Pull request: Please pull u-boot-imx-20240115
Hi Tom,
Please pull from u-boot-imx, thanks.
The following changes since commit 3c04fcf3137d5f694d52b8f355373e4baabe5f78:
Merge patch series "k3-j721e: beagleboneai: Fix USB" (2024-01-20 11:39:13 -0500)
https://gitlab.denx.de/u-boot/custodians/u-boot-imx.git tags/u-boot-imx-master-20240122
for you to fetch changes up to a80e0e7711a2b2890a583d88dcd9af978ddada32:
ARM: imx: Enable kaslrseed command on DH i.MX8M Plus DHCOM (2024-01-22 08:40:02 -0300)
u-boot-imx-master-20240122 --------------------------
CI: https://source.denx.de/u-boot/custodians/u-boot-imx/-/pipelines/19406
- Allow i.MX8M Plus DHCOM to operate in overdrive mode. - Allow i.MX8M Plus eDM SBC to operate in overdrive mode. - Enable the 'kaslrseed' command on DH i.MX8M Plus DHCOM. - Select LTO by default on i.MX8M. - Convert pico-dwarf/hobbit-imx6ul to CONFIG_DM_SERIAL. - Fix 'reset' command on wandboard.
---------------------------------------------------------------- Fabio Estevam (3): imx8m: Enable LTO by default wandboard: Convert to watchdog driver model pico-dwarf/hobbit-imx6ul: Convert to CONFIG_DM_SERIAL
Marek Vasut (3): ARM: imx: Enable SPL_BOARD_INIT on DH i.MX8M Plus DHCOM ARM: imx: Configure GIC clock parent on Data Modul i.MX8M Plus eDM SBC ARM: imx: Enable kaslrseed command on DH i.MX8M Plus DHCOM
arch/arm/dts/imx6qdl-wandboard-u-boot.dtsi | 10 ++++++++++ arch/arm/mach-imx/imx8m/Kconfig | 1 + board/data_modul/imx8mp_edm_sbc/spl.c | 13 +++++++++++++ configs/imx8mp_data_modul_edm_sbc_defconfig | 1 + configs/imx8mp_dhcom_pdk2_defconfig | 3 +++ configs/imx8mp_dhcom_pdk3_defconfig | 3 +++ configs/pico-dwarf-imx6ul_defconfig | 1 + configs/pico-hobbit-imx6ul_defconfig | 1 + configs/wandboard_defconfig | 3 +++ 9 files changed, 36 insertions(+)
On Mon, Jan 22, 2024 at 10:02:58AM -0300, Fabio Estevam wrote:
Hi Tom,
Fabio Estevam
