[U-Boot] [PATCH 3/4] configs: nx25-ae250:Rename as ax25-ae350
Rename nx25 as ax25 ae250 as ae350 nx25-ae250 as ax25-ae350 including filename, variable, string and definition.
Signed-off-by: Rick Chen rick@andestech.com Signed-off-by: Rick Chen rickchen36@gmail.com Cc: Greentime Hu green.hu@gmail.com --- configs/ax25-ae350_defconfig | 40 ++++++++++++++ configs/nx25-ae250_defconfig | 40 -------------- include/configs/ax25-ae350.h | 125 +++++++++++++++++++++++++++++++++++++++++++ include/configs/nx25-ae250.h | 125 ------------------------------------------- 4 files changed, 165 insertions(+), 165 deletions(-) create mode 100644 configs/ax25-ae350_defconfig delete mode 100644 configs/nx25-ae250_defconfig create mode 100644 include/configs/ax25-ae350.h delete mode 100644 include/configs/nx25-ae250.h
diff --git a/configs/ax25-ae350_defconfig b/configs/ax25-ae350_defconfig new file mode 100644 index 0000000..4caee50 --- /dev/null +++ b/configs/ax25-ae350_defconfig @@ -0,0 +1,40 @@ +CONFIG_RISCV=y +CONFIG_SYS_TEXT_BASE=0x00000000 +CONFIG_DEFAULT_DEVICE_TREE="ae350" +CONFIG_TARGET_AX25_AE350=y +CONFIG_FIT=y +CONFIG_BOOTDELAY=3 +# CONFIG_AUTO_COMPLETE is not set +CONFIG_SYS_PROMPT="RISC-V # " +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_SF_TEST=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_OF_BOARD=y +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_DM=y +CONFIG_CLK=y +CONFIG_MMC=y +CONFIG_DM_MMC=y +CONFIG_FTSDC010=y +CONFIG_FTSDC010_SDIO=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_DM_ETH=y +CONFIG_FTMAC100=y +CONFIG_BAUDRATE=38400 +CONFIG_DM_SERIAL=y +CONFIG_SYS_NS16550=y +CONFIG_DM_SPI=y +CONFIG_ATCSPI200_SPI=y +CONFIG_TIMER=y +CONFIG_ATCPIT100_TIMER=y +CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/nx25-ae250_defconfig b/configs/nx25-ae250_defconfig deleted file mode 100644 index 4370832..0000000 --- a/configs/nx25-ae250_defconfig +++ /dev/null @@ -1,40 +0,0 @@ -CONFIG_RISCV=y -CONFIG_SYS_TEXT_BASE=0x00000000 -CONFIG_DEFAULT_DEVICE_TREE="ae250" -CONFIG_TARGET_NX25_AE250=y -CONFIG_FIT=y -CONFIG_BOOTDELAY=3 -# CONFIG_AUTO_COMPLETE is not set -CONFIG_SYS_PROMPT="RISC-V # " -CONFIG_CMD_MMC=y -CONFIG_CMD_SF=y -CONFIG_CMD_SF_TEST=y -# CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y -CONFIG_CMD_PING=y -CONFIG_CMD_CACHE=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_FAT=y -CONFIG_OF_CONTROL=y -CONFIG_OF_BOARD=y -CONFIG_ENV_IS_IN_SPI_FLASH=y -CONFIG_NET_RANDOM_ETHADDR=y -CONFIG_DM=y -CONFIG_CLK=y -CONFIG_MMC=y -CONFIG_DM_MMC=y -CONFIG_FTSDC010=y -CONFIG_FTSDC010_SDIO=y -CONFIG_DM_SPI_FLASH=y -CONFIG_SPI_FLASH=y -CONFIG_SPI_FLASH_MACRONIX=y -CONFIG_DM_ETH=y -CONFIG_FTMAC100=y -CONFIG_BAUDRATE=38400 -CONFIG_DM_SERIAL=y -CONFIG_SYS_NS16550=y -CONFIG_DM_SPI=y -CONFIG_ATCSPI200_SPI=y -CONFIG_TIMER=y -CONFIG_ATCPIT100_TIMER=y -CONFIG_DISTRO_DEFAULTS=y diff --git a/include/configs/ax25-ae350.h b/include/configs/ax25-ae350.h new file mode 100644 index 0000000..a90c75a --- /dev/null +++ b/include/configs/ax25-ae350.h @@ -0,0 +1,125 @@ +/* + * Copyright (C) 2017 Andes Technology Corporation + * Rick Chen, Andes Technology Corporation rick@andestech.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* + * CPU and Board Configuration Options + */ +#define CONFIG_BOOTP_SEND_HOSTNAME +#define CONFIG_BOOTP_SERVERIP + +/* + * Miscellaneous configurable options + */ +#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ + +/* + * Print Buffer Size + */ +#define CONFIG_SYS_PBSIZE \ + (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) + +/* + * max number of command args + */ +#define CONFIG_SYS_MAXARGS 16 + +/* + * Boot Argument Buffer Size + */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE + +/* + * Size of malloc() pool + * 512kB is suggested, (CONFIG_ENV_SIZE + 128 * 1024) was not enough + */ +#define CONFIG_SYS_MALLOC_LEN (512 << 10) + +/* DT blob (fdt) address */ +#define CONFIG_SYS_FDT_BASE 0x000f0000 + +/* + * Physical Memory Map + */ +#define CONFIG_NR_DRAM_BANKS 2 +#define PHYS_SDRAM_0 0x00000000 /* SDRAM Bank #1 */ +#define PHYS_SDRAM_1 \ + (PHYS_SDRAM_0 + PHYS_SDRAM_0_SIZE) /* SDRAM Bank #2 */ +#define PHYS_SDRAM_0_SIZE 0x20000000 /* 512 MB */ +#define PHYS_SDRAM_1_SIZE 0x20000000 /* 512 MB */ +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_0 + +/* + * Serial console configuration + */ +#define CONFIG_SYS_NS16550_SERIAL +#ifndef CONFIG_DM_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE -4 +#endif +#define CONFIG_SYS_NS16550_CLK 19660800 + +/* Init Stack Pointer */ +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_SDRAM_BASE + 0x1000000 - \ + GENERATED_GBL_DATA_SIZE) + +/* + * Load address and memory test area should agree with + * arch/riscv/config.mk. Be careful not to overwrite U-Boot itself. + */ +#define CONFIG_SYS_LOAD_ADDR 0x100000 /* SDRAM */ + +/* + * memtest works on 512 MB in DRAM + */ +#define CONFIG_SYS_MEMTEST_START PHYS_SDRAM_0 +#define CONFIG_SYS_MEMTEST_END (PHYS_SDRAM_0 + PHYS_SDRAM_0_SIZE) + +/* environments */ +#define CONFIG_ENV_SPI_BUS 0 +#define CONFIG_ENV_SPI_CS 0 +#define CONFIG_ENV_SPI_MAX_HZ 50000000 +#define CONFIG_ENV_SPI_MODE 0 +#define CONFIG_ENV_SECT_SIZE 0x1000 +#define CONFIG_ENV_OVERWRITE + +/* SPI FLASH */ +#define CONFIG_SF_DEFAULT_BUS 0 +#define CONFIG_SF_DEFAULT_CS 0 +#define CONFIG_SF_DEFAULT_SPEED 1000000 +#define CONFIG_SF_DEFAULT_MODE 0 + +/* + * For booting Linux, the board info and command line data + * have to be in the first 16 MB of memory, since this is + * the maximum mapped by the Linux kernel during initialization. + */ + +/* Initial Memory map for Linux*/ +#define CONFIG_SYS_BOOTMAPSZ (64 << 20) +/* Increase max gunzip size */ +#define CONFIG_SYS_BOOTM_LEN (64 << 20) + +/* When we use RAM as ENV */ +#define CONFIG_ENV_SIZE 0x2000 + +/* Enable distro boot */ +#define BOOT_TARGET_DEVICES(func) \ + func(MMC, mmc, 0) \ + func(DHCP, dhcp, na) +#include <config_distro_bootcmd.h> + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "kernel_addr_r=0x00080000\0" \ + "pxefile_addr_r=0x01f00000\0" \ + "scriptaddr=0x01f00000\0" \ + "fdt_addr_r=0x02000000\0" \ + "ramdisk_addr_r=0x02800000\0" \ + BOOTENV + +#endif /* __CONFIG_H */ diff --git a/include/configs/nx25-ae250.h b/include/configs/nx25-ae250.h deleted file mode 100644 index a90c75a..0000000 --- a/include/configs/nx25-ae250.h +++ /dev/null @@ -1,125 +0,0 @@ -/* - * Copyright (C) 2017 Andes Technology Corporation - * Rick Chen, Andes Technology Corporation rick@andestech.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -/* - * CPU and Board Configuration Options - */ -#define CONFIG_BOOTP_SEND_HOSTNAME -#define CONFIG_BOOTP_SERVERIP - -/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ - -/* - * Print Buffer Size - */ -#define CONFIG_SYS_PBSIZE \ - (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) - -/* - * max number of command args - */ -#define CONFIG_SYS_MAXARGS 16 - -/* - * Boot Argument Buffer Size - */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE - -/* - * Size of malloc() pool - * 512kB is suggested, (CONFIG_ENV_SIZE + 128 * 1024) was not enough - */ -#define CONFIG_SYS_MALLOC_LEN (512 << 10) - -/* DT blob (fdt) address */ -#define CONFIG_SYS_FDT_BASE 0x000f0000 - -/* - * Physical Memory Map - */ -#define CONFIG_NR_DRAM_BANKS 2 -#define PHYS_SDRAM_0 0x00000000 /* SDRAM Bank #1 */ -#define PHYS_SDRAM_1 \ - (PHYS_SDRAM_0 + PHYS_SDRAM_0_SIZE) /* SDRAM Bank #2 */ -#define PHYS_SDRAM_0_SIZE 0x20000000 /* 512 MB */ -#define PHYS_SDRAM_1_SIZE 0x20000000 /* 512 MB */ -#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_0 - -/* - * Serial console configuration - */ -#define CONFIG_SYS_NS16550_SERIAL -#ifndef CONFIG_DM_SERIAL -#define CONFIG_SYS_NS16550_REG_SIZE -4 -#endif -#define CONFIG_SYS_NS16550_CLK 19660800 - -/* Init Stack Pointer */ -#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_SDRAM_BASE + 0x1000000 - \ - GENERATED_GBL_DATA_SIZE) - -/* - * Load address and memory test area should agree with - * arch/riscv/config.mk. Be careful not to overwrite U-Boot itself. - */ -#define CONFIG_SYS_LOAD_ADDR 0x100000 /* SDRAM */ - -/* - * memtest works on 512 MB in DRAM - */ -#define CONFIG_SYS_MEMTEST_START PHYS_SDRAM_0 -#define CONFIG_SYS_MEMTEST_END (PHYS_SDRAM_0 + PHYS_SDRAM_0_SIZE) - -/* environments */ -#define CONFIG_ENV_SPI_BUS 0 -#define CONFIG_ENV_SPI_CS 0 -#define CONFIG_ENV_SPI_MAX_HZ 50000000 -#define CONFIG_ENV_SPI_MODE 0 -#define CONFIG_ENV_SECT_SIZE 0x1000 -#define CONFIG_ENV_OVERWRITE - -/* SPI FLASH */ -#define CONFIG_SF_DEFAULT_BUS 0 -#define CONFIG_SF_DEFAULT_CS 0 -#define CONFIG_SF_DEFAULT_SPEED 1000000 -#define CONFIG_SF_DEFAULT_MODE 0 - -/* - * For booting Linux, the board info and command line data - * have to be in the first 16 MB of memory, since this is - * the maximum mapped by the Linux kernel during initialization. - */ - -/* Initial Memory map for Linux*/ -#define CONFIG_SYS_BOOTMAPSZ (64 << 20) -/* Increase max gunzip size */ -#define CONFIG_SYS_BOOTM_LEN (64 << 20) - -/* When we use RAM as ENV */ -#define CONFIG_ENV_SIZE 0x2000 - -/* Enable distro boot */ -#define BOOT_TARGET_DEVICES(func) \ - func(MMC, mmc, 0) \ - func(DHCP, dhcp, na) -#include <config_distro_bootcmd.h> - -#define CONFIG_EXTRA_ENV_SETTINGS \ - "kernel_addr_r=0x00080000\0" \ - "pxefile_addr_r=0x01f00000\0" \ - "scriptaddr=0x01f00000\0" \ - "fdt_addr_r=0x02000000\0" \ - "ramdisk_addr_r=0x02800000\0" \ - BOOTENV - -#endif /* __CONFIG_H */
Andes
