[PATCH v2] i2c: eeprom: Use reg property instead of offset and size
Remove adhoc dt binding for fixed-partition definition for i2c eeprom. fixed-partition are using reg property instead of offset/size pair.
Changes in v2: - Bootcount tested on zynqmp zcu104 - Add missing address/size cells - Use dev_read_addr_size_index - Check parameters
Just build tested - ge_bx50v3_defconfig Definitely please retest on hardware.
--- arch/arm/dts/imx53-ppd-uboot.dtsi | 15 +++++++++------ arch/arm/dts/imx6q-bx50v3-uboot.dtsi | 12 +++++++----- drivers/misc/i2c_eeprom.c | 20 ++++++++++---------- 3 files changed, 26 insertions(+), 21 deletions(-)
diff --git a/arch/arm/dts/imx53-ppd-uboot.dtsi b/arch/arm/dts/imx53-ppd-uboot.dtsi index d38a1bc264c9..b308a517a73c 100644 --- a/arch/arm/dts/imx53-ppd-uboot.dtsi +++ b/arch/arm/dts/imx53-ppd-uboot.dtsi @@ -22,17 +22,20 @@ };
&eeprom { + #address-cells = <1>; + #size-cells = <0>; + partitions { compatible = "fixed-partitions"; + #address-cells = <1>; + #size-cells = <1>;
- vpd { - offset = <0>; - size = <1022>; + vpd@0 { + reg = <0 1022>; };
- bootcount: bootcount { - offset = <1022>; - size = <2>; + bootcount: bootcount@1022 { + reg = <1022 2>; }; }; }; diff --git a/arch/arm/dts/imx6q-bx50v3-uboot.dtsi b/arch/arm/dts/imx6q-bx50v3-uboot.dtsi index df446e0ed149..996eb18046c7 100644 --- a/arch/arm/dts/imx6q-bx50v3-uboot.dtsi +++ b/arch/arm/dts/imx6q-bx50v3-uboot.dtsi @@ -21,17 +21,19 @@ };
&eeprom { + #address-cells = <1>; + #size-cells = <0>; partitions { compatible = "fixed-partitions"; + #address-cells = <1>; + #size-cells = <1>;
bootcount: bootcount { - offset = <1022>; - size = <2>; + reg = <1022 2>; }; }; }; diff --git a/drivers/misc/i2c_eeprom.c b/drivers/misc/i2c_eeprom.c index 45c34d388c8a..335cf70e8b7e 100644 --- a/drivers/misc/i2c_eeprom.c +++ b/drivers/misc/i2c_eeprom.c @@ -301,19 +301,19 @@ static int i2c_eeprom_partition_probe(struct udevice *dev) static int i2c_eeprom_partition_ofdata_to_platdata(struct udevice *dev) { struct i2c_eeprom_partition *priv = dev_get_priv(dev); - u32 offset, size; - int ret; + fdt_size_t addr, size;
- ret = dev_read_u32(dev, "offset", &offset); - if (ret) - return ret; + addr = dev_read_addr_size_index(dev, 0, &size); + if (addr == FDT_ADDR_T_NONE) + return -EINVAL;
- ret = dev_read_u32(dev, "size", &size); - if (ret) - return ret; + if (!size) + return -EINVAL; + + priv->offset = (u32)addr; + priv->size = (u32)size;
- priv->offset = offset; - priv->size = size; + debug("%s: base %x, size %x\n", __func__, priv->offset, priv->size);
return 0; }
Changes in v2:
- Check parameters
We have a sandbox I2C EEPROM, so you should be able to use the existing test, right?
REgards, Simon
Changes in v2:
- Check parameters
The way how I have tested it was via drivers/bootcount/i2c-eeprom.c driver which define which eeprom stores it. Do you have any existing tests for bootcount done via sandbox?
If bootcount is not the right way to go then doing this code should be better way. It means just define some partitions (0 size - for failure, then proper range, proper write, write behind size for failure).
Thanks, Michal
Hi Michal,
Changes in v2:
- Check parameters
Can you use drivers/misc/i2c_eeprom.c?
See test/dm/bootcount.c for the sandbox tests for bootcount.
Hi Michal,
Am 17.06.2020 um 05:12 schrieb Simon Glass:
Hi Michal,
Changes in v2:
- Check parameters
Any updates on this?
@Robert: May you find time to test this change and give us feedback?
Thanks!
bye, Heiko
On 06. 07. 20 7:56, Heiko Schocher wrote:
Hi Michal,
Hi Michal,
Changes in v2:
- Check parameters
Just came from my vacation and it will take some time to get to this. If anybody wants to create that test feel free to do it. Definitely testing on Robert side would be good.
Thanks, Michal
Hi Michal,
Hi Michal,
Changes in v2:
- Check parameters
I have sent v3 of this patch with adding testcase for i2c eeprom based bootcount as Simon mentioned. Also tested it on xilinx zynqmp zcu104 board. Please take a look at it.
Thanks, Michal
Hi Michel,
Am 22.07.2020 um 12:23 schrieb Michal Simek:
Hi Michal,
Hi Michal,
On Mon, 15 Jun 2020 at 07:41, Michal Simek michal.simek@xilinx.com wrote: > > Remove adhoc dt binding for fixed-partition definition for i2c eeprom. > fixed-partition are using reg property instead of offset/size pair. > > Signed-off-by: Michal Simek michal.simek@xilinx.com > --- > > Changes in v2: > - Bootcount tested on zynqmp zcu104 > - Add missing address/size cells > - Use dev_read_addr_size_index > - Check parameters > > Just build tested - ge_bx50v3_defconfig > Definitely please retest on hardware. > > --- > arch/arm/dts/imx53-ppd-uboot.dtsi | 15 +++++++++------ > arch/arm/dts/imx6q-bx50v3-uboot.dtsi | 12 +++++++----- > drivers/misc/i2c_eeprom.c | 20 ++++++++++---------- > 3 files changed, 26 insertions(+), 21 deletions(-) >
Thanks!
Already superseeded this patch in patchwork.
bye, Heiko
Heiko Schocher
Michal Simek
