[PATCH v4] Makefile: use shell to calculate map_size
The error message "bc: command not found" is easily missed since the build continues. bc is not a part of coreutils or base-devel. POSIX sh can also do the calculation.
Signed-off-by: Leon M. Busch-George leon@georgemail.eu Reviewed-by: Dragan Simic dsimic@manjaro.org --- Makefile | 15 ++++++++++----- 1 file changed, 10 insertions(+), 5 deletions(-)
diff --git a/Makefile b/Makefile index a2bc9d5903..fac3a05dd5 100644 --- a/Makefile +++ b/Makefile @@ -1273,12 +1273,17 @@ OBJCOPYFLAGS_u-boot-nodtb.bin := -O binary \ $(if $(CONFIG_MPC85XX_HAVE_RESET_VECTOR),$(if $(CONFIG_OF_SEPARATE),-R .bootpg -R .resetvec))
binary_size_check: u-boot-nodtb.bin FORCE - @file_size=$(shell wc -c u-boot-nodtb.bin | awk '{print $$1}') ; \ + @file_size=$(shell wc -c u-boot-nodtb.bin | awk '{ print $$1 }') ; \ map_size=$(shell cat u-boot.map | \ - awk '/_image_copy_start/ {start = $$1} /_image_binary_end/ {end = $$1} END {if (start != "" && end != "") print "ibase=16; " toupper(end) " - " toupper(start)}' \ - | sed 's/0X//g' \ - | bc); \ - if [ "" != "$$map_size" ]; then \ + awk ' \ + /_image_copy_start/ { start = $$1 } \ + /_image_binary_end/ { end = $$1 } \ + END { \ + if (start != "" && end != "") \ + print end " " start; \ + }' \ + | sh -c 'read end start && echo $$((end - start))'); \ + if [ -n "$$map_size" ]; then \ if test $$map_size -ne $$file_size; then \ echo "u-boot.map shows a binary size of $$map_size" >&2 ; \ echo " but u-boot-nodtb.bin shows $$file_size" >&2 ; \
