[U-Boot] [PATCH v2] usbtty: Added usbtty_configured() checks. Fixed attribute(packed) warnings.
Added usb_configured() checks in usbtty_puts() and usbtty_putc() to get around a hang when usb is not connected and the user has set up multi-io (setenv stdout serial,usbtty etc). Got rid of redundant __attribute__((packed)) directives that were causing warnings from gcc.
Signed-off-by: Atin Malaviya atin.malaviya@gmail.com ---
This makes the previous v1 patch in http://lists.denx.de/pipermail/u-boot/2009-February/046705.html obsolete. This patch is against the mainline u-boot next branch.
drivers/serial/usbtty.c | 18 +++++++++++------- 1 files changed, 11 insertions(+), 7 deletions(-)
diff --git a/drivers/serial/usbtty.c b/drivers/serial/usbtty.c index 7eba470..2624e6f 100644 --- a/drivers/serial/usbtty.c +++ b/drivers/serial/usbtty.c @@ -150,8 +150,7 @@ struct acm_config_desc {
/* Slave Interface */ struct usb_interface_descriptor data_class_interface; - struct usb_endpoint_descriptor - data_endpoints[NUM_ENDPOINTS-1] __attribute__((packed)); + struct usb_endpoint_descriptor data_endpoints[NUM_ENDPOINTS-1]; } __attribute__((packed));
static struct acm_config_desc acm_configuration_descriptors[NUM_CONFIGS] = { @@ -280,10 +279,8 @@ static struct rs232_emu rs232_desc={ struct gserial_config_desc {
struct usb_configuration_descriptor configuration_desc; - struct usb_interface_descriptor - interface_desc[NUM_GSERIAL_INTERFACES] __attribute__((packed)); - struct usb_endpoint_descriptor - data_endpoints[NUM_ENDPOINTS] __attribute__((packed)); + struct usb_interface_descriptor interface_desc[NUM_GSERIAL_INTERFACES]; + struct usb_endpoint_descriptor data_endpoints[NUM_ENDPOINTS];
@@ -433,6 +430,9 @@ int usbtty_getc (void) */ void usbtty_putc (const char c) { + if (!usbtty_configured ()) + return; + buf_push (&usbtty_output, &c, 1); /* If \n, also do \r */ if (c == '\n') @@ -486,8 +486,12 @@ static void __usbtty_puts (const char *str, int len) void usbtty_puts (const char *str) { int n; - int len = strlen (str); + int len; + + if (!usbtty_configured ()) + return;
+ len = strlen (str); /* add '\r' for each '\n' */ while (len > 0) { n = next_nl_pos (str);
Atin Malaviya
