[U-Boot] [PATCH] sc_sps_1: Adjust board config to use 'mxs' SoC code
Fix build failure due the move of mx28 code to 'mxs' SoC.
Signed-off-by: Otavio Salvador otavio@ossystems.com.br --- board/schulercontrol/sc_sps_1/sc_sps_1.c | 4 ++-- board/schulercontrol/sc_sps_1/spl_boot.c | 4 ++-- boards.cfg | 2 +- include/configs/sc_sps_1.h | 4 ++-- 4 files changed, 7 insertions(+), 7 deletions(-)
diff --git a/board/schulercontrol/sc_sps_1/sc_sps_1.c b/board/schulercontrol/sc_sps_1/sc_sps_1.c index 0fee289..5f58e0b 100644 --- a/board/schulercontrol/sc_sps_1/sc_sps_1.c +++ b/board/schulercontrol/sc_sps_1/sc_sps_1.c @@ -85,8 +85,8 @@ int board_mmc_init(bd_t *bis) #ifdef CONFIG_CMD_NET int board_eth_init(bd_t *bis) { - struct mx28_clkctrl_regs *clkctrl_regs = - (struct mx28_clkctrl_regs *)MXS_CLKCTRL_BASE; + struct mxs_clkctrl_regs *clkctrl_regs = + (struct mxs_clkctrl_regs *)MXS_CLKCTRL_BASE; int ret;
ret = cpu_eth_init(bis); diff --git a/board/schulercontrol/sc_sps_1/spl_boot.c b/board/schulercontrol/sc_sps_1/spl_boot.c index 4d2151d..7fcbc18 100644 --- a/board/schulercontrol/sc_sps_1/spl_boot.c +++ b/board/schulercontrol/sc_sps_1/spl_boot.c @@ -156,10 +156,10 @@ const iomux_cfg_t iomux_setup[] = {
void board_init_ll(void) { - mx28_common_spl_init(iomux_setup, ARRAY_SIZE(iomux_setup)); + mxs_common_spl_init(iomux_setup, ARRAY_SIZE(iomux_setup)); }
-void mx28_adjust_memory_params(uint32_t *dram_vals) +void mxs_adjust_memory_params(uint32_t *dram_vals) { dram_vals[0x74 >> 2] = 0x0f02010a; } diff --git a/boards.cfg b/boards.cfg index f7708f1..4f88006 100644 --- a/boards.cfg +++ b/boards.cfg @@ -174,7 +174,7 @@ magnesium arm arm926ejs imx27lite logicpd apx4devkit arm arm926ejs apx4devkit bluegiga mxs apx4devkit m28evk arm arm926ejs m28evk denx mxs m28evk mx28evk arm arm926ejs mx28evk freescale mxs mx28evk -sc_sps_1 arm arm926ejs - schulercontrol mx28 +sc_sps_1 arm arm926ejs sc_sps_1 schulercontrol mxs nhk8815 arm arm926ejs nhk8815 st nomadik nhk8815_onenand arm arm926ejs nhk8815 st nomadik nhk8815:BOOT_ONENAND omap5912osk arm arm926ejs - ti omap diff --git a/include/configs/sc_sps_1.h b/include/configs/sc_sps_1.h index 4feb271..f0b6f2b 100644 --- a/include/configs/sc_sps_1.h +++ b/include/configs/sc_sps_1.h @@ -54,8 +54,8 @@ */ #define CONFIG_SPL #define CONFIG_SPL_NO_CPU_SUPPORT_CODE -#define CONFIG_SPL_START_S_PATH "arch/arm/cpu/arm926ejs/mx28" -#define CONFIG_SPL_LDSCRIPT "arch/arm/cpu/arm926ejs/mx28/u-boot-spl.lds" +#define CONFIG_SPL_START_S_PATH "arch/arm/cpu/arm926ejs/mxs" +#define CONFIG_SPL_LDSCRIPT "arch/arm/cpu/arm926ejs/mxs/u-boot-spl.lds" #define CONFIG_SPL_LIBCOMMON_SUPPORT #define CONFIG_SPL_LIBGENERIC_SUPPORT #define CONFIG_SPL_GPIO_SUPPORT
- struct mxs_clkctrl_regs *clkctrl_regs =
int ret;(struct mxs_clkctrl_regs *)MXS_CLKCTRL_BASE;
Of course, you are right. I think I changed myself V2 of Marek's patch, and I did not with V3.
Acked-by: Stefano Babic sbabic@denx.de
Best regards, Stefano Babic
Dear Stefano Babic,
int ret;
Please apply.
Best regards, Marek Vasut
Applied to u-boot-imx, thanks.
Otavio Salvador
Stefano Babic
