[U-Boot] [PATCH] spl: exynos: make spl_boot common for all exynos based platforms
The spl_boot.c which copies the u-boot from the booting device to ram is made common for all the exynos based platforms. To do so:
1. Moved smdk5250/spl_boot.c to common armv7/exynos folder and updated to make it common for exynos4 and exynos5 2. Introduced a CONFIG_SPL_BOOTING option as only exynos5250 supports booting from SPI device 3. Renamed some config options to make them common between exynos5250, origen and smdkv310.
SD/MMC booting: tested on exynos4210 based origen, exynos5250 based Arndale and SMDK5250 boards. SPI booting: tested on SMDK5250 board
Signed-off-by: Inderpal Singh inderpal.singh@linaro.org --- It depends on the patchset at [1] as it provides the infrastructure to detect the SOC type and revision in spl at runtime.
[1] http://www.mail-archive.com/u-boot@lists.denx.de/msg108301.html
arch/arm/cpu/armv7/exynos/Makefile | 4 ++ .../arm/cpu/armv7/exynos}/spl_boot.c | 33 +++++++---- board/samsung/origen/Makefile | 4 -- board/samsung/origen/mmc_boot.c | 58 ------------------- board/samsung/smdk5250/Makefile | 4 -- board/samsung/smdkv310/Makefile | 4 -- board/samsung/smdkv310/mmc_boot.c | 60 -------------------- include/configs/exynos5250-dt.h | 10 ++-- include/configs/origen.h | 21 +++---- include/configs/smdkv310.h | 21 +++---- 10 files changed, 54 insertions(+), 165 deletions(-) rename {board/samsung/smdk5250 => arch/arm/cpu/armv7/exynos}/spl_boot.c (73%) delete mode 100644 board/samsung/origen/mmc_boot.c delete mode 100644 board/samsung/smdkv310/mmc_boot.c
diff --git a/arch/arm/cpu/armv7/exynos/Makefile b/arch/arm/cpu/armv7/exynos/Makefile index b9cf921..c507608 100644 --- a/arch/arm/cpu/armv7/exynos/Makefile +++ b/arch/arm/cpu/armv7/exynos/Makefile @@ -24,6 +24,10 @@ LIB = $(obj)lib$(SOC).o
COBJS += clock.o power.o soc.o system.o pinmux.o tzpc_init.o
+ifdef CONFIG_SPL_BUILD +COBJS += spl_boot.o +endif + SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS))
diff --git a/board/samsung/smdk5250/spl_boot.c b/arch/arm/cpu/armv7/exynos/spl_boot.c similarity index 73% rename from board/samsung/smdk5250/spl_boot.c rename to arch/arm/cpu/armv7/exynos/spl_boot.c index d8f3c1e..e970ff6 100644 --- a/board/samsung/smdk5250/spl_boot.c +++ b/arch/arm/cpu/armv7/exynos/spl_boot.c @@ -23,6 +23,8 @@ #include<common.h> #include<config.h>
+#define OM_STAT (0x1f << 1) + enum boot_mode { BOOT_MODE_MMC = 4, BOOT_MODE_SERIAL = 20, @@ -31,8 +33,6 @@ enum boot_mode { BOOT_MODE_USB, /* Boot using USB download */ };
- typedef u32 (*spi_copy_func_t)(u32 offset, u32 nblock, u32 dst); - /* * Copy U-boot from mmc to RAM: * COPY_BL2_FNPTR_ADDR: Address in iRAM, which Contains @@ -40,26 +40,37 @@ enum boot_mode { */ void copy_uboot_to_ram(void) { - spi_copy_func_t spi_copy; enum boot_mode bootmode; - u32 (*copy_bl2)(u32, u32, u32); + u32 (*copy_bl2)(u32, u32, u32) = NULL; + u32 offset = 0, size = 0;
- bootmode = readl(EXYNOS5_POWER_BASE) & OM_STAT; + bootmode = readl(samsung_get_base_power()) & OM_STAT;
switch (bootmode) { +#ifdef CONFIG_SPI_BOOTING case BOOT_MODE_SERIAL: - spi_copy = *(spi_copy_func_t *)EXYNOS_COPY_SPI_FNPTR_ADDR; - spi_copy(SPI_FLASH_UBOOT_POS, CONFIG_BL2_SIZE, - CONFIG_SYS_TEXT_BASE); + offset = CONFIG_BL2_OFFSET - CONFIG_RES_BLOCK_SIZE; + size = CONFIG_BL2_SIZE; + copy_bl2 = (void *) *(u32 *)EXYNOS_COPY_SPI_FNPTR_ADDR; break; +#endif case BOOT_MODE_MMC: - copy_bl2 = (void *) *(u32 *)COPY_BL2_FNPTR_ADDR; - copy_bl2(BL2_START_OFFSET, BL2_SIZE_BLOC_COUNT, - CONFIG_SYS_TEXT_BASE); + offset = CONFIG_BL2_BLOCK_OFFSET; + size = CONFIG_BL2_SIZE_BLOCK_COUNT; + + /* Only SMDKv310 EVT0 directly jumps to BootROM copy function */ + if (s5p_get_cpu_rev()) + copy_bl2 = (void *) *(u32 *)COPY_BL2_FNPTR_ADDR; + else + copy_bl2 = (void *) COPY_BL2_FNPTR_ADDR; + break; default: break; } + + if (copy_bl2) + copy_bl2(offset, size, CONFIG_SYS_TEXT_BASE); }
void board_init_f(unsigned long bootflag) diff --git a/board/samsung/origen/Makefile b/board/samsung/origen/Makefile index 3a885a5..6133b26 100644 --- a/board/samsung/origen/Makefile +++ b/board/samsung/origen/Makefile @@ -31,10 +31,6 @@ ifndef CONFIG_SPL_BUILD COBJS += origen.o endif
-ifdef CONFIG_SPL_BUILD -COBJS += mmc_boot.o -endif - SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS))
diff --git a/board/samsung/origen/mmc_boot.c b/board/samsung/origen/mmc_boot.c deleted file mode 100644 index 072f161..0000000 --- a/board/samsung/origen/mmc_boot.c +++ /dev/null @@ -1,58 +0,0 @@ -/* - * Copyright (C) 2011 Samsung Electronics - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include<common.h> -#include<config.h> - -/* -* Copy U-boot from mmc to RAM: -* COPY_BL2_FNPTR_ADDR: Address in iRAM, which Contains -* Pointer to API (Data transfer from mmc to ram) -*/ -void copy_uboot_to_ram(void) -{ - u32 (*copy_bl2)(u32, u32, u32) = (void *) *(u32 *)COPY_BL2_FNPTR_ADDR; - - copy_bl2(BL2_START_OFFSET, BL2_SIZE_BLOC_COUNT, CONFIG_SYS_TEXT_BASE); -} - -void board_init_f(unsigned long bootflag) -{ - __attribute__((noreturn)) void (*uboot)(void); - copy_uboot_to_ram(); - - /* Jump to U-Boot image */ - uboot = (void *)CONFIG_SYS_TEXT_BASE; - (*uboot)(); - /* Never returns Here */ -} - -/* Place Holders */ -void board_init_r(gd_t *id, ulong dest_addr) -{ - /* Function attribute is no-return */ - /* This Function never executes */ - while (1) - ; -} - -void save_boot_params(u32 r0, u32 r1, u32 r2, u32 r3) {} diff --git a/board/samsung/smdk5250/Makefile b/board/samsung/smdk5250/Makefile index f2c32ee..075b1a7 100644 --- a/board/samsung/smdk5250/Makefile +++ b/board/samsung/smdk5250/Makefile @@ -38,10 +38,6 @@ COBJS += smdk5250.o endif endif
-ifdef CONFIG_SPL_BUILD -COBJS += spl_boot.o -endif - SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS))
diff --git a/board/samsung/smdkv310/Makefile b/board/samsung/smdkv310/Makefile index 56e0c16..e79045d 100644 --- a/board/samsung/smdkv310/Makefile +++ b/board/samsung/smdkv310/Makefile @@ -30,10 +30,6 @@ ifndef CONFIG_SPL_BUILD COBJS += smdkv310.o endif
diff --git a/board/samsung/smdkv310/mmc_boot.c b/board/samsung/smdkv310/mmc_boot.c deleted file mode 100644 index d3fc18d..0000000 --- a/board/samsung/smdkv310/mmc_boot.c +++ /dev/null @@ -1,60 +0,0 @@ -/* - * Copyright (C) 2011 Samsung Electronics - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include<common.h> -#include<config.h> - -/* -* Copy U-boot from mmc to RAM: -* COPY_BL2_FNPTR_ADDR: Address in iRAM, which Contains -* API (Data transfer from mmc to ram) -*/ -void copy_uboot_to_ram(void) -{ - u32 (*copy_bl2)(u32, u32, u32) = (void *)COPY_BL2_FNPTR_ADDR; - - copy_bl2(BL2_START_OFFSET, BL2_SIZE_BLOC_COUNT, CONFIG_SYS_TEXT_BASE); -} - -void board_init_f(unsigned long bootflag) -{ - __attribute__((noreturn)) void (*uboot)(void); - copy_uboot_to_ram(); - - /* Jump to U-Boot image */ - uboot = (void *)CONFIG_SYS_TEXT_BASE; - (*uboot)(); - /* Never returns Here */ -} - -/* Place Holders */ -void board_init_r(gd_t *id, ulong dest_addr) -{ - /*Function attribute is no-return*/ - /*This Function never executes*/ - while (1) - ; -} - -void save_boot_params(u32 r0, u32 r1, u32 r2, u32 r3) -{ -} diff --git a/include/configs/exynos5250-dt.h b/include/configs/exynos5250-dt.h index 16d3ab1..7308522 100644 --- a/include/configs/exynos5250-dt.h +++ b/include/configs/exynos5250-dt.h @@ -206,12 +206,14 @@ #define CONFIG_ENV_OFFSET (CONFIG_BL2_OFFSET + CONFIG_BL2_SIZE)
/* U-boot copy size from boot Media to DRAM.*/ -#define BL2_START_OFFSET (CONFIG_BL2_OFFSET/512) -#define BL2_SIZE_BLOC_COUNT (CONFIG_BL2_SIZE/512) +#define CONFIG_BL2_BLOCK_OFFSET (CONFIG_BL2_OFFSET/512) +#define CONFIG_BL2_SIZE_BLOCK_COUNT (CONFIG_BL2_SIZE/512)
-#define OM_STAT (0x1f << 1) +#define CONFIG_SPI_BOOTING + +#ifdef CONFIG_SPI_BOOTING #define EXYNOS_COPY_SPI_FNPTR_ADDR 0x02020058 -#define SPI_FLASH_UBOOT_POS (CONFIG_SEC_FW_SIZE + CONFIG_BL1_SIZE) +#endif
#define CONFIG_DOS_PARTITION
diff --git a/include/configs/origen.h b/include/configs/origen.h index e179911..c4f2ec0 100644 --- a/include/configs/origen.h +++ b/include/configs/origen.h @@ -139,20 +139,21 @@ /* MIU (Memory Interleaving Unit) */ #define CONFIG_MIU_2BIT_21_7_INTERLEAVED
-#define CONFIG_ENV_IS_IN_MMC 1 -#define CONFIG_SYS_MMC_ENV_DEV 0 -#define CONFIG_ENV_SIZE (16 << 10) /* 16 KB */ -#define RESERVE_BLOCK_SIZE (512) -#define BL1_SIZE (16 << 10) /*16 K reserved for BL1*/ -#define CONFIG_ENV_OFFSET (RESERVE_BLOCK_SIZE + BL1_SIZE) -#define CONFIG_DOS_PARTITION 1 +#define CONFIG_ENV_IS_IN_MMC 1 +#define CONFIG_SYS_MMC_ENV_DEV 0 +#define CONFIG_ENV_SIZE (16 << 10) /* 16 KB */ +#define CONFIG_RES_BLOCK_SIZE (512) +#define CONFIG_BL1_SIZE (16 << 10) /*16 K reserved for BL1*/ +#define CONFIG_ENV_OFFSET (CONFIG_RES_BLOCK_SIZE + CONFIG_BL1_SIZE) +#define CONFIG_BL2_OFFSET (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE) +#define CONFIG_DOS_PARTITION 1
#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_LOAD_ADDR - GENERATED_GBL_DATA_SIZE)
/* U-boot copy size from boot Media to DRAM.*/ -#define COPY_BL2_SIZE 0x80000 -#define BL2_START_OFFSET ((CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE)/512) -#define BL2_SIZE_BLOC_COUNT (COPY_BL2_SIZE/512) +#define CONFIG_BL2_SIZE 0x80000 +#define CONFIG_BL2_BLOCK_OFFSET (CONFIG_BL2_OFFSET/512) +#define CONFIG_BL2_SIZE_BLOCK_COUNT (CONFIG_BL2_SIZE/512)
/* Enable devicetree support */ #define CONFIG_OF_LIBFDT diff --git a/include/configs/smdkv310.h b/include/configs/smdkv310.h index 5e43066..8bb8de7 100644 --- a/include/configs/smdkv310.h +++ b/include/configs/smdkv310.h @@ -138,20 +138,21 @@ /* MIU (Memory Interleaving Unit) */ #define CONFIG_MIU_2BIT_INTERLEAVED
/* Ethernet Controllor Driver */ #ifdef CONFIG_CMD_NET
Dear Minkyu,
Please let me know if you have any comments for this patch.
With Regards, Inder
- Moved smdk5250/spl_boot.c to common armv7/exynos folder and updated to make it common for exynos4 and exynos5
- Introduced a CONFIG_SPL_BOOTING option as only exynos5250 supports booting from SPI device
- Renamed some config options to make them common between exynos5250, origen and smdkv310.
- Copy U-boot from mmc to RAM:
- COPY_BL2_FNPTR_ADDR: Address in iRAM, which Contains
bootmode = readl(samsung_get_base_power()) & OM_STAT; switch (bootmode) {
else
if (copy_bl2)
- Copyright (C) 2011 Samsung Electronics
- project.
- MA 02111-1307 USA
(*uboot)();
while (1)
- project.
- MA 02111-1307 USA
(*uboot)();
while (1)
1.7.9.5
Dear Inderpal Singh,
On 27/03/13 17:48, Inderpal Singh wrote:
Dear Minkyu,
With Regards, Inder
Since this patch had wait too long on queue, need to rebase. I'm sorry to late review.
Is this ifdef needs?
According to your comment, you should check cpu_ids.
else
if (copy_bl2)
- project.
- MA 02111-1307 USA
(*uboot)();
while (1)
- project.
- MA 02111-1307 USA
(*uboot)();
while (1)
I think this ifdef is unnecessary. You already know that we will use spi booting on this board.
1.7.9.5
This patch needs to test. Please help to test this patch and let me know.
Thanks, Minkyu Kang.
Dear Minkyu Kang,
Thanks for the review.
Dear Minkyu,
With Regards, Inder
Arndale
I introduced this ifdef because only exynos5250 has EXYNOS_COPY_SPI_FNPTR_ADDR defined. If i don't use this ifdef, It won't compile for origen, smdkv310 etc.
function */
The s5p_cpu_rev is being set to zero only for Exynos4210 EVT0, hence I thought only revision check is sufficient. That's, perhaps, not very clear. I will change it to check both cpuid as well as cpu_rev.
else
if (copy_bl2)
- project.
- MA 02111-1307 USA
(*uboot)();
while (1)
- project.
- MA 02111-1307 USA
(*uboot)();
while (1)
As this is consolidation patch, I introduced this to solve the compilation issue for other boards as mentioned above.
Now, the USB download boot mode is also supported on exynos5250 and it has one more EXYNOS_COPY_USB_FNPTR_ADDR. The other boards won't have this as well.
Let me know your thinking about handling this issue for spl_boot.c consolidation.
With Regards, Inder
CONFIG_BL1_SIZE)
KB */
BL1*/
BL1*/
CONFIG_BL1_SIZE)
KB */
BL1*/
BL1*/
CONFIG_BL1_SIZE)
1.7.9.5
[1] http://www.mail-archive.com/u-boot <at> lists.denx.de/msg108301.html
This gives 404 not found...
Geoff Levand
Inderpal Singh
Minkyu Kang
