[U-Boot] [PATCH] relocate-rela: use compiler.h endian macros
Use the endian macros from u-boot's compiler.h instead of duplicating the definitions.
This also avoids a build error on OpenBSD by removing swap64 which collides with a system definition in endian.h pulled in by inttypes.h.
Signed-off-by: Jonathan Gray jsg@jsg.id.au --- tools/relocate-rela.c | 41 ++++------------------------------------- 1 file changed, 4 insertions(+), 37 deletions(-)
diff --git a/tools/relocate-rela.c b/tools/relocate-rela.c index 670b9fd..3c9d134 100644 --- a/tools/relocate-rela.c +++ b/tools/relocate-rela.c @@ -15,6 +15,7 @@ #include <stdio.h> #include <stdlib.h> #include <string.h> +#include "compiler.h"
#ifndef R_AARCH64_RELATIVE #define R_AARCH64_RELATIVE 1027 @@ -50,40 +51,6 @@ static bool supported_rela(Elf64_Rela *rela) } }
-static inline uint64_t swap64(uint64_t val) -{ - return ((val >> 56) & 0x00000000000000ffULL) | - ((val >> 40) & 0x000000000000ff00ULL) | - ((val >> 24) & 0x0000000000ff0000ULL) | - ((val >> 8) & 0x00000000ff000000ULL) | - ((val << 8) & 0x000000ff00000000ULL) | - ((val << 24) & 0x0000ff0000000000ULL) | - ((val << 40) & 0x00ff000000000000ULL) | - ((val << 56) & 0xff00000000000000ULL); -} - -#if __BYTE_ORDER == __LITTLE_ENDIAN -static inline uint64_t be64(uint64_t val) -{ - return swap64(val); -} - -static inline uint64_t le64(uint64_t val) -{ - return val; -} -#else -static inline uint64_t le64(uint64_t val) -{ - return swap64(val); -} - -static inline uint64_t be64(uint64_t val) -{ - return val; -} -#endif - static bool read_num(const char *str, uint64_t *num) { char *endptr; @@ -148,9 +115,9 @@ int main(int argc, char **argv) return 4; }
- swrela.r_offset = le64(rela.r_offset); - swrela.r_info = le64(rela.r_info); - swrela.r_addend = le64(rela.r_addend); + swrela.r_offset = cpu_to_le64(rela.r_offset); + swrela.r_info = cpu_to_le64(rela.r_info); + swrela.r_addend = cpu_to_le64(rela.r_addend);
if (!supported_rela(&swrela)) continue;
Any objections to this?
- return val;
- return val;
-} -#endif
-- 2.10.2
Jonathan Gray
