[U-Boot] [RFC PATCH 1/2] sh: make lds more generic
currently the sh lds need to sync the lds enty and TEXT_BASE manualy and the reloc_dst is based on it
instead provide it now from the ldflags
tested on r2dplus
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com Cc: Nobuhiro Iwamatsu iwamatsu.nobuhiro@renesas.com --- board/mpr2/u-boot.lds | 13 +++---------- board/ms7720se/u-boot.lds | 15 +++------------ board/ms7722se/u-boot.lds | 15 +++------------ board/ms7750se/u-boot.lds | 15 +++------------ board/renesas/MigoR/u-boot.lds | 15 +++------------ board/renesas/ap325rxa/u-boot.lds | 15 +++------------ board/renesas/r2dplus/u-boot.lds | 15 +++------------ board/renesas/r7780mp/u-boot.lds | 15 +++------------ board/renesas/rsk7203/u-boot.lds | 10 ++-------- board/renesas/sh7763rdp/u-boot.lds | 15 +++------------ board/renesas/sh7785lcr/u-boot.lds | 7 ++++--- sh_config.mk | 1 + 12 files changed, 34 insertions(+), 117 deletions(-)
diff --git a/board/mpr2/u-boot.lds b/board/mpr2/u-boot.lds index deae344..4180522 100644 --- a/board/mpr2/u-boot.lds +++ b/board/mpr2/u-boot.lds @@ -34,16 +34,9 @@ ENTRY(_start) SECTIONS { /* - Base address of internal SDRAM is 0x8C000000. - U-Boot resides in the last 256 kB of the 64 MB. - - NOTE: This address must match with the definition of - TEXT_BASE in config.mk (in this directory). - - */ - . = 0x8C000000 + (64*1024*1024) - (256*1024); - - PROVIDE (reloc_dst = .); + * entry and reloct_dst will be provide by command line + */ + . = .;
PROVIDE (_ftext = .); PROVIDE (_fcode = .); diff --git a/board/ms7720se/u-boot.lds b/board/ms7720se/u-boot.lds index 1f9b792..7aaaaf8 100644 --- a/board/ms7720se/u-boot.lds +++ b/board/ms7720se/u-boot.lds @@ -31,18 +31,9 @@ ENTRY(_start) SECTIONS { /* - Base address of internal SDRAM is 0x0C000000. - Although size of SDRAM can be either 16 or 32 MBytes, - we assume 16 MBytes (ie ignore upper half if the full - 32 MBytes is present). - - NOTE: This address must match with the definition of - TEXT_BASE in config.mk (in this directory). - - */ - . = 0x8C000000 + (64*1024*1024) - (256*1024); - - PROVIDE (reloc_dst = .); + * entry and reloct_dst will be provide by command line + */ + . = .;
PROVIDE (_ftext = .); PROVIDE (_fcode = .); diff --git a/board/ms7722se/u-boot.lds b/board/ms7722se/u-boot.lds index 7b0fb67..db3741c 100644 --- a/board/ms7722se/u-boot.lds +++ b/board/ms7722se/u-boot.lds @@ -28,18 +28,9 @@ ENTRY(_start) SECTIONS { /* - Base address of internal SDRAM is 0x0C000000. - Although size of SDRAM can be either 16 or 32 MBytes, - we assume 16 MBytes (ie ignore upper half if the full - 32 MBytes is present). - - NOTE: This address must match with the definition of - TEXT_BASE in config.mk (in this directory). - - */ - . = 0x8C000000 + (64*1024*1024) - (256*1024); - - PROVIDE (reloc_dst = .); + * entry and reloct_dst will be provide by command line + */ + . = .;
PROVIDE (_ftext = .); PROVIDE (_fcode = .); diff --git a/board/ms7750se/u-boot.lds b/board/ms7750se/u-boot.lds index 7b0fb67..db3741c 100644 --- a/board/ms7750se/u-boot.lds +++ b/board/ms7750se/u-boot.lds @@ -28,18 +28,9 @@ ENTRY(_start) SECTIONS { /* - Base address of internal SDRAM is 0x0C000000. - Although size of SDRAM can be either 16 or 32 MBytes, - we assume 16 MBytes (ie ignore upper half if the full - 32 MBytes is present). - - NOTE: This address must match with the definition of - TEXT_BASE in config.mk (in this directory). - - */ - . = 0x8C000000 + (64*1024*1024) - (256*1024); - - PROVIDE (reloc_dst = .); + * entry and reloct_dst will be provide by command line + */ + . = .;
PROVIDE (_ftext = .); PROVIDE (_fcode = .); diff --git a/board/renesas/MigoR/u-boot.lds b/board/renesas/MigoR/u-boot.lds index c004b83..9b83cad 100644 --- a/board/renesas/MigoR/u-boot.lds +++ b/board/renesas/MigoR/u-boot.lds @@ -28,18 +28,9 @@ ENTRY(_start) SECTIONS { /* - Base address of internal SDRAM is 0x0C000000. - Although size of SDRAM can be either 16 or 32 MBytes, - we assume 16 MBytes (ie ignore upper half if the full - 32 MBytes is present). - - NOTE: This address must match with the definition of - TEXT_BASE in config.mk (in this directory). - - */ - . = 0x8C000000 + (64*1024*1024) - (256*1024); - - PROVIDE (reloc_dst = .); + * entry and reloct_dst will be provide by command line + */ + . = .;
PROVIDE (_ftext = .); PROVIDE (_fcode = .); diff --git a/board/renesas/ap325rxa/u-boot.lds b/board/renesas/ap325rxa/u-boot.lds index 94bacca..9b83cad 100644 --- a/board/renesas/ap325rxa/u-boot.lds +++ b/board/renesas/ap325rxa/u-boot.lds @@ -28,18 +28,9 @@ ENTRY(_start) SECTIONS { /* - Base address of internal SDRAM is 0x88000000. - Although size of SDRAM can be either 16 or 32 MBytes, - we assume 16 MBytes (ie ignore upper half if the full - 32 MBytes is present). - - NOTE: This address must match with the definition of - TEXT_BASE in config.mk (in this directory). - - */ - . = 0x88000000 + (128*1024*1024) - (256*1024); - - PROVIDE (reloc_dst = .); + * entry and reloct_dst will be provide by command line + */ + . = .;
PROVIDE (_ftext = .); PROVIDE (_fcode = .); diff --git a/board/renesas/r2dplus/u-boot.lds b/board/renesas/r2dplus/u-boot.lds index e1c15b0..93a7d31 100644 --- a/board/renesas/r2dplus/u-boot.lds +++ b/board/renesas/r2dplus/u-boot.lds @@ -28,18 +28,9 @@ ENTRY(_start) SECTIONS { /* - Base address of internal SDRAM is 0x0C000000. - Although size of SDRAM can be either 16 or 32 MBytes, - we assume 16 MBytes (ie ignore upper half if the full - 32 MBytes is present). - - NOTE: This address must match with the definition of - TEXT_BASE in config.mk (in this directory). - - */ - . = 0x0C000000 + (64*1024*1024) - (256*1024); - - PROVIDE (reloc_dst = .); + * entry and reloct_dst will be provide by command line + */ + . = .;
PROVIDE (_ftext = .); PROVIDE (_fcode = .); diff --git a/board/renesas/r7780mp/u-boot.lds b/board/renesas/r7780mp/u-boot.lds index f32d0b8..93a7d31 100644 --- a/board/renesas/r7780mp/u-boot.lds +++ b/board/renesas/r7780mp/u-boot.lds @@ -28,18 +28,9 @@ ENTRY(_start) SECTIONS { /* - Base address of internal SDRAM is 0x0C000000. - Although size of SDRAM can be either 16 or 32 MBytes, - we assume 16 MBytes (ie ignore upper half if the full - 32 MBytes is present). - - NOTE: This address must match with the definition of - TEXT_BASE in config.mk (in this directory). - - */ - . = 0x08000000 + (128*1024*1024) - (256*1024); - - PROVIDE (reloc_dst = .); + * entry and reloct_dst will be provide by command line + */ + . = .;
PROVIDE (_ftext = .); PROVIDE (_fcode = .); diff --git a/board/renesas/rsk7203/u-boot.lds b/board/renesas/rsk7203/u-boot.lds index bd4a550..7f3cfbd 100644 --- a/board/renesas/rsk7203/u-boot.lds +++ b/board/renesas/rsk7203/u-boot.lds @@ -28,15 +28,9 @@ ENTRY(_start) SECTIONS { /* - * Base address of internal SDRAM is 0x0C000000. - * - * NOTE: This address must match with the definition of - *TEXT_BASE in config.mk (in this directory). + * entry and reloct_dst will be provide by command line */ - - . = 0x0C000000 + (8*1024*1024) - (256*1024); - - PROVIDE (reloc_dst = .); + . = .;
PROVIDE (_ftext = .); PROVIDE (_fcode = .); diff --git a/board/renesas/sh7763rdp/u-boot.lds b/board/renesas/sh7763rdp/u-boot.lds index b1a967d..93a7d31 100644 --- a/board/renesas/sh7763rdp/u-boot.lds +++ b/board/renesas/sh7763rdp/u-boot.lds @@ -28,18 +28,9 @@ ENTRY(_start) SECTIONS { /* - Base address of internal SDRAM is 0x0C000000. - Although size of SDRAM can be either 16 or 32 MBytes, - we assume 16 MBytes (ie ignore upper half if the full - 32 MBytes is present). - - NOTE: This address must match with the definition of - TEXT_BASE in config.mk (in this directory). - - */ - . = 0x8C000000 + (64*1024*1024) - (256*1024); - - PROVIDE (reloc_dst = .); + * entry and reloct_dst will be provide by command line + */ + . = .;
PROVIDE (_ftext = .); PROVIDE (_fcode = .); diff --git a/board/renesas/sh7785lcr/u-boot.lds b/board/renesas/sh7785lcr/u-boot.lds index 255ab37..777ab92 100644 --- a/board/renesas/sh7785lcr/u-boot.lds +++ b/board/renesas/sh7785lcr/u-boot.lds @@ -28,9 +28,10 @@ ENTRY(_start)
SECTIONS { - . = 0x88000000 + (128 * 1024 * 1024) - (512 * 1024); - - PROVIDE (reloc_dst = .); + /* + * entry and reloct_dst will be provide by command line + */ + . = .;
PROVIDE (_ftext = .); PROVIDE (_fcode = .); diff --git a/sh_config.mk b/sh_config.mk index 49d50f7..c19db53 100644 --- a/sh_config.mk +++ b/sh_config.mk @@ -22,3 +22,4 @@ #
PLATFORM_CPPFLAGS += -DCONFIG_SH -D__SH__ +PLATFORM_LDFLAGS += -e $(TEXT_BASE) --defsym reloc_dst=$(TEXT_BASE)
all sh boards use the same cpu lds so move it to cpu/$(CPU)
that could be overwrite in following order SOC BOARD via the corresponding config.mk
tested on r2dplus
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com Cc: Nobuhiro Iwamatsu iwamatsu.nobuhiro@renesas.com --- board/ms7722se/u-boot.lds | 96 ------------------------ board/ms7750se/u-boot.lds | 96 ------------------------ board/renesas/MigoR/u-boot.lds | 96 ------------------------ board/renesas/ap325rxa/u-boot.lds | 96 ------------------------ board/renesas/r2dplus/u-boot.lds | 96 ------------------------ board/renesas/r7780mp/u-boot.lds | 96 ------------------------ board/renesas/sh7763rdp/u-boot.lds | 96 ------------------------ board/renesas/sh7785lcr/u-boot.lds | 97 ------------------------- {board/renesas/rsk7203 => cpu/sh2}/u-boot.lds | 0 {board/mpr2 => cpu/sh3}/u-boot.lds | 0 {board/ms7720se => cpu/sh4}/u-boot.lds | 12 ++-- sh_config.mk | 2 + 12 files changed, 8 insertions(+), 775 deletions(-) delete mode 100644 board/ms7722se/u-boot.lds delete mode 100644 board/ms7750se/u-boot.lds delete mode 100644 board/renesas/MigoR/u-boot.lds delete mode 100644 board/renesas/ap325rxa/u-boot.lds delete mode 100644 board/renesas/r2dplus/u-boot.lds delete mode 100644 board/renesas/r7780mp/u-boot.lds delete mode 100644 board/renesas/sh7763rdp/u-boot.lds delete mode 100644 board/renesas/sh7785lcr/u-boot.lds rename {board/renesas/rsk7203 => cpu/sh2}/u-boot.lds (100%) rename {board/mpr2 => cpu/sh3}/u-boot.lds (100%) rename {board/ms7720se => cpu/sh4}/u-boot.lds (95%)
diff --git a/board/ms7722se/u-boot.lds b/board/ms7722se/u-boot.lds deleted file mode 100644 index db3741c..0000000 --- a/board/ms7722se/u-boot.lds +++ /dev/null @@ -1,96 +0,0 @@ -/* - * Copyrigth (c) 2007 - * Nobuhiro Iwamatsu iwamatsu@nigauri.org - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -OUTPUT_FORMAT("elf32-sh-linux", "elf32-sh-linux", "elf32-sh-linux") -OUTPUT_ARCH(sh) -ENTRY(_start) - -SECTIONS -{ - /* - * entry and reloct_dst will be provide by command line - */ - . = .; - - PROVIDE (_ftext = .); - PROVIDE (_fcode = .); - PROVIDE (_start = .); - - .text : - { - cpu/sh4/start.o (.text) - . = ALIGN(8192); - common/env_embedded.o (.ppcenv) - . = ALIGN(8192); - common/env_embedded.o (.ppcenvr) - . = ALIGN(8192); - *(.text) - . = ALIGN(4); - } =0xFF - PROVIDE (_ecode = .); - .rodata : - { - *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) - . = ALIGN(4); - } - PROVIDE (_etext = .); - - - PROVIDE (_fdata = .); - .data : - { - *(.data) - . = ALIGN(4); - } - PROVIDE (_edata = .); - - PROVIDE (_fgot = .); - .got : - { - *(.got) - . = ALIGN(4); - } - PROVIDE (_egot = .); - - PROVIDE (__u_boot_cmd_start = .); - .u_boot_cmd : - { - *(.u_boot_cmd) - . = ALIGN(4); - } - PROVIDE (__u_boot_cmd_end = .); - - PROVIDE (reloc_dst_end = .); - /* _reloc_dst_end = .; */ - - PROVIDE (bss_start = .); - PROVIDE (__bss_start = .); - .bss (NOLOAD) : - { - *(.bss) - . = ALIGN(4); - } - PROVIDE (bss_end = .); - - PROVIDE (_end = .); -} diff --git a/board/ms7750se/u-boot.lds b/board/ms7750se/u-boot.lds deleted file mode 100644 index db3741c..0000000 --- a/board/ms7750se/u-boot.lds +++ /dev/null @@ -1,96 +0,0 @@ -/* - * Copyrigth (c) 2007 - * Nobuhiro Iwamatsu iwamatsu@nigauri.org - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -OUTPUT_FORMAT("elf32-sh-linux", "elf32-sh-linux", "elf32-sh-linux") -OUTPUT_ARCH(sh) -ENTRY(_start) - -SECTIONS -{ - /* - * entry and reloct_dst will be provide by command line - */ - . = .; - - PROVIDE (_ftext = .); - PROVIDE (_fcode = .); - PROVIDE (_start = .); - - .text : - { - cpu/sh4/start.o (.text) - . = ALIGN(8192); - common/env_embedded.o (.ppcenv) - . = ALIGN(8192); - common/env_embedded.o (.ppcenvr) - . = ALIGN(8192); - *(.text) - . = ALIGN(4); - } =0xFF - PROVIDE (_ecode = .); - .rodata : - { - *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) - . = ALIGN(4); - } - PROVIDE (_etext = .); - - - PROVIDE (_fdata = .); - .data : - { - *(.data) - . = ALIGN(4); - } - PROVIDE (_edata = .); - - PROVIDE (_fgot = .); - .got : - { - *(.got) - . = ALIGN(4); - } - PROVIDE (_egot = .); - - PROVIDE (__u_boot_cmd_start = .); - .u_boot_cmd : - { - *(.u_boot_cmd) - . = ALIGN(4); - } - PROVIDE (__u_boot_cmd_end = .); - - PROVIDE (reloc_dst_end = .); - /* _reloc_dst_end = .; */ - - PROVIDE (bss_start = .); - PROVIDE (__bss_start = .); - .bss (NOLOAD) : - { - *(.bss) - . = ALIGN(4); - } - PROVIDE (bss_end = .); - - PROVIDE (_end = .); -} diff --git a/board/renesas/MigoR/u-boot.lds b/board/renesas/MigoR/u-boot.lds deleted file mode 100644 index 9b83cad..0000000 --- a/board/renesas/MigoR/u-boot.lds +++ /dev/null @@ -1,96 +0,0 @@ -/* - * Copyrigth (c) 2007 - * Nobuhiro Iwamatsu iwamatsu@nigauri.org - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -OUTPUT_FORMAT("elf32-sh-linux", "elf32-sh-linux", "elf32-sh-linux") -OUTPUT_ARCH(sh) -ENTRY(_start) - -SECTIONS -{ - /* - * entry and reloct_dst will be provide by command line - */ - . = .; - - PROVIDE (_ftext = .); - PROVIDE (_fcode = .); - PROVIDE (_start = .); - - .text : - { - cpu/sh4/start.o (.text) - . = ALIGN(8192); - common/env_embedded.o (.ppcenv) - . = ALIGN(8192); - common/env_embedded.o (.ppcenvr) - . = ALIGN(8192); - *(.text) - . = ALIGN(4); - } =0xFF - PROVIDE (_ecode = .); - .rodata : - { - *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) - . = ALIGN(4); - } - PROVIDE (_etext = .); - - - PROVIDE (_fdata = .); - .data : - { - *(.data) - . = ALIGN(4); - } - PROVIDE (_edata = .); - - PROVIDE (_fgot = .); - .got : - { - *(.got) - . = ALIGN(4); - } - PROVIDE (_egot = .); - - PROVIDE (__u_boot_cmd_start = .); - .u_boot_cmd : - { - *(.u_boot_cmd) - . = ALIGN(4); - } - PROVIDE (__u_boot_cmd_end = .); - - PROVIDE (reloc_dst_end = .); - /* _reloc_dst_end = .; */ - - PROVIDE (bss_start = .); - PROVIDE (__bss_start = .); - .bss : - { - *(.bss) - . = ALIGN(4); - } - PROVIDE (bss_end = .); - - PROVIDE (_end = .); -} diff --git a/board/renesas/ap325rxa/u-boot.lds b/board/renesas/ap325rxa/u-boot.lds deleted file mode 100644 index 9b83cad..0000000 --- a/board/renesas/ap325rxa/u-boot.lds +++ /dev/null @@ -1,96 +0,0 @@ -/* - * Copyrigth (c) 2007 - * Nobuhiro Iwamatsu iwamatsu@nigauri.org - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -OUTPUT_FORMAT("elf32-sh-linux", "elf32-sh-linux", "elf32-sh-linux") -OUTPUT_ARCH(sh) -ENTRY(_start) - -SECTIONS -{ - /* - * entry and reloct_dst will be provide by command line - */ - . = .; - - PROVIDE (_ftext = .); - PROVIDE (_fcode = .); - PROVIDE (_start = .); - - .text : - { - cpu/sh4/start.o (.text) - . = ALIGN(8192); - common/env_embedded.o (.ppcenv) - . = ALIGN(8192); - common/env_embedded.o (.ppcenvr) - . = ALIGN(8192); - *(.text) - . = ALIGN(4); - } =0xFF - PROVIDE (_ecode = .); - .rodata : - { - *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) - . = ALIGN(4); - } - PROVIDE (_etext = .); - - - PROVIDE (_fdata = .); - .data : - { - *(.data) - . = ALIGN(4); - } - PROVIDE (_edata = .); - - PROVIDE (_fgot = .); - .got : - { - *(.got) - . = ALIGN(4); - } - PROVIDE (_egot = .); - - PROVIDE (__u_boot_cmd_start = .); - .u_boot_cmd : - { - *(.u_boot_cmd) - . = ALIGN(4); - } - PROVIDE (__u_boot_cmd_end = .); - - PROVIDE (reloc_dst_end = .); - /* _reloc_dst_end = .; */ - - PROVIDE (bss_start = .); - PROVIDE (__bss_start = .); - .bss : - { - *(.bss) - . = ALIGN(4); - } - PROVIDE (bss_end = .); - - PROVIDE (_end = .); -} diff --git a/board/renesas/r2dplus/u-boot.lds b/board/renesas/r2dplus/u-boot.lds deleted file mode 100644 index 93a7d31..0000000 --- a/board/renesas/r2dplus/u-boot.lds +++ /dev/null @@ -1,96 +0,0 @@ -/* - * Copyrigth (c) 2007,2008 - * Nobuhiro Iwamatsu iwamatsu@nigauri.org - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -OUTPUT_FORMAT("elf32-sh-linux", "elf32-sh-linux", "elf32-sh-linux") -OUTPUT_ARCH(sh) -ENTRY(_start) - -SECTIONS -{ - /* - * entry and reloct_dst will be provide by command line - */ - . = .; - - PROVIDE (_ftext = .); - PROVIDE (_fcode = .); - PROVIDE (_start = .); - - .text : - { - cpu/sh4/start.o (.text) - . = ALIGN(8192); - common/env_embedded.o (.ppcenv) - . = ALIGN(8192); - common/env_embedded.o (.ppcenvr) - . = ALIGN(8192); - *(.text) - . = ALIGN(4); - } =0xFF - PROVIDE (_ecode = .); - .rodata : - { - *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) - . = ALIGN(4); - } - PROVIDE (_etext = .); - - - PROVIDE (_fdata = .); - .data : - { - *(.data) - . = ALIGN(4); - } - PROVIDE (_edata = .); - - PROVIDE (_fgot = .); - .got : - { - *(.got) - . = ALIGN(4); - } - PROVIDE (_egot = .); - - PROVIDE (__u_boot_cmd_start = .); - .u_boot_cmd : - { - *(.u_boot_cmd) - . = ALIGN(4); - } - PROVIDE (__u_boot_cmd_end = .); - - PROVIDE (reloc_dst_end = .); - /* _reloc_dst_end = .; */ - - PROVIDE (bss_start = .); - PROVIDE (__bss_start = .); - .bss : - { - *(.bss) - . = ALIGN(4); - } - PROVIDE (bss_end = .); - - PROVIDE (_end = .); -} diff --git a/board/renesas/r7780mp/u-boot.lds b/board/renesas/r7780mp/u-boot.lds deleted file mode 100644 index 93a7d31..0000000 --- a/board/renesas/r7780mp/u-boot.lds +++ /dev/null @@ -1,96 +0,0 @@ -/* - * Copyrigth (c) 2007,2008 - * Nobuhiro Iwamatsu iwamatsu@nigauri.org - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -OUTPUT_FORMAT("elf32-sh-linux", "elf32-sh-linux", "elf32-sh-linux") -OUTPUT_ARCH(sh) -ENTRY(_start) - -SECTIONS -{ - /* - * entry and reloct_dst will be provide by command line - */ - . = .; - - PROVIDE (_ftext = .); - PROVIDE (_fcode = .); - PROVIDE (_start = .); - - .text : - { - cpu/sh4/start.o (.text) - . = ALIGN(8192); - common/env_embedded.o (.ppcenv) - . = ALIGN(8192); - common/env_embedded.o (.ppcenvr) - . = ALIGN(8192); - *(.text) - . = ALIGN(4); - } =0xFF - PROVIDE (_ecode = .); - .rodata : - { - *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) - . = ALIGN(4); - } - PROVIDE (_etext = .); - - - PROVIDE (_fdata = .); - .data : - { - *(.data) - . = ALIGN(4); - } - PROVIDE (_edata = .); - - PROVIDE (_fgot = .); - .got : - { - *(.got) - . = ALIGN(4); - } - PROVIDE (_egot = .); - - PROVIDE (__u_boot_cmd_start = .); - .u_boot_cmd : - { - *(.u_boot_cmd) - . = ALIGN(4); - } - PROVIDE (__u_boot_cmd_end = .); - - PROVIDE (reloc_dst_end = .); - /* _reloc_dst_end = .; */ - - PROVIDE (bss_start = .); - PROVIDE (__bss_start = .); - .bss : - { - *(.bss) - . = ALIGN(4); - } - PROVIDE (bss_end = .); - - PROVIDE (_end = .); -} diff --git a/board/renesas/sh7763rdp/u-boot.lds b/board/renesas/sh7763rdp/u-boot.lds deleted file mode 100644 index 93a7d31..0000000 --- a/board/renesas/sh7763rdp/u-boot.lds +++ /dev/null @@ -1,96 +0,0 @@ -/* - * Copyrigth (c) 2007,2008 - * Nobuhiro Iwamatsu iwamatsu@nigauri.org - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -OUTPUT_FORMAT("elf32-sh-linux", "elf32-sh-linux", "elf32-sh-linux") -OUTPUT_ARCH(sh) -ENTRY(_start) - -SECTIONS -{ - /* - * entry and reloct_dst will be provide by command line - */ - . = .; - - PROVIDE (_ftext = .); - PROVIDE (_fcode = .); - PROVIDE (_start = .); - - .text : - { - cpu/sh4/start.o (.text) - . = ALIGN(8192); - common/env_embedded.o (.ppcenv) - . = ALIGN(8192); - common/env_embedded.o (.ppcenvr) - . = ALIGN(8192); - *(.text) - . = ALIGN(4); - } =0xFF - PROVIDE (_ecode = .); - .rodata : - { - *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) - . = ALIGN(4); - } - PROVIDE (_etext = .); - - - PROVIDE (_fdata = .); - .data : - { - *(.data) - . = ALIGN(4); - } - PROVIDE (_edata = .); - - PROVIDE (_fgot = .); - .got : - { - *(.got) - . = ALIGN(4); - } - PROVIDE (_egot = .); - - PROVIDE (__u_boot_cmd_start = .); - .u_boot_cmd : - { - *(.u_boot_cmd) - . = ALIGN(4); - } - PROVIDE (__u_boot_cmd_end = .); - - PROVIDE (reloc_dst_end = .); - /* _reloc_dst_end = .; */ - - PROVIDE (bss_start = .); - PROVIDE (__bss_start = .); - .bss : - { - *(.bss) - . = ALIGN(4); - } - PROVIDE (bss_end = .); - - PROVIDE (_end = .); -} diff --git a/board/renesas/sh7785lcr/u-boot.lds b/board/renesas/sh7785lcr/u-boot.lds deleted file mode 100644 index 777ab92..0000000 --- a/board/renesas/sh7785lcr/u-boot.lds +++ /dev/null @@ -1,97 +0,0 @@ -/* - * Copyrigth (c) 2007 - * Nobuhiro Iwamatsu iwamatsu@nigauri.org - * Copyrigth (c) 2008-2009 Yoshihiro Shimoda shimoda.yoshihiro@renesas.com - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -OUTPUT_FORMAT("elf32-sh-linux", "elf32-sh-linux", "elf32-sh-linux") -OUTPUT_ARCH(sh) -ENTRY(_start) - -SECTIONS -{ - /* - * entry and reloct_dst will be provide by command line - */ - . = .; - - PROVIDE (_ftext = .); - PROVIDE (_fcode = .); - PROVIDE (_start = .); - - .text : - { - cpu/sh4/start.o (.text) - . = ALIGN(8192); - common/env_embedded.o (.ppcenv) - . = ALIGN(8192); - common/env_embedded.o (.ppcenvr) - . = ALIGN(8192); - *(.text) - . = ALIGN(4); - } =0xFF - PROVIDE (_ecode = .); - .rodata : - { - *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) - . = ALIGN(4); - } - PROVIDE (_etext = .); - - - PROVIDE (_fdata = .); - .data : - { - *(.data) - . = ALIGN(4); - } - PROVIDE (_edata = .); - - PROVIDE (_fgot = .); - .got : - { - *(.got) - . = ALIGN(4); - } - PROVIDE (_egot = .); - - PROVIDE (__u_boot_cmd_start = .); - .u_boot_cmd : - { - *(.u_boot_cmd) - . = ALIGN(4); - } - PROVIDE (__u_boot_cmd_end = .); - - PROVIDE (reloc_dst_end = .); - /* _reloc_dst_end = .; */ - - PROVIDE (bss_start = .); - PROVIDE (__bss_start = .); - .bss : - { - *(.bss) - . = ALIGN(4); - } - PROVIDE (bss_end = .); - - PROVIDE (_end = .); -} diff --git a/board/renesas/rsk7203/u-boot.lds b/cpu/sh2/u-boot.lds similarity index 100% rename from board/renesas/rsk7203/u-boot.lds rename to cpu/sh2/u-boot.lds diff --git a/board/mpr2/u-boot.lds b/cpu/sh3/u-boot.lds similarity index 100% rename from board/mpr2/u-boot.lds rename to cpu/sh3/u-boot.lds diff --git a/board/ms7720se/u-boot.lds b/cpu/sh4/u-boot.lds similarity index 95% rename from board/ms7720se/u-boot.lds rename to cpu/sh4/u-boot.lds index 7aaaaf8..80fb8f0 100644 --- a/board/ms7720se/u-boot.lds +++ b/cpu/sh4/u-boot.lds @@ -1,10 +1,10 @@ /* - * Copyrigth (c) 2007 - * Yoshihiro Shimoda shimoda.yoshihiro@renesas.com - * - * Copyrigth (c) 2007 + * Copyright (C) 2007 * Nobuhiro Iwamatsu iwamatsu@nigauri.org * + * Copyright (C) 2008-2009 + * Yoshihiro Shimoda shimoda.yoshihiro@renesas.com + * * See file CREDITS for list of people who contributed to this * project. * @@ -41,7 +41,7 @@ SECTIONS
.text : { - cpu/sh3/start.o (.text) + cpu/sh4/start.o (.text) . = ALIGN(8192); common/env_embedded.o (.ppcenv) . = ALIGN(8192); @@ -88,7 +88,7 @@ SECTIONS
PROVIDE (bss_start = .); PROVIDE (__bss_start = .); - .bss : + .bss (NOLOAD) : { *(.bss) . = ALIGN(4); diff --git a/sh_config.mk b/sh_config.mk index c19db53..407e076 100644 --- a/sh_config.mk +++ b/sh_config.mk @@ -23,3 +23,5 @@
PLATFORM_CPPFLAGS += -DCONFIG_SH -D__SH__ PLATFORM_LDFLAGS += -e $(TEXT_BASE) --defsym reloc_dst=$(TEXT_BASE) + +LDSCRIPT := $(SRCTREE)/cpu/$(CPU)/u-boot.lds
tested on r2dplus
Ping
Best Regards, J.
2009/5/23 Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com:
tested on r2dplus
Ping
Sorry, answer is late. I will test this patch, and rend report for you. If no problem, I will apply this patch to testing branch.
Best regards, Nobuhiro
2009/5/14 Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com:
tested on r2dplus
Appilied these patch collection. Thank you!
Dear Nobuhiro Iwamatsu,
In message 29ab51dc0905262313h17934f09u904a4e7325207148@mail.gmail.com you wrote:
tested on r2dplus
Sorry, but I don't agree. The commit message is terrible. "sh lds need to sync the lds enty" - what is that suppoosed to mean?
I insist on readable and understandable commit messages.
Hi, Wolfgang.
2009/5/27 Wolfgang Denk wd@denx.de:
tested on r2dplus
OK , you are right.
Jean-Christophe, please update commit message and resend.
Nobuhiro Iwamatsu
