[U-Boot-Users] [PATCH] PPC4xx: Add AMCC/IBM DDR2 SDRAM ECC Field Mnemonics
Add additional DDR2 SDRAM memory controller DCR mneomnics, condition revision ID DCR based on 405EX, and add field mnemonics for bus error status and ECC error status registers.
Signed-off-by: Grant Erickson gerickson@nuovations.com --- include/asm-ppc/ppc4xx-sdram.h | 52 ++++++++++++++++++++++++++++++++++++++++ 1 files changed, 52 insertions(+), 0 deletions(-)
diff --git a/include/asm-ppc/ppc4xx-sdram.h b/include/asm-ppc/ppc4xx-sdram.h index b528497..97c9c51 100644 --- a/include/asm-ppc/ppc4xx-sdram.h +++ b/include/asm-ppc/ppc4xx-sdram.h @@ -353,6 +353,14 @@ /* * Memory controller registers */ +#define SDRAM_BESR 0x00 /* PLB bus error status (read/clear) */ +#define SDRAM_BESRT 0x01 /* PLB bus error status (test/set) */ +#define SDRAM_BEARL 0x02 /* PLB bus error address low */ +#define SDRAM_BEARH 0x03 /* PLB bus error address high */ +#define SDRAM_WMIRQ 0x06 /* PLB write master interrupt (read/clear) */ +#define SDRAM_WMIRQT 0x07 /* PLB write master interrupt (test/set) */ +#define SDRAM_PLBOPT 0x08 /* PLB slave options */ +#define SDRAM_PUABA 0x09 /* PLB upper address base */ #ifndef CONFIG_405EX #define SDRAM_MCSTAT 0x14 /* memory controller status */ #else @@ -402,9 +410,35 @@ #define SDRAM_MMODE 0x88 /* memory mode */ #define SDRAM_MEMODE 0x89 /* memory extended mode */ #define SDRAM_ECCCR 0x98 /* ECC error status */ +#define SDRAM_ECCES SDRAM_ECCCR #define SDRAM_CID 0xA4 /* core ID */ +#ifndef CONFIG_405EX #define SDRAM_RID 0xA8 /* revision ID */ +#endif +#define SDRAM_FCSR 0xB0 /* feedback calibration status */ #define SDRAM_RTSR 0xB1 /* run time status tracking */ +#ifdef CONFIG_405EX +#define SDRAM_RID 0xF8 /* revision ID */ +#endif + +/* + * Memory Controller Bus Error Status + */ +#define SDRAM_BESR_MASK PPC_REG_VAL(7, 0xFF) +#define SDRAM_BESR_M0ID_MASK PPC_REG_VAL(3, 0xF) +#define SDRAM_BESR_M0ID_ICU PPC_REG_VAL(3, 0x0) +#define SDRAM_BESR_M0ID_PCIE0 PPC_REG_VAL(3, 0x1) +#define SDRAM_BESR_M0ID_PCIE1 PPC_REG_VAL(3, 0x2) +#define SDRAM_BESR_M0ID_DMA PPC_REG_VAL(3, 0x3) +#define SDRAM_BESR_M0ID_DCU PPC_REG_VAL(3, 0x4) +#define SDRAM_BESR_M0ID_OPB PPC_REG_VAL(3, 0x5) +#define SDRAM_BESR_M0ID_MAL PPC_REG_VAL(3, 0x6) +#define SDRAM_BESR_M0ID_SEC PPC_REG_VAL(3, 0x7) +#define SDRAM_BESR_M0ET_MASK PPC_REG_VAL(6, 0x7) +#define SDRAM_BESR_M0ET_NONE PPC_REG_VAL(6, 0x0) +#define SDRAM_BESR_M0ET_ECC PPC_REG_VAL(6, 0x1) +#define SDRAM_BESR_M0RW_WRITE PPC_REG_VAL(7, 0) +#define SDRAM_BESR_M0RW_READ PPC_REG_VAL(8, 1)
/* * Memory Controller Status @@ -863,6 +897,24 @@ #define SDRAM_SDTR3_RFC_ENCODE(n) ((((u32)(n))&0x3F)<<0)
/* + * ECC Error Status + */ +#define SDRAM_ECCES_MASK PPC_REG_VAL(21, 0x3FFFFF) +#define SDRAM_ECCES_BNCE_MASK PPC_REG_VAL(15, 0xFFFF) +#define SDRAM_ECCES_BNCE_ENCODE(lane) PPC_REG_VAL(((lane) & 0xF), 1) +#define SDRAM_ECCES_CKBER_MASK PPC_REG_VAL(17, 0x3) +#define SDRAM_ECCES_CKBER_NONE PPC_REG_VAL(17, 0) +#define SDRAM_ECCES_CKBER_16_ECC_0_3 PPC_REG_VAL(17, 2) +#define SDRAM_ECCES_CKBER_32_ECC_0_3 PPC_REG_VAL(17, 1) +#define SDRAM_ECCES_CKBER_32_ECC_4_8 PPC_REG_VAL(17, 2) +#define SDRAM_ECCES_CKBER_32_ECC_0_8 PPC_REG_VAL(17, 3) +#define SDRAM_ECCES_CE PPC_REG_VAL(18, 1) +#define SDRAM_ECCES_UE PPC_REG_VAL(19, 1) +#define SDRAM_ECCES_BKNER_MASK PPC_REG_VAL(21, 0x3) +#define SDRAM_ECCES_BK0ER PPC_REG_VAL(20, 1) +#define SDRAM_ECCES_BK1ER PPC_REG_VAL(21, 1) + +/* * Memory Bank 0-1 configuration */ #define SDRAM_BXCF_M_AM_MASK 0x00000F00 /* Addressing mode */
Applied to "next" branch in u-boot-ppc4xx repository. Thanks.
Best regards, Stefan
Grant Erickson
Stefan Roese
