[PATCH v2] rockchip: cru: Enable cpu info support for rk3568
Add cru structure definition in head file to support cpu_info driver.
Signed-off-by: Anton vao@asu-vei.ru Signed-off-by: Kever Yang kever.yang@rock-chips.com ---
Changes in v2: Format the patch header, add commit message and signature.
arch/arm/include/asm/arch-rockchip/cru.h | 2 ++ arch/arm/include/asm/arch-rockchip/cru_rk3568.h | 2 ++ 2 files changed, 4 insertions(+)
diff --git a/arch/arm/include/asm/arch-rockchip/cru.h b/arch/arm/include/asm/arch-rockchip/cru.h index 13ea4aba8e..9778790f34 100644 --- a/arch/arm/include/asm/arch-rockchip/cru.h +++ b/arch/arm/include/asm/arch-rockchip/cru.h @@ -15,6 +15,8 @@ # include <asm/arch-rockchip/cru_rk3288.h> #elif defined(CONFIG_ROCKCHIP_RK3399) # include <asm/arch-rockchip/cru_rk3399.h> +#elif defined(CONFIG_ROCKCHIP_RK3568) +#include <asm/arch-rockchip/cru_rk3568.h> #endif
/* CRU_GLB_RST_ST */ diff --git a/arch/arm/include/asm/arch-rockchip/cru_rk3568.h b/arch/arm/include/asm/arch-rockchip/cru_rk3568.h index 399f19ad21..76f1ad5510 100644 --- a/arch/arm/include/asm/arch-rockchip/cru_rk3568.h +++ b/arch/arm/include/asm/arch-rockchip/cru_rk3568.h @@ -106,6 +106,8 @@ struct rk3568_cru { unsigned int emmc_con[2];/* Address Offset: 0x0598 */ };
+#define rockchip_cru rk3568_cru + check_member(rk3568_cru, mode_con00, 0xc0); check_member(rk3568_cru, softrst_con[0], 0x400);
Kever Yang
