[PATCH] ARM: stm32mp: Fix dram_bank_mmu_setup() for LMB located above ram_top
Previously, all LMB marked with LMB_NOMAP (above and below ram_top) are considered as invalid entry in TLB.
Since commit 1a48b0be93d4 ("lmb: prohibit allocations above ram_top even from same bank") all LMB located above ram_top are now marked LMB_NOOVERWRITE and no more LMB_MAP.
This area above ram_top is reserved for OPTEE and must not be cacheable, otherwise this leads to a Panic on some boards (Issue on STM32MP135F-DK).
Restore previous behavior by marking invalid entry all TLB above ram_top.
Fixes: 1a48b0be93d4 ("lmb: prohibit allocations above ram_top even from same bank")
Signed-off-by: Patrice Chotard patrice.chotard@foss.st.com cc: Sughosh Ganu sughosh.ganu@linaro.org ---
arch/arm/mach-stm32mp/stm32mp1/cpu.c | 7 ++++++- 1 file changed, 6 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-stm32mp/stm32mp1/cpu.c b/arch/arm/mach-stm32mp/stm32mp1/cpu.c index 62cc98910a7..cb1b84c9af9 100644 --- a/arch/arm/mach-stm32mp/stm32mp1/cpu.c +++ b/arch/arm/mach-stm32mp/stm32mp1/cpu.c @@ -53,6 +53,7 @@ void dram_bank_mmu_setup(int bank) struct bd_info *bd = gd->bd; int i; phys_addr_t start; + phys_addr_t addr; phys_size_t size; bool use_lmb = false; enum dcache_option option; @@ -77,8 +78,12 @@ void dram_bank_mmu_setup(int bank) for (i = start >> MMU_SECTION_SHIFT; i < (start >> MMU_SECTION_SHIFT) + (size >> MMU_SECTION_SHIFT); i++) { + addr = i << MMU_SECTION_SHIFT; option = DCACHE_DEFAULT_OPTION; - if (use_lmb && lmb_is_reserved_flags(i << MMU_SECTION_SHIFT, LMB_NOMAP)) + if (use_lmb && + (lmb_is_reserved_flags(i << MMU_SECTION_SHIFT, LMB_NOMAP) || + addr >= gd->ram_top) + ) option = 0; /* INVALID ENTRY in TLB */ set_section_dcache(i, option); }
On Fri, 13 Dec 2024 at 18:59, Patrice Chotard patrice.chotard@foss.st.com wrote:
Acked-by: Sughosh Ganu sughosh.ganu@linaro.org
-sughosh
if (use_lmb &&
-- 2.25.1
And apologies for applying this directly, I wanted to make sure the regression fix got in ASAP.
No Problem , i understand ;-) I expected to send a pull request today or tomorrow including this patch.
Patrice
minor: OP-TEE
- phys_addr_t addr; phys_size_t size; bool use_lmb = false; enum dcache_option option;
option = DCACHE_DEFAULT_OPTION;addr = i << MMU_SECTION_SHIFT;
if (use_lmb &&
set_section_dcache(i, option); }) option = 0; /* INVALID ENTRY in TLB */
Reviewed-by: Patrick Delaunay patrick.delaunay@foss.st.com
Thanks Patrick
participants (5)
Patrice CHOTARD
Patrice Chotard
Patrick DELAUNAY
Sughosh Ganu
