[PATCH] treewide: Remove the unnecessary space before semicolon
%s/return ;/return;
Signed-off-by: Bin Meng bmeng@tinylab.org ---
arch/powerpc/cpu/mpc85xx/cpu_init.c | 2 +- arch/powerpc/cpu/mpc85xx/cpu_init_early.c | 2 +- arch/powerpc/cpu/mpc85xx/fdt.c | 6 +++--- arch/powerpc/cpu/mpc85xx/liodn.c | 4 ++-- arch/powerpc/cpu/mpc85xx/mpc8548_serdes.c | 2 +- arch/powerpc/cpu/mpc85xx/portals.c | 8 ++++---- arch/powerpc/cpu/mpc85xx/tlb.c | 2 +- arch/powerpc/cpu/mpc8xxx/fdt.c | 2 +- arch/powerpc/cpu/mpc8xxx/law.c | 2 +- arch/powerpc/lib/bootm.c | 4 ++-- board/ti/evm/evm.c | 2 +- drivers/ddr/fsl/util.c | 2 +- drivers/net/fm/init.c | 4 ++-- 13 files changed, 21 insertions(+), 21 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/cpu_init.c b/arch/powerpc/cpu/mpc85xx/cpu_init.c index 92a7e608ce..90f024d0a7 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu_init.c +++ b/arch/powerpc/cpu/mpc85xx/cpu_init.c @@ -446,7 +446,7 @@ ulong cpu_init_f(void) /* Implement a dummy function for those platforms w/o SERDES */ static void __fsl_serdes__init(void) { - return ; + return; } __attribute__((weak, alias("__fsl_serdes__init"))) void fsl_serdes_init(void);
diff --git a/arch/powerpc/cpu/mpc85xx/cpu_init_early.c b/arch/powerpc/cpu/mpc85xx/cpu_init_early.c index 1bba216371..e6347cfd2d 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu_init_early.c +++ b/arch/powerpc/cpu/mpc85xx/cpu_init_early.c @@ -76,7 +76,7 @@ void setup_ifc(void) ifc_out32(&(ifc_regs.gregs->csor_cs[0].csor), CONFIG_SYS_CSOR0); ifc_out32(&(ifc_regs.gregs->amask_cs[0].amask), CONFIG_SYS_AMASK0);
- return ; + return; } #endif
diff --git a/arch/powerpc/cpu/mpc85xx/fdt.c b/arch/powerpc/cpu/mpc85xx/fdt.c index c8ad6a1b01..61d8aa7f4c 100644 --- a/arch/powerpc/cpu/mpc85xx/fdt.c +++ b/arch/powerpc/cpu/mpc85xx/fdt.c @@ -271,13 +271,13 @@ static inline void ft_fixup_l2cache(void *blob)
if (ph == NULL) { debug("no next-level-cache property\n"); - return ; + return; }
off = fdt_node_offset_by_phandle(blob, *ph); if (off < 0) { printf("%s: %s\n", __func__, fdt_strerror(off)); - return ; + return; }
ft_fixup_l2cache_compatible(blob, off); @@ -373,7 +373,7 @@ next: l3_off = fdt_node_offset_by_phandle(blob, l3_off); if (l3_off < 0) { printf("%s: %s\n", __func__, fdt_strerror(off)); - return ; + return; } ft_fixup_l3cache(blob, l3_off); } diff --git a/arch/powerpc/cpu/mpc85xx/liodn.c b/arch/powerpc/cpu/mpc85xx/liodn.c index a084002494..34974c92bd 100644 --- a/arch/powerpc/cpu/mpc85xx/liodn.c +++ b/arch/powerpc/cpu/mpc85xx/liodn.c @@ -111,7 +111,7 @@ static void setup_fman_liodn_base(enum fsl_dpaa_dev dev, #endif default: printf("Error: Invalid device type to %s\n", __FUNCTION__); - return ; + return; }
base = (liodn_bases[dev].id[0] << 16) | liodn_bases[dev].id[0]; @@ -232,7 +232,7 @@ static void fdt_fixup_srio_liodn(void *blob, struct srio_liodn_id_table *tbl) /* search for srio node, if doesn't exist just return - nothing todo */ srio_off = fdt_node_offset_by_compatible(blob, -1, "fsl,srio"); if (srio_off < 0) - return ; + return;
for (i = 0; i < srio_liodn_tbl_sz; i++) { int off, portid = tbl[i].portid; diff --git a/arch/powerpc/cpu/mpc85xx/mpc8548_serdes.c b/arch/powerpc/cpu/mpc85xx/mpc8548_serdes.c index 2a5c3e3200..38f30afdfc 100644 --- a/arch/powerpc/cpu/mpc85xx/mpc8548_serdes.c +++ b/arch/powerpc/cpu/mpc85xx/mpc8548_serdes.c @@ -45,7 +45,7 @@ void fsl_serdes_init(void)
if (srds1_cfg >= ARRAY_SIZE(serdes1_cfg_tbl)) { printf("Invalid PORDEVSR[IO_SEL] = %d\n", srds1_cfg); - return ; + return; }
for (lane = 0; lane < SRDS1_MAX_LANES; lane++) { diff --git a/arch/powerpc/cpu/mpc85xx/portals.c b/arch/powerpc/cpu/mpc85xx/portals.c index 52e2124fb9..6b4cbddcdf 100644 --- a/arch/powerpc/cpu/mpc85xx/portals.c +++ b/arch/powerpc/cpu/mpc85xx/portals.c @@ -21,7 +21,7 @@ void fdt_portal(void *blob, const char *compat, const char *container,
off = fdt_node_offset_by_compatible(blob, -1, compat); if (off < 0) - return ; + return;
off = fdt_parent_offset(blob, off); /* if non-zero assume we have a container */ @@ -35,7 +35,7 @@ void fdt_portal(void *blob, const char *compat, const char *container, range = fdt_getprop_w(blob, off, "ranges", &len); if (range == NULL) { printf("ERROR: container for %s has no ranges", compat); - return ; + return; }
range[0] = 0; @@ -61,13 +61,13 @@ void fdt_portal(void *blob, const char *compat, const char *container, if (container && (memcmp(container, name, len))) { printf("WARNING: container names didn't match %s %s\n", container, name); - return ; + return; }
memcpy(&buf, name, len); len += sprintf(&buf[len], "@%llx", addr); fdt_set_name(blob, off, buf); - return ; + return; }
printf("ERROR: %s isn't in a container. Not supported\n", compat); diff --git a/arch/powerpc/cpu/mpc85xx/tlb.c b/arch/powerpc/cpu/mpc85xx/tlb.c index e39fe14382..81e60722f9 100644 --- a/arch/powerpc/cpu/mpc85xx/tlb.c +++ b/arch/powerpc/cpu/mpc85xx/tlb.c @@ -41,7 +41,7 @@ __weak void init_tlbs(void) tlb_table[i].mas7); }
#if !defined(CONFIG_NAND_SPL) && \ diff --git a/arch/powerpc/cpu/mpc8xxx/fdt.c b/arch/powerpc/cpu/mpc8xxx/fdt.c index 871554a7f4..3004290248 100644 --- a/arch/powerpc/cpu/mpc8xxx/fdt.c +++ b/arch/powerpc/cpu/mpc8xxx/fdt.c @@ -128,7 +128,7 @@ void ft_srio_setup(void *blob) /* search for srio node, if doesn't exist just return - nothing todo */ srio_off = fdt_node_offset_by_compatible(blob, -1, "fsl,srio"); if (srio_off < 0) - return ; + return;
#ifdef CONFIG_SRIO1 if (is_serdes_configured(SRIO1)) diff --git a/arch/powerpc/cpu/mpc8xxx/law.c b/arch/powerpc/cpu/mpc8xxx/law.c index 198b5b10a5..24bbe3b45f 100644 --- a/arch/powerpc/cpu/mpc8xxx/law.c +++ b/arch/powerpc/cpu/mpc8xxx/law.c @@ -353,5 +353,5 @@ void init_laws(void) } #endif
- return ; + return; } diff --git a/arch/powerpc/lib/bootm.c b/arch/powerpc/lib/bootm.c index 512787854c..8ae8d8a3e7 100644 --- a/arch/powerpc/lib/bootm.c +++ b/arch/powerpc/lib/bootm.c @@ -113,7 +113,7 @@ static void boot_jump_linux(struct bootm_headers *images) cmd_start, cmd_end, 0, 0); /* does not return */ } - return ; + return; }
void arch_lmb_reserve(struct lmb *lmb) @@ -148,7 +148,7 @@ void arch_lmb_reserve(struct lmb *lmb) cpu_mp_lmb_reserve(lmb); #endif
static void boot_prep_linux(struct bootm_headers *images) diff --git a/board/ti/evm/evm.c b/board/ti/evm/evm.c index 39b5c706a9..a7f9a7eca1 100644 --- a/board/ti/evm/evm.c +++ b/board/ti/evm/evm.c @@ -234,7 +234,7 @@ static void reset_net_chip(void) ret = gpio_request(rst_gpio, ""); if (ret < 0) { printf("Unable to get GPIO %d\n", rst_gpio); - return ; + return; }
/* Configure as output */ diff --git a/drivers/ddr/fsl/util.c b/drivers/ddr/fsl/util.c index 43cb01804b..589d7df731 100644 --- a/drivers/ddr/fsl/util.c +++ b/drivers/ddr/fsl/util.c @@ -147,7 +147,7 @@ __fsl_ddr_set_lawbar(const common_timing_params_t *memctl_common_params, if (set_ddr_laws(base, size, law_memctl) < 0) { printf("%s: ERROR (ctrl #%d, TRGT ID=%x)\n", __func__, ctrl_num, law_memctl); - return ; + return; } debug("setup ddr law base = 0x%llx, size 0x%llx, TRGT_ID 0x%x\n", base, size, law_memctl); diff --git a/drivers/net/fm/init.c b/drivers/net/fm/init.c index af94dabe29..43d2000d24 100644 --- a/drivers/net/fm/init.c +++ b/drivers/net/fm/init.c @@ -149,7 +149,7 @@ void fman_enet_init(void) } }
void fm_disable_port(enum fm_port port) @@ -233,7 +233,7 @@ static void __def_board_ft_fman_fixup_port(void *blob, char * prop, phys_addr_t pa, enum fm_port port, int offset) { - return ; + return; }
void board_ft_fman_fixup_port(void *blob, char * prop, phys_addr_t pa,
On 26.10.22 06:40, Bin Meng wrote:
%s/return ;/return;
Nice.
Reviewed by: Stefan Roese sr@denx.de
Thanks, Stefan
- return ;
- return; } __attribute__((weak, alias("__fsl_serdes__init"))) void fsl_serdes_init(void);
- return ;
- return; } #endif
return ;
return;
return ;
return;
return ;
} ft_fixup_l3cache(blob, l3_off); }return;
return ;
return;
return ;
return;
return ;
return;
return ;
return;
return ;
return;
range[0] = 0;
return ;
return;
return ;
return;
- return ;
return; }
return ;
return;
- return ;
- return; }
- return ;
return; }
- return ;
return; }
return ;
return;
return ;
} debug("setup ddr law base = 0x%llx, size 0x%llx, TRGT_ID 0x%x\n", base, size, law_memctl);return;
- return ;
return; }
- return ;
return; }
Viele Grüße, Stefan Roese
On Wed, Oct 26, 2022 at 12:40:07PM +0800, Bin Meng wrote:
%s/return ;/return;
Bin Meng
Stefan Roese
