[U-Boot] [PATCH] fdt relocate: have more attention to use a bootmap or not
Platforms with flat device tree support can use a bootmap to relocate the fdt_blob. This is not a must. That's why the relocation function boot_relocate_fdt() should be use only if CONFIG_OF_LIBFDT was defined together with CONFIG_SYS_BOOTMAPSZ (see common/cmd_bootm.c).
On MicroBlaze platforms there is no need to use a bootmap to relocate a fdt blob. So we need a more precise focus on the compilation and usage of boot_relocate_fdt().
In general it is valid to exclude the function boot_relocate_fdt() if the bootmap size CONFIG_SYS_BOOTMAPSZ is not defined.
Signed-off-by: Stephan Linz linz@li-pro.net --- arch/powerpc/lib/bootm.c | 4 ++-- common/image.c | 2 ++ 2 files changed, 4 insertions(+), 2 deletions(-)
diff --git a/arch/powerpc/lib/bootm.c b/arch/powerpc/lib/bootm.c index 6702df5..0efd66c 100644 --- a/arch/powerpc/lib/bootm.c +++ b/arch/powerpc/lib/bootm.c @@ -253,7 +253,7 @@ static int boot_body_linux(bootm_headers_t *images) if (ret) return ret;
-#if defined(CONFIG_OF_LIBFDT) +#if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_SYS_BOOTMAPSZ) ret = boot_relocate_fdt(lmb, bootmap_base, of_flat_tree, &of_size); if (ret) return ret; @@ -292,7 +292,7 @@ static int boot_body_linux(bootm_headers_t *images) if (*initrd_start && *initrd_end) fdt_initrd(*of_flat_tree, *initrd_start, *initrd_end, 1); } -#endif /* CONFIG_OF_LIBFDT */ +#endif /* CONFIG_OF_LIBFDT && CONFIG_SYS_BOOTMAPSZ */ return 0; }
diff --git a/common/image.c b/common/image.c index 2b6007e..b23b6a8 100644 --- a/common/image.c +++ b/common/image.c @@ -1178,6 +1178,7 @@ static int fit_check_fdt (const void *fit, int fdt_noffset, int verify) * 0 - success * 1 - failure */ +#if defined(CONFIG_SYS_BOOTMAPSZ) int boot_relocate_fdt (struct lmb *lmb, ulong bootmap_base, char **of_flat_tree, ulong *of_size) { @@ -1257,6 +1258,7 @@ int boot_relocate_fdt (struct lmb *lmb, ulong bootmap_base, error: return 1; } +#endif /* CONFIG_SYS_BOOTMAPSZ */
/** * boot_get_fdt - main fdt handling routine
Dear Stephan Linz,
In message 0ac40268094bc00a447aeb4f5775c670a79868e9.1277481856.git.linz@li-pro.net you wrote:
Applied, thanks.
Stephan Linz
