[U-Boot] [PATCH] x86: coreboot: make it possible to process unhandled tags
coreboot makes it possible to add own entries into coreboot's table at a per mainboard basis. As there might be some custom ones it makes sense to provide a way to process them.
Signed-off-by: Christian Gmeiner christian.gmeiner@gmail.com --- arch/x86/cpu/coreboot/tables.c | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/arch/x86/cpu/coreboot/tables.c b/arch/x86/cpu/coreboot/tables.c index bc18b710c9..a7c55c7dd1 100644 --- a/arch/x86/cpu/coreboot/tables.c +++ b/arch/x86/cpu/coreboot/tables.c @@ -109,6 +109,8 @@ static void cb_parse_string(unsigned char *ptr, char **info) *info = (char *)((struct cb_string *)ptr)->string; }
+__weak void cb_parse_unhandled(u32 tag, unsigned char *ptr) {} + static int cb_parse_header(void *addr, int len, struct sysinfo_t *info) { struct cb_header *header; @@ -211,6 +213,9 @@ static int cb_parse_header(void *addr, int len, struct sysinfo_t *info) case CB_TAG_VBNV: cb_parse_vbnv(ptr, info); break; + default: + cb_parse_unhandled(rec->tag, ptr); + break; }
ptr += rec->size;
On Wed, Apr 17, 2019 at 8:42 PM Christian Gmeiner christian.gmeiner@gmail.com wrote:
nits: I would prefer to have {} in sparate lines.
I can fix this when applying.
default:
break; } ptr += rec->size;
Fixed the nits and applied to u-boot-x86, thanks!
Bin Meng
Christian Gmeiner
