[U-Boot] [PATCH 1/3] Move CONFIG_PHY_ADDR to Kconfig
CONFIG_PHY_ADDR is used for old-style configuration. This makes impossible changing the PHY address, if multiple boards share a same config header file (for example include/configs/sunxi-common.h).
Moving this to Kconfig helps overcoming this issue. It's defined as entry inside PHYLIB section.
After the implemention, moveconfig was run. The issues are: - edb9315a - CONFIG_PHYLIB is not enabled. Entry is deleted.
- ds414 - CONFIG_PHYLIB is in incompatible format: { 0x1, 0x0 }. This entry is also deleted.
- devkit3250 - The PHY_ADDR is in hex format (0x1F). Manually CONFIG_PHY_ADDR=31 is added in the defconfig.
After the changes the suspicious defconfigs passes building.
Signed-off-by: Stefan Mavrodiev stefan@olimex.com --- README | 4 ---- configs/devkit3250_defconfig | 1 + configs/khadas-vim_defconfig | 1 + configs/libretech-cc_defconfig | 1 + configs/p212_defconfig | 1 + drivers/net/phy/Kconfig | 7 +++++++ include/configs/am335x_shc.h | 1 - include/configs/baltos.h | 1 - include/configs/devkit3250.h | 1 - include/configs/ds414.h | 1 - include/configs/edb93xx.h | 1 - include/configs/khadas-vim.h | 2 -- include/configs/libretech-cc.h | 2 -- include/configs/p212.h | 2 -- include/configs/pepper.h | 1 - include/configs/sunxi-common.h | 2 -- include/configs/work_92105.h | 1 - include/configs/x600.h | 1 - scripts/config_whitelist.txt | 1 - 19 files changed, 11 insertions(+), 21 deletions(-)
diff --git a/README b/README index b53ea7d..499184d 100644 --- a/README +++ b/README @@ -1436,10 +1436,6 @@ The following options need to be configured: be at least 4MB.
- MII/PHY support: - CONFIG_PHY_ADDR - - The address of PHY on MII bus. - CONFIG_PHY_CLOCK_FREQ (ppc4xx)
The clock frequency of the MII bus diff --git a/configs/devkit3250_defconfig b/configs/devkit3250_defconfig index 2ad08ae..930b631 100644 --- a/configs/devkit3250_defconfig +++ b/configs/devkit3250_defconfig @@ -36,6 +36,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_NAND=y CONFIG_SPL_NAND_SIMPLE=y CONFIG_PHYLIB=y +CONFIG_PHY_ADDR=31 CONFIG_DM_SERIAL=y CONFIG_SYS_NS16550=y CONFIG_USB=y diff --git a/configs/khadas-vim_defconfig b/configs/khadas-vim_defconfig index 4ceab90..e9a96d3 100644 --- a/configs/khadas-vim_defconfig +++ b/configs/khadas-vim_defconfig @@ -20,6 +20,7 @@ CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM_GPIO=y CONFIG_DM_MMC=y CONFIG_MMC_MESON_GX=y +CONFIG_PHY_ADDR=8 CONFIG_PHY_MESON_GXL=y CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/libretech-cc_defconfig b/configs/libretech-cc_defconfig index 3bccff1..86852b1 100644 --- a/configs/libretech-cc_defconfig +++ b/configs/libretech-cc_defconfig @@ -20,6 +20,7 @@ CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM_GPIO=y CONFIG_DM_MMC=y CONFIG_MMC_MESON_GX=y +CONFIG_PHY_ADDR=8 CONFIG_PHY_MESON_GXL=y CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/p212_defconfig b/configs/p212_defconfig index cb9be4a..9466238 100644 --- a/configs/p212_defconfig +++ b/configs/p212_defconfig @@ -20,6 +20,7 @@ CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM_GPIO=y CONFIG_DM_MMC=y CONFIG_MMC_MESON_GX=y +CONFIG_PHY_ADDR=8 CONFIG_PHY_MESON_GXL=y CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y diff --git a/drivers/net/phy/Kconfig b/drivers/net/phy/Kconfig index 95b7534..c934aed 100644 --- a/drivers/net/phy/Kconfig +++ b/drivers/net/phy/Kconfig @@ -12,6 +12,13 @@ menuconfig PHYLIB
if PHYLIB
+config PHY_ADDR + int "PHY address" + default 1 if ARCH_SUNXI + default 0 + help + The address of PHY on MII bus. Usually in range of 0 to 31. + config B53_SWITCH bool "Broadcom BCM53xx (RoboSwitch) Ethernet switch PHY support." help diff --git a/include/configs/am335x_shc.h b/include/configs/am335x_shc.h index e2d329a..2b705fc 100644 --- a/include/configs/am335x_shc.h +++ b/include/configs/am335x_shc.h @@ -264,7 +264,6 @@ #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_SUBNETMASK #define CONFIG_NET_RETRY_COUNT 10 -#define CONFIG_PHY_ADDR 0 #define CONFIG_PHY_SMSC
/* I2C configuration */ diff --git a/include/configs/baltos.h b/include/configs/baltos.h index 75dd0c5..31ae20c 100644 --- a/include/configs/baltos.h +++ b/include/configs/baltos.h @@ -285,7 +285,6 @@ #endif
/* Network. */ -#define CONFIG_PHY_ADDR 0 #define CONFIG_PHY_SMSC #define CONFIG_MII #define CONFIG_PHY_ATHEROS diff --git a/include/configs/devkit3250.h b/include/configs/devkit3250.h index 526a81a..b66b90e 100644 --- a/include/configs/devkit3250.h +++ b/include/configs/devkit3250.h @@ -73,7 +73,6 @@ #define CONFIG_RMII #define CONFIG_PHY_SMSC #define CONFIG_LPC32XX_ETH -#define CONFIG_PHY_ADDR 0x1F #define CONFIG_SYS_FAULT_ECHO_LINK_DOWN
/* diff --git a/include/configs/ds414.h b/include/configs/ds414.h index c840c93..03e96df 100644 --- a/include/configs/ds414.h +++ b/include/configs/ds414.h @@ -41,7 +41,6 @@ #define CONFIG_ENV_SECT_SIZE (64 << 10) /* 64KiB sectors */
#define CONFIG_PHY_MARVELL /* there is a marvell phy */ -#define CONFIG_PHY_ADDR { 0x1, 0x0 } #define CONFIG_SYS_NETA_INTERFACE_TYPE PHY_INTERFACE_MODE_RGMII
#define CONFIG_SYS_ALT_MEMTEST diff --git a/include/configs/edb93xx.h b/include/configs/edb93xx.h index fcad7c4..03a1eff 100644 --- a/include/configs/edb93xx.h +++ b/include/configs/edb93xx.h @@ -97,7 +97,6 @@ #define CONFIG_DRIVER_EP93XX_MAC #define CONFIG_MII_SUPPRESS_PREAMBLE #define CONFIG_MII -#define CONFIG_PHY_ADDR 1 #undef CONFIG_NETCONSOLE
/* SDRAM configuration */ diff --git a/include/configs/khadas-vim.h b/include/configs/khadas-vim.h index 9d99bc5..f44b388 100644 --- a/include/configs/khadas-vim.h +++ b/include/configs/khadas-vim.h @@ -12,8 +12,6 @@
#define CONFIG_MISC_INIT_R
-#define CONFIG_PHY_ADDR 8 - #define MESON_FDTFILE_SETTING "fdtfile=amlogic/meson-gxl-s905x-khadas-vim.dtb\0"
#include <configs/meson-gxbb-common.h> diff --git a/include/configs/libretech-cc.h b/include/configs/libretech-cc.h index ffaca26..08dfb30 100644 --- a/include/configs/libretech-cc.h +++ b/include/configs/libretech-cc.h @@ -12,8 +12,6 @@
-#define CONFIG_PHY_ADDR 8 - #define MESON_FDTFILE_SETTING "fdtfile=amlogic/meson-gxl-s905x-libretech-cc.dtb\0"
#include <configs/meson-gxbb-common.h> diff --git a/include/configs/p212.h b/include/configs/p212.h index 793b556..0477384 100644 --- a/include/configs/p212.h +++ b/include/configs/p212.h @@ -12,8 +12,6 @@
-#define CONFIG_PHY_ADDR 8 - /* Serial setup */ #define CONFIG_CONS_INDEX 0
diff --git a/include/configs/pepper.h b/include/configs/pepper.h index 7ef2529..960afa0 100644 --- a/include/configs/pepper.h +++ b/include/configs/pepper.h @@ -77,7 +77,6 @@ #define CONFIG_SYS_NS16550_COM1 0x44e09000
/* Ethernet support */ -#define CONFIG_PHY_ADDR 0 #define CONFIG_PHY_RESET_DELAY 1000
/* SPL */ diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index 9b3944a..e252e7fb 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -296,12 +296,10 @@ extern int soft_i2c_gpio_scl;
/* Ethernet support */ #ifdef CONFIG_SUN4I_EMAC -#define CONFIG_PHY_ADDR 1 #define CONFIG_MII /* MII PHY management */ #endif
#ifdef CONFIG_SUN7I_GMAC -#define CONFIG_PHY_ADDR 1 #define CONFIG_MII /* MII PHY management */ #define CONFIG_PHY_REALTEK #endif diff --git a/include/configs/work_92105.h b/include/configs/work_92105.h index 7faab4e..c0a9833 100644 --- a/include/configs/work_92105.h +++ b/include/configs/work_92105.h @@ -57,7 +57,6 @@
#define CONFIG_PHY_SMSC #define CONFIG_LPC32XX_ETH -#define CONFIG_PHY_ADDR 0 #define CONFIG_SYS_FAULT_ECHO_LINK_DOWN /* FIXME: remove "Waiting for PHY auto negotiation to complete..." message */
diff --git a/include/configs/x600.h b/include/configs/x600.h index 66a8e88..ea9500a 100644 --- a/include/configs/x600.h +++ b/include/configs/x600.h @@ -71,7 +71,6 @@ /* Ethernet config options */ #define CONFIG_MII #define CONFIG_PHY_RESET_DELAY 10000 /* in usec */ -#define CONFIG_PHY_ADDR 0 /* PHY address */
#define CONFIG_SPEAR_GPIO
diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index ef83c00..c94e6ce 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -1593,7 +1593,6 @@ CONFIG_PERIF2_FREQ CONFIG_PERIF3_FREQ CONFIG_PERIF4_FREQ CONFIG_PHYSMEM -CONFIG_PHY_ADDR CONFIG_PHY_BASE_ADR CONFIG_PHY_BCM5421S CONFIG_PHY_ET1011C_TX_CLK_FIX
Thanks for taking the time to do this.
Acked-by: Maxime Ripard maxime.ripard@free-electrons.com
Maxime
Maxime Ripard
Stefan Mavrodiev
