Re: [U-Boot] [PATCH 1/5] vybrid: add vybrid CPU support
Hi, Liu Hui,
-----Original Message----- From: Wang Huan-B18965 Sent: Sunday, April 28, 2013 12:48 PM To: Liu Hui-R64343; u-boot@lists.denx.de Cc: sbabic@denx.de; Estevam Fabio-R49496; TsiChung Liew; Jin Zhengxiong- R64188 Subject: RE: [PATCH 1/5] vybrid: add vybrid CPU support
Hi, Liu Hui:
-----Original Message----- From: Liu Hui-R64343 Sent: Monday, April 15, 2013 11:25 AM To: Wang Huan-B18965; u-boot@lists.denx.de Cc: sbabic@denx.de; Estevam Fabio-R49496; TsiChung Liew; Jin Zhengxiong- R64188 Subject: RE: [PATCH 1/5] vybrid: add vybrid CPU support
-----Original Message----- From: Wang Huan-B18965 Sent: Friday, April 12, 2013 2:54 PM To: u-boot@lists.denx.de Cc: sbabic@denx.de; Liu Hui-R64343; Estevam Fabio-R49496; TsiChung Liew; Jin Zhengxiong-R64188 Subject: [PATCH 1/5] vybrid: add vybrid CPU support
The Vybrid devices are a family of Freescale's latest Dual Single Core offering with ARM Cortex A5 and CM4 based processors for Advanced Connected Radio, Entry Infotainment, and Cluster as well as high end industrial and general purpose applications.
This patch adds vybrid CPU support.
Signed-off-by: TsiChung Liew tsicliew@gmail.com Signed-off-by: Jason Jin Jason.jin@freescale.com Signed-off-by: Alison Wang b18965@freescale.com
Makefile | 8 + arch/arm/cpu/armv7/vybrid-common/Makefile | 46 ++ arch/arm/cpu/armv7/vybrid-common/cpu.c | 127 ++++ arch/arm/cpu/armv7/vybrid-common/speed.c | 37 ++ arch/arm/cpu/armv7/vybrid-common/timer.c | 140 +++++ arch/arm/cpu/armv7/vybrid/Makefile | 45 ++ arch/arm/cpu/armv7/vybrid/asm-offsets.c | 70 +++ arch/arm/cpu/armv7/vybrid/clock.c | 278 +++++++++ arch/arm/cpu/armv7/vybrid/iomux.c | 42 ++ arch/arm/cpu/armv7/vybrid/lowlevel_init.S | 128 ++++ arch/arm/cpu/armv7/vybrid/soc.c | 42 ++ arch/arm/include/asm/arch-vybrid/clock.h | 41 ++ arch/arm/include/asm/arch-vybrid/iomux.h | 323 ++++++++++ arch/arm/include/asm/arch-vybrid/serial-vybrid.h | 213 +++++++ arch/arm/include/asm/arch-vybrid/sys_proto.h | 30 + arch/arm/include/asm/arch-vybrid/timer.h | 405 +++++++++++++ arch/arm/include/asm/arch-vybrid/vybrid-pins.h | 88 +++ arch/arm/include/asm/arch-vybrid/vybrid-regs.h | 735 +++++++++++++++++++++++ arch/arm/include/asm/global_data.h | 3 + arch/arm/include/asm/mach-types.h | 56 ++ 20 files changed, 2857 insertions(+) create mode 100644 arch/arm/cpu/armv7/vybrid-common/Makefile create mode 100644 arch/arm/cpu/armv7/vybrid-common/cpu.c create mode 100644 arch/arm/cpu/armv7/vybrid-common/speed.c create mode 100644 arch/arm/cpu/armv7/vybrid-common/timer.c create mode 100644 arch/arm/cpu/armv7/vybrid/Makefile create mode 100644 arch/arm/cpu/armv7/vybrid/asm-offsets.c create mode 100644 arch/arm/cpu/armv7/vybrid/clock.c create mode 100644 arch/arm/cpu/armv7/vybrid/iomux.c create mode 100644 arch/arm/cpu/armv7/vybrid/lowlevel_init.S create mode 100644 arch/arm/cpu/armv7/vybrid/soc.c create mode 100644 arch/arm/include/asm/arch-vybrid/clock.h create mode 100644 arch/arm/include/asm/arch-vybrid/iomux.h create mode 100644 arch/arm/include/asm/arch-vybrid/serial-vybrid.h create mode 100644 arch/arm/include/asm/arch-vybrid/sys_proto.h create mode 100644 arch/arm/include/asm/arch-vybrid/timer.h create mode 100644 arch/arm/include/asm/arch-vybrid/vybrid-pins.h create mode 100644 arch/arm/include/asm/arch-vybrid/vybrid-regs.h
+.section ".text.init", "x"
+.globl lowlevel_init +lowlevel_init:
/* ARM errata ID #468414 */
mrc 15, 0, r1, c1, c0, 1
orr r1, r1, #(1 << 5) /* enable L1NEON bit */
mcr 15, 0, r1, c1, c0, 1
Does this errata applied to A5 too?
You did not answer this question? :)
[Alison Wang] This errata doesn't apply to A5. I will remove it. Thanks.
+#ifndef CONFIG_SYS_BOOTHDR
init_clock
/* r12 saved upper lr*/
mov pc,lr
+/* Board level setting value */ +DDR_PERCHARGE_CMD: .word 0x04008008 +DDR_REFRESH_CMD: .word 0x00008010 +DDR_LMR1_W: .word 0x00338018 +DDR_LMR_CMD: .word 0xB2220000 +DDR_TIMING_W: .word 0xB02567A9 +DDR_MISC_W: .word 0x000A0104 diff --git a/arch/arm/cpu/armv7/vybrid/soc.c b/arch/arm/cpu/armv7/vybrid/soc.c new file mode 100644 index 0000000..e73d6c4 --- /dev/null +++ b/arch/arm/cpu/armv7/vybrid/soc.c @@ -0,0 +1,42 @@ +/*
- Copyright 2012-2013 Freescale Semiconductor, Inc.
- project.
- MA 02111-1307 USA
+#include <common.h> +#include <asm/arch/vybrid-regs.h> +#include <asm/arch/clock.h> +#include <asm/arch/sys_proto.h>
+#include <asm/errno.h> +#include <asm/io.h>
+#if !(defined(CONFIG_VYBRID)) +#error "CPU_TYPE not defined" +#endif
+u32 get_cpu_rev(void) +{
int system_rev = 0x600000;
What's the hard code 0x600000 means?
Ditto,
[Alison Wang] Because CPU revision could not read from hardware, I wrote it like this . I will remove it in the next patch version.
int reg = __raw_readl(ROM_SI_REV);
system_rev |= reg;
return system_rev;
+#define _VYBRID_BUILD_GPIO_PIN(gp, gi, ga, mi, pi) \
_VYBRID_BUILD_PIN(gp, gi, ga, mi, pi)
+#define _VYBRID_BUILD_NON_GPIO_PIN(mi, pi) \
_VYBRID_BUILD_PIN(NON_GPIO_PORT, 0, 0, mi, pi)
+#define PIN_TO_IOMUX_MUX(pin) ((pin >> MUX_I) & PIN_TO_MUX_MASK) +#define PIN_TO_IOMUX_PAD(pin) ((pin >> PAD_I) & PIN_TO_PAD_MASK) +#define PIN_TO_ALT_GPIO(pin) ((pin >> GPIO_I) &
PIN_TO_ALT_GPIO_MASK)
+#define PIN_TO_IOMUX_INDEX(pin) (PIN_TO_IOMUX_MUX(pin) >> 2)
+enum iomux_input_select {
AUDMUX_P4_INPUT = 0,
Could you please consider the common iomux-v3 code? [Alison Wang] I consider the common iomux-v3 code, and find that i.mx and MVF platform (vybrid) have different registers' definitions for IOMUXC. On i.mx there are two registers for mux_mode and control value, but on MVF platform there is only one register.
For MVF platform, IOMUXC register is as follows: 31 30 29 28 27 26 25 24 23 | 22 21 20 | 19 18 17 16 Reserved | MUX_MODE | Reserved 15 14 | 13 12 |11 |10 | 9 | 8 7 6 | 5 4 | 3 | 2 | 1 | 0 | Reserved | SPEED |SRE|ODE|HYS| DSE | PUS |PKE|PUE|OBE|IBE|
In arch/arm/imx-common/iomux-v3.c, u32 pad_ctrl = (pad & MUX_PAD_CTRL_MASK) >> MUX_PAD_CTRL_SHIFT; (MUX_PAD_CTRL_MASK is 0x3ffff !)
if (mux_ctrl_ofs) __raw_writel(mux_mode, base + mux_ctrl_ofs); if (sel_input_ofs) __raw_writel(sel_input, base + sel_input_ofs); if (!(pad_ctrl & NO_PAD_CTRL) && pad_ctrl_ofs) __raw_writel(pad_ctrl, base + pad_ctrl_ofs);
I think the above codes are not suitable for MVF platform.
In MVF platform, the address for IOMUXC_PTA6 is 4004_8000h base + 0h offset, so pad_ctrl_ofs and mux_ctrl_ofs will be 0. I think the codes "if (mux_ctrl_ofs)" and " if (!(pad_ctrl & NO_PAD_CTRL) && pad_ctrl_ofs)" are not suitable for MVF platform.
The definitions for some macros such as PAD_CTL_PUS_100K_DOWN are not suitable for MVF platform, too.
I think I could use iomux-v3 code, if adding some "#ifdef" for MVF platform in iomux-v3 code. But I think it may be better if the code could be modified to be suitable for both i.mx and MVF platforms. What's your suggestions? Thanks.
From your comments, the current code is not fit perfectly for the
VF platform, but we can consider changing the code to make it fit for both.
But I do not strongly insist that we must use the same code. If you find it's Ugly to support both with the same code, I'm fine with the current code.
[Alison Wang] I will change the code to make it fit for both in the next patch version. Thanks.
Jason Liu
+#endif /* __ASSEMBLY__ */ +#endif /* __ASM_ARCH_VYBRID_PINS_H__ */ diff --git a/arch/arm/include/asm/arch-vybrid/vybrid-regs.h b/arch/arm/include/asm/arch-vybrid/vybrid-regs.h new file mode 100644 index 0000000..51cfba5
Thanks!
Best Regards, Alison Wang
Wang Huan-B18965
