[U-Boot] [PATCH V2] arm: mxs: Preprocess u-boot.bd so they contain full path
The u-boot-imx23.bd and u-boot-imx28.bd need to be preprocessed, otherwise they have issues with out-of-tree build where elftosb tool couldn't sometimes find the u-boot.bin and spl/u-boot-spl.bin .
Preprocess these .bd files with sed and insert full path to u-boot.bin and spl/u-boot-spl.bin to prevent this issue. Moreover, to avoid adding more churn into main Makefile, move all this preprocessing and u-boot.sb generation into CPU directory instead.
Signed-off-by: Marek Vasut marex@denx.de Cc: Fabio Estevam fabio.estevam@freescale.com Cc: Stefano Babic sbabic@denx.de --- .gitignore | 1 + Makefile | 7 ++----- arch/arm/cpu/arm926ejs/mxs/Makefile | 10 ++++++++++ arch/arm/cpu/arm926ejs/mxs/u-boot-imx23.bd | 4 ++-- arch/arm/cpu/arm926ejs/mxs/u-boot-imx28.bd | 4 ++-- 5 files changed, 17 insertions(+), 9 deletions(-)
V2: Add .gitignore entry
diff --git a/.gitignore b/.gitignore index ed21203..c79d577 100644 --- a/.gitignore +++ b/.gitignore @@ -46,6 +46,7 @@ /u-boot.ais /u-boot.dtb /u-boot.sb +/u-boot.bd /u-boot.geany
# diff --git a/Makefile b/Makefile index 3fd6d15..1874456 100644 --- a/Makefile +++ b/Makefile @@ -512,13 +512,9 @@ $(obj)u-boot.ais: $(obj)spl/u-boot-spl.bin $(obj)u-boot.img cat $(obj)spl/u-boot-spl-pad.ais $(obj)u-boot.img > \ $(obj)u-boot.ais
-# Specify the target for use in elftosb call -ELFTOSB_TARGET-$(CONFIG_MX23) = imx23 -ELFTOSB_TARGET-$(CONFIG_MX28) = imx28
$(obj)u-boot.sb: $(obj)u-boot.bin $(obj)spl/u-boot-spl.bin - elftosb -zf $(ELFTOSB_TARGET-y) -c $(TOPDIR)/$(CPUDIR)/$(SOC)/u-boot-$(ELFTOSB_TARGET-y).bd \ - -o $(obj)u-boot.sb + $(MAKE) -C $(SRCTREE)/$(CPUDIR)/$(SOC)/ $(OBJTREE)/u-boot.sb
# On x600 (SPEAr600) U-Boot is appended to U-Boot SPL. # Both images are created using mkimage (crc etc), so that the ROM @@ -849,6 +845,7 @@ clobber: tidy @rm -f $(obj)u-boot.ais @rm -f $(obj)u-boot.dtb @rm -f $(obj)u-boot.sb + @rm -f $(obj)u-boot.bd @rm -f $(obj)u-boot.spr @rm -f $(obj)nand_spl/{u-boot.{lds,lst},System.map} @rm -f $(obj)nand_spl/{u-boot-nand_spl.lds,u-boot-spl,u-boot-spl.map} diff --git a/arch/arm/cpu/arm926ejs/mxs/Makefile b/arch/arm/cpu/arm926ejs/mxs/Makefile index eeecf89..038c1c1 100644 --- a/arch/arm/cpu/arm926ejs/mxs/Makefile +++ b/arch/arm/cpu/arm926ejs/mxs/Makefile @@ -40,6 +40,16 @@ all: $(obj).depend $(LIB) $(LIB): $(OBJS) $(call cmd_link_o_target, $(OBJS))
+# Specify the target for use in elftosb call +ELFTOSB_TARGET-$(CONFIG_MX23) = imx23 +ELFTOSB_TARGET-$(CONFIG_MX28) = imx28 + +$(OBJTREE)/u-boot.bd: $(SRCTREE)/$(CPUDIR)/$(SOC)/u-boot-$(ELFTOSB_TARGET-y).bd + sed "s@OBJTREE@$(OBJTREE)@g" $^ > $@ + +$(OBJTREE)/u-boot.sb: $(OBJTREE)/u-boot.bin $(OBJTREE)/spl/u-boot-spl.bin $(OBJTREE)/u-boot.bd + elftosb -zf $(ELFTOSB_TARGET-y) -c $(OBJTREE)/u-boot.bd -o $(OBJTREE)/u-boot.sb + #########################################################################
# defines $(obj).depend target diff --git a/arch/arm/cpu/arm926ejs/mxs/u-boot-imx23.bd b/arch/arm/cpu/arm926ejs/mxs/u-boot-imx23.bd index 3a51879..8b6c30e 100644 --- a/arch/arm/cpu/arm926ejs/mxs/u-boot-imx23.bd +++ b/arch/arm/cpu/arm926ejs/mxs/u-boot-imx23.bd @@ -4,8 +4,8 @@ options { }
sources { - u_boot_spl="spl/u-boot-spl.bin"; - u_boot="u-boot.bin"; + u_boot_spl="OBJTREE/spl/u-boot-spl.bin"; + u_boot="OBJTREE/u-boot.bin"; }
section (0) { diff --git a/arch/arm/cpu/arm926ejs/mxs/u-boot-imx28.bd b/arch/arm/cpu/arm926ejs/mxs/u-boot-imx28.bd index c60615a..a5fa648 100644 --- a/arch/arm/cpu/arm926ejs/mxs/u-boot-imx28.bd +++ b/arch/arm/cpu/arm926ejs/mxs/u-boot-imx28.bd @@ -1,6 +1,6 @@ sources { - u_boot_spl="spl/u-boot-spl.bin"; - u_boot="u-boot.bin"; + u_boot_spl="OBJTREE/spl/u-boot-spl.bin"; + u_boot="OBJTREE/u-boot.bin"; }
section (0) {
Acked-by: Otavio Salvador otavio@ossystems.com.br
-- Otavio Salvador O.S. Systems E-mail: otavio@ossystems.com.br http://www.ossystems.com.br Mobile: +55 53 9981-7854 http://projetos.ossystems.com.br
Hi Stefano,
this one too ;-)
-o
$(obj)u-boot.sb
- @rm -f $(obj)u-boot.bd @rm -f $(obj)u-boot.spr @rm -f $(obj)nand_spl/{u-boot.{lds,lst},System.map} @rm -f $(obj)nand_spl/{u-boot-nand_spl.lds,u-boot-spl,u-boot-spl.map}
sources {
- u_boot_spl="OBJTREE/spl/u-boot-spl.bin";
- u_boot="OBJTREE/u-boot.bin";
section (0) {
Best regards, Marek Vasut
Otavio Salvador
