U-Boot: extlinux.conf boot menu support appears to be broken by commit 739e8361f3fe78038251216df6096a32bc2d5839
Hello,
it looks like the following commit has broken the extlinux.conf boot menu support in U-Boot:
-----8<----------8<----------8<----------8<----------8<----------8<----- commit 739e8361f3fe78038251216df6096a32bc2d5839 Author: Manuel Traut manuel.traut@mt.com Date: Fri Nov 18 09:00:27 2022 +0100
distro/pxeboot: Handle prompt variable
Regarding the documentation found here: https://github.com/u-boot/u-boot/blob/master/common/menu.c#L347
If both timeout and prompt is set to 0 the default entry shall be booted immediately. However the current behaviour is that the prompt is shown (tested with distroboot) until the user selects an entry (no timeout).
This change implements a behaviour as documented. It was tested with distroboot.
Signed-off-by: Manuel Traut manuel.traut@mt.com Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Simon Glass sjg@chromium.org -----8<----------8<----------8<----------8<----------8<----------8<-----
Since the commit above, a system with the following /boot/extlinux/extlinux.conf (which sets timeout to 50) immediately boots the first entry in the config without displaying a boot menu. According to the description, that should only happen if both prompt and timeout are set to zero in the config, but it also happens with timeout set to a non-zero value as in the config below:
-----8<----------8<----------8<----------8<----------8<----------8<----- ## /boot/extlinux/extlinux.conf ## ## IMPORTANT WARNING ## ## The configuration of this file is generated automatically. ## Do not edit this file manually, use: u-boot-update
default l0 menu title U-Boot menu prompt 0 timeout 50
label l0 menu label Debian GNU/Linux bookworm/sid 6.1.0-1-riscv64 linux /boot/vmlinux-6.1.0-1-riscv64 initrd /boot/initrd.img-6.1.0-1-riscv64 append root=/dev/vda1 rw noquiet
label l0r menu label Debian GNU/Linux bookworm/sid 6.1.0-1-riscv64 (rescue target) linux /boot/vmlinux-6.1.0-1-riscv64 initrd /boot/initrd.img-6.1.0-1-riscv64 append root=/dev/vda1 rw noquiet single
label l1 menu label Debian GNU/Linux bookworm/sid 6.0.0-6-riscv64 linux /boot/vmlinux-6.0.0-6-riscv64 initrd /boot/initrd.img-6.0.0-6-riscv64 append root=/dev/vda1 rw noquiet
label l1r menu label Debian GNU/Linux bookworm/sid 6.0.0-6-riscv64 (rescue target) linux /boot/vmlinux-6.0.0-6-riscv64 initrd /boot/initrd.img-6.0.0-6-riscv64 append root=/dev/vda1 rw noquiet single
label l2 menu label Debian GNU/Linux bookworm/sid 6.0.0-5-riscv64 linux /boot/vmlinux-6.0.0-5-riscv64 initrd /boot/initrd.img-6.0.0-5-riscv64 append root=/dev/vda1 rw noquiet
label l2r menu label Debian GNU/Linux bookworm/sid 6.0.0-5-riscv64 (rescue target) linux /boot/vmlinux-6.0.0-5-riscv64 initrd /boot/initrd.img-6.0.0-5-riscv64 append root=/dev/vda1 rw noquiet single -----8<----------8<----------8<----------8<----------8<----------8<-----
Up to commit 51c5c28af59c19407d6602336ac7374dd1432c49 the boot process with the extlinux.conf above looks as follows:
-----8<----------8<----------8<----------8<----------8<----------8<----- Hit any key to stop autoboot: 0
Device 0: QEMU VirtIO Block Device Type: Hard Disk Capacity: 102400.0 MB = 100.0 GB (209715200 x 512) ... is now current device Scanning virtio 0:1... Found /boot/extlinux/extlinux.conf Retrieving file: /boot/extlinux/extlinux.conf U-Boot menu 1: Debian GNU/Linux bookworm/sid 6.1.0-1-riscv64 2: Debian GNU/Linux bookworm/sid 6.1.0-1-riscv64 (rescue target) 3: Debian GNU/Linux bookworm/sid 6.0.0-6-riscv64 4: Debian GNU/Linux bookworm/sid 6.0.0-6-riscv64 (rescue target) 5: Debian GNU/Linux bookworm/sid 6.0.0-5-riscv64 6: Debian GNU/Linux bookworm/sid 6.0.0-5-riscv64 (rescue target) Enter choice: -----8<----------8<----------8<----------8<----------8<----------8<-----
The user can then either select a boot menu entry or - if there is no user input - the system boots the first entry after the timeout set in extlinux.conf is over.
Starting with commit 739e8361f3fe78038251216df6096a32bc2d5839, the boot process looks as follows, i.e. there isn't a boot menu anymore but the system immediately boots the first entry:
-----8<----------8<----------8<----------8<----------8<----------8<----- Device 0: QEMU VirtIO Block Device Type: Hard Disk Capacity: 102400.0 MB = 100.0 GB (209715200 x 512) ... is now current device Scanning virtio 0:1... Found /boot/extlinux/extlinux.conf Retrieving file: /boot/extlinux/extlinux.conf 1: Debian GNU/Linux bookworm/sid 6.1.0-1-riscv64 Retrieving file: /boot/vmlinux-6.1.0-1-riscv64 Retrieving file: /boot/initrd.img-6.1.0-1-riscv64 append: root=/dev/vda1 rw noquiet Moving Image from 0x84000000 to 0x80200000, end=815e5000 ## Flattened Device Tree blob at ff7344b0 Booting using the fdt blob at 0xff7344b0 Working FDT set to ff7344b0 Using Device Tree in place at 00000000ff7344b0, end 00000000ff738dea Working FDT set to ff7344b0
Starting kernel ... [...] -----8<----------8<----------8<----------8<----------8<----------8<-----
Regards, Karsten
Hi Karsten,
thanks for your report.
Can you test with the attached patch? I do not have access to a hardware today, but I will test it tomorrow.
Regards Manuel
Am 16.01.2023 um 19:50 hat Karsten Merker geschrieben:
Hello,
distro/pxeboot: Handle prompt variable Regarding the documentation found here: https://github.com/u-boot/u-boot/blob/master/common/menu.c#L347 If both timeout and prompt is set to 0 the default entry shall be booted immediately. However the current behaviour is that the prompt is shown (tested with distroboot) until the user selects an entry (no timeout). This change implements a behaviour as documented. It was tested with distroboot. Signed-off-by: Manuel Traut <manuel.traut@mt.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org>
Regards, Karsten -- Hiermit widerspreche ich ausdrücklich der Nutzung sowie der Weitergabe meiner personenbezogenen Daten für Zwecke der Werbung sowie der Markt- oder Meinungsforschung.
From: Manuel Traut manuel.traut@mt.com Date: Tue, 17 Jan 2023 09:30:27 +0100 Subject: [PATCH] menu: Ignore prompt variable if timeout is != 0
Since 739e8361f3fe78038251216df6096a32bc2d5839, a system with the following /boot/extlinux/extlinux.conf (which sets timeout to 50) immediately boots the first entry in the config without displaying a boot menu. According to the description, that should only happen if both prompt and timeout are set to zero in the config, but it also happens with timeout set to a non-zero value.
Reported-by: Karsten Merker merker@debian.org Signed-off-by: Manuel Traut manuel.traut@mt.com
Tested-by: Karsten Merker merker@debian.org
Hello,
many thanks for the patch. I have tested it on top of current git head and it solves the extlinux.conf menu issue: with timeout set to a non-zero value the menu gets displayed and with timeout set to zero the system immediately boots the default entry, i.e. both cases work as expected.
JFTR, here are the boot logs for both test cases:
With timeout=50: ================
U-Boot 2023.01-00623-g1d3da4d31b (Jan 17 2023 - 21:17:48 +0100) [...] Hit any key to stop autoboot: 0
Device 0: QEMU VirtIO Block Device Type: Hard Disk Capacity: 102400.0 MB = 100.0 GB (209715200 x 512) ... is now current device Scanning virtio 0:1... Found /boot/extlinux/extlinux.conf Retrieving file: /boot/extlinux/extlinux.conf U-Boot menu 1: Debian GNU/Linux bookworm/sid 6.1.0-1-riscv64 2: Debian GNU/Linux bookworm/sid 6.1.0-1-riscv64 (rescue target) 3: Debian GNU/Linux bookworm/sid 6.0.0-6-riscv64 4: Debian GNU/Linux bookworm/sid 6.0.0-6-riscv64 (rescue target) 5: Debian GNU/Linux bookworm/sid 6.0.0-5-riscv64 6: Debian GNU/Linux bookworm/sid 6.0.0-5-riscv64 (rescue target) Enter choice: 1 1: Debian GNU/Linux bookworm/sid 6.1.0-1-riscv64 Retrieving file: /boot/vmlinux-6.1.0-1-riscv64 Retrieving file: /boot/initrd.img-6.1.0-1-riscv64 append: root=/dev/vda1 rw noquiet Moving Image from 0x84000000 to 0x80200000, end=815e5000 ## Flattened Device Tree blob at ff7334b0 Booting using the fdt blob at 0xff7334b0 Working FDT set to ff7334b0 Using Device Tree in place at 00000000ff7334b0, end 00000000ff737dea Working FDT set to ff7334b0
Starting kernel ...
With timeout=0: ===============
Device 0: QEMU VirtIO Block Device Type: Hard Disk Capacity: 102400.0 MB = 100.0 GB (209715200 x 512) ... is now current device Scanning virtio 0:1... Found /boot/extlinux/extlinux.conf Retrieving file: /boot/extlinux/extlinux.conf 1: Debian GNU/Linux bookworm/sid 6.1.0-1-riscv64 Retrieving file: /boot/vmlinux-6.1.0-1-riscv64 Retrieving file: /boot/initrd.img-6.1.0-1-riscv64 append: root=/dev/vda1 rw noquiet Moving Image from 0x84000000 to 0x80200000, end=815e5000 ## Flattened Device Tree blob at ff7334b0 Booting using the fdt blob at 0xff7334b0 Working FDT set to ff7334b0 Using Device Tree in place at 00000000ff7334b0, end 00000000ff737dea Working FDT set to ff7334b0
Starting kernel ... -----8<----------8<----------8<----------8<----------8<----------8<-----
Regards, Karsten
Karsten Merker
Manuel Traut
