[PATCH] env/fat.c: allow loading from a FAT partition on the MMC boot device
I don't want to have to specify the device; only the partition.
This allows me to use the same image on internal eMMC or SD card for Banana Pi R2, and it finds its own environment either way.
Signed-off-by: David Woodhouse dwmw2@infradead.org --- env/Kconfig | 4 ++++ env/fat.c | 29 +++++++++++++++++++++++++++-- 2 files changed, 31 insertions(+), 2 deletions(-)
diff --git a/env/Kconfig b/env/Kconfig index 38e7fadbb9..5784136674 100644 --- a/env/Kconfig +++ b/env/Kconfig @@ -434,6 +434,10 @@ config ENV_FAT_DEVICE_AND_PART If none, first valid partition in device D. If no partition table then means device D.
+ If ENV_FAT_INTERFACE is set to "mmc" then device 'D' can be omitted, + leaving the string starting with a colon, and the boot device will + be used. + config ENV_FAT_FILE string "Name of the FAT file to use for the environment" depends on ENV_IS_IN_FAT diff --git a/env/fat.c b/env/fat.c index 35a1955e63..37c15d16cd 100644 --- a/env/fat.c +++ b/env/fat.c @@ -29,6 +29,31 @@ # define LOADENV #endif
+__weak int mmc_get_env_dev(void) +{ + return CONFIG_SYS_MMC_ENV_DEV; +} + +static char *env_fat_device_and_part(void) +{ +#ifdef CONFIG_MMC + static char *part_str; + + if (!part_str) { + part_str = CONFIG_ENV_FAT_DEVICE_AND_PART; + if (!strcmp(CONFIG_ENV_FAT_INTERFACE, "mmc") + && part_str[0] == ':') { + part_str = "0" CONFIG_ENV_FAT_DEVICE_AND_PART; + part_str[0] += mmc_get_env_dev(); + } + } + + return part_str; +#else + return CONFIG_ENV_FAT_DEVICE_AND_PART; +#endif +} + static int env_fat_save(void) { env_t __aligned(ARCH_DMA_MINALIGN) env_new; @@ -43,7 +68,7 @@ static int env_fat_save(void) return err;
part = blk_get_device_part_str(CONFIG_ENV_FAT_INTERFACE, - CONFIG_ENV_FAT_DEVICE_AND_PART, + env_fat_device_and_part(), &dev_desc, &info, 1); if (part < 0) return 1; @@ -89,7 +114,7 @@ static int env_fat_load(void) #endif
part = blk_get_device_part_str(CONFIG_ENV_FAT_INTERFACE, - CONFIG_ENV_FAT_DEVICE_AND_PART, + env_fat_device_and_part(), &dev_desc, &info, 1); if (part < 0) goto err_env_relocate;
Ping?
be used.
- static char *part_str;
- if (!part_str) {
- return part_str;
+#else
- return CONFIG_ENV_FAT_DEVICE_AND_PART;
+#endif +}
if (part < 0) return 1;env_fat_device_and_part(), &dev_desc, &info, 1);
if (part < 0) goto err_env_relocate;env_fat_device_and_part(), &dev_desc, &info, 1);
So, the biggest problem here, which I found while testing, is that since CONFIG_SYS_MMC_ENV_DEV isn't always defined, this blows up a few cases. Migrating this to Kconfig needs to happen anyhow, so I started on that. Doing so however isn't trivial as we have cases where we set the value to 0 (along with SYS_MMC_ENV_PART), and setting it to 0 isn't the same code paths as unset. I've sent out patches to deal with that now. For the moment, I'm adding a #ifndef / #define 0 / #endif to this patch.
David Woodhouse
