 1) << 6) | ((row - 13) << 3) | (bw & 0x2) | die_bw; for (i = 10; i < 17; i++) { if (((tmp & 0x7) == (ddr4_cfg_2_rbc[i - 10] & 0x7)) && @@ -246,6 +179,18 @@ static unsigned int calculate_ddrconfig(struct rk3328_sdram_params *sdram_params goto out; }
+ /* when DDR_TEST, CS always at MSB position for easy test */ + if (cs == 2 && row == cs1_row) { + /* include 2cs cap both 2^n or both (2^n - 2^(n-2)) */ + for (i = 5; i < 8; i++) { + if ((bw + col - 11) == (ddr_cfg_2_rbc[i] & + 0x3)) { + ddrconf = i; + goto out; + } + } + } + tmp = ((row - 13) << 4) | (1 << 2) | ((bw + col - 11) << 0); for (i = 0; i < 5; i++) if (((tmp & 0xf) == (ddr_cfg_2_rbc[i] & 0xf)) && @@ -257,23 +202,11 @@ static unsigned int calculate_ddrconfig(struct rk3328_sdram_params *sdram_params
out: if (ddrconf > 20) - printf("calculate_ddrconfig error\n"); + printf("calculate ddrconfig error\n");
return ddrconf; }
-/* n: Unit bytes */ -static void copy_to_reg(u32 *dest, u32 *src, u32 n) -{ - int i; - - for (i = 0; i < n / sizeof(u32); i++) { - writel(*src, dest); - src++; - dest++; - } -} - /******* * calculate controller dram address map, and setting to register. * argument sdram_ch.ddrconf must be right value before @@ -282,273 +215,42 @@ static void copy_to_reg(u32 *dest, u32 *src, u32 n) static void set_ctl_address_map(struct dram_info *dram, struct rk3328_sdram_params *sdram_params) { + struct sdram_cap_info *cap_info = &sdram_params->ch.cap_info; void __iomem *pctl_base = dram->pctl;
- copy_to_reg((u32 *)(pctl_base + DDR_PCTL2_ADDRMAP0), - &addrmap[sdram_ch.ddrconfig][0], 9 * 4); - if (sdram_params->dramtype == LPDDR3 && sdram_ch.row_3_4) + sdram_copy_to_reg((u32 *)(pctl_base + DDR_PCTL2_ADDRMAP0), + &addrmap[cap_info->ddrconfig][0], 9 * 4); + if (sdram_params->base.dramtype == LPDDR3 && cap_info->row_3_4) setbits_le32(pctl_base + DDR_PCTL2_ADDRMAP6, 1 << 31); - if (sdram_params->dramtype == DDR4 && sdram_ch.bw == 0x1) + if (sdram_params->base.dramtype == DDR4 && cap_info->bw == 0x1) setbits_le32(pctl_base + DDR_PCTL2_PCCFG, 1 << 8);
- if (sdram_ch.rank == 1) + if (cap_info->rank == 1) clrsetbits_le32(pctl_base + DDR_PCTL2_ADDRMAP0, 0x1f, 0x1f); }
-static void phy_dll_bypass_set(struct dram_info *dram, u32 freq) -{ - u32 tmp; - void __iomem *phy_base = dram->phy; - - setbits_le32(PHY_REG(phy_base, 0x13), 1 << 4); - clrbits_le32(PHY_REG(phy_base, 0x14), 1 << 3); - setbits_le32(PHY_REG(phy_base, 0x26), 1 << 4); - clrbits_le32(PHY_REG(phy_base, 0x27), 1 << 3); - setbits_le32(PHY_REG(phy_base, 0x36), 1 << 4); - clrbits_le32(PHY_REG(phy_base, 0x37), 1 << 3); - setbits_le32(PHY_REG(phy_base, 0x46), 1 << 4); - clrbits_le32(PHY_REG(phy_base, 0x47), 1 << 3); - setbits_le32(PHY_REG(phy_base, 0x56), 1 << 4); - clrbits_le32(PHY_REG(phy_base, 0x57), 1 << 3); - - if (freq <= 400) - /* DLL bypass */ - setbits_le32(PHY_REG(phy_base, 0xa4), 0x1f); - else - clrbits_le32(PHY_REG(phy_base, 0xa4), 0x1f); - if (freq <= 680) - tmp = 2; - else - tmp = 1; - writel(tmp, PHY_REG(phy_base, 0x28)); - writel(tmp, PHY_REG(phy_base, 0x38)); - writel(tmp, PHY_REG(phy_base, 0x48)); - writel(tmp, PHY_REG(phy_base, 0x58)); -} - -static void set_ds_odt(struct dram_info *dram, - struct rk3328_sdram_params *sdram_params) -{ - u32 cmd_drv, clk_drv, dqs_drv, dqs_odt; - void __iomem *phy_base = dram->phy; - - if (sdram_params->dramtype == DDR3) { - cmd_drv = PHY_DDR3_RON_RTT_34ohm; - clk_drv = PHY_DDR3_RON_RTT_45ohm; - dqs_drv = PHY_DDR3_RON_RTT_34ohm; - dqs_odt = PHY_DDR3_RON_RTT_225ohm; - } else { - cmd_drv = PHY_DDR4_LPDDR3_RON_RTT_34ohm; - clk_drv = PHY_DDR4_LPDDR3_RON_RTT_43ohm; - dqs_drv = PHY_DDR4_LPDDR3_RON_RTT_34ohm; - dqs_odt = PHY_DDR4_LPDDR3_RON_RTT_240ohm; - } - /* DS */ - writel(cmd_drv, PHY_REG(phy_base, 0x11)); - clrsetbits_le32(PHY_REG(phy_base, 0x12), 0x1f << 3, cmd_drv << 3); - writel(clk_drv, PHY_REG(phy_base, 0x16)); - writel(clk_drv, PHY_REG(phy_base, 0x18)); - writel(dqs_drv, PHY_REG(phy_base, 0x20)); - writel(dqs_drv, PHY_REG(phy_base, 0x2f)); - writel(dqs_drv, PHY_REG(phy_base, 0x30)); - writel(dqs_drv, PHY_REG(phy_base, 0x3f)); - writel(dqs_drv, PHY_REG(phy_base, 0x40)); - writel(dqs_drv, PHY_REG(phy_base, 0x4f)); - writel(dqs_drv, PHY_REG(phy_base, 0x50)); - writel(dqs_drv, PHY_REG(phy_base, 0x5f)); - /* ODT */ - writel(dqs_odt, PHY_REG(phy_base, 0x21)); - writel(dqs_odt, PHY_REG(phy_base, 0x2e)); - writel(dqs_odt, PHY_REG(phy_base, 0x31)); - writel(dqs_odt, PHY_REG(phy_base, 0x3e)); - writel(dqs_odt, PHY_REG(phy_base, 0x41)); - writel(dqs_odt, PHY_REG(phy_base, 0x4e)); - writel(dqs_odt, PHY_REG(phy_base, 0x51)); - writel(dqs_odt, PHY_REG(phy_base, 0x5e)); -} - -static void phy_cfg(struct dram_info *dram, - struct rk3328_sdram_params *sdram_params) -{ - u32 i; - void __iomem *phy_base = dram->phy; - - phy_dll_bypass_set(dram, sdram_params->ddr_freq); - for (i = 0; sdram_params->phy_regs.phy[i][0] != 0xFFFFFFFF; i++) { - writel(sdram_params->phy_regs.phy[i][1], - phy_base + sdram_params->phy_regs.phy[i][0]); - } - if (sdram_ch.bw == 2) { - clrsetbits_le32(PHY_REG(phy_base, 0), 0xf << 4, 0xf << 4); - } else { - clrsetbits_le32(PHY_REG(phy_base, 0), 0xf << 4, 3 << 4); - /* disable DQS2,DQS3 tx dll for saving power */ - clrbits_le32(PHY_REG(phy_base, 0x46), 1 << 3); - clrbits_le32(PHY_REG(phy_base, 0x56), 1 << 3); - } - set_ds_odt(dram, sdram_params); - /* deskew */ - setbits_le32(PHY_REG(phy_base, 2), 8); - copy_to_reg(PHY_REG(phy_base, 0xb0), - &sdram_params->skew.a0_a1_skew[0], 15 * 4); - copy_to_reg(PHY_REG(phy_base, 0x70), - &sdram_params->skew.cs0_dm0_skew[0], 44 * 4); - copy_to_reg(PHY_REG(phy_base, 0xc0), - &sdram_params->skew.cs1_dm0_skew[0], 44 * 4); -} - -static int update_refresh_reg(struct dram_info *dram) -{ - void __iomem *pctl_base = dram->pctl; - u32 ret; - - ret = readl(pctl_base + DDR_PCTL2_RFSHCTL3) ^ (1 << 1); - writel(ret, pctl_base + DDR_PCTL2_RFSHCTL3); - - return 0; -} - static int data_training(struct dram_info *dram, u32 cs, u32 dramtype) -{ - u32 ret; - u32 dis_auto_zq = 0; - void __iomem *pctl_base = dram->pctl; - void __iomem *phy_base = dram->phy; - - /* disable zqcs */ - if (!(readl(pctl_base + DDR_PCTL2_ZQCTL0) & - (1ul << 31))) { - dis_auto_zq = 1; - setbits_le32(pctl_base + DDR_PCTL2_ZQCTL0, 1 << 31); - } - /* disable auto refresh */ - setbits_le32(pctl_base + DDR_PCTL2_RFSHCTL3, 1); - update_refresh_reg(dram); - - if (dramtype == DDR4) { - clrsetbits_le32(PHY_REG(phy_base, 0x29), 0x3, 0); - clrsetbits_le32(PHY_REG(phy_base, 0x39), 0x3, 0); - clrsetbits_le32(PHY_REG(phy_base, 0x49), 0x3, 0); - clrsetbits_le32(PHY_REG(phy_base, 0x59), 0x3, 0); - } - /* choose training cs */ - clrsetbits_le32(PHY_REG(phy_base, 2), 0x33, (0x20 >> cs)); - /* enable gate training */ - clrsetbits_le32(PHY_REG(phy_base, 2), 0x33, (0x20 >> cs) | 1); - udelay(50); - ret = readl(PHY_REG(phy_base, 0xff)); - /* disable gate training */ - clrsetbits_le32(PHY_REG(phy_base, 2), 0x33, (0x20 >> cs) | 0); - /* restore zqcs */ - if (dis_auto_zq) - clrbits_le32(pctl_base + DDR_PCTL2_ZQCTL0, 1 << 31); - /* restore auto refresh */ - clrbits_le32(pctl_base + DDR_PCTL2_RFSHCTL3, 1); - update_refresh_reg(dram); - - if (dramtype == DDR4) { - clrsetbits_le32(PHY_REG(phy_base, 0x29), 0x3, 0x2); - clrsetbits_le32(PHY_REG(phy_base, 0x39), 0x3, 0x2); - clrsetbits_le32(PHY_REG(phy_base, 0x49), 0x3, 0x2); - clrsetbits_le32(PHY_REG(phy_base, 0x59), 0x3, 0x2); - } - - if (ret & 0x10) { - ret = -1; - } else { - ret = (ret & 0xf) ^ (readl(PHY_REG(phy_base, 0)) >> 4); - ret = (ret == 0) ? 0 : -1; - } - return ret; -} - -/* rank = 1: cs0 - * rank = 2: cs1 - * rank = 3: cs0 & cs1 - * note: be careful of keep mr original val - */ -static int write_mr(struct dram_info *dram, u32 rank, u32 mr_num, u32 arg, - u32 dramtype) { void __iomem *pctl_base = dram->pctl; - - while (readl(pctl_base + DDR_PCTL2_MRSTAT) & MR_WR_BUSY) - continue; - if (dramtype == DDR3 || dramtype == DDR4) { - writel((mr_num << 12) | (rank << 4) | (0 << 0), - pctl_base + DDR_PCTL2_MRCTRL0); - writel(arg, pctl_base + DDR_PCTL2_MRCTRL1); - } else { - writel((rank << 4) | (0 << 0), - pctl_base + DDR_PCTL2_MRCTRL0); - writel((mr_num << 8) | (arg & 0xff), - pctl_base + DDR_PCTL2_MRCTRL1); - } - - setbits_le32(pctl_base + DDR_PCTL2_MRCTRL0, 1u << 31); - while (readl(pctl_base + DDR_PCTL2_MRCTRL0) & (1u << 31)) - continue; - while (readl(pctl_base + DDR_PCTL2_MRSTAT) & MR_WR_BUSY) - continue; - - return 0; -} - -/* - * rank : 1:cs0, 2:cs1, 3:cs0&cs1 - * vrefrate: 4500: 45%, - */ -static int write_vrefdq(struct dram_info *dram, u32 rank, u32 vrefrate, - u32 dramtype) -{ - u32 tccd_l, value; u32 dis_auto_zq = 0; - void __iomem *pctl_base = dram->pctl; + u32 pwrctl; + u32 ret;
- if (dramtype != DDR4 || vrefrate < 4500 || vrefrate > 9200) - return -1; + /* disable auto low-power */ + pwrctl = readl(pctl_base + DDR_PCTL2_PWRCTL); + writel(0, pctl_base + DDR_PCTL2_PWRCTL);
- tccd_l = (readl(pctl_base + DDR_PCTL2_DRAMTMG4) >> 16) & 0xf; - tccd_l = (tccd_l - 4) << 10; + dis_auto_zq = pctl_dis_zqcs_aref(dram->pctl);
- if (vrefrate > 7500) { - /* range 1 */ - value = ((vrefrate - 6000) / 65) | tccd_l; - } else { - /* range 2 */ - value = ((vrefrate - 4500) / 65) | tccd_l | (1 << 6); - } + ret = phy_data_training(dram->phy, cs, dramtype);
- /* disable zqcs */ - if (!(readl(pctl_base + DDR_PCTL2_ZQCTL0) & - (1ul << 31))) { - dis_auto_zq = 1; - setbits_le32(pctl_base + DDR_PCTL2_ZQCTL0, 1 << 31); - } - /* disable auto refresh */ - setbits_le32(pctl_base + DDR_PCTL2_RFSHCTL3, 1); - update_refresh_reg(dram); - - /* enable vrefdq calibratin */ - write_mr(dram, rank, 6, value | (1 << 7), dramtype); - udelay(1);/* tvrefdqe */ - /* write vrefdq value */ - write_mr(dram, rank, 6, value | (1 << 7), dramtype); - udelay(1);/* tvref_time */ - write_mr(dram, rank, 6, value | (0 << 7), dramtype); - udelay(1);/* tvrefdqx */ - - /* restore zqcs */ - if (dis_auto_zq) - clrbits_le32(pctl_base + DDR_PCTL2_ZQCTL0, 1 << 31); - /* restore auto refresh */ - clrbits_le32(pctl_base + DDR_PCTL2_RFSHCTL3, 1); - update_refresh_reg(dram); + pctl_rest_zqcs_aref(dram->pctl, dis_auto_zq);
- return 0; -} + /* restore auto low-power */ + writel(pwrctl, pctl_base + DDR_PCTL2_PWRCTL);
-#define _MAX_(x, y) ((x) > (y) ? (x) : (y)) + return ret; +}
static void rx_deskew_switch_adjust(struct dram_info *dram) { @@ -557,7 +259,7 @@ static void rx_deskew_switch_adjust(struct dram_info *dram) void __iomem *phy_base = dram->phy;
for (i = 0; i < 4; i++) - gate_val = _MAX_(readl(PHY_REG(phy_base, 0xfb + i)), gate_val); + gate_val = MAX(readl(PHY_REG(phy_base, 0xfb + i)), gate_val);
deskew_val = (gate_val >> 3) + 1; deskew_val = (deskew_val > 0x1f) ? 0x1f : deskew_val; @@ -566,8 +268,6 @@ static void rx_deskew_switch_adjust(struct dram_info *dram) (deskew_val & 0x1c) << 2); }
-#undef _MAX_ - static void tx_deskew_switch_adjust(struct dram_info *dram) { void __iomem *phy_base = dram->phy; @@ -580,40 +280,39 @@ static void set_ddrconfig(struct dram_info *dram, u32 ddrconfig) writel(ddrconfig, &dram->msch->ddrconf); }
+static void sdram_msch_config(struct msch_regs *msch, + struct sdram_msch_timings *noc_timings) +{ + writel(noc_timings->ddrtiming.d32, &msch->ddrtiming); + + writel(noc_timings->ddrmode.d32, &msch->ddrmode); + writel(noc_timings->readlatency, &msch->readlatency); + + writel(noc_timings->activate.d32, &msch->activate); + writel(noc_timings->devtodev.d32, &msch->devtodev); + writel(noc_timings->ddr4timing.d32, &msch->ddr4_timing); + writel(noc_timings->agingx0, &msch->aging0); + writel(noc_timings->agingx0, &msch->aging1); + writel(noc_timings->agingx0, &msch->aging2); + writel(noc_timings->agingx0, &msch->aging3); + writel(noc_timings->agingx0, &msch->aging4); + writel(noc_timings->agingx0, &msch->aging5); +} + static void dram_all_config(struct dram_info *dram, struct rk3328_sdram_params *sdram_params) { - u32 sys_reg = 0, tmp = 0; - - set_ddrconfig(dram, sdram_ch.ddrconfig); - - sys_reg |= SYS_REG_ENC_DDRTYPE(sdram_params->dramtype); - sys_reg |= SYS_REG_ENC_ROW_3_4(sdram_ch.row_3_4, 0); - sys_reg |= SYS_REG_ENC_RANK(sdram_ch.rank, 0); - sys_reg |= SYS_REG_ENC_COL(sdram_ch.col, 0); - sys_reg |= SYS_REG_ENC_BK(sdram_ch.bk, 0); - SYS_REG_ENC_CS0_ROW(sdram_ch.cs0_row, sys_reg, tmp, 0); - if (sdram_ch.cs1_row) - SYS_REG_ENC_CS1_ROW(sdram_ch.cs1_row, sys_reg, tmp, 0); - sys_reg |= SYS_REG_ENC_BW(sdram_ch.bw, 0); - sys_reg |= SYS_REG_ENC_DBW(sdram_ch.dbw, 0); - - writel(sys_reg, &dram->grf->os_reg[2]); - - writel(sdram_ch.noc_timings.ddrtiming.d32, &dram->msch->ddrtiming); - - writel(sdram_ch.noc_timings.ddrmode.d32, &dram->msch->ddrmode); - writel(sdram_ch.noc_timings.readlatency, &dram->msch->readlatency); - - writel(sdram_ch.noc_timings.activate.d32, &dram->msch->activate); - writel(sdram_ch.noc_timings.devtodev.d32, &dram->msch->devtodev); - writel(sdram_ch.noc_timings.ddr4timing.d32, &dram->msch->ddr4_timing); - writel(sdram_ch.noc_timings.agingx0, &dram->msch->aging0); - writel(sdram_ch.noc_timings.agingx0, &dram->msch->aging1); - writel(sdram_ch.noc_timings.agingx0, &dram->msch->aging2); - writel(sdram_ch.noc_timings.agingx0, &dram->msch->aging3); - writel(sdram_ch.noc_timings.agingx0, &dram->msch->aging4); - writel(sdram_ch.noc_timings.agingx0, &dram->msch->aging5); + struct sdram_cap_info *cap_info = &sdram_params->ch.cap_info; + u32 sys_reg2 = 0; + u32 sys_reg3 = 0; + + set_ddrconfig(dram, cap_info->ddrconfig); + sdram_org_config(cap_info, &sdram_params->base, &sys_reg2, + &sys_reg3, 0); + writel(sys_reg2, &dram->grf->os_reg[2]); + writel(sys_reg3, &dram->grf->os_reg[3]); + + sdram_msch_config(dram->msch, &sdram_ch.noc_timings); }
static void enable_low_power(struct dram_info *dram, @@ -641,6 +340,7 @@ static void enable_low_power(struct dram_info *dram, static int sdram_init(struct dram_info *dram, struct rk3328_sdram_params *sdram_params, u32 pre_init) { + struct sdram_cap_info *cap_info = &sdram_params->ch.cap_info; void __iomem *pctl_base = dram->pctl;
rkclk_ddr_reset(dram, 1, 1, 1, 1); @@ -652,30 +352,18 @@ static int sdram_init(struct dram_info *dram, */ rkclk_ddr_reset(dram, 1, 1, 1, 0); rkclk_configure_ddr(dram, sdram_params); - if (pre_init == 0) { - switch (sdram_params->dramtype) { - case DDR3: - printf("DDR3\n"); - break; - case DDR4: - printf("DDR4\n"); - break; - case LPDDR3: - default: - printf("LPDDR3\n"); - break; - } - } + /* release phy srst to provide clk to ctrl */ rkclk_ddr_reset(dram, 1, 1, 0, 0); udelay(10); - phy_soft_reset(dram); + phy_soft_reset(dram->phy); /* release ctrl presetn, and config ctl registers */ rkclk_ddr_reset(dram, 1, 0, 0, 0); - pctl_cfg(dram, sdram_params); - sdram_ch.ddrconfig = calculate_ddrconfig(sdram_params); + pctl_cfg(dram->pctl, &sdram_params->pctl_regs, SR_IDLE, PD_IDLE); + cap_info->ddrconfig = calculate_ddrconfig(sdram_params); set_ctl_address_map(dram, sdram_params); - phy_cfg(dram, sdram_params); + phy_cfg(dram->phy, &sdram_params->phy_regs, &sdram_params->skew, + &sdram_params->base, cap_info->bw);
/* enable dfi_init_start to init phy after ctl srstn deassert */ setbits_le32(pctl_base + DDR_PCTL2_DFIMISC, (1 << 5) | (1 << 4)); @@ -685,13 +373,18 @@ static int sdram_init(struct dram_info *dram, continue;
/* do ddr gate training */ - if (data_training(dram, 0, sdram_params->dramtype) != 0) { + if (data_training(dram, 0, sdram_params->base.dramtype) != 0) { + printf("data training error\n"); + return -1; + } + if (data_training(dram, 1, sdram_params->base.dramtype) != 0) { printf("data training error\n"); return -1; }
- if (sdram_params->dramtype == DDR4) - write_vrefdq(dram, 0x3, 5670, sdram_params->dramtype); + if (sdram_params->base.dramtype == DDR4) + pctl_write_vrefdq(dram->pctl, 0x3, 5670, + sdram_params->base.dramtype);
if (pre_init == 0) { rx_deskew_switch_adjust(dram); @@ -708,7 +401,7 @@ static u64 dram_detect_cap(struct dram_info *dram, struct rk3328_sdram_params *sdram_params, unsigned char channel) { - void __iomem *pctl_base = dram->pctl; + struct sdram_cap_info *cap_info = &sdram_params->ch.cap_info;
/* * for ddr3: ddrconf = 3 @@ -718,14 +411,10 @@ static u64 dram_detect_cap(struct dram_info *dram, */ u32 bk, bktmp; u32 col, coltmp; - u32 row, rowtmp, row_3_4; - void __iomem *test_addr, *test_addr1; - u32 dbw; + u32 rowtmp; u32 cs; u32 bw = 1; - u64 cap = 0; - u32 dram_type = sdram_params->dramtype; - u32 pwrctl; + u32 dram_type = sdram_params->base.dramtype;
if (dram_type != DDR4) { /* detect col and bk for ddr3/lpddr3 */ @@ -733,33 +422,10 @@ static u64 dram_detect_cap(struct dram_info *dram, bktmp = 3; rowtmp = 16;
- for (col = coltmp; col >= 9; col -= 1) { - writel(0, SDRAM_ADDR); - test_addr = (void __iomem *)(SDRAM_ADDR + - (1ul << (col + bw - 1ul))); - writel(PATTERN, test_addr); - if ((readl(test_addr) == PATTERN) && - (readl(SDRAM_ADDR) == 0)) - break; - } - if (col == 8) { - printf("col error\n"); + if (sdram_detect_col(cap_info, coltmp) != 0) goto cap_err; - } - - test_addr = (void __iomem *)(SDRAM_ADDR + - (1ul << (coltmp + bktmp + bw - 1ul))); - writel(0, SDRAM_ADDR); - writel(PATTERN, test_addr); - if ((readl(test_addr) == PATTERN) && - (readl(SDRAM_ADDR) == 0)) - bk = 3; - else - bk = 2; - if (dram_type == LPDDR3) - dbw = 2; - else - dbw = 1; + sdram_detect_bank(cap_info, coltmp, bktmp); + sdram_detect_dbw(cap_info, dram_type); } else { /* detect bg for ddr4 */ coltmp = 10; @@ -768,178 +434,49 @@ static u64 dram_detect_cap(struct dram_info *dram,
col = 10; bk = 2; - test_addr = (void __iomem *)(SDRAM_ADDR + - (1ul << (coltmp + bw + 1ul))); - writel(0, SDRAM_ADDR); - writel(PATTERN, test_addr); - if ((readl(test_addr) == PATTERN) && - (readl(SDRAM_ADDR) == 0)) - dbw = 0; - else - dbw = 1; + cap_info->col = col; + cap_info->bk = bk; + sdram_detect_bg(cap_info, coltmp); } + /* detect row */ - for (row = rowtmp; row > 12; row--) { - writel(0, SDRAM_ADDR); - test_addr = (void __iomem *)(SDRAM_ADDR + - (1ul << (row + bktmp + coltmp + bw - 1ul))); - writel(PATTERN, test_addr); - if ((readl(test_addr) == PATTERN) && - (readl(SDRAM_ADDR) == 0)) - break; - } - if (row == 12) { - printf("row error"); + if (sdram_detect_row(cap_info, coltmp, bktmp, rowtmp) != 0) goto cap_err; - } - /* detect row_3_4 */ - test_addr = SDRAM_ADDR; - test_addr1 = (void __iomem *)(SDRAM_ADDR + - (0x3ul << (row + bktmp + coltmp + bw - 1ul - 1ul))); - - writel(0, test_addr); - writel(PATTERN, test_addr1); - if ((readl(test_addr) == 0) && - (readl(test_addr1) == PATTERN)) - row_3_4 = 0; - else - row_3_4 = 1;
- /* disable auto low-power */ - pwrctl = readl(pctl_base + DDR_PCTL2_PWRCTL); - writel(0, pctl_base + DDR_PCTL2_PWRCTL); + /* detect row_3_4 */ + sdram_detect_row_3_4(cap_info, coltmp, bktmp);
- /* bw and cs detect using phy read gate training */ + /* bw and cs detect using data training */ if (data_training(dram, 1, dram_type) == 0) cs = 1; else cs = 0; + cap_info->rank = cs + 1;
bw = 2; + cap_info->bw = bw;
- /* restore auto low-power */ - writel(pwrctl, pctl_base + DDR_PCTL2_PWRCTL); - - sdram_ch.rank = cs + 1; - sdram_ch.col = col; - sdram_ch.bk = bk; - sdram_ch.dbw = dbw; - sdram_ch.bw = bw; - sdram_ch.cs0_row = row; - if (cs) - sdram_ch.cs1_row = row; - else - sdram_ch.cs1_row = 0; - sdram_ch.row_3_4 = row_3_4; - - if (dram_type == DDR4) - cap = 1llu << (cs + row + bk + col + ((dbw == 0) ? 2 : 1) + bw); - else - cap = 1llu << (cs + row + bk + col + bw); - - return cap; - -cap_err: - return 0; -} - -static u32 remodify_sdram_params(struct rk3328_sdram_params *sdram_params) -{ - u32 tmp = 0, tmp_adr = 0, i; - - for (i = 0; sdram_params->pctl_regs.pctl[i][0] != 0xFFFFFFFF; i++) { - if (sdram_params->pctl_regs.pctl[i][0] == 0) { - tmp = sdram_params->pctl_regs.pctl[i][1];/* MSTR */ - tmp_adr = i; - } - } - - tmp &= ~((3ul << 30) | (3ul << 24) | (3ul << 12)); - - switch (sdram_ch.dbw) { - case 2: - tmp |= (3ul << 30); - break; - case 1: - tmp |= (2ul << 30); - break; - case 0: - default: - tmp |= (1ul << 30); - break; + cap_info->cs0_high16bit_row = cap_info->cs0_row; + if (cs) { + cap_info->cs1_row = cap_info->cs0_row; + cap_info->cs1_high16bit_row = cap_info->cs0_row; + } else { + cap_info->cs1_row = 0; + cap_info->cs1_high16bit_row = 0; }
- if (sdram_ch.rank == 2) - tmp |= 3 << 24; - else - tmp |= 1 << 24; - - tmp |= (2 - sdram_ch.bw) << 12; - - sdram_params->pctl_regs.pctl[tmp_adr][1] = tmp; - - if (sdram_ch.bw == 2) - sdram_ch.noc_timings.ddrtiming.b.bwratio = 0; - else - sdram_ch.noc_timings.ddrtiming.b.bwratio = 1; - return 0; -} - -static int dram_detect_cs1_row(struct rk3328_sdram_params *sdram_params, - unsigned char channel) -{ - u32 ret = 0; - u32 cs1_bit; - void __iomem *test_addr, *cs1_addr; - u32 row, bktmp, coltmp, bw; - u32 ddrconf = sdram_ch.ddrconfig; - - if (sdram_ch.rank == 2) { - cs1_bit = addrmap[ddrconf][0] + 8; - - if (cs1_bit > 31) - goto out; - - cs1_addr = (void __iomem *)(1ul << cs1_bit); - if (cs1_bit < 20) - cs1_bit = 1; - else - cs1_bit = 0; - - if (sdram_params->dramtype == DDR4) { - if (sdram_ch.dbw == 0) - bktmp = sdram_ch.bk + 2; - else - bktmp = sdram_ch.bk + 1; - } else { - bktmp = sdram_ch.bk; - } - bw = sdram_ch.bw; - coltmp = sdram_ch.col; - - /* detect cs1 row */ - for (row = sdram_ch.cs0_row; row > 12; row--) { - test_addr = (void __iomem *)(SDRAM_ADDR + cs1_addr + - (1ul << (row + cs1_bit + bktmp + - coltmp + bw - 1ul))); - writel(0, SDRAM_ADDR + cs1_addr); - writel(PATTERN, test_addr); - if ((readl(test_addr) == PATTERN) && - (readl(SDRAM_ADDR + cs1_addr) == 0)) { - ret = row; - break; - } - } - } - -out: - return ret; +cap_err: + return -1; }
static int sdram_init_detect(struct dram_info *dram, struct rk3328_sdram_params *sdram_params) { + u32 sys_reg = 0; + u32 sys_reg3 = 0; + struct sdram_cap_info *cap_info = &sdram_params->ch.cap_info; + debug("Starting SDRAM initialization...\n");
memcpy(&sdram_ch, &sdram_params->ch, @@ -949,13 +486,29 @@ static int sdram_init_detect(struct dram_info *dram, dram_detect_cap(dram, sdram_params, 0);
/* modify bw, cs related timing */ - remodify_sdram_params(sdram_params); + pctl_remodify_sdram_params(&sdram_params->pctl_regs, cap_info, + sdram_params->base.dramtype); + + if (cap_info->bw == 2) + sdram_ch.noc_timings.ddrtiming.b.bwratio = 0; + else + sdram_ch.noc_timings.ddrtiming.b.bwratio = 1; + /* reinit sdram by real dram cap */ sdram_init(dram, sdram_params, 0);
/* redetect cs1 row */ - sdram_ch.cs1_row = - dram_detect_cs1_row(sdram_params, 0); + sdram_detect_cs1_row(cap_info, sdram_params->base.dramtype); + if (cap_info->cs1_row) { + sys_reg = readl(&dram->grf->os_reg[2]); + sys_reg3 = readl(&dram->grf->os_reg[3]); + SYS_REG_ENC_CS1_ROW(cap_info->cs1_row, + sys_reg, sys_reg3, 0); + writel(sys_reg, &dram->grf->os_reg[2]); + writel(sys_reg3, &dram->grf->os_reg[3]); + } + + sdram_print_ddr_info(&sdram_params->ch.cap_info, &sdram_params->base);
return 0; }
RK3399's controller and phy are able to re-use the common code, migrate to use the common driver and remove duplicated code.
Signed-off-by: YouMin Chen cym@rock-chips.com Signed-off-by: Kever Yang kever.yang@rock-chips.com ---
Changes in v2: None
arch/arm/dts/rk3399-sdram-ddr3-1333.dtsi | 4 + arch/arm/dts/rk3399-sdram-ddr3-1600.dtsi | 4 + arch/arm/dts/rk3399-sdram-ddr3-1866.dtsi | 4 + .../arm/dts/rk3399-sdram-lpddr3-2GB-1600.dtsi | 4 + .../arm/dts/rk3399-sdram-lpddr3-4GB-1600.dtsi | 4 + .../rk3399-sdram-lpddr3-samsung-4GB-1866.dtsi | 4 + arch/arm/dts/rk3399-sdram-lpddr4-100.dtsi | 4 + .../include/asm/arch-rockchip/sdram_rk3399.h | 97 +- arch/arm/mach-rockchip/Kconfig | 1 + drivers/ram/rockchip/Kconfig | 21 +- drivers/ram/rockchip/Makefile | 2 +- .../ram/rockchip/sdram-rk3399-lpddr4-400.inc | 28 +- .../ram/rockchip/sdram-rk3399-lpddr4-800.inc | 28 +- drivers/ram/rockchip/sdram_debug.c | 147 +++ drivers/ram/rockchip/sdram_rk3399.c | 968 ++++++++++++------ 15 files changed, 932 insertions(+), 388 deletions(-) create mode 100644 drivers/ram/rockchip/sdram_debug.c
diff --git a/arch/arm/dts/rk3399-sdram-ddr3-1333.dtsi b/arch/arm/dts/rk3399-sdram-ddr3-1333.dtsi index 3708bd674b..7fae249536 100644 --- a/arch/arm/dts/rk3399-sdram-ddr3-1333.dtsi +++ b/arch/arm/dts/rk3399-sdram-ddr3-1333.dtsi @@ -13,6 +13,8 @@ 0x0 0xf 0xf + 0xf + 0xf 1 0x80120e12 0x11030802 @@ -28,6 +30,8 @@ 0x0 0xf 0xf + 0xf + 0xf 1 0x80120e12 0x11030802 diff --git a/arch/arm/dts/rk3399-sdram-ddr3-1600.dtsi b/arch/arm/dts/rk3399-sdram-ddr3-1600.dtsi index fcd01f8b46..23c7c34a9a 100644 --- a/arch/arm/dts/rk3399-sdram-ddr3-1600.dtsi +++ b/arch/arm/dts/rk3399-sdram-ddr3-1600.dtsi @@ -13,6 +13,8 @@ 0x0 0xf 0xf + 0xf + 0xf 1 0x80151015 0x14040902 @@ -28,6 +30,8 @@ 0x0 0xf 0xf + 0xf + 0xf 1 0x80151015 0x14040902 diff --git a/arch/arm/dts/rk3399-sdram-ddr3-1866.dtsi b/arch/arm/dts/rk3399-sdram-ddr3-1866.dtsi index c46c1996be..ea029ca90a 100644 --- a/arch/arm/dts/rk3399-sdram-ddr3-1866.dtsi +++ b/arch/arm/dts/rk3399-sdram-ddr3-1866.dtsi @@ -13,6 +13,8 @@ 0x0 0xf 0xf + 0xf + 0xf 1 0x80181219 0x17050a03 @@ -28,6 +30,8 @@ 0x0 0xf 0xf + 0xf + 0xf 1 0x80181219 0x17050a03 diff --git a/arch/arm/dts/rk3399-sdram-lpddr3-2GB-1600.dtsi b/arch/arm/dts/rk3399-sdram-lpddr3-2GB-1600.dtsi index d14e833d22..7296dbb80e 100644 --- a/arch/arm/dts/rk3399-sdram-lpddr3-2GB-1600.dtsi +++ b/arch/arm/dts/rk3399-sdram-lpddr3-2GB-1600.dtsi @@ -14,6 +14,8 @@ 0x0 0xf 0xf + 0xf + 0xf 1 0x1d191519 0x14040808 @@ -29,6 +31,8 @@ 0x0 0xf 0xf + 0xf + 0xf 1 0x1d191519 0x14040808 diff --git a/arch/arm/dts/rk3399-sdram-lpddr3-4GB-1600.dtsi b/arch/arm/dts/rk3399-sdram-lpddr3-4GB-1600.dtsi index fc4cccb6a0..bf429c21e4 100644 --- a/arch/arm/dts/rk3399-sdram-lpddr3-4GB-1600.dtsi +++ b/arch/arm/dts/rk3399-sdram-lpddr3-4GB-1600.dtsi @@ -13,6 +13,8 @@ 0x0 0xf 0xf + 0xf + 0xf 1 0x1d191519 0x14040808 @@ -28,6 +30,8 @@ 0x0 0xf 0xf + 0xf + 0xf 1 0x1d191519 0x14040808 diff --git a/arch/arm/dts/rk3399-sdram-lpddr3-samsung-4GB-1866.dtsi b/arch/arm/dts/rk3399-sdram-lpddr3-samsung-4GB-1866.dtsi index 2a627e1be5..96f459fd0b 100644 --- a/arch/arm/dts/rk3399-sdram-lpddr3-samsung-4GB-1866.dtsi +++ b/arch/arm/dts/rk3399-sdram-lpddr3-samsung-4GB-1866.dtsi @@ -13,6 +13,8 @@ 0x0 0xf 0xf + 0xf + 0xf 1
0x801d181e @@ -30,6 +32,8 @@ 0x0 0xf 0xf + 0xf + 0xf 1
0x801d181e diff --git a/arch/arm/dts/rk3399-sdram-lpddr4-100.dtsi b/arch/arm/dts/rk3399-sdram-lpddr4-100.dtsi index 4a4414a960..f0c478d189 100644 --- a/arch/arm/dts/rk3399-sdram-lpddr4-100.dtsi +++ b/arch/arm/dts/rk3399-sdram-lpddr4-100.dtsi @@ -15,6 +15,8 @@ 0x0 0xf 0xf + 0xf + 0xf 1 0x80241d22 0x15050f08 @@ -30,6 +32,8 @@ 0x0 0xf 0xf + 0xf + 0xf 1 0x80241d22 0x15050f08 diff --git a/arch/arm/include/asm/arch-rockchip/sdram_rk3399.h b/arch/arm/include/asm/arch-rockchip/sdram_rk3399.h index 485bb3d889..9e1e22520f 100644 --- a/arch/arm/include/asm/arch-rockchip/sdram_rk3399.h +++ b/arch/arm/include/asm/arch-rockchip/sdram_rk3399.h @@ -6,6 +6,7 @@ #ifndef _ASM_ARCH_SDRAM_RK3399_H #define _ASM_ARCH_SDRAM_RK3399_H #include <asm/arch-rockchip/sdram_common.h> +#include <asm/arch-rockchip/sdram_msch.h>
struct rk3399_ddr_pctl_regs { u32 denali_ctl[332]; @@ -19,55 +20,6 @@ struct rk3399_ddr_pi_regs { u32 denali_pi[200]; };
-union noc_ddrtimingc0 { - u32 d32; - struct { - unsigned burstpenalty : 4; - unsigned reserved0 : 4; - unsigned wrtomwr : 6; - unsigned reserved1 : 18; - } b; -}; - -union noc_ddrmode { - u32 d32; - struct { - unsigned autoprecharge : 1; - unsigned bypassfiltering : 1; - unsigned fawbank : 1; - unsigned burstsize : 2; - unsigned mwrsize : 2; - unsigned reserved2 : 1; - unsigned forceorder : 8; - unsigned forceorderstate : 8; - unsigned reserved3 : 8; - } b; -}; - -struct rk3399_msch_regs { - u32 coreid; - u32 revisionid; - u32 ddrconf; - u32 ddrsize; - u32 ddrtiminga0; - u32 ddrtimingb0; - u32 ddrtimingc0; - u32 devtodev0; - u32 reserved0[(0x110 - 0x20) / 4]; - u32 ddrmode; - u32 reserved1[(0x1000 - 0x114) / 4]; - u32 agingx0; -}; - -struct rk3399_msch_timings { - u32 ddrtiminga0; - u32 ddrtimingb0; - union noc_ddrtimingc0 ddrtimingc0; - u32 devtodev0; - union noc_ddrmode ddrmode; - u32 agingx0; -}; - struct rk3399_ddr_cic_regs { u32 cic_ctrl0; u32 cic_ctrl1; @@ -84,14 +36,38 @@ struct rk3399_ddr_cic_regs { #define START 1
/* DENALI_CTL_68 */ -#define PWRUP_SREFRESH_EXIT (1 << 16) +#define PWRUP_SREFRESH_EXIT BIT(16)
/* DENALI_CTL_274 */ #define MEM_RST_VALID 1
+struct msch_regs { + u32 coreid; + u32 revisionid; + u32 ddrconf; + u32 ddrsize; + union noc_ddrtiminga0 ddrtiminga0; + union noc_ddrtimingb0 ddrtimingb0; + union noc_ddrtimingc0 ddrtimingc0; + union noc_devtodev0 devtodev0; + u32 reserved0[(0x110 - 0x20) / 4]; + union noc_ddrmode ddrmode; + u32 reserved1[(0x1000 - 0x114) / 4]; + u32 agingx0; +}; + +struct sdram_msch_timings { + union noc_ddrtiminga0 ddrtiminga0; + union noc_ddrtimingb0 ddrtimingb0; + union noc_ddrtimingc0 ddrtimingc0; + union noc_devtodev0 devtodev0; + union noc_ddrmode ddrmode; + u32 agingx0; +}; + struct rk3399_sdram_channel { struct sdram_cap_info cap_info; - struct rk3399_msch_timings noc_timings; + struct sdram_msch_timings noc_timings; };
struct rk3399_sdram_params { @@ -102,11 +78,20 @@ struct rk3399_sdram_params { struct rk3399_ddr_publ_regs phy_regs; };
-#define PI_CA_TRAINING (1 << 0) -#define PI_WRITE_LEVELING (1 << 1) -#define PI_READ_GATE_TRAINING (1 << 2) -#define PI_READ_LEVELING (1 << 3) -#define PI_WDQ_LEVELING (1 << 4) +#define PI_CA_TRAINING BIT(0) +#define PI_WRITE_LEVELING BIT(1) +#define PI_READ_GATE_TRAINING BIT(2) +#define PI_READ_LEVELING BIT(3) +#define PI_WDQ_LEVELING BIT(4) #define PI_FULL_TRAINING 0xff
+enum { + STRIDE_128B = 0, + STRIDE_256B = 1, + STRIDE_512B = 2, + STRIDE_4KB = 3, + UN_STRIDE = 4, + PART_STRIDE = 5 +}; + #endif diff --git a/arch/arm/mach-rockchip/Kconfig b/arch/arm/mach-rockchip/Kconfig index 5f1ad51cac..7746b661e5 100644 --- a/arch/arm/mach-rockchip/Kconfig +++ b/arch/arm/mach-rockchip/Kconfig @@ -184,6 +184,7 @@ config ROCKCHIP_RK3399 select DM_REGULATOR_FIXED select BOARD_LATE_INIT imply ROCKCHIP_COMMON_BOARD + imply ROCKCHIP_SDRAM_COMMON imply SPL_ROCKCHIP_COMMON_BOARD imply TPL_SERIAL_SUPPORT imply TPL_LIBCOMMON_SUPPORT diff --git a/drivers/ram/rockchip/Kconfig b/drivers/ram/rockchip/Kconfig index dcc06b3fd3..3f44fb3fce 100644 --- a/drivers/ram/rockchip/Kconfig +++ b/drivers/ram/rockchip/Kconfig @@ -11,29 +11,10 @@ config ROCKCHIP_SDRAM_COMMON help This enable sdram common driver
-if RAM_ROCKCHIP - -config RAM_ROCKCHIP_DEBUG - bool "Rockchip ram drivers debugging" - help - This enables debugging ram driver API's for the platforms - based on Rockchip SoCs. - - This is an option for developers to understand the ram drivers - initialization, configurations and etc. - -config RAM_RK3399 - bool "Ram driver for Rockchip RK3399" - default ROCKCHIP_RK3399 - help - This enables ram drivers support for the platforms based on - Rockchip RK3399 SoC. - config RAM_RK3399_LPDDR4 bool "LPDDR4 support for Rockchip RK3399" - depends on RAM_RK3399 + depends on RAM_ROCKCHIP && ROCKCHIP_RK3399 help This enables LPDDR4 sdram code support for the platforms based on Rockchip RK3399 SoC.
-endif # RAM_ROCKCHIP diff --git a/drivers/ram/rockchip/Makefile b/drivers/ram/rockchip/Makefile index b42ef91c21..47b9b1bebb 100644 --- a/drivers/ram/rockchip/Makefile +++ b/drivers/ram/rockchip/Makefile @@ -9,4 +9,4 @@ obj-$(CONFIG_ROCKCHIP_RK3188) = sdram_rk3188.o obj-$(CONFIG_ROCKCHIP_RK322X) = sdram_rk322x.o obj-$(CONFIG_ROCKCHIP_RK3288) = sdram_rk3288.o obj-$(CONFIG_ROCKCHIP_RK3328) += sdram_rk3328.o sdram_pctl_px30.o sdram_phy_px30.o -obj-$(CONFIG_RAM_RK3399) += sdram_rk3399.o +obj-$(CONFIG_ROCKCHIP_RK3399) += sdram_rk3399.o diff --git a/drivers/ram/rockchip/sdram-rk3399-lpddr4-400.inc b/drivers/ram/rockchip/sdram-rk3399-lpddr4-400.inc index c50a03d9dd..6ddc01c49d 100644 --- a/drivers/ram/rockchip/sdram-rk3399-lpddr4-400.inc +++ b/drivers/ram/rockchip/sdram-rk3399-lpddr4-400.inc @@ -16,15 +16,23 @@ .row_3_4 = 0x0, .cs0_row = 0xF, .cs1_row = 0xF, + .cs0_high16bit_row = 0xF, + .cs1_high16bit_row = 0xF, .ddrconfig = 1, }, { - .ddrtiminga0 = 0x80241d22, - .ddrtimingb0 = 0x15050f08, + .ddrtiminga0 = { + 0x80241d22, + }, + .ddrtimingb0 = { + 0x15050f08, + }, .ddrtimingc0 = { 0x00000602, }, - .devtodev0 = 0x00002122, + .devtodev0 = { + 0x00002122, + }, .ddrmode = { 0x0000004c, }, @@ -41,15 +49,23 @@ .row_3_4 = 0x0, .cs0_row = 0xF, .cs1_row = 0xF, + .cs0_high16bit_row = 0xF, + .cs1_high16bit_row = 0xF, .ddrconfig = 1, }, { - .ddrtiminga0 = 0x80241d22, - .ddrtimingb0 = 0x15050f08, + .ddrtiminga0 = { + 0x80241d22, + }, + .ddrtimingb0 = { + 0x15050f08, + }, .ddrtimingc0 = { 0x00000602, }, - .devtodev0 = 0x00002122, + .devtodev0 = { + 0x00002122, + }, .ddrmode = { 0x0000004c, }, diff --git a/drivers/ram/rockchip/sdram-rk3399-lpddr4-800.inc b/drivers/ram/rockchip/sdram-rk3399-lpddr4-800.inc index d8ae3359a3..307f6ee458 100644 --- a/drivers/ram/rockchip/sdram-rk3399-lpddr4-800.inc +++ b/drivers/ram/rockchip/sdram-rk3399-lpddr4-800.inc @@ -16,15 +16,23 @@ .row_3_4 = 0x0, .cs0_row = 0xF, .cs1_row = 0xF, + .cs0_high16bit_row = 0xF, + .cs1_high16bit_row = 0xF, .ddrconfig = 1, }, { - .ddrtiminga0 = 0x80241d22, - .ddrtimingb0 = 0x15050f08, + .ddrtiminga0 = { + 0x80241d22, + }, + .ddrtimingb0 = { + 0x15050f08, + }, .ddrtimingc0 = { 0x00000602, }, - .devtodev0 = 0x00002122, + .devtodev0 = { + 0x00002122, + }, .ddrmode = { 0x0000004c, }, @@ -41,15 +49,23 @@ .row_3_4 = 0x0, .cs0_row = 0xF, .cs1_row = 0xF, + .cs0_high16bit_row = 0xF, + .cs1_high16bit_row = 0xF, .ddrconfig = 1, }, { - .ddrtiminga0 = 0x80241d22, - .ddrtimingb0 = 0x15050f08, + .ddrtiminga0 = { + 0x80241d22, + }, + .ddrtimingb0 = { + 0x15050f08, + }, .ddrtimingc0 = { 0x00000602, }, - .devtodev0 = 0x00002122, + .devtodev0 = { + 0x00002122, + }, .ddrmode = { 0x0000004c, }, diff --git a/drivers/ram/rockchip/sdram_debug.c b/drivers/ram/rockchip/sdram_debug.c new file mode 100644 index 0000000000..133d1938d5 --- /dev/null +++ b/drivers/ram/rockchip/sdram_debug.c @@ -0,0 +1,147 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * (C) Copyright 2019 Rockchip Electronics Co., Ltd + * (C) Copyright 2019 Amarula Solutions. + * Author: Jagan Teki jagan@amarulasolutions.com + */ + +#include <common.h> +#include <debug_uart.h> +#include <asm/arch-rockchip/sdram.h> + +void sdram_print_dram_type(unsigned char dramtype) +{ + switch (dramtype) { + case DDR3: + printascii("DDR3"); + break; + case DDR4: + printascii("DDR4"); + break; + case LPDDR2: + printascii("LPDDR2"); + break; + case LPDDR3: + printascii("LPDDR3"); + break; + case LPDDR4: + printascii("LPDDR4"); + break; + default: + printascii("Unknown Device"); + break; + } +} + +/** + * cs = 0, cs0 + * cs = 1, cs1 + * cs => 2, cs0+cs1 + * note: it didn't consider about row_3_4 + */ +u64 sdram_get_cs_cap(struct sdram_cap_info *cap_info, u32 cs, u32 dram_type) +{ + u32 bg; + u64 cap[2]; + + if (dram_type == DDR4) + /* DDR4 8bit dram BG = 2(4bank groups), + * 16bit dram BG = 1 (2 bank groups) + */ + bg = (cap_info->dbw == 0) ? 2 : 1; + else + bg = 0; + + cap[0] = 1llu << (cap_info->bw + cap_info->col + + bg + cap_info->bk + cap_info->cs0_row); + + if (cap_info->rank == 2) + cap[1] = 1llu << (cap_info->bw + cap_info->col + + bg + cap_info->bk + cap_info->cs1_row); + else + cap[1] = 0; + + if (cs == 0) + return cap[0]; + else if (cs == 1) + return cap[1]; + else + return (cap[0] + cap[1]); +} + +void sdram_print_ddr_info(struct sdram_cap_info *cap_info, + struct sdram_base_params *base) +{ + u32 bg, cap; + + bg = (cap_info->dbw == 0) ? 2 : 1; + + sdram_print_dram_type(base->dramtype); + + printascii(", "); + printdec(base->ddr_freq); + printascii("MHz\n"); + + printascii("BW="); + printdec(8 << cap_info->bw); + + printascii(" Col="); + printdec(cap_info->col); + + printascii(" Bk="); + printdec(0x1 << cap_info->bk); + if (base->dramtype == DDR4) { + printascii(" BG="); + printdec(1 << bg); + } + + printascii(" CS0 Row="); + printdec(cap_info->cs0_row); + if (cap_info->rank > 1) { + printascii(" CS1 Row="); + printdec(cap_info->cs1_row); + } + + printascii(" CS="); + printdec(cap_info->rank); + + printascii(" Die BW="); + printdec(8 << cap_info->dbw); + + cap = sdram_get_cs_cap(cap_info, 3, base->dramtype); + if (cap_info->row_3_4) + cap = cap * 3 / 4; + + printascii(" Size="); + printdec(cap >> 20); + printascii("MB\n"); +} + +void sdram_print_stride(unsigned int stride) +{ + switch (stride) { + case 0xc: + printf("128B stride\n"); + break; + case 5: + case 9: + case 0xd: + case 0x11: + case 0x19: + printf("256B stride\n"); + break; + case 0xa: + case 0xe: + case 0x12: + printf("512B stride\n"); + break; + case 0xf: + printf("4K stride\n"); + break; + case 0x1f: + printf("32MB + 256B stride\n"); + break; + default: + printf("no stride\n"); + } +} diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index 9b7de4ae41..073fba0990 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -52,7 +52,7 @@ struct chan_info { struct rk3399_ddr_pctl_regs *pctl; struct rk3399_ddr_pi_regs *pi; struct rk3399_ddr_publ_regs *publ; - struct rk3399_msch_regs *msch; + struct msch_regs *msch; };
struct dram_info { @@ -74,10 +74,15 @@ struct dram_info { };
struct sdram_rk3399_ops { - int (*data_training)(struct dram_info *dram, u32 channel, u8 rank, - struct rk3399_sdram_params *sdram); - int (*set_rate)(struct dram_info *dram, - struct rk3399_sdram_params *params); + int (*data_training_first)(struct dram_info *dram, u32 channel, u8 rank, + struct rk3399_sdram_params *sdram); + int (*set_rate_index)(struct dram_info *dram, + struct rk3399_sdram_params *params); + void (*modify_param)(const struct chan_info *chan, + struct rk3399_sdram_params *params); + struct rk3399_sdram_params * + (*get_phy_index_params)(u32 phy_fn, + struct rk3399_sdram_params *params); };
#if defined(CONFIG_TPL_BUILD) || \ @@ -196,11 +201,6 @@ struct io_setting { }, };
-/** - * phy = 0, PHY boot freq - * phy = 1, PHY index 0 - * phy = 2, PHY index 1 - */ static struct io_setting * lpddr4_get_io_settings(const struct rk3399_sdram_params *params, u32 mr5) { @@ -223,32 +223,21 @@ lpddr4_get_io_settings(const struct rk3399_sdram_params *params, u32 mr5) return io; }
-static void *get_denali_phy(const struct chan_info *chan, - struct rk3399_sdram_params *params, bool reg) -{ - return reg ? &chan->publ->denali_phy : ¶ms->phy_regs.denali_phy; -} - static void *get_denali_ctl(const struct chan_info *chan, struct rk3399_sdram_params *params, bool reg) { return reg ? &chan->pctl->denali_ctl : ¶ms->pctl_regs.denali_ctl; }
-static void *get_ddrc0_con(struct dram_info *dram, u8 channel) +static void *get_denali_phy(const struct chan_info *chan, + struct rk3399_sdram_params *params, bool reg) { - return (channel == 0) ? &dram->grf->ddrc0_con0 : &dram->grf->ddrc0_con1; + return reg ? &chan->publ->denali_phy : ¶ms->phy_regs.denali_phy; }
-static void copy_to_reg(u32 *dest, const u32 *src, u32 n) +static void *get_ddrc0_con(struct dram_info *dram, u8 channel) { - int i; - - for (i = 0; i < n / sizeof(u32); i++) { - writel(*src, dest); - src++; - dest++; - } + return (channel == 0) ? &dram->grf->ddrc0_con0 : &dram->grf->ddrc1_con0; }
static void rkclk_ddr_reset(struct rk3399_cru *cru, u32 channel, u32 ctl, @@ -344,7 +333,7 @@ static void set_memory_map(const struct chan_info *chan, u32 channel, ((3 - sdram_ch->cap_info.bk) << 16) | ((16 - row) << 24));
- if (IS_ENABLED(CONFIG_RAM_RK3399_LPDDR4)) { + if (params->base.dramtype == LPDDR4) { if (cs_map == 1) cs_map = 0x5; else if (cs_map == 2) @@ -496,7 +485,7 @@ static int phy_io_config(const struct chan_info *chan, /* PHY_939 PHY_PAD_CS_DRIVE */ clrsetbits_le32(&denali_phy[939], 0x7 << 14, mode_sel << 14);
- if (IS_ENABLED(CONFIG_RAM_RK3399_LPDDR4)) { + if (params->base.dramtype == LPDDR4) { /* BOOSTP_EN & BOOSTN_EN */ reg_value = ((PHY_BOOSTP_EN << 4) | PHY_BOOSTN_EN); /* PHY_925 PHY_PAD_FDBK_DRIVE2 */ @@ -563,7 +552,7 @@ static int phy_io_config(const struct chan_info *chan, /* PHY_939 PHY_PAD_CS_DRIVE */ clrsetbits_le32(&denali_phy[939], 0x3 << 17, speed << 17);
- if (IS_ENABLED(CONFIG_RAM_RK3399_LPDDR4)) { + if (params->base.dramtype == LPDDR4) { /* RX_CM_INPUT */ reg_value = PHY_RX_CM_INPUT; /* PHY_924 PHY_PAD_FDBK_DRIVE */ @@ -733,7 +722,7 @@ static void set_ds_odt(const struct chan_info *chan,
/* phy_adr_tsel_select_ 8bits DENALI_PHY_544/672/800 offset_0 */ reg_value = tsel_wr_select_ca_n | (tsel_wr_select_ca_p << 0x4); - if (IS_ENABLED(CONFIG_RAM_RK3399_LPDDR4)) { + if (params->base.dramtype == LPDDR4) { /* LPDDR4 these register read always return 0, so * can not use clrsetbits_le32(), need to write32 */ @@ -810,46 +799,107 @@ static void set_ds_odt(const struct chan_info *chan, phy_io_config(chan, params, mr5); }
-static void pctl_start(struct dram_info *dram, u8 channel) +static void pctl_start(struct dram_info *dram, + struct rk3399_sdram_params *params, + u32 channel_mask) { - const struct chan_info *chan = &dram->chan[channel]; - u32 *denali_ctl = chan->pctl->denali_ctl; - u32 *denali_phy = chan->publ->denali_phy; - u32 *ddrc0_con = get_ddrc0_con(dram, channel); + const struct chan_info *chan_0 = &dram->chan[0]; + const struct chan_info *chan_1 = &dram->chan[1]; + + u32 *denali_ctl_0 = chan_0->pctl->denali_ctl; + u32 *denali_phy_0 = chan_0->publ->denali_phy; + u32 *ddrc0_con_0 = get_ddrc0_con(dram, 0); + u32 *denali_ctl_1 = chan_1->pctl->denali_ctl; + u32 *denali_phy_1 = chan_1->publ->denali_phy; + u32 *ddrc1_con_0 = get_ddrc0_con(dram, 1); u32 count = 0; u32 byte, tmp;
- writel(0x01000000, &ddrc0_con); + /* PHY_DLL_RST_EN */ + if (channel_mask & 1) { + writel(0x01000000, &ddrc0_con_0); + clrsetbits_le32(&denali_phy_0[957], 0x3 << 24, 0x2 << 24); + }
- clrsetbits_le32(&denali_phy[957], 0x3 << 24, 0x2 << 24); + if (channel_mask & 1) { + count = 0; + while (!(readl(&denali_ctl_0[203]) & (1 << 3))) { + if (count > 1000) { + printf("%s: Failed to init pctl channel 0\n", + __func__); + while (1) + ; + } + udelay(1); + count++; + }
- while (!(readl(&denali_ctl[203]) & (1 << 3))) { - if (count > 1000) { - printf("%s: Failed to init pctl for channel %d\n", - __func__, channel); - while (1) - ; + writel(0x01000100, &ddrc0_con_0); + for (byte = 0; byte < 4; byte++) { + tmp = 0x820; + writel((tmp << 16) | tmp, + &denali_phy_0[53 + (128 * byte)]); + writel((tmp << 16) | tmp, + &denali_phy_0[54 + (128 * byte)]); + writel((tmp << 16) | tmp, + &denali_phy_0[55 + (128 * byte)]); + writel((tmp << 16) | tmp, + &denali_phy_0[56 + (128 * byte)]); + writel((tmp << 16) | tmp, + &denali_phy_0[57 + (128 * byte)]); + clrsetbits_le32(&denali_phy_0[58 + (128 * byte)], + 0xffff, tmp); } + clrsetbits_le32(&denali_ctl_0[68], PWRUP_SREFRESH_EXIT, + dram->pwrup_srefresh_exit[0]); + }
- udelay(1); - count++; + if (channel_mask & 2) { + writel(0x01000000, &ddrc1_con_0); + clrsetbits_le32(&denali_phy_1[957], 0x3 << 24, 0x2 << 24); } + if (channel_mask & 2) { + count = 0; + while (!(readl(&denali_ctl_1[203]) & (1 << 3))) { + if (count > 1000) { + printf("%s: Failed to init pctl channel 1\n", + __func__); + while (1) + ; + } + udelay(1); + count++; + }
- writel(0x01000100, &ddrc0_con); + writel(0x01000100, &ddrc1_con_0); + for (byte = 0; byte < 4; byte++) { + tmp = 0x820; + writel((tmp << 16) | tmp, + &denali_phy_1[53 + (128 * byte)]); + writel((tmp << 16) | tmp, + &denali_phy_1[54 + (128 * byte)]); + writel((tmp << 16) | tmp, + &denali_phy_1[55 + (128 * byte)]); + writel((tmp << 16) | tmp, + &denali_phy_1[56 + (128 * byte)]); + writel((tmp << 16) | tmp, + &denali_phy_1[57 + (128 * byte)]); + clrsetbits_le32(&denali_phy_1[58 + (128 * byte)], + 0xffff, tmp); + }
- for (byte = 0; byte < 4; byte++) { - tmp = 0x820; - writel((tmp << 16) | tmp, &denali_phy[53 + (128 * byte)]); - writel((tmp << 16) | tmp, &denali_phy[54 + (128 * byte)]); - writel((tmp << 16) | tmp, &denali_phy[55 + (128 * byte)]); - writel((tmp << 16) | tmp, &denali_phy[56 + (128 * byte)]); - writel((tmp << 16) | tmp, &denali_phy[57 + (128 * byte)]); + clrsetbits_le32(&denali_ctl_1[68], PWRUP_SREFRESH_EXIT, + dram->pwrup_srefresh_exit[1]);
- clrsetbits_le32(&denali_phy[58 + (128 * byte)], 0xffff, tmp); + /* + * restore channel 1 RESET original setting + * to avoid 240ohm too weak to prevent ESD test + */ + if (params->base.dramtype == LPDDR4) + clrsetbits_le32(&denali_phy_1[937], 0xff, + params->phy_regs.denali_phy[937] & + 0xFF); } - - clrsetbits_le32(&denali_ctl[68], PWRUP_SREFRESH_EXIT, - dram->pwrup_srefresh_exit[channel]); }
static int pctl_cfg(struct dram_info *dram, const struct chan_info *chan, @@ -861,13 +911,16 @@ static int pctl_cfg(struct dram_info *dram, const struct chan_info *chan, const u32 *params_ctl = params->pctl_regs.denali_ctl; const u32 *params_phy = params->phy_regs.denali_phy; u32 tmp, tmp1, tmp2; + struct rk3399_sdram_params *params_cfg; + u32 byte;
+ dram->ops->modify_param(chan, params); /* * work around controller bug: * Do not program DRAM_CLASS until NO_PHY_IND_TRAIN_INT is programmed */ - copy_to_reg(&denali_ctl[1], ¶ms_ctl[1], - sizeof(struct rk3399_ddr_pctl_regs) - 4); + sdram_copy_to_reg(&denali_ctl[1], ¶ms_ctl[1], + sizeof(struct rk3399_ddr_pctl_regs) - 4); writel(params_ctl[0], &denali_ctl[0]);
/* @@ -884,8 +937,8 @@ static int pctl_cfg(struct dram_info *dram, const struct chan_info *chan, writel(tmp + tmp1, &denali_ctl[14]); }
- copy_to_reg(denali_pi, ¶ms->pi_regs.denali_pi[0], - sizeof(struct rk3399_ddr_pi_regs)); + sdram_copy_to_reg(denali_pi, ¶ms->pi_regs.denali_pi[0], + sizeof(struct rk3399_ddr_pi_regs));
/* rank count need to set for init */ set_memory_map(chan, channel, params); @@ -894,7 +947,7 @@ static int pctl_cfg(struct dram_info *dram, const struct chan_info *chan, writel(params->phy_regs.denali_phy[911], &denali_phy[911]); writel(params->phy_regs.denali_phy[912], &denali_phy[912]);
- if (IS_ENABLED(CONFIG_RAM_RK3399_LPDDR4)) { + if (params->base.dramtype == LPDDR4) { writel(params->phy_regs.denali_phy[898], &denali_phy[898]); writel(params->phy_regs.denali_phy[919], &denali_phy[919]); } @@ -927,41 +980,67 @@ static int pctl_cfg(struct dram_info *dram, const struct chan_info *chan, } }
- copy_to_reg(&denali_phy[896], ¶ms_phy[896], (958 - 895) * 4); - copy_to_reg(&denali_phy[0], ¶ms_phy[0], (90 - 0 + 1) * 4); - copy_to_reg(&denali_phy[128], ¶ms_phy[128], (218 - 128 + 1) * 4); - copy_to_reg(&denali_phy[256], ¶ms_phy[256], (346 - 256 + 1) * 4); - copy_to_reg(&denali_phy[384], ¶ms_phy[384], (474 - 384 + 1) * 4); - copy_to_reg(&denali_phy[512], ¶ms_phy[512], (549 - 512 + 1) * 4); - copy_to_reg(&denali_phy[640], ¶ms_phy[640], (677 - 640 + 1) * 4); - copy_to_reg(&denali_phy[768], ¶ms_phy[768], (805 - 768 + 1) * 4); - set_ds_odt(chan, params, true, 0); + sdram_copy_to_reg(&denali_phy[896], ¶ms_phy[896], (958 - 895) * 4); + sdram_copy_to_reg(&denali_phy[0], ¶ms_phy[0], (90 - 0 + 1) * 4); + sdram_copy_to_reg(&denali_phy[128], ¶ms_phy[128], + (218 - 128 + 1) * 4); + sdram_copy_to_reg(&denali_phy[256], ¶ms_phy[256], + (346 - 256 + 1) * 4); + sdram_copy_to_reg(&denali_phy[384], ¶ms_phy[384], + (474 - 384 + 1) * 4); + sdram_copy_to_reg(&denali_phy[512], ¶ms_phy[512], + (549 - 512 + 1) * 4); + sdram_copy_to_reg(&denali_phy[640], ¶ms_phy[640], + (677 - 640 + 1) * 4); + sdram_copy_to_reg(&denali_phy[768], ¶ms_phy[768], + (805 - 768 + 1) * 4);
- /* - * phy_dqs_tsel_wr_timing_X 8bits DENALI_PHY_84/212/340/468 offset_8 - * dqs_tsel_wr_end[7:4] add Half cycle - */ - tmp = (readl(&denali_phy[84]) >> 8) & 0xff; - clrsetbits_le32(&denali_phy[84], 0xff << 8, (tmp + 0x10) << 8); - tmp = (readl(&denali_phy[212]) >> 8) & 0xff; - clrsetbits_le32(&denali_phy[212], 0xff << 8, (tmp + 0x10) << 8); - tmp = (readl(&denali_phy[340]) >> 8) & 0xff; - clrsetbits_le32(&denali_phy[340], 0xff << 8, (tmp + 0x10) << 8); - tmp = (readl(&denali_phy[468]) >> 8) & 0xff; - clrsetbits_le32(&denali_phy[468], 0xff << 8, (tmp + 0x10) << 8); + if (params->base.dramtype == LPDDR4) + params_cfg = dram->ops->get_phy_index_params(1, params); + else + params_cfg = dram->ops->get_phy_index_params(0, params); + + clrsetbits_le32(¶ms_cfg->phy_regs.denali_phy[896], 0x3 << 8, + 0 << 8); + writel(params_cfg->phy_regs.denali_phy[896], &denali_phy[896]); + + writel(params->phy_regs.denali_phy[83] + (0x10 << 16), + &denali_phy[83]); + writel(params->phy_regs.denali_phy[84] + (0x10 << 8), + &denali_phy[84]); + writel(params->phy_regs.denali_phy[211] + (0x10 << 16), + &denali_phy[211]); + writel(params->phy_regs.denali_phy[212] + (0x10 << 8), + &denali_phy[212]); + writel(params->phy_regs.denali_phy[339] + (0x10 << 16), + &denali_phy[339]); + writel(params->phy_regs.denali_phy[340] + (0x10 << 8), + &denali_phy[340]); + writel(params->phy_regs.denali_phy[467] + (0x10 << 16), + &denali_phy[467]); + writel(params->phy_regs.denali_phy[468] + (0x10 << 8), + &denali_phy[468]);
- /* - * phy_dqs_tsel_wr_timing_X 8bits DENALI_PHY_83/211/339/467 offset_8 - * dq_tsel_wr_end[7:4] add Half cycle - */ - tmp = (readl(&denali_phy[83]) >> 16) & 0xff; - clrsetbits_le32(&denali_phy[83], 0xff << 16, (tmp + 0x10) << 16); - tmp = (readl(&denali_phy[211]) >> 16) & 0xff; - clrsetbits_le32(&denali_phy[211], 0xff << 16, (tmp + 0x10) << 16); - tmp = (readl(&denali_phy[339]) >> 16) & 0xff; - clrsetbits_le32(&denali_phy[339], 0xff << 16, (tmp + 0x10) << 16); - tmp = (readl(&denali_phy[467]) >> 16) & 0xff; - clrsetbits_le32(&denali_phy[467], 0xff << 16, (tmp + 0x10) << 16); + if (params->base.dramtype == LPDDR4) { + /* + * to improve write dqs and dq phase from 1.5ns to 3.5ns + * at 50MHz. this's the measure result from oscilloscope + * of dqs and dq write signal. + */ + for (byte = 0; byte < 4; byte++) { + tmp = 0x680; + clrsetbits_le32(&denali_phy[1 + (128 * byte)], + 0xfff << 8, tmp << 8); + } + /* + * to workaround 366ball two channel's RESET connect to + * one RESET signal of die + */ + if (channel == 1) + clrsetbits_le32(&denali_phy[937], 0xff, + PHY_DRV_ODT_240 | + (PHY_DRV_ODT_240 << 0x4)); + }
return 0; } @@ -1392,7 +1471,7 @@ static void set_ddrconfig(const struct chan_info *chan, unsigned char channel, u32 ddrconfig) { /* only need to set ddrconfig */ - struct rk3399_msch_regs *ddr_msch_regs = chan->msch; + struct msch_regs *ddr_msch_regs = chan->msch; unsigned int cs0_cap = 0; unsigned int cs1_cap = 0;
@@ -1413,52 +1492,43 @@ static void set_ddrconfig(const struct chan_info *chan, &ddr_msch_regs->ddrsize); }
+static void sdram_msch_config(struct msch_regs *msch, + struct sdram_msch_timings *noc_timings) +{ + writel(noc_timings->ddrtiminga0.d32, + &msch->ddrtiminga0.d32); + writel(noc_timings->ddrtimingb0.d32, + &msch->ddrtimingb0.d32); + writel(noc_timings->ddrtimingc0.d32, + &msch->ddrtimingc0.d32); + writel(noc_timings->devtodev0.d32, + &msch->devtodev0.d32); + writel(noc_timings->ddrmode.d32, + &msch->ddrmode.d32); +} + static void dram_all_config(struct dram_info *dram, - const struct rk3399_sdram_params *params) + struct rk3399_sdram_params *params) { u32 sys_reg2 = 0; u32 sys_reg3 = 0; unsigned int channel, idx;
- sys_reg2 |= SYS_REG_ENC_DDRTYPE(params->base.dramtype); - sys_reg2 |= SYS_REG_ENC_NUM_CH(params->base.num_channels); - for (channel = 0, idx = 0; (idx < params->base.num_channels) && (channel < 2); channel++) { - const struct rk3399_sdram_channel *info = ¶ms->ch[channel]; - struct rk3399_msch_regs *ddr_msch_regs; - const struct rk3399_msch_timings *noc_timing; + struct msch_regs *ddr_msch_regs; + struct sdram_msch_timings *noc_timing;
if (params->ch[channel].cap_info.col == 0) continue; idx++; - sys_reg2 |= SYS_REG_ENC_ROW_3_4(info->cap_info.row_3_4, channel); - sys_reg2 |= SYS_REG_ENC_CHINFO(channel); - sys_reg2 |= SYS_REG_ENC_RANK(info->cap_info.rank, channel); - sys_reg2 |= SYS_REG_ENC_COL(info->cap_info.col, channel); - sys_reg2 |= SYS_REG_ENC_BK(info->cap_info.bk, channel); - sys_reg2 |= SYS_REG_ENC_BW(info->cap_info.bw, channel); - sys_reg2 |= SYS_REG_ENC_DBW(info->cap_info.dbw, channel); - SYS_REG_ENC_CS0_ROW(info->cap_info.cs0_row, sys_reg2, sys_reg3, channel); - if (info->cap_info.cs1_row) - SYS_REG_ENC_CS1_ROW(info->cap_info.cs1_row, sys_reg2, - sys_reg3, channel); - sys_reg3 |= SYS_REG_ENC_CS1_COL(info->cap_info.col, channel); - sys_reg3 |= SYS_REG_ENC_VERSION(DDR_SYS_REG_VERSION); - + sdram_org_config(¶ms->ch[channel].cap_info, + ¶ms->base, &sys_reg2, + &sys_reg3, channel); ddr_msch_regs = dram->chan[channel].msch; noc_timing = ¶ms->ch[channel].noc_timings; - writel(noc_timing->ddrtiminga0, - &ddr_msch_regs->ddrtiminga0); - writel(noc_timing->ddrtimingb0, - &ddr_msch_regs->ddrtimingb0); - writel(noc_timing->ddrtimingc0.d32, - &ddr_msch_regs->ddrtimingc0); - writel(noc_timing->devtodev0, - &ddr_msch_regs->devtodev0); - writel(noc_timing->ddrmode.d32, - &ddr_msch_regs->ddrmode); + sdram_msch_config(ddr_msch_regs, noc_timing);
/** * rank 1 memory clock disable (dfi_dram_clk_disable = 1) @@ -1494,7 +1564,7 @@ static void set_cap_relate_config(const struct chan_info *chan, { u32 *denali_ctl = chan->pctl->denali_ctl; u32 tmp; - struct rk3399_msch_timings *noc_timing; + struct sdram_msch_timings *noc_timing;
if (params->base.dramtype == LPDDR3) { tmp = (8 << params->ch[channel].cap_info.bw) / @@ -1566,9 +1636,14 @@ static u32 calculate_ddrconfig(struct rk3399_sdram_params *params, u32 channel) return i; }
+static void set_ddr_stride(struct rk3399_pmusgrf_regs *pmusgrf, u32 stride) +{ + rk_clrsetreg(&pmusgrf->soc_con4, 0x1f << 10, stride << 10); +} + #if !defined(CONFIG_RAM_RK3399_LPDDR4) -static int default_data_training(struct dram_info *dram, u32 channel, u8 rank, - struct rk3399_sdram_params *params) +static int data_training_first(struct dram_info *dram, u32 channel, u8 rank, + struct rk3399_sdram_params *params) { u8 training_flag = PI_READ_GATE_TRAINING;
@@ -1629,31 +1704,72 @@ static int switch_to_phy_index1(struct dram_info *dram, return 0; }
+struct rk3399_sdram_params + *get_phy_index_params(u32 phy_fn, + struct rk3399_sdram_params *params) +{ + if (phy_fn == 0) + return params; + else + return NULL; +} + +void modify_param(const struct chan_info *chan, + struct rk3399_sdram_params *params) +{ + struct rk3399_sdram_params *params_cfg; + u32 *denali_pi_params; + + denali_pi_params = params->pi_regs.denali_pi; + + /* modify PHY F0/F1/F2 params */ + params_cfg = get_phy_index_params(0, params); + set_ds_odt(chan, params_cfg, false, 0); + + clrsetbits_le32(&denali_pi_params[45], 0x1 << 24, 0x1 << 24); + clrsetbits_le32(&denali_pi_params[61], 0x1 << 24, 0x1 << 24); + clrsetbits_le32(&denali_pi_params[76], 0x1 << 24, 0x1 << 24); + clrsetbits_le32(&denali_pi_params[77], 0x1, 0x1); +} #else
-struct rk3399_sdram_params lpddr4_timings[] = { - #include "sdram-rk3399-lpddr4-400.inc" - #include "sdram-rk3399-lpddr4-800.inc" +struct rk3399_sdram_params dfs_cfgs_lpddr4[] = { +#include "sdram-rk3399-lpddr4-400.inc" +#include "sdram-rk3399-lpddr4-800.inc" };
+static struct rk3399_sdram_params + *lpddr4_get_phy_index_params(u32 phy_fn, + struct rk3399_sdram_params *params) +{ + if (phy_fn == 0) + return params; + else if (phy_fn == 1) + return &dfs_cfgs_lpddr4[1]; + else if (phy_fn == 2) + return &dfs_cfgs_lpddr4[0]; + else + return NULL; +} + static void *get_denali_pi(const struct chan_info *chan, struct rk3399_sdram_params *params, bool reg) { return reg ? &chan->pi->denali_pi : ¶ms->pi_regs.denali_pi; }
-static u32 lpddr4_get_phy(struct rk3399_sdram_params *params, u32 ctl) +static u32 lpddr4_get_phy_fn(struct rk3399_sdram_params *params, u32 ctl_fn) { - u32 lpddr4_phy[] = {1, 0, 0xb}; + u32 lpddr4_phy_fn[] = {1, 0, 0xb};
- return lpddr4_phy[ctl]; + return lpddr4_phy_fn[ctl_fn]; }
-static u32 lpddr4_get_ctl(struct rk3399_sdram_params *params, u32 phy) +static u32 lpddr4_get_ctl_fn(struct rk3399_sdram_params *params, u32 phy_fn) { - u32 lpddr4_ctl[] = {1, 0, 2}; + u32 lpddr4_ctl_fn[] = {1, 0, 2};
- return lpddr4_ctl[phy]; + return lpddr4_ctl_fn[phy_fn]; }
static u32 get_ddr_stride(struct rk3399_pmusgrf_regs *pmusgrf) @@ -1661,12 +1777,7 @@ static u32 get_ddr_stride(struct rk3399_pmusgrf_regs *pmusgrf) return ((readl(&pmusgrf->soc_con4) >> 10) & 0x1F); }
-static void set_ddr_stride(struct rk3399_pmusgrf_regs *pmusgrf, u32 stride) -{ - rk_clrsetreg(&pmusgrf->soc_con4, 0x1f << 10, stride << 10); -} - -/** +/* * read mr_num mode register * rank = 1: cs0 * rank = 2: cs1 @@ -1797,7 +1908,7 @@ end: }
static void set_lpddr4_dq_odt(const struct chan_info *chan, - struct rk3399_sdram_params *params, u32 ctl, + struct rk3399_sdram_params *params, u32 ctl_fn, bool en, bool ctl_phy_reg, u32 mr5) { u32 *denali_ctl = get_denali_ctl(chan, params, ctl_phy_reg); @@ -1805,14 +1916,13 @@ static void set_lpddr4_dq_odt(const struct chan_info *chan, struct io_setting *io; u32 reg_value;
- if (!en) - return; - io = lpddr4_get_io_settings(params, mr5); + if (en) + reg_value = io->dq_odt; + else + reg_value = 0;
- reg_value = io->dq_odt; - - switch (ctl) { + switch (ctl_fn) { case 0: clrsetbits_le32(&denali_ctl[139], 0x7 << 24, reg_value << 24); clrsetbits_le32(&denali_ctl[153], 0x7 << 24, reg_value << 24); @@ -1845,7 +1955,7 @@ static void set_lpddr4_dq_odt(const struct chan_info *chan, }
static void set_lpddr4_ca_odt(const struct chan_info *chan, - struct rk3399_sdram_params *params, u32 ctl, + struct rk3399_sdram_params *params, u32 ctl_fn, bool en, bool ctl_phy_reg, u32 mr5) { u32 *denali_ctl = get_denali_ctl(chan, params, ctl_phy_reg); @@ -1853,14 +1963,13 @@ static void set_lpddr4_ca_odt(const struct chan_info *chan, struct io_setting *io; u32 reg_value;
- if (!en) - return; - io = lpddr4_get_io_settings(params, mr5); + if (en) + reg_value = io->ca_odt; + else + reg_value = 0;
- reg_value = io->ca_odt; - - switch (ctl) { + switch (ctl_fn) { case 0: clrsetbits_le32(&denali_ctl[139], 0x7 << 28, reg_value << 28); clrsetbits_le32(&denali_ctl[153], 0x7 << 28, reg_value << 28); @@ -1893,7 +2002,7 @@ static void set_lpddr4_ca_odt(const struct chan_info *chan, }
static void set_lpddr4_MR3(const struct chan_info *chan, - struct rk3399_sdram_params *params, u32 ctl, + struct rk3399_sdram_params *params, u32 ctl_fn, bool ctl_phy_reg, u32 mr5) { u32 *denali_ctl = get_denali_ctl(chan, params, ctl_phy_reg); @@ -1905,7 +2014,7 @@ static void set_lpddr4_MR3(const struct chan_info *chan,
reg_value = ((io->pdds << 3) | 1);
- switch (ctl) { + switch (ctl_fn) { case 0: clrsetbits_le32(&denali_ctl[138], 0xFFFF, reg_value); clrsetbits_le32(&denali_ctl[152], 0xFFFF, reg_value); @@ -1940,7 +2049,7 @@ static void set_lpddr4_MR3(const struct chan_info *chan, }
static void set_lpddr4_MR12(const struct chan_info *chan, - struct rk3399_sdram_params *params, u32 ctl, + struct rk3399_sdram_params *params, u32 ctl_fn, bool ctl_phy_reg, u32 mr5) { u32 *denali_ctl = get_denali_ctl(chan, params, ctl_phy_reg); @@ -1952,7 +2061,7 @@ static void set_lpddr4_MR12(const struct chan_info *chan,
reg_value = io->ca_vref;
- switch (ctl) { + switch (ctl_fn) { case 0: clrsetbits_le32(&denali_ctl[140], 0xFFFF << 16, reg_value << 16); @@ -1989,7 +2098,7 @@ static void set_lpddr4_MR12(const struct chan_info *chan, }
static void set_lpddr4_MR14(const struct chan_info *chan, - struct rk3399_sdram_params *params, u32 ctl, + struct rk3399_sdram_params *params, u32 ctl_fn, bool ctl_phy_reg, u32 mr5) { u32 *denali_ctl = get_denali_ctl(chan, params, ctl_phy_reg); @@ -2001,7 +2110,7 @@ static void set_lpddr4_MR14(const struct chan_info *chan,
reg_value = io->dq_vref;
- switch (ctl) { + switch (ctl_fn) { case 0: clrsetbits_le32(&denali_ctl[142], 0xFFFF << 16, reg_value << 16); @@ -2037,22 +2146,73 @@ static void set_lpddr4_MR14(const struct chan_info *chan, } }
+void lpddr4_modify_param(const struct chan_info *chan, + struct rk3399_sdram_params *params) +{ + struct rk3399_sdram_params *params_cfg; + u32 *denali_ctl_params; + u32 *denali_pi_params; + u32 *denali_phy_params; + + denali_ctl_params = params->pctl_regs.denali_ctl; + denali_pi_params = params->pi_regs.denali_pi; + denali_phy_params = params->phy_regs.denali_phy; + + set_lpddr4_dq_odt(chan, params, 2, true, false, 0); + set_lpddr4_ca_odt(chan, params, 2, true, false, 0); + set_lpddr4_MR3(chan, params, 2, false, 0); + set_lpddr4_MR12(chan, params, 2, false, 0); + set_lpddr4_MR14(chan, params, 2, false, 0); + params_cfg = lpddr4_get_phy_index_params(0, params); + set_ds_odt(chan, params_cfg, false, 0); + /* read two cycle preamble */ + clrsetbits_le32(&denali_ctl_params[200], 0x3 << 24, 0x3 << 24); + clrsetbits_le32(&denali_phy_params[7], 0x3 << 24, 0x3 << 24); + clrsetbits_le32(&denali_phy_params[135], 0x3 << 24, 0x3 << 24); + clrsetbits_le32(&denali_phy_params[263], 0x3 << 24, 0x3 << 24); + clrsetbits_le32(&denali_phy_params[391], 0x3 << 24, 0x3 << 24); + + /* boot frequency two cycle preamble */ + clrsetbits_le32(&denali_phy_params[2], 0x3 << 16, 0x3 << 16); + clrsetbits_le32(&denali_phy_params[130], 0x3 << 16, 0x3 << 16); + clrsetbits_le32(&denali_phy_params[258], 0x3 << 16, 0x3 << 16); + clrsetbits_le32(&denali_phy_params[386], 0x3 << 16, 0x3 << 16); + + clrsetbits_le32(&denali_pi_params[45], 0x3 << 8, 0x3 << 8); + clrsetbits_le32(&denali_pi_params[58], 0x1, 0x1); + + /* + * bypass mode need PHY_SLICE_PWR_RDC_DISABLE_x = 1, + * boot frequency mode use bypass mode + */ + setbits_le32(&denali_phy_params[10], 1 << 16); + setbits_le32(&denali_phy_params[138], 1 << 16); + setbits_le32(&denali_phy_params[266], 1 << 16); + setbits_le32(&denali_phy_params[394], 1 << 16); + + clrsetbits_le32(&denali_pi_params[45], 0x1 << 24, 0x1 << 24); + clrsetbits_le32(&denali_pi_params[61], 0x1 << 24, 0x1 << 24); + clrsetbits_le32(&denali_pi_params[76], 0x1 << 24, 0x1 << 24); + clrsetbits_le32(&denali_pi_params[77], 0x1, 0x1); +} + static void lpddr4_copy_phy(struct dram_info *dram, - struct rk3399_sdram_params *params, u32 phy, - struct rk3399_sdram_params *timings, + struct rk3399_sdram_params *params, u32 phy_fn, + struct rk3399_sdram_params *params_cfg, u32 channel) { u32 *denali_ctl, *denali_phy; u32 *denali_phy_params; u32 speed = 0; - u32 ctl, mr5; + u32 ctl_fn, mr5;
denali_ctl = dram->chan[channel].pctl->denali_ctl; denali_phy = dram->chan[channel].publ->denali_phy; - denali_phy_params = timings->phy_regs.denali_phy; + denali_phy_params = params_cfg->phy_regs.denali_phy;
/* switch index */ - clrsetbits_le32(&denali_phy_params[896], 0x3 << 8, phy << 8); + clrsetbits_le32(&denali_phy_params[896], 0x3 << 8, + phy_fn << 8); writel(denali_phy_params[896], &denali_phy[896]);
/* phy_pll_ctrl_ca, phy_pll_ctrl */ @@ -2112,14 +2272,14 @@ static void lpddr4_copy_phy(struct dram_info *dram, * phy_clk_wrdqz_slave_delay_x * phy_clk_wrdqs_slave_delay_x */ - copy_to_reg((u32 *)&denali_phy[59], (u32 *)&denali_phy_params[59], - (63 - 58) * 4); - copy_to_reg((u32 *)&denali_phy[187], (u32 *)&denali_phy_params[187], - (191 - 186) * 4); - copy_to_reg((u32 *)&denali_phy[315], (u32 *)&denali_phy_params[315], - (319 - 314) * 4); - copy_to_reg((u32 *)&denali_phy[443], (u32 *)&denali_phy_params[443], - (447 - 442) * 4); + sdram_copy_to_reg((u32 *)&denali_phy[59], + (u32 *)&denali_phy_params[59], (63 - 58) * 4); + sdram_copy_to_reg((u32 *)&denali_phy[187], + (u32 *)&denali_phy_params[187], (191 - 186) * 4); + sdram_copy_to_reg((u32 *)&denali_phy[315], + (u32 *)&denali_phy_params[315], (319 - 314) * 4); + sdram_copy_to_reg((u32 *)&denali_phy[443], + (u32 *)&denali_phy_params[443], (447 - 442) * 4);
/* * phy_dqs_tsel_wr_timing_x 8bits denali_phy_84/212/340/468 offset_8 @@ -2218,31 +2378,30 @@ static void lpddr4_copy_phy(struct dram_info *dram, * phy_wrlvl_delay_period_threshold_x * phy_wrlvl_early_force_zero_x */ - copy_to_reg((u32 *)&denali_phy[64], (u32 *)&denali_phy_params[64], - (67 - 63) * 4); + sdram_copy_to_reg((u32 *)&denali_phy[64], + (u32 *)&denali_phy_params[64], (67 - 63) * 4); clrsetbits_le32(&denali_phy[68], 0xfffffc00, denali_phy_params[68] & 0xfffffc00); - copy_to_reg((u32 *)&denali_phy[69], (u32 *)&denali_phy_params[69], - (79 - 68) * 4); - copy_to_reg((u32 *)&denali_phy[192], (u32 *)&denali_phy_params[192], - (195 - 191) * 4); + sdram_copy_to_reg((u32 *)&denali_phy[69], + (u32 *)&denali_phy_params[69], (79 - 68) * 4); + sdram_copy_to_reg((u32 *)&denali_phy[192], + (u32 *)&denali_phy_params[192], (195 - 191) * 4); clrsetbits_le32(&denali_phy[196], 0xfffffc00, denali_phy_params[196] & 0xfffffc00); - copy_to_reg((u32 *)&denali_phy[197], (u32 *)&denali_phy_params[197], - (207 - 196) * 4); - copy_to_reg((u32 *)&denali_phy[320], (u32 *)&denali_phy_params[320], - (323 - 319) * 4); + sdram_copy_to_reg((u32 *)&denali_phy[197], + (u32 *)&denali_phy_params[197], (207 - 196) * 4); + sdram_copy_to_reg((u32 *)&denali_phy[320], + (u32 *)&denali_phy_params[320], (323 - 319) * 4); clrsetbits_le32(&denali_phy[324], 0xfffffc00, denali_phy_params[324] & 0xfffffc00); - copy_to_reg((u32 *)&denali_phy[325], (u32 *)&denali_phy_params[325], - (335 - 324) * 4); - - copy_to_reg((u32 *)&denali_phy[448], (u32 *)&denali_phy_params[448], - (451 - 447) * 4); + sdram_copy_to_reg((u32 *)&denali_phy[325], + (u32 *)&denali_phy_params[325], (335 - 324) * 4); + sdram_copy_to_reg((u32 *)&denali_phy[448], + (u32 *)&denali_phy_params[448], (451 - 447) * 4); clrsetbits_le32(&denali_phy[452], 0xfffffc00, denali_phy_params[452] & 0xfffffc00); - copy_to_reg((u32 *)&denali_phy[453], (u32 *)&denali_phy_params[453], - (463 - 452) * 4); + sdram_copy_to_reg((u32 *)&denali_phy[453], + (u32 *)&denali_phy_params[453], (463 - 452) * 4);
/* phy_two_cyc_preamble_x */ clrsetbits_le32(&denali_phy[7], 0x3 << 24, @@ -2255,11 +2414,11 @@ static void lpddr4_copy_phy(struct dram_info *dram, denali_phy_params[391] & (0x3 << 24));
/* speed */ - if (timings->base.ddr_freq < 400 * MHz) + if (params_cfg->base.ddr_freq < 400) speed = 0x0; - else if (timings->base.ddr_freq < 800 * MHz) + else if (params_cfg->base.ddr_freq < 800) speed = 0x1; - else if (timings->base.ddr_freq < 1200 * MHz) + else if (params_cfg->base.ddr_freq < 1200) speed = 0x2;
/* phy_924 phy_pad_fdbk_drive */ @@ -2279,52 +2438,75 @@ static void lpddr4_copy_phy(struct dram_info *dram, /* phy_939 phy_pad_cs_drive */ clrsetbits_le32(&denali_phy[939], 0x3 << 17, speed << 17);
- read_mr(dram->chan[channel].pctl, 1, 5, &mr5); - set_ds_odt(&dram->chan[channel], timings, true, mr5); + if (params_cfg->base.dramtype == LPDDR4) { + read_mr(dram->chan[channel].pctl, 1, 5, &mr5); + set_ds_odt(&dram->chan[channel], params_cfg, true, mr5); + set_ds_odt(&dram->chan[channel], params_cfg, true, mr5); + + ctl_fn = lpddr4_get_ctl_fn(params_cfg, phy_fn); + set_lpddr4_dq_odt(&dram->chan[channel], params_cfg, + ctl_fn, true, true, mr5); + set_lpddr4_ca_odt(&dram->chan[channel], params_cfg, + ctl_fn, true, true, mr5); + set_lpddr4_MR3(&dram->chan[channel], params_cfg, + ctl_fn, true, mr5); + set_lpddr4_MR12(&dram->chan[channel], params_cfg, + ctl_fn, true, mr5); + set_lpddr4_MR14(&dram->chan[channel], params_cfg, + ctl_fn, true, mr5); + + set_lpddr4_dq_odt(&dram->chan[channel], params_cfg, + ctl_fn, true, true, mr5); + set_lpddr4_ca_odt(&dram->chan[channel], params_cfg, + ctl_fn, true, true, mr5); + set_lpddr4_MR3(&dram->chan[channel], params_cfg, + ctl_fn, true, mr5); + set_lpddr4_MR12(&dram->chan[channel], params_cfg, + ctl_fn, true, mr5); + set_lpddr4_MR14(&dram->chan[channel], params_cfg, + ctl_fn, true, mr5);
- ctl = lpddr4_get_ctl(timings, phy); - set_lpddr4_dq_odt(&dram->chan[channel], timings, ctl, true, true, mr5); - set_lpddr4_ca_odt(&dram->chan[channel], timings, ctl, true, true, mr5); - set_lpddr4_MR3(&dram->chan[channel], timings, ctl, true, mr5); - set_lpddr4_MR12(&dram->chan[channel], timings, ctl, true, mr5); - set_lpddr4_MR14(&dram->chan[channel], timings, ctl, true, mr5); - - /* - * if phy_sw_master_mode_x not bypass mode, - * clear phy_slice_pwr_rdc_disable. - * note: need use timings, not ddr_publ_regs - */ - if (!((denali_phy_params[86] >> 8) & (1 << 2))) { - clrbits_le32(&denali_phy[10], 1 << 16); - clrbits_le32(&denali_phy[138], 1 << 16); - clrbits_le32(&denali_phy[266], 1 << 16); - clrbits_le32(&denali_phy[394], 1 << 16); - } + /* + * if phy_sw_master_mode_x not bypass mode, + * clear phy_slice_pwr_rdc_disable. + * note: need use timings, not ddr_publ_regs + */ + if (!((denali_phy_params[86] >> 8) & (1 << 2))) { + clrbits_le32(&denali_phy[10], 1 << 16); + clrbits_le32(&denali_phy[138], 1 << 16); + clrbits_le32(&denali_phy[266], 1 << 16); + clrbits_le32(&denali_phy[394], 1 << 16); + }
- /* - * when PHY_PER_CS_TRAINING_EN=1, W2W_DIFFCS_DLY_Fx can't - * smaller than 8 - * NOTE: need use timings, not ddr_publ_regs - */ - if ((denali_phy_params[84] >> 16) & 1) { - if (((readl(&denali_ctl[217 + ctl]) >> 16) & 0x1f) < 8) - clrsetbits_le32(&denali_ctl[217 + ctl], - 0x1f << 16, 8 << 16); + /* + * when PHY_PER_CS_TRAINING_EN=1, W2W_DIFFCS_DLY_Fx can't + * smaller than 8 + * NOTE: need use timings, not ddr_publ_regs + */ + if ((denali_phy_params[84] >> 16) & 1) { + if (((readl(&denali_ctl[217 + ctl_fn]) >> + 16) & 0x1f) < 8) + clrsetbits_le32(&denali_ctl[217 + ctl_fn], + 0x1f << 16, + 8 << 16); + } } }
static void lpddr4_set_phy(struct dram_info *dram, - struct rk3399_sdram_params *params, u32 phy, - struct rk3399_sdram_params *timings) + struct rk3399_sdram_params *params, u32 phy_fn, + struct rk3399_sdram_params *params_cfg) { u32 channel;
for (channel = 0; channel < 2; channel++) - lpddr4_copy_phy(dram, params, phy, timings, channel); + lpddr4_copy_phy(dram, params, phy_fn, params_cfg, + channel); }
static int lpddr4_set_ctl(struct dram_info *dram, - struct rk3399_sdram_params *params, u32 ctl, u32 hz) + struct rk3399_sdram_params *params, + u32 fn, u32 hz) { u32 channel; int ret_clk, ret; @@ -2343,7 +2525,7 @@ static int lpddr4_set_ctl(struct dram_info *dram,
/* change freq */ writel((((0x3 << 4) | (1 << 2) | 1) << 16) | - (ctl << 4) | (1 << 2) | 1, &dram->cic->cic_ctrl0); + (fn << 4) | (1 << 2) | 1, &dram->cic->cic_ctrl0); while (!(readl(&dram->cic->cic_status0) & (1 << 2))) ;
@@ -2366,12 +2548,12 @@ static int lpddr4_set_ctl(struct dram_info *dram, clrbits_le32(&dram->pmu->pmu_noc_auto_ena, (0x3 << 7));
/* lpddr4 ctl2 can not do training, all training will fail */ - if (!(params->base.dramtype == LPDDR4 && ctl == 2)) { + if (!(params->base.dramtype == LPDDR4 && fn == 2)) { for (channel = 0; channel < 2; channel++) { if (!(params->ch[channel].cap_info.col)) continue; ret = data_training(dram, channel, params, - PI_FULL_TRAINING); + PI_FULL_TRAINING); if (ret) printf("%s: channel %d training failed!\n", __func__, channel); @@ -2387,24 +2569,221 @@ static int lpddr4_set_ctl(struct dram_info *dram, static int lpddr4_set_rate(struct dram_info *dram, struct rk3399_sdram_params *params) { - u32 ctl; - u32 phy; + u32 ctl_fn; + u32 phy_fn;
- for (ctl = 0; ctl < 2; ctl++) { - phy = lpddr4_get_phy(params, ctl); + for (ctl_fn = 0; ctl_fn < 2; ctl_fn++) { + phy_fn = lpddr4_get_phy_fn(params, ctl_fn);
- lpddr4_set_phy(dram, params, phy, &lpddr4_timings[ctl]); - lpddr4_set_ctl(dram, params, ctl, - lpddr4_timings[ctl].base.ddr_freq); + lpddr4_set_phy(dram, params, phy_fn, &dfs_cfgs_lpddr4[ctl_fn]); + lpddr4_set_ctl(dram, params, ctl_fn, + dfs_cfgs_lpddr4[ctl_fn].base.ddr_freq);
- debug("%s: change freq to %d mhz %d, %d\n", __func__, - lpddr4_timings[ctl].base.ddr_freq / MHz, ctl, phy); + printf("%s: change freq to %d mhz %d, %d\n", __func__, + dfs_cfgs_lpddr4[ctl_fn].base.ddr_freq, ctl_fn, phy_fn); }
return 0; } #endif /* CONFIG_RAM_RK3399_LPDDR4 */
+/* CS0,n=1 + * CS1,n=2 + * CS0 & CS1, n=3 + * cs0_cap: MB unit + */ +static void dram_set_cs(const struct chan_info *chan, u32 cs_map, u32 cs0_cap, + unsigned char dramtype) +{ + u32 *denali_ctl = chan->pctl->denali_ctl; + u32 *denali_pi = chan->pi->denali_pi; + struct msch_regs *ddr_msch_regs = chan->msch; + + clrsetbits_le32(&denali_ctl[196], 0x3, cs_map); + writel((cs0_cap / 32) | (((4096 - cs0_cap) / 32) << 8), + &ddr_msch_regs->ddrsize); + if (dramtype == LPDDR4) { + if (cs_map == 1) + cs_map = 0x5; + else if (cs_map == 2) + cs_map = 0xa; + else + cs_map = 0xF; + } + /*PI_41 PI_CS_MAP:RW:24:4*/ + clrsetbits_le32(&denali_pi[41], + 0xf << 24, cs_map << 24); + if (cs_map == 1 && dramtype == DDR3) + writel(0x2EC7FFFF, &denali_pi[34]); +} + +static void dram_set_bw(const struct chan_info *chan, u32 bw) +{ + u32 *denali_ctl = chan->pctl->denali_ctl; + + if (bw == 2) + clrbits_le32(&denali_ctl[196], 1 << 16); + else + setbits_le32(&denali_ctl[196], 1 << 16); +} + +static void dram_set_max_col(const struct chan_info *chan, u32 bw, u32 *pcol) +{ + u32 *denali_ctl = chan->pctl->denali_ctl; + struct msch_regs *ddr_msch_regs = chan->msch; + u32 *denali_pi = chan->pi->denali_pi; + u32 ddrconfig; + + clrbits_le32(&denali_ctl[191], 0xf); + clrsetbits_le32(&denali_ctl[190], + (7 << 24), + ((16 - ((bw == 2) ? 14 : 15)) << 24)); + /*PI_199 PI_COL_DIFF:RW:0:4*/ + clrbits_le32(&denali_pi[199], 0xf); + /*PI_155 PI_ROW_DIFF:RW:24:3*/ + clrsetbits_le32(&denali_pi[155], + (7 << 24), + ((16 - 12) << 24)); + ddrconfig = (bw == 2) ? 3 : 2; + writel(ddrconfig | (ddrconfig << 8), &ddr_msch_regs->ddrconf); + /* set max cs0 size */ + writel((4096 / 32) | ((0 / 32) << 8), + &ddr_msch_regs->ddrsize); + + *pcol = 12; +} + +static void dram_set_max_bank(const struct chan_info *chan, u32 bw, u32 *pbank, + u32 *pcol) +{ + u32 *denali_ctl = chan->pctl->denali_ctl; + u32 *denali_pi = chan->pi->denali_pi; + + clrbits_le32(&denali_ctl[191], 0xf); + clrbits_le32(&denali_ctl[190], (3 << 16)); + /*PI_199 PI_COL_DIFF:RW:0:4*/ + clrbits_le32(&denali_pi[199], 0xf); + /*PI_155 PI_BANK_DIFF:RW:16:2*/ + clrbits_le32(&denali_pi[155], (3 << 16)); + + *pbank = 3; + *pcol = 12; +} + +static void dram_set_max_row(const struct chan_info *chan, u32 bw, u32 *prow, + u32 *pbank, u32 *pcol) +{ + u32 *denali_ctl = chan->pctl->denali_ctl; + u32 *denali_pi = chan->pi->denali_pi; + struct msch_regs *ddr_msch_regs = chan->msch; + + clrsetbits_le32(&denali_ctl[191], 0xf, 12 - 10); + clrbits_le32(&denali_ctl[190], + (0x3 << 16) | (0x7 << 24)); + /*PI_199 PI_COL_DIFF:RW:0:4*/ + clrsetbits_le32(&denali_pi[199], 0xf, 12 - 10); + /*PI_155 PI_ROW_DIFF:RW:24:3 PI_BANK_DIFF:RW:16:2*/ + clrbits_le32(&denali_pi[155], + (0x3 << 16) | (0x7 << 24)); + writel(1 | (1 << 8), &ddr_msch_regs->ddrconf); + /* set max cs0 size */ + writel((4096 / 32) | ((0 / 32) << 8), + &ddr_msch_regs->ddrsize); + + *prow = 16; + *pbank = 3; + *pcol = (bw == 2) ? 10 : 11; +} + +static u64 dram_detect_cap(struct dram_info *dram, + struct rk3399_sdram_params *params, + unsigned char channel) +{ + const struct chan_info *chan = &dram->chan[channel]; + struct sdram_cap_info *cap_info = ¶ms->ch[channel].cap_info; + u32 bw; + u32 col_tmp; + u32 bk_tmp; + u32 row_tmp; + u32 cs0_cap; + u32 training_flag; + u32 ddrconfig; + + /* detect bw */ + bw = 2; + if (params->base.dramtype != LPDDR4) { + dram_set_bw(chan, bw); + cap_info->bw = bw; + if (data_training(dram, channel, params, + PI_READ_GATE_TRAINING)) { + bw = 1; + dram_set_bw(chan, 1); + cap_info->bw = bw; + if (data_training(dram, channel, params, + PI_READ_GATE_TRAINING)) { + printf("16bit error!!!\n"); + goto error; + } + } + } + /* + * LPDDR3 CA training msut be trigger before other training. + * DDR3 is not have CA training. + */ + if (params->base.dramtype == LPDDR3) + training_flag = PI_WRITE_LEVELING; + else + training_flag = PI_FULL_TRAINING; + + if (params->base.dramtype != LPDDR4) { + if (data_training(dram, channel, params, training_flag)) { + printf("full training error!!!\n"); + goto error; + } + } + + /* detect col */ + dram_set_max_col(chan, bw, &col_tmp); + if (sdram_detect_col(cap_info, col_tmp) != 0) + goto error; + + /* detect bank */ + dram_set_max_bank(chan, bw, &bk_tmp, &col_tmp); + sdram_detect_bank(cap_info, col_tmp, bk_tmp); + + /* detect row */ + dram_set_max_row(chan, bw, &row_tmp, &bk_tmp, &col_tmp); + if (sdram_detect_row(cap_info, col_tmp, bk_tmp, row_tmp) != 0) + goto error; + + /* detect row_3_4 */ + sdram_detect_row_3_4(cap_info, col_tmp, bk_tmp); + + /* set ddrconfig */ + cs0_cap = (1 << (cap_info->cs0_row + cap_info->col + cap_info->bk + + cap_info->bw - 20)); + if (cap_info->row_3_4) + cs0_cap = cs0_cap * 3 / 4; + + cap_info->cs1_row = cap_info->cs0_row; + set_memory_map(chan, channel, params); + ddrconfig = calculate_ddrconfig(params, channel); + if (-1 == ddrconfig) + goto error; + set_ddrconfig(chan, params, channel, + cap_info->ddrconfig); + + /* detect cs1 row */ + sdram_detect_cs1_row(cap_info, params->base.dramtype); + + /* detect die bw */ + sdram_detect_dbw(cap_info, params->base.dramtype); + + return 0; +error: + return (-1); +} + static unsigned char calculate_stride(struct rk3399_sdram_params *params) { unsigned int stride = params->base.stride; @@ -2491,39 +2870,13 @@ static void clear_channel_params(struct rk3399_sdram_params *params, u8 channel) params->ch[channel].cap_info.ddrconfig = 0; }
-static int pctl_init(struct dram_info *dram, struct rk3399_sdram_params *params) -{ - int channel; - int ret; - - for (channel = 0; channel < 2; channel++) { - const struct chan_info *chan = &dram->chan[channel]; - struct rk3399_cru *cru = dram->cru; - struct rk3399_ddr_publ_regs *publ = chan->publ; - - phy_pctrl_reset(cru, channel); - phy_dll_bypass_set(publ, params->base.ddr_freq); - - ret = pctl_cfg(dram, chan, channel, params); - if (ret < 0) { - printf("%s: pctl config failed\n", __func__); - return ret; - } - - /* start to trigger initialization */ - pctl_start(dram, channel); - } - - return 0; -} - static int sdram_init(struct dram_info *dram, struct rk3399_sdram_params *params) { unsigned char dramtype = params->base.dramtype; unsigned int ddr_freq = params->base.ddr_freq; int channel, ch, rank; - int ret; + u32 tmp, ret;
@@ -2534,22 +2887,35 @@ static int sdram_init(struct dram_info *dram, return -E2BIG; }
+ /* detect rank */ for (ch = 0; ch < 2; ch++) { params->ch[ch].cap_info.rank = 2; for (rank = 2; rank != 0; rank--) { - ret = pctl_init(dram, params); - if (ret < 0) { - printf("%s: pctl init failed\n", __func__); - return ret; + for (channel = 0; channel < 2; channel++) { + const struct chan_info *chan = + &dram->chan[channel]; + struct rk3399_cru *cru = dram->cru; + struct rk3399_ddr_publ_regs *publ = chan->publ; + + phy_pctrl_reset(cru, channel); + phy_dll_bypass_set(publ, ddr_freq); + pctl_cfg(dram, chan, channel, params); }
+ /* start to trigger initialization */ + pctl_start(dram, params, 3); + /* LPDDR2/LPDDR3 need to wait DAI complete, max 10us */ if (dramtype == LPDDR3) udelay(10);
+ tmp = (rank == 2) ? 3 : 1; + dram_set_cs(&dram->chan[ch], tmp, 2048, + params->base.dramtype); params->ch[ch].cap_info.rank = rank;
- ret = dram->ops->data_training(dram, ch, rank, params); + ret = dram->ops->data_training_first(dram, ch, + rank, params); if (!ret) { debug("%s: data trained for rank %d, ch %d\n", __func__, rank, ch); @@ -2563,38 +2929,37 @@ static int sdram_init(struct dram_info *dram, params->base.num_channels = 0; for (channel = 0; channel < 2; channel++) { const struct chan_info *chan = &dram->chan[channel]; - struct sdram_cap_info *cap_info = ¶ms->ch[channel].cap_info; - u8 training_flag = PI_FULL_TRAINING; + struct sdram_cap_info *cap_info = + ¶ms->ch[channel].cap_info;
if (cap_info->rank == 0) { - clear_channel_params(params, channel); + clear_channel_params(params, 1); continue; } else { params->base.num_channels++; }
- debug("Channel "); - debug(channel ? "1: " : "0: "); + printf("Channel "); + printf(channel ? "1: " : "0: ");
- /* LPDDR3 should have write and read gate training */ - if (params->base.dramtype == LPDDR3) - training_flag = PI_WRITE_LEVELING | - PI_READ_GATE_TRAINING; + if (channel == 0) + set_ddr_stride(dram->pmusgrf, 0x17); + else + set_ddr_stride(dram->pmusgrf, 0x18);
- if (params->base.dramtype != LPDDR4) { - ret = data_training(dram, channel, params, - training_flag); - if (!ret) { - debug("%s: data train failed for channel %d\n", - __func__, ret); - continue; - } + if (dram_detect_cap(dram, params, channel)) { + printf("Cap error!\n"); + continue; }
sdram_print_ddr_info(cap_info, ¶ms->base); set_memory_map(chan, channel, params); - cap_info->ddrconfig = calculate_ddrconfig(params, channel); - + cap_info->ddrconfig = + calculate_ddrconfig(params, channel); + if (-1 == cap_info->ddrconfig) { + printf("no ddrconfig find, Cap not support!\n"); + continue; + } set_ddrconfig(chan, params, channel, cap_info->ddrconfig); set_cap_relate_config(chan, params, channel); } @@ -2608,7 +2973,8 @@ static int sdram_init(struct dram_info *dram,
params->base.stride = calculate_stride(params); dram_all_config(dram, params); - dram->ops->set_rate(dram, params); + + dram->ops->set_rate_index(dram, params);
debug("Finish SDRAM initialization...\n"); return 0; @@ -2655,11 +3021,15 @@ static int conv_of_platdata(struct udevice *dev)
static const struct sdram_rk3399_ops rk3399_ops = { #if !defined(CONFIG_RAM_RK3399_LPDDR4) - .data_training = default_data_training, - .set_rate = switch_to_phy_index1, + .data_training_first = data_training_first, + .set_rate_index = switch_to_phy_index1, + .modify_param = modify_param, + .get_phy_index_params = get_phy_index_params, #else - .data_training = lpddr4_mr_detect, - .set_rate = lpddr4_set_rate, + .data_training_first = lpddr4_mr_detect, + .set_rate_index = lpddr4_set_rate, + .modify_param = lpddr4_modify_param, + .get_phy_index_params = lpddr4_get_phy_index_params, #endif };
Update lpddr timing in lpddr4-400 and lpddr4-800 file from rockchip vendor code;
Changes in v2: None
drivers/ram/rockchip/sdram-rk3399-lpddr4-400.inc | 12 ++++++------ drivers/ram/rockchip/sdram-rk3399-lpddr4-800.inc | 6 +++--- 2 files changed, 9 insertions(+), 9 deletions(-)
diff --git a/drivers/ram/rockchip/sdram-rk3399-lpddr4-400.inc b/drivers/ram/rockchip/sdram-rk3399-lpddr4-400.inc index 6ddc01c49d..209ef57228 100644 --- a/drivers/ram/rockchip/sdram-rk3399-lpddr4-400.inc +++ b/drivers/ram/rockchip/sdram-rk3399-lpddr4-400.inc @@ -22,16 +22,16 @@ }, { .ddrtiminga0 = { - 0x80241d22, + 0x8010100d, }, .ddrtimingb0 = { - 0x15050f08, + 0x08020b04, }, .ddrtimingc0 = { 0x00000602, }, .devtodev0 = { - 0x00002122, + 0x00002562, }, .ddrmode = { 0x0000004c, @@ -55,16 +55,16 @@ }, { .ddrtiminga0 = { - 0x80241d22, + 0x8010100d, }, .ddrtimingb0 = { - 0x15050f08, + 0x08020b04, }, .ddrtimingc0 = { 0x00000602, }, .devtodev0 = { - 0x00002122, + 0x00002562, }, .ddrmode = { 0x0000004c, diff --git a/drivers/ram/rockchip/sdram-rk3399-lpddr4-800.inc b/drivers/ram/rockchip/sdram-rk3399-lpddr4-800.inc index 307f6ee458..7d11b4c563 100644 --- a/drivers/ram/rockchip/sdram-rk3399-lpddr4-800.inc +++ b/drivers/ram/rockchip/sdram-rk3399-lpddr4-800.inc @@ -22,16 +22,16 @@ }, { .ddrtiminga0 = { - 0x80241d22, + 0x801c1819, }, .ddrtimingb0 = { - 0x15050f08, + 0x10040c05, }, .ddrtimingc0 = { 0x00000602, }, .devtodev0 = { - 0x00002122, + 0x00002672, }, .ddrmode = { 0x0000004c,
The io setting are updated after some bugfix in different rk3399 boards, sync the code from vendor.
Changes in v2: None
drivers/ram/rockchip/sdram_rk3399.c | 44 +++++++++-------------------- 1 file changed, 14 insertions(+), 30 deletions(-)
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index 073fba0990..43b72fc658 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -149,38 +149,21 @@ struct io_setting { 32, /* rd_vref; (unit %, range 3.3% - 48.7%) */ }, { - 800 * MHz, + 933 * MHz, 0, /* dram side */ 1, /* dq_odt; */ 0, /* ca_odt; */ - 1, /* pdds; */ + 3, /* pdds; */ 0x72, /* dq_vref; */ 0x72, /* ca_vref; */ /* phy side */ - PHY_DRV_ODT_40, /* rd_odt; */ - PHY_DRV_ODT_48, /* wr_dq_drv; */ + PHY_DRV_ODT_80, /* rd_odt; */ + PHY_DRV_ODT_40, /* wr_dq_drv; */ PHY_DRV_ODT_40, /* wr_ca_drv; */ PHY_DRV_ODT_40, /* wr_ckcs_drv; */ 1, /* rd_odt_en; */ - 17, /* rd_vref; (unit %, range 3.3% - 48.7%) */ - }, - { - 933 * MHz, - 0, - /* dram side */ - 3, /* dq_odt; */ - 0, /* ca_odt; */ - 6, /* pdds; */ - 0x59, /* dq_vref; 32% */ - 0x72, /* ca_vref; */ - /* phy side */ - PHY_DRV_ODT_HI_Z, /* rd_odt; */ - PHY_DRV_ODT_48, /* wr_dq_drv; */ - PHY_DRV_ODT_40, /* wr_ca_drv; */ - PHY_DRV_ODT_40, /* wr_ckcs_drv; */ - 0, /* rd_odt_en; */ - 32, /* rd_vref; (unit %, range 3.3% - 48.7%) */ + 20, /* rd_vref; (unit %, range 3.3% - 48.7%) */ }, { 1066 * MHz, @@ -188,16 +171,16 @@ struct io_setting { /* dram side */ 6, /* dq_odt; */ 0, /* ca_odt; */ - 1, /* pdds; */ + 3, /* pdds; */ 0x10, /* dq_vref; */ 0x72, /* ca_vref; */ /* phy side */ - PHY_DRV_ODT_40, /* rd_odt; */ + PHY_DRV_ODT_80, /* rd_odt; */ PHY_DRV_ODT_60, /* wr_dq_drv; */ PHY_DRV_ODT_40, /* wr_ca_drv; */ PHY_DRV_ODT_40, /* wr_ckcs_drv; */ 1, /* rd_odt_en; */ - 17, /* rd_vref; (unit %, range 3.3% - 48.7%) */ + 20, /* rd_vref; (unit %, range 3.3% - 48.7%) */ }, };
@@ -599,16 +582,17 @@ static void set_ds_odt(const struct chan_info *chan, tsel_rd_select_n = io->rd_odt;
tsel_idle_select_p = PHY_DRV_ODT_HI_Z; - tsel_idle_select_n = PHY_DRV_ODT_240; + tsel_idle_select_n = PHY_DRV_ODT_HI_Z;
tsel_wr_select_dq_p = io->wr_dq_drv; - tsel_wr_select_dq_n = PHY_DRV_ODT_40; + tsel_wr_select_dq_n = PHY_DRV_ODT_34_3;
tsel_wr_select_ca_p = io->wr_ca_drv; - tsel_wr_select_ca_n = PHY_DRV_ODT_40; + tsel_wr_select_ca_n = PHY_DRV_ODT_34_3;
tsel_ckcs_select_p = io->wr_ckcs_drv; tsel_ckcs_select_n = PHY_DRV_ODT_34_3; + switch (tsel_rd_select_n) { case PHY_DRV_ODT_240: soc_odt = 1; @@ -648,8 +632,8 @@ static void set_ds_odt(const struct chan_info *chan, tsel_wr_select_dq_p = PHY_DRV_ODT_34_3; tsel_wr_select_dq_n = PHY_DRV_ODT_34_3;
- tsel_wr_select_ca_p = PHY_DRV_ODT_48; - tsel_wr_select_ca_n = PHY_DRV_ODT_48; + tsel_wr_select_ca_p = PHY_DRV_ODT_34_3; + tsel_wr_select_ca_n = PHY_DRV_ODT_34_3;
tsel_ckcs_select_p = PHY_DRV_ODT_34_3; tsel_ckcs_select_n = PHY_DRV_ODT_34_3;
Update the calculation of the stride to support all the DRAM case.
Signed-off-by: YouMin Chen cym@rock-chips.com Signed-off-by: Kever Yang kever.yang@rock-chips.com ---
Changes in v2: None
drivers/ram/rockchip/sdram_rk3399.c | 158 +++++++++++++++++++++------- 1 file changed, 119 insertions(+), 39 deletions(-)
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index 43b72fc658..9e6194f34a 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -2770,15 +2770,20 @@ error:
static unsigned char calculate_stride(struct rk3399_sdram_params *params) { - unsigned int stride = params->base.stride; - unsigned int channel, chinfo = 0; + unsigned int gstride_type; + unsigned int channel; + unsigned int chinfo = 0; + unsigned int cap = 0; + unsigned int stride = -1; unsigned int ch_cap[2] = {0, 0}; - u64 cap; + + gstride_type = STRIDE_256B;
for (channel = 0; channel < 2; channel++) { unsigned int cs0_cap = 0; unsigned int cs1_cap = 0; - struct sdram_cap_info *cap_info = ¶ms->ch[channel].cap_info; + struct sdram_cap_info *cap_info = + ¶ms->ch[channel].cap_info;
if (cap_info->col == 0) continue; @@ -2796,49 +2801,124 @@ static unsigned char calculate_stride(struct rk3399_sdram_params *params) chinfo |= 1 << channel; }
- /* stride calculation for 1 channel */ - if (params->base.num_channels == 1 && chinfo & 1) - return 0x17; /* channel a */ - - /* stride calculation for 2 channels, default gstride type is 256B */ - if (ch_cap[0] == ch_cap[1]) { - cap = ch_cap[0] + ch_cap[1]; - switch (cap) { - /* 512MB */ - case 512: - stride = 0; - break; - /* 1GB */ - case 1024: - stride = 0x5; - break; + cap = ch_cap[0] + ch_cap[1]; + if (params->base.num_channels == 1) { + if (chinfo & 1) /* channel a only */ + stride = 0x17; + else /* channel b only */ + stride = 0x18; + } else {/* 2 channel */ + if (ch_cap[0] == ch_cap[1]) { + /* interleaved */ + if (gstride_type == PART_STRIDE) { + /* + * first 64MB no interleaved other 256B interleaved + * if 786M+768M.useful space from 0-1280MB and + * 1536MB-1792MB + * if 1.5G+1.5G(continuous).useful space from 0-2560MB + * and 3072MB-3584MB + */ + stride = 0x1F; + } else { + switch (cap) { + /* 512MB */ + case 512: + stride = 0; + break; + /* 1GB unstride or 256B stride*/ + case 1024: + stride = (gstride_type == UN_STRIDE) ? + 0x1 : 0x5; + break; + /* + * 768MB + 768MB same as total 2GB memory + * useful space: 0-768MB 1GB-1792MB + */ + case 1536: + /* 2GB unstride or 256B or 512B stride */ + case 2048: + stride = (gstride_type == UN_STRIDE) ? + 0x2 : + ((gstride_type == STRIDE_512B) ? + 0xA : 0x9); + break; + /* 1536MB + 1536MB */ + case 3072: + stride = (gstride_type == UN_STRIDE) ? + 0x3 : + ((gstride_type == STRIDE_512B) ? + 0x12 : 0x11); + break; + /* 4GB unstride or 128B,256B,512B,4KB stride */ + case 4096: + stride = (gstride_type == UN_STRIDE) ? + 0x3 : (0xC + gstride_type); + break; + } + } + } + if (ch_cap[0] == 2048 && ch_cap[1] == 1024) { + /* 2GB + 1GB */ + stride = (gstride_type == UN_STRIDE) ? 0x3 : 0x19; + } /* - * 768MB + 768MB same as total 2GB memory - * useful space: 0-768MB 1GB-1792MB + * remain two channel capability not equal OR capability + * power function of 2 */ - case 1536: - /* 2GB */ - case 2048: - stride = 0x9; - break; - /* 1536MB + 1536MB */ - case 3072: - stride = 0x11; - break; - /* 4GB */ - case 4096: - stride = 0xD; - break; - default: - printf("%s: Unable to calculate stride for ", __func__); - print_size((cap * (1 << 20)), " capacity\n"); - break; + if (stride == (-1)) { + switch ((ch_cap[0] > ch_cap[1]) ? + ch_cap[0] : ch_cap[1]) { + case 256: /* 256MB + 128MB */ + stride = 0; + break; + case 512: /* 512MB + 256MB */ + stride = 1; + break; + case 1024:/* 1GB + 128MB/256MB/384MB/512MB/768MB */ + stride = 2; + break; + case 2048: /* 2GB + 128MB/256MB/384MB/512MB/768MB/1GB */ + stride = 3; + break; + default: + break; + } } + if (stride == (-1)) + goto error; + } + switch (stride) { + case 0xc: + printf("128B stride\n"); + break; + case 5: + case 9: + case 0xd: + case 0x11: + case 0x19: + printf("256B stride\n"); + break; + case 0xa: + case 0xe: + case 0x12: + printf("512B stride\n"); + break; + case 0xf: + printf("4K stride\n"); + break; + case 0x1f: + printf("32MB + 256B stride\n"); + break; + default: + printf("no stride\n"); }
sdram_print_stride(stride);
return stride; +error: + printf("Cap not support!\n"); + return (-1); }
There are some code different with rockchip vendor code which may lead to different bugs, including: 1) Fix setting error about LPDDR3 dram size ODT. 2) Set phy io speed to 0x2. 3) Fix setting error about phy_pad_fdbk_drive. 4) Fix setting error about PI_WDQLVL_VREF_EN
Changes in v2: - Split the patches into multi smaller patches for easy to maintain, review and test; - Keep the DRAM_ROCKCHIP_DEBUG macro and enable it by default; - Update the rockchip_sdram_size to support sys_reg3;
drivers/ram/rockchip/sdram_rk3399.c | 41 ++++++++++++++--------------- 1 file changed, 20 insertions(+), 21 deletions(-)
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index 9e6194f34a..09ab13826a 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -44,6 +44,11 @@ #define CS0_MR22_VAL 0 #define CS1_MR22_VAL 3
+/* LPDDR3 DRAM DS */ +#define LPDDR3_DS_34 0x1 +#define LPDDR3_DS_40 0x2 +#define LPDDR3_DS_48 0x3 + #define CRU_SFTRST_DDR_CTRL(ch, n) ((0x1 << (8 + 16 + (ch) * 4)) | \ ((n) << (8 + (ch) * 4))) #define CRU_SFTRST_DDR_PHY(ch, n) ((0x1 << (9 + 16 + (ch) * 4)) | \ @@ -291,7 +296,8 @@ static void set_memory_map(const struct chan_info *chan, u32 channel, if (sdram_ch->cap_info.ddrconfig < 2 || sdram_ch->cap_info.ddrconfig == 4) row = 16; - else if (sdram_ch->cap_info.ddrconfig == 3) + else if (sdram_ch->cap_info.ddrconfig == 3 || + sdram_ch->cap_info.ddrconfig == 5) row = 14; else row = 15; @@ -335,11 +341,12 @@ static int phy_io_config(const struct chan_info *chan, const struct rk3399_sdram_params *params, u32 mr5) { u32 *denali_phy = chan->publ->denali_phy; + u32 *denali_ctl = chan->pctl->denali_ctl; u32 vref_mode_dq, vref_value_dq, vref_mode_ac, vref_value_ac; u32 mode_sel; - u32 reg_value; - u32 drv_value, odt_value; u32 speed; + u32 reg_value; + u32 ds_value, odt_value;
/* vref setting & mode setting */ if (params->base.dramtype == LPDDR4) { @@ -365,12 +372,12 @@ static int phy_io_config(const struct chan_info *chan, } else if (params->base.dramtype == LPDDR3) { if (params->base.odt == 1) { vref_mode_dq = 0x5; /* LPDDR3 ODT */ - drv_value = (readl(&denali_phy[6]) >> 12) & 0xf; + ds_value = readl(&denali_ctl[138]) & 0xf; odt_value = (readl(&denali_phy[6]) >> 4) & 0xf; - if (drv_value == PHY_DRV_ODT_48) { + if (ds_value == LPDDR3_DS_48) { switch (odt_value) { case PHY_DRV_ODT_240: - vref_value_dq = 0x16; + vref_value_dq = 0x1B; break; case PHY_DRV_ODT_120: vref_value_dq = 0x26; @@ -382,7 +389,7 @@ static int phy_io_config(const struct chan_info *chan, debug("Invalid ODT value.\n"); return -EINVAL; } - } else if (drv_value == PHY_DRV_ODT_40) { + } else if (ds_value == LPDDR3_DS_40) { switch (odt_value) { case PHY_DRV_ODT_240: vref_value_dq = 0x19; @@ -397,7 +404,7 @@ static int phy_io_config(const struct chan_info *chan, debug("Invalid ODT value.\n"); return -EINVAL; } - } else if (drv_value == PHY_DRV_ODT_34_3) { + } else if (ds_value == LPDDR3_DS_34) { switch (odt_value) { case PHY_DRV_ODT_240: vref_value_dq = 0x17; @@ -509,14 +516,7 @@ static int phy_io_config(const struct chan_info *chan, }
/* speed setting */ - if (params->base.ddr_freq < 400) - speed = 0x0; - else if (params->base.ddr_freq < 800) - speed = 0x1; - else if (params->base.ddr_freq < 1200) - speed = 0x2; - else - speed = 0x3; + speed = 0x2;
/* PHY_924 PHY_PAD_FDBK_DRIVE */ clrsetbits_le32(&denali_phy[924], 0x3 << 21, speed << 21); @@ -739,9 +739,9 @@ static void set_ds_odt(const struct chan_info *chan,
/* phy_pad_fdbk_drive 23bit DENALI_PHY_924/925 */ clrsetbits_le32(&denali_phy[924], 0xff, - tsel_wr_select_dq_n | (tsel_wr_select_dq_p << 4)); + tsel_wr_select_ca_n | (tsel_wr_select_ca_p << 4)); clrsetbits_le32(&denali_phy[925], 0xff, - tsel_rd_select_n | (tsel_rd_select_p << 4)); + tsel_wr_select_dq_n | (tsel_wr_select_dq_p << 4));
/* phy_dq_tsel_enable_X 3bits DENALI_PHY_5/133/261/389 offset_16 */ reg_value = (tsel_rd_en | (tsel_wr_en << 1) | (tsel_idle_en << 2)) @@ -1340,10 +1340,9 @@ static int data_training_wdql(const struct chan_info *chan, u32 channel,
/* * disable PI_WDQLVL_VREF_EN before wdq leveling? - * PI_181 PI_WDQLVL_VREF_EN:RW:8:1 + * PI_117 PI_WDQLVL_VREF_EN:RW:8:1 */ - clrbits_le32(&denali_pi[181], 0x1 << 8); - + clrbits_le32(&denali_pi[117], 0x1 << 8); /* PI_124 PI_WDQLVL_EN:RW:16:2 */ clrsetbits_le32(&denali_pi[124], 0x3 << 16, 0x2 << 16);
Kever Yang
