[U-Boot] [PATCH v5] Export redesign
this is an atempt to make the export of functions typesafe. I replaced the jumptable void ** by a struct (jt_funcs) with function pointers. The EXPORT_FUNC macro now has 3 fixed parameters and one variadic parameter The first is the name of the exported function, the rest of the parameters are used to format a functionpointer in the jumptable,
the EXPORT_FUNC macros are expanded three times, 1. to declare the members of the struct 2. to initialize the structmember pointers 3. to call the functions in stubs.c
Signed-off-by: Martin Dorwig dorwig@tetronik.com Acked-by: Simon Glass sjg@chromium.org
Signed-off-by: Simon Glass sjg@chromium.org (resending to the list since my tweaks are not quite trivial)
Changes in v5: - Update to deal with I2C moving to driver model
arch/blackfin/cpu/cpu.c | 3 +- board/BuS/eb_cpux9k2/cpux9k2.c | 2 +- common/cmd_load.c | 2 +- common/console.c | 20 ++++---- common/exports.c | 29 ++---------- doc/README.standalone | 41 +++++++++++----- examples/standalone/stubs.c | 64 +++++++++++++------------ include/_exports.h | 99 +++++++++++++++++++++++++++------------ include/asm-generic/global_data.h | 2 +- include/exports.h | 20 ++++---- 10 files changed, 162 insertions(+), 120 deletions(-)
diff --git a/arch/blackfin/cpu/cpu.c b/arch/blackfin/cpu/cpu.c index b7f1188..91aa5cc 100644 --- a/arch/blackfin/cpu/cpu.c +++ b/arch/blackfin/cpu/cpu.c @@ -24,6 +24,7 @@
#include "cpu.h" #include "initcode.h" +#include "exports.h"
ulong bfin_poweron_retx; DECLARE_GLOBAL_DATA_PTR; @@ -121,7 +122,7 @@ static void display_global_data(void) printf(" |-ram_size: %lx\n", gd->ram_size); printf(" |-env_addr: %lx\n", gd->env_addr); printf(" |-env_valid: %lx\n", gd->env_valid); - printf(" |-jt(%p): %p\n", gd->jt, *(gd->jt)); + printf(" |-jt(%p): %p\n", gd->jt, gd->jt->get_version); printf(" \-bd: %p\n", gd->bd); printf(" |-bi_boot_params: %lx\n", bd->bi_boot_params); printf(" |-bi_memstart: %lx\n", bd->bi_memstart); diff --git a/board/BuS/eb_cpux9k2/cpux9k2.c b/board/BuS/eb_cpux9k2/cpux9k2.c index 5e4778e..76ad7c4 100644 --- a/board/BuS/eb_cpux9k2/cpux9k2.c +++ b/board/BuS/eb_cpux9k2/cpux9k2.c @@ -98,7 +98,7 @@ int misc_init_r(void) puts("Error: invalid MAC at EEPROM\n"); } } - gd->jt[XF_do_reset] = (void *) do_reset; + gd->jt->do_reset = do_reset;
#ifdef CONFIG_STATUS_LED status_led_set(STATUS_LED_BOOT, STATUS_LED_BLINKING); diff --git a/common/cmd_load.c b/common/cmd_load.c index f6e522c..d043e6d 100644 --- a/common/cmd_load.c +++ b/common/cmd_load.c @@ -222,7 +222,7 @@ static int read_record(char *buf, ulong len) }
/* Check for the console hangup (if any different from serial) */ - if (gd->jt[XF_getc] != getc) { + if (gd->jt->getc != getc) { if (ctrlc()) { return (-1); } diff --git a/common/console.c b/common/console.c index fc1963b..3f25e76 100644 --- a/common/console.c +++ b/common/console.c @@ -125,13 +125,13 @@ static int console_setfile(int file, struct stdio_dev * dev) */ switch (file) { case stdin: - gd->jt[XF_getc] = getc; - gd->jt[XF_tstc] = tstc; + gd->jt->getc = getc; + gd->jt->tstc = tstc; break; case stdout: - gd->jt[XF_putc] = putc; - gd->jt[XF_puts] = puts; - gd->jt[XF_printf] = printf; + gd->jt->putc = putc; + gd->jt->puts = puts; + gd->jt->printf = printf; break; } break; @@ -758,11 +758,11 @@ int console_init_r(void) #endif
/* set default handlers at first */ - gd->jt[XF_getc] = serial_getc; - gd->jt[XF_tstc] = serial_tstc; - gd->jt[XF_putc] = serial_putc; - gd->jt[XF_puts] = serial_puts; - gd->jt[XF_printf] = serial_printf; + gd->jt->getc = serial_getc; + gd->jt->tstc = serial_tstc; + gd->jt->putc = serial_putc; + gd->jt->puts = serial_puts; + gd->jt->printf = serial_printf;
/* stdin stdout and stderr are in environment */ /* scan for it */ diff --git a/common/exports.c b/common/exports.c index 459e18c..333107c 100644 --- a/common/exports.c +++ b/common/exports.c @@ -1,6 +1,7 @@ #include <common.h> #include <exports.h> #include <spi.h> +#include <i2c.h>
@@ -13,34 +14,10 @@ unsigned long get_version(void) return XF_VERSION; }
-/* Reuse _exports.h with a little trickery to avoid bitrot */ -#define EXPORT_FUNC(sym) gd->jt[XF_##sym] = (void *)sym; - -#if !defined(CONFIG_X86) && !defined(CONFIG_PPC) -# define install_hdlr dummy -# define free_hdlr dummy -#else /* kludge for non-standard function naming */ -# define install_hdlr irq_install_handler -# define free_hdlr irq_free_handler -#endif -#if !defined(CONFIG_CMD_I2C) || \ - (defined(CONFIG_DM_I2C) && !defined(CONFIG_DM_I2C_COMPAT)) -# define i2c_write dummy -# define i2c_read dummy -#endif -#if !defined(CONFIG_CMD_SPI) || defined(CONFIG_DM_SPI) -# define spi_init dummy -# define spi_setup_slave dummy -# define spi_free_slave dummy -#endif -#ifndef CONFIG_CMD_SPI -# define spi_claim_bus dummy -# define spi_release_bus dummy -# define spi_xfer dummy -#endif +#define EXPORT_FUNC(f, a, x, ...) gd->jt->x = f;
void jumptable_init(void) { - gd->jt = malloc(XF_MAX * sizeof(void *)); + gd->jt = malloc(sizeof(struct jt_funcs)); #include <_exports.h> } diff --git a/doc/README.standalone b/doc/README.standalone index e3000ef..659a12f 100644 --- a/doc/README.standalone +++ b/doc/README.standalone @@ -5,18 +5,18 @@ Design Notes on Exporting U-Boot Functions to Standalone Applications: table is allocated and initialized in the jumptable_init() routine (common/exports.c). Other routines may also modify the jump table, however. The jump table can be accessed as the 'jt' field of the - 'global_data' structure. The slot numbers for the jump table are + 'global_data' structure. The struct members for the jump table are defined in the <include/exports.h> header. E.g., to substitute the malloc() and free() functions that will be available to standalone applications, one should do the following:
- gd->jt[XF_malloc] = my_malloc; - gd->jt[XF_free] = my_free; + gd->jt->malloc = my_malloc; + gd->jt->free = my_free;
- Note that the pointers to the functions all have 'void *' type and - thus the compiler cannot perform type checks on these assignments. + Note that the pointers to the functions are real function pointers + so the compiler can perform type checks on these assignments.
2. The pointer to the jump table is passed to the application in a machine-dependent way. PowerPC, ARM, MIPS, Blackfin and Nios II @@ -65,27 +65,46 @@ Design Notes on Exporting U-Boot Functions to Standalone Applications: => tftp 0x40000 hello_world.bin => go 0x40004
-5. To export some additional function foobar(), the following steps +5. To export some additional function long foobar(int i,char c), the following steps should be undertaken:
- Append the following line at the end of the include/_exports.h file:
- EXPORT_FUNC(foobar) + EXPORT_FUNC(foobar, long, foobar, int, char) + + Parameters to EXPORT_FUNC: + - the first parameter is the function that is exported (default implementation) + - the second parameter is the return value type + - the third parameter is the name of the member in struct jt_funcs + this is also the name that the standalone application will used. + the rest of the parameters are the function arguments
- Add the prototype for this function to the include/exports.h file:
- void foobar(void); + long foobar(int i, char c); + + Initialization with the default implementation is done in jumptable_init() + + You can override the default implementation using:
- - Add the initialization of the jump table slot wherever - appropriate (most likely, to the jumptable_init() function): + gd->jt->foobar = another_foobar;
- gd->jt[XF_foobar] = foobar; + The signature of another_foobar must then match the declaration of foobar.
- Increase the XF_VERSION value by one in the include/exports.h file
+ - If you want to export a function which depends on a CONFIG_XXX + use 2 lines like this: + #ifdef CONFIG_FOOBAR + EXPORT_FUNC(foobar, long, foobar, int, char) + #else + EXPORT_FUNC(dummy, void, foobar, void) + #endif + + 6. The code for exporting the U-Boot functions to applications is mostly machine-independent. The only places written in assembly language are stub functions that perform the jump through the jump diff --git a/examples/standalone/stubs.c b/examples/standalone/stubs.c index 0bf690e..920a0a9 100644 --- a/examples/standalone/stubs.c +++ b/examples/standalone/stubs.c @@ -2,6 +2,8 @@ #include <exports.h> #include <linux/compiler.h>
+#define FO(x) offsetof(struct jt_funcs, x) + #if defined(CONFIG_X86) /* * x86 does not have a dedicated register to store the pointer to @@ -10,23 +12,23 @@ * from flash memory. The global_data address is passed as argv[-1] * to the application program. */ -static void **jt; +static struct jt_funcs *jt; gd_t *global_data;
-#define EXPORT_FUNC(x) \ +#define EXPORT_FUNC(f, a, x, ...) \ asm volatile ( \ " .globl " #x "\n" \ #x ":\n" \ " movl %0, %%eax\n" \ " movl jt, %%ecx\n" \ " jmp *(%%ecx, %%eax)\n" \ - : : "i"(XF_ ## x * sizeof(void *)) : "eax", "ecx"); + : : "i"(FO(x)) : "eax", "ecx"); #elif defined(CONFIG_PPC) /* * r2 holds the pointer to the global_data, r11 is a call-clobbered * register */ -#define EXPORT_FUNC(x) \ +#define EXPORT_FUNC(f, a, x, ...) \ asm volatile ( \ " .globl " #x "\n" \ #x ":\n" \ @@ -34,33 +36,33 @@ gd_t *global_data; " lwz %%r11, %1(%%r11)\n" \ " mtctr %%r11\n" \ " bctr\n" \ - : : "i"(offsetof(gd_t, jt)), "i"(XF_ ## x * sizeof(void *)) : "r11"); + : : "i"(offsetof(gd_t, jt)), "i"(FO(x)) : "r11"); #elif defined(CONFIG_ARM) #ifdef CONFIG_ARM64 /* * x18 holds the pointer to the global_data, x9 is a call-clobbered * register */ -#define EXPORT_FUNC(x) \ +#define EXPORT_FUNC(f, a, x, ...) \ asm volatile ( \ " .globl " #x "\n" \ #x ":\n" \ " ldr x9, [x18, %0]\n" \ " ldr x9, [x9, %1]\n" \ " br x9\n" \ - : : "i"(offsetof(gd_t, jt)), "i"(XF_ ## x * sizeof(void *)) : "x9"); + : : "i"(offsetof(gd_t, jt)), "i"(FO(x)) : "x9"); #else /* * r9 holds the pointer to the global_data, ip is a call-clobbered * register */ -#define EXPORT_FUNC(x) \ +#define EXPORT_FUNC(f, a, x, ...) \ asm volatile ( \ " .globl " #x "\n" \ #x ":\n" \ " ldr ip, [r9, %0]\n" \ " ldr pc, [ip, %1]\n" \ - : : "i"(offsetof(gd_t, jt)), "i"(XF_ ## x * sizeof(void *)) : "ip"); + : : "i"(offsetof(gd_t, jt)), "i"(FO(x)) : "ip"); #endif #elif defined(CONFIG_MIPS) /* @@ -70,19 +72,19 @@ gd_t *global_data; * it; however, GCC/mips generates an additional `nop' after each asm * statement */ -#define EXPORT_FUNC(x) \ +#define EXPORT_FUNC(f, a, x, ...) \ asm volatile ( \ " .globl " #x "\n" \ #x ":\n" \ " lw $25, %0($26)\n" \ " lw $25, %1($25)\n" \ " jr $25\n" \ - : : "i"(offsetof(gd_t, jt)), "i"(XF_ ## x * sizeof(void *)) : "t9"); + : : "i"(offsetof(gd_t, jt)), "i"(FO(x)) : "t9"); #elif defined(CONFIG_NIOS2) /* * gp holds the pointer to the global_data, r8 is call-clobbered */ -#define EXPORT_FUNC(x) \ +#define EXPORT_FUNC(f, a, x, ...) \ asm volatile ( \ " .globl " #x "\n" \ #x ":\n" \ @@ -92,13 +94,13 @@ gd_t *global_data; " ldw r8, 0(r8)\n" \ " ldw r8, %1(r8)\n" \ " jmp r8\n" \ - : : "i"(offsetof(gd_t, jt)), "i"(XF_ ## x * sizeof(void *)) : "gp"); + : : "i"(offsetof(gd_t, jt)), "i"(FO(x)) : "gp"); #elif defined(CONFIG_M68K) /* * d7 holds the pointer to the global_data, a0 is a call-clobbered * register */ -#define EXPORT_FUNC(x) \ +#define EXPORT_FUNC(f, a, x, ...) \ asm volatile ( \ " .globl " #x "\n" \ #x ":\n" \ @@ -108,50 +110,50 @@ gd_t *global_data; " adda.l %1, %%a0\n" \ " move.l (%%a0), %%a0\n" \ " jmp (%%a0)\n" \ - : : "i"(offsetof(gd_t, jt)), "i"(XF_ ## x * sizeof(void *)) : "a0"); + : : "i"(offsetof(gd_t, jt)), "i"(FO(x)) : "a0"); #elif defined(CONFIG_MICROBLAZE) /* * r31 holds the pointer to the global_data. r5 is a call-clobbered. */ -#define EXPORT_FUNC(x) \ +#define EXPORT_FUNC(f, a, x, ...) \ asm volatile ( \ " .globl " #x "\n" \ #x ":\n" \ " lwi r5, r31, %0\n" \ " lwi r5, r5, %1\n" \ " bra r5\n" \ - : : "i"(offsetof(gd_t, jt)), "i"(XF_ ## x * sizeof(void *)) : "r5"); + : : "i"(offsetof(gd_t, jt)), "i"(FO(x)) : "r5"); #elif defined(CONFIG_BLACKFIN) /* * P3 holds the pointer to the global_data, P0 is a call-clobbered * register */ -#define EXPORT_FUNC(x) \ +#define EXPORT_FUNC(f, a, x, ...) \ asm volatile ( \ " .globl _" #x "\n_" \ #x ":\n" \ " P0 = [P3 + %0]\n" \ " P0 = [P0 + %1]\n" \ " JUMP (P0)\n" \ - : : "i"(offsetof(gd_t, jt)), "i"(XF_ ## x * sizeof(void *)) : "P0"); + : : "i"(offsetof(gd_t, jt)), "i"(FO(x)) : "P0"); #elif defined(CONFIG_AVR32) /* * r6 holds the pointer to the global_data. r8 is call clobbered. */ -#define EXPORT_FUNC(x) \ +#define EXPORT_FUNC(f, a, x, ...) \ asm volatile( \ " .globl\t" #x "\n" \ #x ":\n" \ " ld.w r8, r6[%0]\n" \ " ld.w pc, r8[%1]\n" \ : \ - : "i"(offsetof(gd_t, jt)), "i"(XF_ ##x) \ + : "i"(offsetof(gd_t, jt)), "i"(FO(x)) \ : "r8"); #elif defined(CONFIG_SH) /* * r13 holds the pointer to the global_data. r1 is a call clobbered. */ -#define EXPORT_FUNC(x) \ +#define EXPORT_FUNC(f, a, x, ...) \ asm volatile ( \ " .align 2\n" \ " .globl " #x "\n" \ @@ -164,12 +166,12 @@ gd_t *global_data; " jmp @r1\n" \ " nop\n" \ " nop\n" \ - : : "i"(offsetof(gd_t, jt)), "i"(XF_ ## x * sizeof(void *)) : "r1", "r2"); + : : "i"(offsetof(gd_t, jt)), "i"(FO(x)) : "r1", "r2"); #elif defined(CONFIG_SPARC) /* * g7 holds the pointer to the global_data. g1 is call clobbered. */ -#define EXPORT_FUNC(x) \ +#define EXPORT_FUNC(f, a, x, ...) \ asm volatile( \ " .globl\t" #x "\n" \ #x ":\n" \ @@ -179,26 +181,26 @@ gd_t *global_data; " ld [%%g1 + %1], %%g1\n" \ " jmp %%g1\n" \ " nop\n" \ - : : "i"(offsetof(gd_t, jt)), "i"(XF_ ## x * sizeof(void *)) : "g1" ); + : : "i"(offsetof(gd_t, jt)), "i"(FO(x)) : "g1"); #elif defined(CONFIG_NDS32) /* * r16 holds the pointer to the global_data. gp is call clobbered. * not support reduced register (16 GPR). */ -#define EXPORT_FUNC(x) \ +#define EXPORT_FUNC(f, a, x, ...) \ asm volatile ( \ " .globl " #x "\n" \ #x ":\n" \ " lwi $r16, [$gp + (%0)]\n" \ " lwi $r16, [$r16 + (%1)]\n" \ " jr $r16\n" \ - : : "i"(offsetof(gd_t, jt)), "i"(XF_ ## x * sizeof(void *)) : "$r16"); + : : "i"(offsetof(gd_t, jt)), "i"(FO(x)) : "$r16"); #elif defined(CONFIG_OPENRISC) /* * r10 holds the pointer to the global_data, r13 is a call-clobbered * register */ -#define EXPORT_FUNC(x) \ +#define EXPORT_FUNC(f, a, x, ...) \ asm volatile ( \ " .globl " #x "\n" \ #x ":\n" \ @@ -206,12 +208,12 @@ gd_t *global_data; " l.lwz r13, %1(r13)\n" \ " l.jr r13\n" \ " l.nop\n" \ - : : "i"(offsetof(gd_t, jt)), "i"(XF_ ## x * sizeof(void *)) : "r13"); + : : "i"(offsetof(gd_t, jt)), "i"(FO(x)) : "r13"); #elif defined(CONFIG_ARC) /* * r25 holds the pointer to the global_data. r10 is call clobbered. */ -#define EXPORT_FUNC(x) \ +#define EXPORT_FUNC(f, a, x, ...) \ asm volatile( \ " .align 4\n" \ " .globl " #x "\n" \ @@ -219,7 +221,7 @@ gd_t *global_data; " ld r10, [r25, %0]\n" \ " ld r10, [r10, %1]\n" \ " j [r10]\n" \ - : : "i"(offsetof(gd_t, jt)), "i"(XF_ ## x * sizeof(void *)) : "r10"); + : : "i"(offsetof(gd_t, jt)), "i"(FO(x)) : "r10"); #else /*" addi $sp, $sp, -24\n" \ " br $r16\n" */ diff --git a/include/_exports.h b/include/_exports.h index 349a3c5..5944703 100644 --- a/include/_exports.h +++ b/include/_exports.h @@ -1,32 +1,73 @@ /* - * You do not need to use #ifdef around functions that may not exist + * You need to use #ifdef around functions that may not exist * in the final configuration (such as i2c). + * use a dummyfunction as first parameter to EXPORT_FUNC. + * As an example see the CONFIG_CMD_I2C section below */ -EXPORT_FUNC(get_version) -EXPORT_FUNC(getc) -EXPORT_FUNC(tstc) -EXPORT_FUNC(putc) -EXPORT_FUNC(puts) -EXPORT_FUNC(printf) -EXPORT_FUNC(install_hdlr) -EXPORT_FUNC(free_hdlr) -EXPORT_FUNC(malloc) -EXPORT_FUNC(free) -EXPORT_FUNC(udelay) -EXPORT_FUNC(get_timer) -EXPORT_FUNC(vprintf) -EXPORT_FUNC(do_reset) -EXPORT_FUNC(getenv) -EXPORT_FUNC(setenv) -EXPORT_FUNC(simple_strtoul) -EXPORT_FUNC(strict_strtoul) -EXPORT_FUNC(simple_strtol) -EXPORT_FUNC(strcmp) -EXPORT_FUNC(i2c_write) -EXPORT_FUNC(i2c_read) -EXPORT_FUNC(spi_init) -EXPORT_FUNC(spi_setup_slave) -EXPORT_FUNC(spi_free_slave) -EXPORT_FUNC(spi_claim_bus) -EXPORT_FUNC(spi_release_bus) -EXPORT_FUNC(spi_xfer) +#ifndef EXPORT_FUNC +#define EXPORT_FUNC(a, b, c, ...) +#endif + EXPORT_FUNC(get_version, unsigned long, get_version, void) + EXPORT_FUNC(getc, int, getc, void) + EXPORT_FUNC(tstc, int, tstc, void) + EXPORT_FUNC(putc, void, putc, const char) + EXPORT_FUNC(puts, void, puts, const char *) + EXPORT_FUNC(printf, int, printf, const char*, ...) +#if defined(CONFIG_X86) || defined(CONFIG_PPC) + EXPORT_FUNC(irq_install_handler, void, install_hdlr, + int, interrupt_handler_t, void*) + + EXPORT_FUNC(irq_free_handler, void, free_hdlr, int) +#else + EXPORT_FUNC(dummy, void, install_hdlr, void) + EXPORT_FUNC(dummy, void, free_hdlr, void) +#endif + EXPORT_FUNC(malloc, void *, malloc, size_t) + EXPORT_FUNC(free, void, free, void *) + EXPORT_FUNC(udelay, void, udelay, unsigned long) + EXPORT_FUNC(get_timer, unsigned long, get_timer, unsigned long) + EXPORT_FUNC(vprintf, int, vprintf, const char *, va_list) + EXPORT_FUNC(do_reset, int, do_reset, cmd_tbl_t *, + int , int , char * const []) + EXPORT_FUNC(getenv, char *, getenv, const char*) + EXPORT_FUNC(setenv, int, setenv, const char *, const char *) + EXPORT_FUNC(simple_strtoul, unsigned long, simple_strtoul, + const char *, char **, unsigned int) + EXPORT_FUNC(strict_strtoul, int, strict_strtoul, + const char *, unsigned int , unsigned long *) + EXPORT_FUNC(simple_strtol, long, simple_strtol, + const char *, char **, unsigned int) + EXPORT_FUNC(strcmp, int, strcmp, const char *cs, const char *ct) +#if defined(CONFIG_CMD_I2C) && \ + (!defined(CONFIG_DM_I2C) || defined(CONFIG_DM_I2C_COMPAT)) + EXPORT_FUNC(i2c_write, int, i2c_write, uchar, uint, int , uchar * , int) + EXPORT_FUNC(i2c_read, int, i2c_read, uchar, uint, int , uchar * , int) +#else + EXPORT_FUNC(dummy, void, i2c_write, void) + EXPORT_FUNC(dummy, void, i2c_read, void) +#endif + +#if !defined(CONFIG_CMD_SPI) || defined(CONFIG_DM_SPI) + EXPORT_FUNC(dummy, void, spi_init, void) + EXPORT_FUNC(dummy, void, spi_setup_slave, void) + EXPORT_FUNC(dummy, void, spi_free_slave, void) +#else + EXPORT_FUNC(spi_init, void, spi_init, void) + EXPORT_FUNC(spi_setup_slave, struct spi_slave *, spi_setup_slave, + unsigned int, unsigned int, unsigned int, unsigned int) + EXPORT_FUNC(spi_free_slave, void, spi_free_slave, struct spi_slave *) +#endif +#ifndef CONFIG_CMD_SPI + EXPORT_FUNC(dummy, void, spi_claim_bus, void) + EXPORT_FUNC(dummy, void, spi_release_bus, void) + EXPORT_FUNC(dummy, void, spi_xfer, void) +#else + EXPORT_FUNC(spi_claim_bus, int, spi_claim_bus, struct spi_slave *) + EXPORT_FUNC(spi_release_bus, void, spi_release_bus, struct spi_slave *) + EXPORT_FUNC(spi_xfer, int, spi_xfer, struct spi_slave *, + unsigned int, const void *, void *, unsigned long) +#endif + EXPORT_FUNC(ustrtoul, unsigned long, ustrtoul, + const char *, char **, unsigned int) + EXPORT_FUNC(ustrtoull, unsigned long long, ustrtoull, + const char *, char **, unsigned int) diff --git a/include/asm-generic/global_data.h b/include/asm-generic/global_data.h index 3d14d5f..6747619 100644 --- a/include/asm-generic/global_data.h +++ b/include/asm-generic/global_data.h @@ -73,7 +73,7 @@ typedef struct global_data { const void *fdt_blob; /* Our device tree, NULL if none */ void *new_fdt; /* Relocated FDT */ unsigned long fdt_size; /* Space reserved for relocated FDT */ - void **jt; /* jump table */ + struct jt_funcs *jt; /* jump table */ char env_buf[32]; /* buffer for getenv() before reloc. */ #ifdef CONFIG_TRACE void *trace_buff; /* The trace buffer */ diff --git a/include/exports.h b/include/exports.h index 41d5085..b918b34 100644 --- a/include/exports.h +++ b/include/exports.h @@ -3,6 +3,8 @@
#ifndef __ASSEMBLY__
+struct spi_slave; + /* These are declarations of exported functions available in C code */ unsigned long get_version(void); int getc(void); @@ -10,22 +12,23 @@ int tstc(void); void putc(const char); void puts(const char*); int printf(const char* fmt, ...); -void install_hdlr(int, void (*interrupt_handler_t)(void *), void*); +void install_hdlr(int, interrupt_handler_t, void*); void free_hdlr(int); void *malloc(size_t); void free(void*); void __udelay(unsigned long); unsigned long get_timer(unsigned long); int vprintf(const char *, va_list); -unsigned long simple_strtoul(const char *cp,char **endp,unsigned int base); +unsigned long simple_strtoul(const char *cp, char **endp, unsigned int base); int strict_strtoul(const char *cp, unsigned int base, unsigned long *res); char *getenv (const char *name); int setenv (const char *varname, const char *varvalue); -long simple_strtol(const char *cp,char **endp,unsigned int base); -int strcmp(const char * cs,const char * ct); +long simple_strtol(const char *cp, char **endp, unsigned int base); +int strcmp(const char *cs, const char *ct); unsigned long ustrtoul(const char *cp, char **endp, unsigned int base); unsigned long long ustrtoull(const char *cp, char **endp, unsigned int base); -#if defined(CONFIG_CMD_I2C) +#if defined(CONFIG_CMD_I2C) && \ + (!defined(CONFIG_DM_I2C) || defined(CONFIG_DM_I2C_COMPAT)) int i2c_write (uchar, uint, int , uchar* , int); int i2c_read (uchar, uint, int , uchar* , int); #endif @@ -34,14 +37,13 @@ void app_startup(char * const *);
#endif /* ifndef __ASSEMBLY__ */
-enum { -#define EXPORT_FUNC(x) XF_ ## x , +struct jt_funcs { +#define EXPORT_FUNC(impl, res, func, ...) res(*func)(__VA_ARGS__); #include <_exports.h> #undef EXPORT_FUNC - - XF_MAX };
+ #define XF_VERSION 6
Dear Simon,
- to declare the members of the struct
- to initialize the structmember pointers
- to call the functions in stubs.c
Is this a 100% binary compatible change? If not, should we not also increment XF_VERSION ?
Hi Wolfgang,
On 26 January 2015 at 07:45, Wolfgang Denk wd@denx.de wrote:
Dear Simon,
If a board has move to driver model and doesn't use CONFIG_DM_I2C_COMPAT (and this should ideally not be used) then the I2C functions are not present. I tested the compatibility to a basic degree.
Perhaps we should increment it anyway, given it is such a major code change?
Dear Simon,
In message CAPnjgZ1wzmspVjB8dqDJBZDu2Dpu+JLSS=CmAdDPkhptYRHQJQ@mail.gmail.com you wrote:
Maybe I'm misreading the code, but would an old standalone application image, compiled for the old jumptable format, really still run on a system with your patch applied? Only in this case we can leave the version unchanged.
It would not hurt, ideed.
Hi Wolfgang,
On 26 January 2015 at 11:55, Wolfgang Denk wd@denx.de wrote:
Dear Simon,
OK I'll do that.
Martin Dorwig
