[U-Boot] [PATCH] arm: bugfix: replace ble with blo in start.S files
Generalized misuse of ble within relocation and bss initialization loops caused one iiteration too many. Instead of ble ('branch if lower or equal'), use blo ('branch if lower').
Signed-off-by: Albert Aribaud albert.aribaud@free.fr --- arch/arm/cpu/arm1136/start.S | 4 ++-- arch/arm/cpu/arm1176/start.S | 6 +++--- arch/arm/cpu/arm720t/start.S | 6 +++--- arch/arm/cpu/arm920t/start.S | 6 +++--- arch/arm/cpu/arm925t/start.S | 6 +++--- arch/arm/cpu/arm926ejs/start.S | 8 ++++---- arch/arm/cpu/arm946es/start.S | 4 ++-- arch/arm/cpu/arm_intcm/start.S | 6 +++--- arch/arm/cpu/armv7/start.S | 4 ++-- arch/arm/cpu/ixp/start.S | 6 +++--- arch/arm/cpu/lh7a40x/start.S | 9 ++++----- arch/arm/cpu/pxa/start.S | 6 +++--- arch/arm/cpu/s3c44b0/start.S | 8 ++++---- arch/arm/cpu/sa1100/start.S | 6 +++--- 14 files changed, 42 insertions(+), 43 deletions(-)
diff --git a/arch/arm/cpu/arm1136/start.S b/arch/arm/cpu/arm1136/start.S index 8b63192..3c65f32 100644 --- a/arch/arm/cpu/arm1136/start.S +++ b/arch/arm/cpu/arm1136/start.S @@ -236,7 +236,7 @@ copy_loop: ldmia r0!, {r9-r10} /* copy from source address [r0] */ stmia r6!, {r9-r10} /* copy to target address [r1] */ cmp r0, r2 /* until source end addreee [r2] */ - ble copy_loop + blo copy_loop
#ifndef CONFIG_PRELOADER /* fix got entries */ @@ -356,7 +356,7 @@ copy_loop: ldmia r0!, {r3-r10} /* copy from source address [r0] */ stmia r1!, {r3-r10} /* copy to target address [r1] */ cmp r0, r2 /* until source end addreee [r2] */ - ble copy_loop + blo copy_loop #endif /* CONFIG_SKIP_RELOCATE_UBOOT */
/* Set up the stack */ diff --git a/arch/arm/cpu/arm1176/start.S b/arch/arm/cpu/arm1176/start.S index e5e7913..7b2c6cc 100644 --- a/arch/arm/cpu/arm1176/start.S +++ b/arch/arm/cpu/arm1176/start.S @@ -285,7 +285,7 @@ copy_loop: ldmia r0!, {r9-r10} /* copy from source address [r0] */ stmia r6!, {r9-r10} /* copy to target address [r1] */ cmp r0, r2 /* until source end addreee [r2] */ - ble copy_loop + blo copy_loop
#ifndef CONFIG_PRELOADER /* fix got entries */ @@ -501,7 +501,7 @@ copy_loop: ldmia r0!, {r3-r10} /* copy from source address [r0] */ stmia r1!, {r3-r10} /* copy to target address [r1] */ cmp r0, r2 /* until source end addreee [r2] */ - ble copy_loop + blo copy_loop #endif /* CONFIG_SKIP_RELOCATE_UBOOT */
#ifdef CONFIG_ENABLE_MMU @@ -559,7 +559,7 @@ clbss_l: str r2, [r0] /* clear loop... */ add r0, r0, #4 cmp r0, r1 - ble clbss_l + blo clbss_l
#ifndef CONFIG_NAND_SPL ldr pc, _start_armboot diff --git a/arch/arm/cpu/arm720t/start.S b/arch/arm/cpu/arm720t/start.S index 0f5f6c4..39567fa 100644 --- a/arch/arm/cpu/arm720t/start.S +++ b/arch/arm/cpu/arm720t/start.S @@ -202,7 +202,7 @@ copy_loop: ldmia r0!, {r9-r10} /* copy from source address [r0] */ stmia r6!, {r9-r10} /* copy to target address [r1] */ cmp r0, r2 /* until source end addreee [r2] */ - ble copy_loop + blo copy_loop
#ifndef CONFIG_PRELOADER /* fix got entries */ @@ -319,7 +319,7 @@ copy_loop: ldmia r0!, {r3-r10} /* copy from source address [r0] */ stmia r1!, {r3-r10} /* copy to target address [r1] */ cmp r0, r2 /* until source end addreee [r2] */ - ble copy_loop + blo copy_loop
@@ -342,7 +342,7 @@ clear_bss: clbss_l:str r2, [r0] /* clear loop... */ add r0, r0, #4 cmp r0, r1 - ble clbss_l + blo clbss_l
diff --git a/arch/arm/cpu/arm920t/start.S b/arch/arm/cpu/arm920t/start.S index a079bb2..06f5623 100644 --- a/arch/arm/cpu/arm920t/start.S +++ b/arch/arm/cpu/arm920t/start.S @@ -247,7 +247,7 @@ copy_loop: ldmia r0!, {r9-r10} /* copy from source address [r0] */ stmia r6!, {r9-r10} /* copy to target address [r1] */ cmp r0, r2 /* until source end addreee [r2] */ - ble copy_loop + blo copy_loop
#ifndef CONFIG_PRELOADER /* fix got entries */ @@ -407,7 +407,7 @@ copy_loop: ldmia r0!, {r3-r10} /* copy from source address [r0] */ stmia r1!, {r3-r10} /* copy to target address [r1] */ cmp r0, r2 /* until source end addreee [r2] */ - ble copy_loop + blo copy_loop #endif /* CONFIG_SKIP_RELOCATE_UBOOT */
/* Set up the stack */ @@ -429,7 +429,7 @@ clear_bss: clbss_l:str r2, [r0] /* clear loop... */ add r0, r0, #4 cmp r0, r1 - ble clbss_l + blo clbss_l
diff --git a/arch/arm/cpu/arm925t/start.S b/arch/arm/cpu/arm925t/start.S index c0a856d..982a4e6 100644 --- a/arch/arm/cpu/arm925t/start.S +++ b/arch/arm/cpu/arm925t/start.S @@ -239,7 +239,7 @@ copy_loop: ldmia r0!, {r9-r10} /* copy from source address [r0] */ stmia r6!, {r9-r10} /* copy to target address [r1] */ cmp r0, r2 /* until source end addreee [r2] */ - ble copy_loop + blo copy_loop
#ifndef CONFIG_PRELOADER /* fix got entries */ @@ -378,7 +378,7 @@ copy_loop: ldmia r0!, {r3-r10} /* copy from source address [r0] */ stmia r1!, {r3-r10} /* copy to target address [r1] */ cmp r0, r2 /* until source end addreee [r2] */ - ble copy_loop + blo copy_loop #endif /* CONFIG_SKIP_RELOCATE_UBOOT */
/* Set up the stack */ @@ -400,7 +400,7 @@ clear_bss: clbss_l:str r2, [r0] /* clear loop... */ add r0, r0, #4 cmp r0, r1 - ble clbss_l + blo clbss_l
diff --git a/arch/arm/cpu/arm926ejs/start.S b/arch/arm/cpu/arm926ejs/start.S index 16ee972..85dbf15 100644 --- a/arch/arm/cpu/arm926ejs/start.S +++ b/arch/arm/cpu/arm926ejs/start.S @@ -236,8 +236,8 @@ stack_setup: copy_loop: ldmia r0!, {r9-r10} /* copy from source address [r0] */ stmia r6!, {r9-r10} /* copy to target address [r1] */ - cmp r0, r2 /* until source end addreee [r2] */ - ble copy_loop + cmp r0, r2 /* until source end address [r2] */ + blo copy_loop
#ifndef CONFIG_PRELOADER /* fix got entries */ @@ -342,7 +342,7 @@ copy_loop: ldmia r0!, {r3-r10} /* copy from source address [r0] */ stmia r1!, {r3-r10} /* copy to target address [r1] */ cmp r0, r2 /* until source end addreee [r2] */ - ble copy_loop + blo copy_loop #endif /* CONFIG_SKIP_RELOCATE_UBOOT */
/* Set up the stack */ @@ -368,7 +368,7 @@ clear_bss: clbss_l:str r2, [r0] /* clear loop... */ add r0, r0, #4 cmp r0, r1 - ble clbss_l + blo clbss_l
bl coloured_LED_init bl red_LED_on diff --git a/arch/arm/cpu/arm946es/start.S b/arch/arm/cpu/arm946es/start.S index 18ed0b2..374bf1e 100644 --- a/arch/arm/cpu/arm946es/start.S +++ b/arch/arm/cpu/arm946es/start.S @@ -208,7 +208,7 @@ copy_loop: ldmia r0!, {r9-r10} /* copy from source address [r0] */ stmia r6!, {r9-r10} /* copy to target address [r1] */ cmp r0, r2 /* until source end addreee [r2] */ - ble copy_loop + blo copy_loop
#ifndef CONFIG_PRELOADER /* fix got entries */ @@ -310,7 +310,7 @@ copy_loop: ldmia r0!, {r3-r10} /* copy from source address [r0] */ stmia r1!, {r3-r10} /* copy to target address [r1] */ cmp r0, r2 /* until source end addreee [r2] */ - ble copy_loop + blo copy_loop
/* Set up the stack */ stack_setup: diff --git a/arch/arm/cpu/arm_intcm/start.S b/arch/arm/cpu/arm_intcm/start.S index b39fdc6..aa3707e 100644 --- a/arch/arm/cpu/arm_intcm/start.S +++ b/arch/arm/cpu/arm_intcm/start.S @@ -206,7 +206,7 @@ copy_loop: ldmia r0!, {r9-r10} /* copy from source address [r0] */ stmia r6!, {r9-r10} /* copy to target address [r1] */ cmp r0, r2 /* until source end addreee [r2] */ - ble copy_loop + blo copy_loop
#ifndef CONFIG_PRELOADER /* fix got entries */ @@ -306,7 +306,7 @@ copy_loop: ldmia r0!, {r3-r10} /* copy from source address [r0] */ stmia r1!, {r3-r10} /* copy to target address [r1] */ cmp r0, r2 /* until source end addreee [r2] */ - ble copy_loop + blo copy_loop
/* Set up the stack */ stack_setup: @@ -327,7 +327,7 @@ clear_bss: clbss_l:str r2, [r0] /* clear loop... */ add r0, r0, #4 cmp r0, r1 - ble clbss_l + blo clbss_l
diff --git a/arch/arm/cpu/armv7/start.S b/arch/arm/cpu/armv7/start.S index f411c0f..53a356e 100644 --- a/arch/arm/cpu/armv7/start.S +++ b/arch/arm/cpu/armv7/start.S @@ -210,7 +210,7 @@ copy_loop: ldmia r0!, {r9-r10} /* copy from source address [r0] */ stmia r6!, {r9-r10} /* copy to target address [r1] */ cmp r0, r2 /* until source end addreee [r2] */ - ble copy_loop + blo copy_loop
#ifndef CONFIG_PRELOADER /* fix got entries */ @@ -325,7 +325,7 @@ copy_loop: @ copy 32 bytes at a time ldmia r0!, {r3 - r10} @ copy from source address [r0] stmia r1!, {r3 - r10} @ copy to target address [r1] cmp r0, r2 @ until source end addreee [r2] - ble copy_loop + blo copy_loop #endif /* CONFIG_SKIP_RELOCATE_UBOOT */
/* Set up the stack */ diff --git a/arch/arm/cpu/ixp/start.S b/arch/arm/cpu/ixp/start.S index b2c8255..cd42e9c 100644 --- a/arch/arm/cpu/ixp/start.S +++ b/arch/arm/cpu/ixp/start.S @@ -331,7 +331,7 @@ copy_loop: ldmia r0!, {r9-r10} /* copy from source address [r0] */ stmia r6!, {r9-r10} /* copy to target address [r1] */ cmp r0, r2 /* until source end addreee [r2] */ - ble copy_loop + blo copy_loop
#ifndef CONFIG_PRELOADER /* fix got entries */ @@ -548,7 +548,7 @@ copy_loop: ldmia r0!, {r3-r10} /* copy from source address [r0] */ stmia r1!, {r3-r10} /* copy to target address [r1] */ cmp r0, r2 /* until source end addreee [r2] */ - ble copy_loop + blo copy_loop #endif /* CONFIG_SKIP_RELOCATE_UBOOT */
/* Set up the stack */ @@ -570,7 +570,7 @@ clear_bss: clbss_l:str r2, [r0] /* clear loop... */ add r0, r0, #4 cmp r0, r1 - ble clbss_l + blo clbss_l
diff --git a/arch/arm/cpu/lh7a40x/start.S b/arch/arm/cpu/lh7a40x/start.S index 002116a..bb0b850 100644 --- a/arch/arm/cpu/lh7a40x/start.S +++ b/arch/arm/cpu/lh7a40x/start.S @@ -219,8 +219,8 @@ stack_setup: copy_loop: ldmia r0!, {r9-r10} /* copy from source address [r0] */ stmia r6!, {r9-r10} /* copy to target address [r1] */ - cmp r0, r2 /* until source end addreee [r2] */ - ble copy_loop + cmp r0, r2 /* until source end address [r2] */ + blo copy_loop
#ifndef CONFIG_PRELOADER /* fix got entries */ @@ -342,8 +342,7 @@ copy_loop: ldmia r0!, {r3-r10} /* copy from source address [r0] */ stmia r1!, {r3-r10} /* copy to target address [r1] */ cmp r0, r2 /* until source end addreee [r2] */ - blt copy_loop /* a 'ble' here actually copies */ - /* four bytes of bss */ + blo copy_loop #endif /* CONFIG_SKIP_RELOCATE_UBOOT */
/* Set up the stack */ @@ -367,7 +366,7 @@ clear_bss: clbss_l:str r2, [r0] /* clear loop... */ add r0, r0, #4 cmp r0, r1 - ble clbss_l + blo clbss_l
diff --git a/arch/arm/cpu/pxa/start.S b/arch/arm/cpu/pxa/start.S index 064ddbc..4cf8856 100644 --- a/arch/arm/cpu/pxa/start.S +++ b/arch/arm/cpu/pxa/start.S @@ -205,7 +205,7 @@ copy_loop: ldmia r0!, {r9-r10} /* copy from source address [r0] */ stmia r6!, {r9-r10} /* copy to target address [r1] */ cmp r0, r2 /* until source end addreee [r2] */ - ble copy_loop + blo copy_loop
#ifndef CONFIG_PRELOADER /* fix got entries */ @@ -310,7 +310,7 @@ copy_loop: ldmia r0!, {r3-r10} /* copy from source address [r0] */ stmia r1!, {r3-r10} /* copy to target address [r1] */ cmp r0, r2 /* until source end address [r2] */ - ble copy_loop + blo copy_loop #endif /* !CONFIG_SKIP_RELOCATE_UBOOT */
/* Set up the stack */ @@ -337,7 +337,7 @@ clear_bss: clbss_l:str r2, [r0] /* clear loop... */ add r0, r0, #4 cmp r0, r1 - ble clbss_l + blo clbss_l #endif
ldr pc, _start_armboot diff --git a/arch/arm/cpu/s3c44b0/start.S b/arch/arm/cpu/s3c44b0/start.S index e1ab5cc..7acc8f6 100644 --- a/arch/arm/cpu/s3c44b0/start.S +++ b/arch/arm/cpu/s3c44b0/start.S @@ -192,7 +192,7 @@ copy_loop: ldmia r0!, {r9-r10} /* copy from source address [r0] */ stmia r6!, {r9-r10} /* copy to target address [r1] */ cmp r0, r2 /* until source end addreee [r2] */ - ble copy_loop + blo copy_loop
#ifndef CONFIG_PRELOADER /* fix got entries */ @@ -225,7 +225,7 @@ vector_copy_loop: ldmia r0!, {r3-r10} stmia r1!, {r3-r10} cmp r0, r2 - ble vector_copy_loop + blo vector_copy_loop #endif /* #ifndef CONFIG_SKIP_RELOCATE_UBOOT */
clear_bss: @@ -311,7 +311,7 @@ copy_loop: ldmia r0!, {r3-r10} /* copy from source address [r0] */ stmia r1!, {r3-r10} /* copy to target address [r1] */ cmp r0, r2 /* until source end addreee [r2] */ - ble copy_loop + blo copy_loop
/* now copy to sram the interrupt vector @@ -324,7 +324,7 @@ vector_copy_loop: ldmia r0!, {r3-r10} stmia r1!, {r3-r10} cmp r0, r2 - ble vector_copy_loop + blo vector_copy_loop #endif /* CONFIG_SKIP_RELOCATE_UBOOT */
/* Set up the stack */ diff --git a/arch/arm/cpu/sa1100/start.S b/arch/arm/cpu/sa1100/start.S index 4730e5a..b4f3356 100644 --- a/arch/arm/cpu/sa1100/start.S +++ b/arch/arm/cpu/sa1100/start.S @@ -196,7 +196,7 @@ copy_loop: ldmia r0!, {r9-r10} /* copy from source address [r0] */ stmia r6!, {r9-r10} /* copy to target address [r1] */ cmp r0, r2 /* until source end addreee [r2] */ - ble copy_loop + blo copy_loop
#ifndef CONFIG_PRELOADER /* fix got entries */ @@ -294,7 +294,7 @@ copy_loop: ldmia r0!, {r3-r10} /* copy from source address [r0] */ stmia r1!, {r3-r10} /* copy to target address [r1] */ cmp r0, r2 /* until source end addreee [r2] */ - ble copy_loop + blo copy_loop #endif /* CONFIG_SKIP_RELOCATE_UBOOT */
/* Set up the stack */ @@ -316,7 +316,7 @@ clear_bss: clbss_l:str r2, [r0] /* clear loop... */ add r0, r0, #4 cmp r0, r1 - ble clbss_l + blo clbss_l
Albert ARIBAUD
Albert Aribaud
