[U-Boot] [U-boot] [Patch] ARM: keystone: clock: use correct BWADJ field mask for PASSPLLCTL0
The mask for BWADJ field of PASSPLLCTL0 register has to be 0xff, but by mistake, here is used shift instead of mask, so correct it.
Signed-off-by: Ivan Khoronzhuk ivan.khoronzhuk@ti.com ---
Based on [U-boot] [Patch] keystone2: use EFUSE_BOOTROM information to configure PLLs http://patchwork.ozlabs.org/patch/373790
arch/arm/cpu/armv7/keystone/clock.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/cpu/armv7/keystone/clock.c b/arch/arm/cpu/armv7/keystone/clock.c index 30d76a6..47fc893 100644 --- a/arch/arm/cpu/armv7/keystone/clock.c +++ b/arch/arm/cpu/armv7/keystone/clock.c @@ -174,7 +174,7 @@ void init_pll(const struct pll_init_data *data) * bypass disabled */ bwadj = pllm >> 1; - tmp |= ((bwadj & PLL_BWADJ_LO_SHIFT) << PLL_BWADJ_LO_SHIFT) | + tmp |= ((bwadj & PLL_BWADJ_LO_MASK) << PLL_BWADJ_LO_SHIFT) | (pllm << PLL_MULT_SHIFT) | (plld & PLL_DIV_MASK) | (pllod << PLL_CLKOD_SHIFT);
Ivan Khoronzhuk
