[PATCH] doc: usage: man-page for pinmux command
Provide a man-page for the pinmux command.
Signed-off-by: Patrick Delaunay patrick.delaunay@foss.st.com ---
Dependency with [1] for the option <pin-name> for status:
pinmux status <pin-name>
[1] cmd: pinmux: support pin name in status command http://patchwork.ozlabs.org/project/uboot/patch/20210521094728.v3.2.I5b70850...
doc/usage/index.rst | 1 + doc/usage/pinmux.rst | 95 ++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 96 insertions(+) create mode 100644 doc/usage/pinmux.rst
diff --git a/doc/usage/index.rst b/doc/usage/index.rst index 41b247bc62..e5717b7141 100644 --- a/doc/usage/index.rst +++ b/doc/usage/index.rst @@ -36,6 +36,7 @@ Shell commands mbr md mmc + pinmux pstore qfw reset diff --git a/doc/usage/pinmux.rst b/doc/usage/pinmux.rst new file mode 100644 index 0000000000..9f4392cd0d --- /dev/null +++ b/doc/usage/pinmux.rst @@ -0,0 +1,95 @@ +.. SPDX-License-Identifier: GPL-2.0+: + +pinmux command +============== + +Synopsis +-------- + +:: + + pinmux list + pinmux dev [pincontroller-name] + pinmux status [-a | pin-name] + +Description +----------- + +The pinmux command is used to show the pin-controller muxing. + +The 'pinmux list' command diplays the available pin-controller. + +The 'pinmux dev' command selects the pin-controller for next commands. + + pincontroller-name + name of the pin-controller to select + +The 'pinmux status' command displays the pin muxing information. + + -a + display pin muxing of all pin-controllers. + pin-name + name of the pin to display + +Example +------- + +:: + + => pinmux list + | Device | Driver | Parent + | pinctrl-gpio | sandbox_pinctrl_gpio | root_driver + | pinctrl | sandbox_pinctrl | root_driver + => + => pinmux dev pinctrl + dev: pinctrl + => + => pinmux status + P0 : UART TX. + P1 : UART RX. + P2 : I2S SCK. + P3 : I2S SD. + P4 : I2S WS. + P5 : GPIO0 bias-pull-up input-disable. + P6 : GPIO1 drive-open-drain. + P7 : GPIO2 bias-pull-down input-enable. + P8 : GPIO3 bias-disable. + => + => pinmux status P0 + P0 : UART TX. + => + => pinmux status -a + -------------------------- + pinctrl-gpio: + a0 : gpio input . + a1 : gpio input . + a2 : gpio input . + a3 : gpio input . + a4 : gpio input . + a5 : gpio output . + a6 : gpio output . + a7 : gpio input . + a8 : gpio input . + a9 : gpio input . + -------------------------- + pinctrl: + P0 : UART TX. + P1 : UART RX. + P2 : I2S SCK. + P3 : I2S SD. + P4 : I2S WS. + P5 : GPIO0 bias-pull-up input-disable. + P6 : GPIO1 drive-open-drain. + P7 : GPIO2 bias-pull-down input-enable. + P8 : GPIO3 bias-disable. + +Configuration +------------- + +The pinmux command is only available if CONFIG_CMD_PINMUX=y. + +Return value +------------ + +The return value $? is set to 0 (true) if the command succeded and to 1 (false) +otherwise.
Hi Patrick
- pinmux pstore qfw reset
+Synopsis +--------
- pinmux list
- pinmux dev [pincontroller-name]
- pinmux status [-a | pin-name]
- pincontroller-name
- -a
- pin-name
+Example +-------
- => pinmux list
- | Device | Driver | Parent
- | pinctrl-gpio | sandbox_pinctrl_gpio | root_driver
- | pinctrl | sandbox_pinctrl | root_driver
- => pinmux dev pinctrl
- dev: pinctrl
- => pinmux status
- P0 : UART TX.
- P1 : UART RX.
- P2 : I2S SCK.
- P3 : I2S SD.
- P4 : I2S WS.
- P5 : GPIO0 bias-pull-up input-disable.
- P6 : GPIO1 drive-open-drain.
- P7 : GPIO2 bias-pull-down input-enable.
- P8 : GPIO3 bias-disable.
- => pinmux status P0
- P0 : UART TX.
- => pinmux status -a
- pinctrl-gpio:
- a0 : gpio input .
- a1 : gpio input .
- a2 : gpio input .
- a3 : gpio input .
- a4 : gpio input .
- a5 : gpio output .
- a6 : gpio output .
- a7 : gpio input .
- a8 : gpio input .
- a9 : gpio input .
- pinctrl:
- P0 : UART TX.
- P1 : UART RX.
- P2 : I2S SCK.
- P3 : I2S SD.
- P4 : I2S WS.
Reviewed-by: Patrice Chotard patrice.chotard@foss.st.com
Thanks Patrice
Patrice CHOTARD
Patrick Delaunay
