[U-Boot] [PATCH] spl: Correct call to spl_common_init() with SPL_STACK_R_MALLOC_SIMPLE_LEN
Calls to IS_ENABLED() on a non-y/n option will always be false, even when set. We can correct this by adding a new bool value that is set based on the conditions required for SPL_STACK_R_MALLOC_SIMPLE_LEN to be set instead.
Fixes: 340f418acd11 ("spl: Add spl_early_init()") Reported-by: Lokesh Vutla lokeshvutla@ti.com Signed-off-by: Tom Rini trini@konsulko.com --- common/spl/spl.c | 5 +++-- 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/common/spl/spl.c b/common/spl/spl.c index d98b9fcb9ade..91180d4b476b 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -227,10 +227,11 @@ int spl_early_init(void) int spl_init(void) { int ret; + bool setup_malloc = !(IS_ENABLED(CONFIG_SPL_STACK_R) && + IS_ENABLED(SPL_SYS_MALLOC_SIMPLE));
if (!(gd->flags & GD_FLG_SPL_EARLY_INIT)) { - ret = spl_common_init( - !IS_ENABLED(CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN)); + ret = spl_common_init(setup_malloc); if (ret) return ret; }
- bool setup_malloc = !(IS_ENABLED(CONFIG_SPL_STACK_R) &&
This should be CONFIG_SPL_SYS_MALLOC_SIMPLE. With this change it works fine.
Thanks and regards, Lokesh
Fixes: 340f418acd11 ("spl: Add spl_early_init()") Reported-by: Lokesh Vutla lokeshvutla@ti.com Signed-off-by: Tom Rini trini@konsulko.com --- Changes in v2: - Fix thinko pointed out by Lokesh --- common/spl/spl.c | 5 +++-- 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/common/spl/spl.c b/common/spl/spl.c index d98b9fcb9ade..0d1e08245f6a 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -227,10 +227,11 @@ int spl_early_init(void) int spl_init(void) { int ret; + bool setup_malloc = !(IS_ENABLED(CONFIG_SPL_STACK_R) && + IS_ENABLED(CONFIG_SPL_SYS_MALLOC_SIMPLE));
Lokesh Vutla
