[U-Boot] [PATCH 1/1] net: mvneta: Add GPIO configuration support
This patch add GPIO configuration support in mvneta driver. Driver will handle PHY reset. GPIO pins should be set in device tree.
Ported from mvpp2x [https://patchwork.ozlabs.org/patch/799654/]
Initial discussion to port the changes into mvneta [https://patchwork.ozlabs.org/patch/1005765/]
Signed-off-by: Aditya Prayoga aditya@kobol.io --- drivers/net/mvneta.c | 15 +++++++++++++++ 1 file changed, 15 insertions(+)
diff --git a/drivers/net/mvneta.c b/drivers/net/mvneta.c index 8cb04b5..333be8f 100644 --- a/drivers/net/mvneta.c +++ b/drivers/net/mvneta.c @@ -27,6 +27,7 @@ #include <asm/arch/soc.h> #include <linux/compat.h> #include <linux/mbus.h> +#include <asm-generic/gpio.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -274,6 +275,9 @@ struct mvneta_port { int init; int phyaddr; struct phy_device *phydev; +#ifdef CONFIG_DM_GPIO + struct gpio_desc phy_reset_gpio; +#endif struct mii_dev *bus; };
@@ -1749,6 +1753,17 @@ static int mvneta_probe(struct udevice *dev) if (ret) return ret;
+#ifdef CONFIG_DM_GPIO + gpio_request_by_name(dev, "phy-reset-gpios", 0, + &pp->phy_reset_gpio, GPIOD_IS_OUT); + + if (dm_gpio_is_valid(&pp->phy_reset_gpio)) { + dm_gpio_set_value(&pp->phy_reset_gpio, 1); + mdelay(10); + dm_gpio_set_value(&pp->phy_reset_gpio, 0); + } +#endif + return board_network_enable(bus); }
Tested-By: Dennis Gilmore dgilmore@redhat.com
- struct gpio_desc phy_reset_gpio;
- gpio_request_by_name(dev, "phy-reset-gpios", 0,
- if (dm_gpio_is_valid(&pp->phy_reset_gpio)) {
mdelay(10);
- return board_network_enable(bus);
mdelay(10);
- return board_network_enable(bus); }
Thanks, Stefan
Hi Aditya,
https://patchwork.ozlabs.org/patch/1007736/ was applied to http://git.denx.de/?p=u-boot/u-boot-net.git
Thanks! -Joe
Aditya Prayoga
Dennis Gilmore
Joe Hershberger
Stefan Roese
