[U-Boot] [PATCH] fastboot: common: fix default fastboot_boot on 64-bit
When booting on a 64-bit system, the boot_addr_start buffer is not large enough to contain a 64-bit number, thus leading to a crash even if fastboot_buf_addr is valid, only the high part of the address will be printed to boot_addr_start :
fastboot with fastboot_buf_addr = 0x0000000006000000: downloading of 92239872 bytes finished Booting kernel at 0x00000000...
"Synchronous Abort" handler, esr 0x96000004 elr: 00000000010561f4 lr : 0000000001056fac (reloc) <snip> x28: 000000007df2d38f x29: 000000007df2d1b0
Resetting CPU ...
With this fix, boot_addr_start can have the full 64-bit address passed to bootm.
Fixes: f73a7df984a9 ("net: fastboot: Merge AOSP UDP fastboot") Cc: Simon Glass sjg@chromium.org Cc: Alex Kiernan alex.kiernan@gmail.com Cc: Sam Protsenko semen.protsenko@linaro.org Signed-off-by: Neil Armstrong narmstrong@baylibre.com --- drivers/fastboot/fb_common.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/fastboot/fb_common.c b/drivers/fastboot/fb_common.c index c6e06aab7a..17eca73be0 100644 --- a/drivers/fastboot/fb_common.c +++ b/drivers/fastboot/fb_common.c @@ -119,7 +119,7 @@ void fastboot_boot(void) if (s) { run_command(s, CMD_FLAG_ENV); } else { - static char boot_addr_start[12]; + static char boot_addr_start[20]; static char *const bootm_args[] = { "bootm", boot_addr_start, NULL };
Resetting CPU ...
Neil Armstrong
